Acorn A7000
Acorn A7000
A7000 (AMC23) with an Acorn monitor
ManufacturerAcorn Computers
TypeDesktop computer
ReleasedJuly 1995[1]
CPUARM7500 at 32 MHz
Memory2, 4 or 8 MB on the board, plus one SIMM socket
Storage3.5-inch floppy drive; IDE hard disc; optional ATAPI CD-ROM
DisplayUp to 1280 × 1024; up to 24 bits per pixel at lower resolutions
Sound16-bit stereo
ROM4 MB (RISC OS 3.60)
PowerInternal 35 W switch-mode supply
Dimensions357 × 283 × 102 mm
WeightAbout 4 kg
OS / FirmwareRISC OS 3.60
PredecessorAcorn Archimedes A5000
SuccessorAcorn A7000+
Model no.AMC01 to AMC05, AMC21 to AMC25, CON10
The Acorn A7000 is a RISC OS desktop computer launched by Acorn in July 1995 as a lower-cost relative of the Risc PC.[1] It is built around the ARM7500, a single chip that combines an ARM7 processor core with a video controller similar to the Risc PC's VIDC20 and most of the functions of its IOMD I/O controller. Acorn described the chip as "almost a Risc PC on a chip".[2] It was followed in 1997 by the faster Acorn A7000+, which shares its case and most of its design.[3]
Differences from the Risc PC
Chris Whytehead lists what Acorn left out to make the A7000 cheaper to build:[1]
  • The ARM7500 is surface-mounted, so the processor cannot be upgraded.
  • There is no second processor slot, so no PC cards.
  • There is no VRAM; the screen memory comes from main memory.
  • There is no backplane. An optional one-slot backplane takes a single expansion card, and it cannot be fitted together with a CD-ROM drive.
  • There is one DRAM slot (the Risc PC has two).
  • The keyboard and mouse are PS/2 types, so standard PC keyboards and mice can be used.
Specification
A7000 specification (Acorn Risc Technologies datasheet DS002, February 1996)
Item Specification
Processor ARM7500, 32 MHz, 4 KB cache
Memory 2, 4 or 8 MB fast page mode DRAM on the board plus one SIMM socket (maximum 136 MB); 4 MB ROM; 240 bytes of battery-backed CMOS RAM
Storage 3.5-inch floppy drive (2 MB unformatted); IDE hard disc (425 MB standard); ATAPI CD-ROM option in the 5.25-inch bay
Video 15-way VGA connector; modes include 1280 × 1024 at 2 bpp, 1024 × 768 at 4 bpp, 800 × 600 and 640 × 480 at 8 bpp, 480 × 352 at 16 bpp, 240 × 352 at 24 bpp; internal genlock port
Sound 16-bit stereo with a mixer for a CD-ROM, 3.5 mm jack for 32 ohm headphones or line out, internal speaker
Ports 9-pin serial, 25-pin parallel, PS/2 keyboard, PS/2 three-button mouse
Expansion Network slot (Ethernet or ATM); one expansion card slot
Power Integral 35 W switch-mode supply, IEC inlet and outlet, auto-ranging 110 to 240 V AC
Size and weight 357 × 283 × 102 mm; about 4 kg
Source: Acorn Risc Technologies.[4] Chris Whytehead's A7000 runs its memory at 16 MHz.[1] On performance, the datasheet says "around 29 MIPS (Dhrystone 2.1) peak", Acorn's ARM7500 leaflet gives the A7000 25 MIPS, and Chris Whytehead measured 17.87 MIPS (ARMSi) and 24,252 Dhrystones per second on his machine.[4][2][1]
Models
A7000 models (Chris Whytehead's list)
Code Configuration
AMC01 2 MB, network interface
AMC02 2 MB, 425 MB hard disc
AMC03 4 MB, 425 MB hard disc
AMC04 4 MB, network interface
AMC05 4 MB, 540 MB hard disc
AMC21 2 MB, network interface, CD-ROM
AMC22 2 MB, 425 MB hard disc, CD-ROM
AMC23 4 MB, 425 MB hard disc, CD-ROM
AMC25 4 MB, 540 MB hard disc, quad-speed CD-ROM
CON10 2 MB, 425 MB hard disc (Early Years)
A7000 with the cover off: CD-ROM in the centre, floppy and hard disc at the right, power supply at the left, main board along the front (photo: Chris's Acorns)
Chris Whytehead's A7000 has main board 1102,005 with a VLSI VY27073B ARM7500. The board carries the SIMM socket, the two RISC OS ROMs, the backplane slot, the IDE and floppy connectors with the CMOS backup battery above them, the network card socket and the power supply connectors.[1] The floppy, IDE, serial and parallel interfaces come from an SMC "Super I/O" controller beside the battery. Stardot members identify it as the FDC37C665, the part used on the Risc PC; Theo Markettos's notes suggest the FDC37C669 for the A7000.[5][6]
The power supply provides +5 V, +12 V and −12 V.[7] Acorn's datasheet describes it as auto-ranging from 110 to 240 V; one owner's A7000+ supply is labelled for 220 to 240 V only, so read the label before using one on 110 V mains.[4][8]
Acorn never published a circuit diagram of the A7000 board, as far as stardot members know, so repairers trace faults with the Risc PC drawings.[6]
Maintenance and repair
The main age problem is the CMOS backup battery, which leaks onto the tracks around the floppy and IDE controller.[6][9] See Acorn A7000 Maintenance Guide and Acorn A7000 Troubleshooting Guide.
