Acorn A7000 Documentation
Acorn's surviving product literature for the A7000 series is hosted here: the Acorn Risc Technologies datasheet for the Acorn A7000, Acorn's leaflet on the ARM7500 chip it is built around, and the leaflet for the Acorn A7000+. The Centre for Computing History holds Acorn's A7000+ Welcome Guide (part 1402,215, issue 1, March 1997), but no scan of it, or of the A7000 Welcome Guide, has been found online.[1] No Acorn circuit diagram, parts list or service manual for either main board has been found; repairers on stardot use the Acorn Risc PC Technical Reference Manual drawings, since much of the A7000 follows the Risc PC.[2]
A7000 datasheet (ART DS002)
[edit | edit source]Two pages, reference DS002/ART/RK, February 1996, from Acorn Risc Technologies, which offered the A7000 as a product, as a licensable design, as a main board on its own and as an ARM7500 development platform. The technical overview gives:
- 32 MHz ARM7500, "around 29 MIPS (Dhrystone 2.1) peak", 4 KB cache, integrated I/O, MMU and video
- 2, 4 or 8 MB of fast page mode DRAM on the base card plus one SIMM socket, maximum 136 MB; 4 MB of ROM; 240 bytes of battery-backed CMOS RAM; a 48-bit unique identifier
- RISC OS 3.6 in ROM; 16-bit stereo sound with a mixer for a CD-ROM; screen modes up to 1280 × 1024
- Network expansion slot (Ethernet or ATM), a 32-bit expansion slot, a 5.25-inch bay for a second IDE disc or ATAPI CD-ROM
- Ports: 9-pin serial, 25-pin parallel, PS/2 keyboard and mouse, 15-way VGA, internal video genlock port
- 357 × 283 × 102 mm, about 4 kg; integral 35 W switch-mode supply with IEC inlet and outlet, auto-ranging 110 to 240 V AC, 50 or 60 Hz
ARM7500 leaflet (APP 868)
[edit | edit source]Two pages, first edition July 1995. It describes the ARM7500 as "almost a Risc PC on a chip": an ARM704 processor with MMU, write buffer and 4 KB cache, a video generator similar to VIDC20, most of the functions of IOMD, two PS/2 ports and a four-channel joystick interface. Its benchmark table gives the A7000 25 MIPS and 44 thousand Dhrystones, against 12 MIPS for a 25 MHz A5000.
A7000+ leaflet (AGP24.79.04)
[edit | edit source]Four pages, 1997. Its specification gives a 48 MHz ARM7500FE with integrated floating point, "around 29 MIPS (dhrystone 2.1) peak", 8 MB of EDO RAM on board with one socket for a SIMM of up to 128 MB, RISC OS 3.71, a 1.2 GB hard disc, an optional 8-speed CD-ROM, the same ports, case size and 35 W auto-ranging supply as the A7000, and screen modes including 1024 × 768 in 256 colours and 800 × 600 in 32,000 colours.
What these documents do not contain
[edit | edit source]- No circuit diagrams, parts lists, board layouts or capacitor values.
- No service or fault-finding information.
- The ART datasheet and the A7000+ leaflet both give "around 29 MIPS", although one describes a 32 MHz ARM7500 and the other a 48 MHz ARM7500FE; Acorn's ARM7500 leaflet gives the A7000 25 MIPS.
Pages that cite these documents
Downloads: A7000 datasheet, ARM7500 leaflet, A7000+ leaflet
[edit | edit source]- ↑ Centre for Computing History, "Acorn A7000+ Welcome Guide", catalogue entry CH17021 (retrieved 2026-10-01): 140-page manual, part no. 1402,215, issue 1, March 1997, reference AMJ02.
- ↑ "A7000 floppy / HD issues", stardot.org.uk forum thread, February 2017 to December 2024. sirbod: "Pity there's no diagrams for the board"; IanJeffray, December 2024: the A7000 schematics "were never published, as far as we know", but the Risc PC schematics cover many parts.
