Acorn Archimedes A440
(Redirected from Acorn Archimedes A440/1)
Acorn Archimedes A440 and A440/1
Archimedes 400-series system unit with colour monitor and keyboard
TypePersonal computer (three-box desktop)
ReleasedA440 announced June 1987, available November 1987; A440/1 1989
Intro priceA440 £2,299 ex VAT (£2,641.60 inc VAT); A440/1 £2,499 ex VAT
CPUARM2 at 8 MHz
Memory4 MB RAM
Storage3.5" floppy drive; 20 MB ST506 hard disc (A440), 50 MB (A440/1)
DisplayAnalogue RGB (modes 0–20 on a multisync monitor); high-resolution mono on two BNC sockets
Sound8 channels, stereo (VIDC1a)
OS / FirmwareA440: Arthur 1.2; A440/1: RISC OS 2.00
SuccessorAcorn Archimedes A540
Model no.AKB20 (A440), AKB44 (A440/1)
The Acorn Archimedes A440 was the top model of the original Archimedes range, launched in June 1987 with availability from November 1987. It had 4 MB of RAM and a 20 MB hard disc as standard. Chris Whytehead believes it was the only 400-series machine produced; the A410 was announced and priced but probably never sold.[1]
Acorn replaced it with the A440/1 in 1989.
Prices
From Acorn's retail price list:[2]
Archimedes 440 prices
Product code Configuration RRP ex VAT RRP inc VAT
AKB20 A440, no monitor £2,299.00 £2,641.60
AKB20/AKF01 A440 with mono monitor £2,349.00 £2,699.10
AKB20/AKF11 A440 with colour monitor £2,499.00 £2,871.60
The base price includes the 4 MB of RAM and the 20 MB hard disc.[2]
Differences from the 300 series
The A440 has its own main board, part 277,300, with an ST506 hard disc controller on board; the 300-series board leaves that area empty.[1][3] Acorn's manual describes the controller as a Hitachi HD63463 with a DP8455 data separator (IC50), and the board has a second hard disc connector for an external, separately powered drive.[4] A four-slot backplane (part 0277,040) is fitted as standard; the 300 series needs an optional two-slot backplane.[1]
The A440 is not a BBC Microcomputer. Its keyboard has no red function keys and no BBC logo above the numeric keypad.[1]
Many designators match the 300-series board: ARM at IC43, MEMC at IC45, IOC at IC21, VIDC at IC17, PCF8583 at IC16, 65C51 at IC9 and 1772 floppy controller at IC47. The 4 MB is thirty-two 511000 (1M × 1, 120 ns) DRAMs.[4] Chris Whytehead's A440 has a VL2333-QC ARM2 at 8 MHz, a MEMC1, a VIDC1a, a Sony MP-F63W-00D floppy drive and a 19 MB Tandon TM 362 hard disc.[1] Screen modes and video levels are those of the 300 series; see Acorn Archimedes A305#Display.[5]
The power supply connects on the same four tags as the 300 series: PL5 +12 V, PL6 0 V, PL7 +5 V and PL8 −5 V. Acorn's first check on a dead machine is to measure these; a power supply that clicks has either a short between two of its outputs or a fault of its own.[4]
Acorn quotes "typically 4 MIPS" for the Archimedes.[5] Chris Whytehead's A440 under RISC OS 2.00 measures 4.56 MIPS on ARMSi v4.0 and 5,383 Dhrystones per second.[1]
Capacitors
The A440 parts list gives the same tantalum and electrolytic positions as the 300 series, with one more 10 µF tantalum:[4]
A440 main board: tantalum and electrolytic capacitors
Designators Value and type Acorn part
C40 and 'B' × 18 4.7 µF 10 V 20 % tantalum 0610,005
C14, C20, C35, C36, C52, C53 10 µF 10 V 20 % tantalum 0610,010
C37, C38, C39 100 µF 16 V 20 % tantalum 0611,101
C50 220 µF 16 V radial electrolytic 0635,221
On the 300 series C37 sits across +12 V and is a known cause of a dead machine when it fails short; see Acorn Archimedes A310#Decoupling capacitors C37, C38 and C39. Confirm C37's rail on the A440's own circuit diagram, drawing 0177,300/C (sheet 1, sheet 2), or on the board before relying on that.
Backup batteries
The A440 uses two LR06 (AA) 1.5 V manganese alkaline cells inside the main unit, which Acorn specified replacing once a year: Acorn part 0817,005, in battery holder assembly 0176,009, connected to PL11.[4] With the power off, IC16 pin 8 should read about 2.8 V; if not, check PL11, D3 and the cells, each above 1.4 V.[4] Chris Whytehead's photograph of an A440 with the top off shows the battery pack next to the fan, at the top right of the case.[1] Alkaline cells left in for decades leak potassium hydroxide; see Battery Explosion, Capacitor or Corrosion Damage and Battery Refurbishment.