  1. ↑ 1.0 1.1 1.2 1.3 1.4 1.5 Whytehead, Chris. "Acorn A7000", Chris's Acorns, The Centre for Computing History (retrieved 2026-10-01). Launched July 1995; differences from the Risc PC; model list; his AMC23: main board 1102,005, VLSI VY27073B ARM7500 at 32 MHz, IOMD functions, 4 MB on board plus 16 MB EDO SIMM, memory clock 16 MHz, TEAC FD-235HF floppy, Seagate ST3660A hard disc, Sony CDU77E-Q6 CD-ROM, RISC OS 3.60 dated 13 April 1995, 24,252 Dhrystones and 17.87 MIPS; CMOS battery above the IDE and floppy connectors; network slot, backplane slot and power connectors on the board.
  2. ↑ 2.0 2.1 Acorn Computers, leaflet "ARM7500", APP 868, first edition July 1995. Hosted on this wiki: File:Acorn ARM7500 leaflet (APP868).pdf. ARM704 core, VIDC20-like video, most of IOMD, two PS/2 ports, joystick interface; benchmark table giving the A7000 25 MIPS.
  3. ↑ Whytehead, Chris. "Acorn A7000+", Chris's Acorns (retrieved 2026-10-01). Launched May 1997; 48 MHz ARM7500FE, 8 MB EDO, 1.2 GB disc, RISC OS 3.71; the only visible difference is the '+'; Castle continued production.
  4. ↑ 4.0 4.1 4.2 Acorn Risc Technologies, datasheet "A7000", DS002/ART/RK, February 1996. Hosted on this wiki: File:Acorn A7000 datasheet (ART DS002).pdf.
  5. ↑ Markettos, Theo. "Acorn/RISC OS technical documents and hardware resources" (retrieved 2026-10-01): FDC37C665GT "IO chip used in the Risc PC"; FDC37C669 "IO chip used in the NC, Bush STB, and I think A7000(+)".
  6. ↑ 6.0 6.1 6.2 "A7000 floppy / HD issues", stardot.org.uk forum thread, February 2017 to December 2024. danielj and sirbod on the FDC37C665 next to the battery and its sensitivity to static and battery damage; sirbod's track repairs under the C13 legend; stevepick on the IDE connector fitted backwards; IanJeffray on the unpublished schematics.
  7. ↑ "A7000+ with new caps, but it's dead Jim", stardot.org.uk forum thread, July to August 2022. cosworthchris: flickering power LED and clicking speaker cured by replacing a dried-out small capacitor in the supply, giving 12 V, −12 V and 5 V; IanJeffray: no need to recap the main board routinely, test the CMOS circuit and I²C lines, CMOS RAM chips "very regularly die"; sirbod: RISC OS can take about 10 minutes to start if the CMOS chip does not respond.
  8. ↑ "A7000+ PSU", stardot.org.uk forum thread, August 2018. klintworth's Castle A7000+ supply is marked 220 to 240 V against the brochure's auto-ranging figure.
  9. ↑ "A7000+ revival, pointers on where to start", stardot.org.uk forum thread, 2017 to 2019. Battery acid damage; vinegar then isopropyl alcohol; jumper wires over the three corroded tracks restored the floppy and IDE; disc error 08 and the Risc PC schematic used for tracing; danielj suggests a NiMH AA in a holder away from the board.
