Atari 800XL
Revision as of 04:08, 23 September 2026 by Josh (talk | contribs) (Rewritten against the Atari 800XL Field Service Manual: +5 V only through a 7-pin DIN, +/-2%, 1.2 A max, no +12 V rail and no on-board regulator; ROM corrected to 24 KB (16 KB OS + 8 KB BASIC); full IC location map with '(not used)' positions flagged; monitor jack output levels added; corrected the garbled '256 hues x 16 luminance' palette text; real <ref> citations)
Atari 800XL
Atari 800XL home computer
ManufacturerAtari, Inc.
TypeHome computer
Released1983
Intro priceUS$299 (1983)
CPUMOS Technology 6502C @ 1.79 MHz (NTSC) / 1.77 MHz (PAL)
Memory64 KB RAM (eight 64K x 1 DRAMs); 24 KB ROM (16 KB OS + 8 KB BASIC Rev. B)
StorageCassette (1010) or 5.25" floppy disk drive (1050) over SIO; ROM cartridge
Display40 x 24 text, up to 320 x 192 pixels; RF and 5-pin DIN monitor output
SoundPOKEY: four audio channels
OS / FirmwareAtari XL Operating System; Atari BASIC Rev. B in ROM
PredecessorAtari 800
SuccessorAtari 65XE
Model no.800XL
The Atari 800XL is the full-memory model of Atari's XL range, announced with the Atari 600XL in June 1983 and sold as the direct replacement for the 1200XL at US$299.[1] It became the most widely sold Atari 8-bit computer.
Atari's own field service manual for the machine is the source for the hardware detail, the component locations, the connector pinouts and the supply ratings below.[2]
Architecture and processor
The 800XL uses the 6502C at 1.79 MHz (NTSC) or 1.77 MHz (PAL), with a single +5 V DC requirement and an integral clock circuit.[2] The main board carries 64 KB of RAM, a 16K x 8 operating-system ROM and an on-board Atari BASIC ROM; the console has a keyboard with four function keys including a HELP key, a RESET key, a detachable RF television cable, an SIO jack, controller jacks, a single cartridge slot, a power LED, a 5-pin DIN monitor jack and a parallel bus interface.[2]
Atari 800XL principal integrated circuits
Position Device Atari part number
U1 LM358 dual op-amp C061702
U2 74LS138 decoder C061428
U3 MMU1B memory management unit C061618
U4 8K x 8 Atari BASIC Rev. B ROM C060302
U5 16K x 8 operating system ROM C061598
U7 ANTIC C021697
U8 6502C CPU C014806
U9-U16 64K x 1 DRAM (eight devices) C060612
U17 GTIA C014805
U18 74LS08 quad AND C017097
U19 74LS14 hex inverter C061850
U20 CD4050B hex buffer C010816
U22 POKEY C012294
U23 PIA C014795
U24, U25 CD4051B keyboard sense/scan multiplexers C014336
U26, U27 74LS158 multiplexer C014345
U28 74LS375 latch C060619
U29 Delay module C060472
U30 74LS51 AND/OR inverter C060474
The crystal Y1 is 3.579545 MHz.[2] Positions U6 and U21 are marked "(not used)" in Atari's parts list, as are a number of capacitor, resistor and inductor positions - an unpopulated footprint on an 800XL board is usually factory-correct, not a missing part.[2]
Memory
  • 64 KB RAM - eight 64K x 1 DRAMs at U9-U16[2]
  • 24 KB ROM - a 16K x 8 operating system ROM at U5 and an 8K x 8 Atari BASIC Rev. B ROM
 at U4. Built-in BASIC behaves as a permanently fitted cartridge; a cartridge in the slot takes
 precedence over it in hardware.[2]
All of the operating system is shadowed by RAM on 64 KB XL and XE machines, which is what makes a RAM-based operating system - and the "Translator" load of the older 400/800 Rev. B operating system for incompatible software - possible.[3][4]
Display, video output and sound
Graphics are produced by ANTIC and GTIA: text up to 40 x 24, bitmap modes up to 320 x 192 pixels, four players and four missiles with collision detection, and programmable display lists with smooth scrolling.
The 5-pin DIN monitor jack (J2) carries composite video and composite luminance from the GTIA video summation circuitry and amplified mono audio from POKEY. Atari specifies the following output levels:[2]
800XL monitor jack output levels (J2)
Signal Minimum Maximum
Composite video 750 mV p-p 1 V p-p
Composite luminance 1.2 V p-p 1.5 V p-p
Audio 600 mV p-p 750 mV p-p
The RF modulator (UM1652) produces 1-2 mV into 75 ohms, with the audio carrier 4.5 MHz above the video carrier; channel 2 uses a 55.25 MHz video carrier and channel 3 a 61.25 MHz one.[2]
POKEY provides four audio channels, keyboard scanning, serial I/O and a random-number generator.