Operating system
The A440 shipped with Arthur 1.2. Chris Whytehead's machine now runs RISC OS 2.00 (ROMs dated 5 October 1988).[1]
The A440/1 (1989)
The 400/1 range replaced the 400 series in 1989, with the MEMC1a as its main change.[6] The A440/1, product code AKB44, has 4 MB of RAM and a hard disc; Acorn's parts list gives the drive as part 0912,012, "50 MB H DISC DRIVE 440/1".[7] It cost £2,499 ex VAT.[8]
The A440/1 uses the Acorn Universal Board (part 0283,000) and the 0283,040 four-slot backplane shared with the A410/1 and A420/1.[6] Its batteries are the same two AA alkaline cells, on PL10, and its power tags are numbered differently from the A440's (PL11 +12 V, PL5 0 V, PL6 +5 V, PL7 −5 V).[7] Board details, the capacitor list and Acorn's fault checks for the 400/1 are on the Acorn Archimedes A410 page.
Chris Whytehead's A440/1 is badged A440/1 but carries serial number 27-AKB40-1007658, an A410/1 code, and has 4 MB and a hard disc; he thinks it was upgraded by the dealer and relabelled.[6]
The R140 was Acorn's Unix workstation on the same hardware: an ARM2, 4 MB and a 60 MB ST506 drive. RISC OS 2 in ROM only boots the disc-based RISC iX (BSD Unix). Early R140s were based on a slightly adapted A440 and later ones on the A440/1. Without a monitor it cost £3,500 ex VAT; the AKA25 Ethernet podule was £599 and the AKA30 SCSI adapter £299.[9] Acorn's Acorn A400-1 and R140 Service Manual covers it with the 400/1 range, and its parts list gives the same 50 MB drive, 0912,012, for the 440/1 and the R140.[7]
Maintenance and repair
  1. ↑ 1.0 1.1 1.2 1.3 1.4 1.5 1.6 1.7 Whytehead, Chris. "Acorn Archimedes A400 Series", Chris's Acorns, archived by The Centre for Computing History. A440 launch and availability, motherboard 277,300 Issue 1, ST506/MFM controller, Tandon TM 362 drive, four-slot backplane 0277,040, keyboard, Arthur 1.2, battery pack position, measured figures.
  2. ↑ 2.0 2.1 Acorn Computers Limited, High Performance Computer Systems Retail Price List and Pricing sheet, undated (1987). Hosted on this wiki: Acorn Archimedes Retail Price List 1987.
  3. ↑ Whytehead, Chris. "Acorn Archimedes A300 Series", Chris's Acorns, archived by The Centre for Computing History.
  4. ↑ 4.0 4.1 4.2 4.3 4.4 4.5 Acorn Computers Limited, High Performance Computer Systems Model 440 Service Manual, part number 0476,155, issue 1, November 1988: technical specification pp. 5–6; hard disc interface p. 28; disassembly and power tags p. 30; basic checks p. 44; configuration, NVM and RTC check p. 49; parts lists pp. 55–60 (battery p. 55, capacitors and DRAM p. 58). Hosted on this wiki: Archimedes 440 Service Manual.
  5. ↑ 5.0 5.1 Acorn Computers Limited, Archimedes 300 Series Module Level Service Manual, part number 0476,140, issue 1, April 1988. Section 1.2 technical specification. Hosted on this wiki: Archimedes 300 Series Service Manual.
  6. ↑ 6.0 6.1 6.2 Whytehead, Chris. "Acorn Archimedes A400/1 Series", Chris's Acorns, archived by The Centre for Computing History. A440/1 product code, board and backplane, documented A440/1 with serial 27-AKB40-1007658.
  7. ↑ 7.0 7.1 7.2 7.3 Acorn Computers Limited, 400/1 & R140 Service Manual, part number 0483,075, issue 1, July 1989: specification p. 7; disassembly, PL10 and power tags p. 17; hard disc tests p. 27; NVM check p. 47; parts list p. 61 (hard disc drives). Hosted on this wiki: Acorn A400-1 and R140 Service Manual.
  8. ↑ "The Acorn Archimedes", 4corn Computers (retrieved 2026-10-01): 1989 prices ex VAT of the A410/1, A420/1 and A440/1.
  9. ↑ Whytehead, Chris. "RISC iX Computers", Chris's Acorns, archived by The Centre for Computing History. R140 hardware, prices and documented machine.