Input, output and expansion
  • Cartridge slot - 30-pin connector (C014389)[2]
  • SIO port - 13-pin right-angle connector (J1, C012995), maximum 19.2 kbaud[2]
  • Two controller jacks - 9-pin right-angle (C010448); pin 7 is +5 V and pin 8 ground[2]
  • Monitor jack - 5-pin DIN (J2, C014388)[2]
  • Parallel Bus Interface - 50-pin edge connector on the rear
  • Power in - 7-pin DIN (C061838)[2]
  • Keyboard header - 24-pin (C061793)[2]
The XL machines have only two controller jacks where the 400 and 800 had four. The PIA's PORTB, which used to serve jacks 3 and 4, is used on the XL for switching the operating system and BASIC in and out and for invoking the self tests.[3]
Keyboard
A 3/4-stroke, 56-key keyboard: 55 alphanumeric keys including special characters and controls, a space bar, four function keys and RESET. The matrix is read through the two CD4051B sense/scan decoders at U24 and U25.[2] (The equivalent parts on the 600XL are at U22 and U23.[5])
HELP returns to the main self-test menu from an individual test. Holding OPTION at power-on disables the built-in BASIC, and with no cartridge or diskette present the self-test menu appears.[2]
Power
The 800XL takes +5 V DC through a 7-pin DIN connector on the rear panel, Atari part C061838. The external supply accepts 110 V AC nominal and provides +5 V DC, +/-2%, rated 1.2 A maximum.[2]
The 800XL is a +5 V only machine. There is no +12 V rail, no 7812 and no on-board regulator or rectifier of any kind: Atari's parts list for the board contains none. The XL line was the first Atari computer family to need only a single 5 V DC supply.[2][3]
Checking a machine
  • PRINT PEEK(65527) from BASIC returns 2 on an 800XL, 1 on a 600XL,
 10 or 11 on a 1200XL and 221 or 255 on a 400 or 800.[3]
  • Hold OPTION at power-on with no cartridge or disk to reach the self-test menu; press
 HELP to return to the menu from a test.[2]
  • Atari's deeper diagnostic for this machine is the SuperSALT test assembly with jumper
 cables and a power supply.[2]
Schematics and service manual
Atari 800XL documentation
Logic board schematics Field service manual
File:Atari 800XL Schematics.pdf File:Atari 800XL Service Manual.pdf
The manual is also available as a page: Atari 800XL Service Manual.
  1. "The Atari 1400XL Computer Systems", Atari Museum (Curt Vendel): "In June of 1983 Atari would follow up from the announcements of the 600XL and 800XL with its other computers", and the 800XL was to be the 1200XL's direct replacement "in a much more affordable design at $299". Secondary source.
  2. 2.00 2.01 2.02 2.03 2.04 2.05 2.06 2.07 2.08 2.09 2.10 2.11 2.12 2.13 2.14 2.15 2.16 2.17 2.18 2.19 2.20 2.21 Atari, Inc., ATARI 800XL Computer Field Service Manual. Section 1 (theory of operation, monitor output levels, power supply, connector pin assignments) and the parts list. Hosted on this wiki: File:Atari 800XL Service Manual.pdf.
  3. 3.0 3.1 3.2 3.3 Robert DeWitt, "Inside Atari: Evolution of the XL Computers", Antic Vol. 3 No. 2 (June 1984), reproduced at atarimagazines.com. Source for the loss of the third and fourth joystick ports, the single 5 V supply, the 600XL having no monitor output, and the PEEK(65527) operating-system revision values.
  4. Matthew Ratcliff, "First Look Inside the XE Game System", Antic Vol. 7 No. 4 (August 1988), reproduced at atarimagazines.com. Source for the DB15 keyboard connector, the two 64K x 4 DRAMs and 17-chip count, the built-in Missile Command bank-switching and the XG-1 light-pen register behaviour.
  5. Atari, Inc., ATARI 600XL Computer Field Service Manual, FD100610 Rev. 1, October 1983. Section 1 (theory of operation, power supply, connector pin assignments), Section 5 (parts list with designators and Atari part numbers). Hosted on this wiki: File:Atari 600XL Field Service Manual.pdf.
