IBM 5110 Troubleshooting Guide
This guide documents fault diagnosis for the IBM 5110 Computing System. The 5110 inherits the IBM 5100's PALM processor and integrated 5-inch CRT, so much of the troubleshooting practice translates directly from the 5100. The 5110 adds the external IBM 5114 Diskette Unit (8-inch floppy drives), IEEE-488 (HP-IB) bus, RS-232 channels, and EBCDIC encoding, each with their own diagnostic surface.
Reference Documents
- SY31-0553-2 โ IBM 5110 System Maintenance Analysis Procedures (MAP), January 1979 โ the per-symptom troubleshooting decision tree.[1]
- SY31-0550-2 โ IBM 5110 Computer Maintenance Information Manual (MIM), February 1979 โ theory of operation and diagnostic procedures.
- SY31-0551-1 โ IBM 5114 Diskette Unit Maintenance, January 1979 โ 8-inch floppy drive diagnostics.
- SY31-0557-0 โ IBM 5110 Async Communications, January 1978 โ comms adapter diagnostics.
- SA21-9311-1 โ Customer Support Functions, October 1978 โ operator-level acceptance test.
Initial Diagnosis Workflow
5110 power-on sequence:
- Power LED on rear illuminates.
- PSU rails stabilise (5110 + 5114 if attached).
- Executable ROS self-test runs.
- Language interpreter loads from Language ROS.
- Language banner ("BASIC READY" or "APL READY") appears on the 5-inch CRT.
If any of these does not occur, stop and diagnose at that stage.
Stage 1 โ No Power
- Mains lead, switch, fuse check on the 5110.
- If a 5114 is attached, check the 5114 mains lead and switch separately โ they have independent power.
- Verify PSU rails at the planar power connector.
Stage 2 โ Power But No Display
Same diagnostic surface as the IBM 5100:
- Front-panel "Display Registers / RAM Hex" switch โ confirms video chain.
- Reseat ROS / RWS / PALM cards.
- Check CRT anode HV.
Stage 3 โ Banner Wrong / Garbled
- Language ROS bit error โ reseat Language ROS.
- Toggle APL / BASIC โ if one banner is clean and the other garbled, isolated to the failed Language ROS.
- On the 5110 the EBCDIC character set is in use โ verify that the garble isn't actually correct EBCDIC characters being read as 5100 encoding.
Stage 4 โ System Won't Read / Write Diskettes (5114)
- No drive activity at all โ cable between 5110 and 5114 unseated, or 5114 PSU dead.
- Drive spins but won't read โ head dirty; head alignment; drive belt slipping.
- Read OK, write produces unreadable diskettes โ head alignment, write-protect sensor stuck.
- Sporadic CRC errors โ drive belt aged, oxide shedding from old diskettes, head dirty.
Stage 5 โ IEEE-488 Bus Not Working
- Cable unseated.
- Terminator missing or failed.
- IEEE-488 controller card on 5110 reseat.
- Test with a known-good instrument.
Diagnostic ROS
Same keyboard sequence at power-on as the IBM 5100; enters Diagnostic ROS for read / write access to RAM, video memory, PALM registers, interrupt vectors and clock counter.[2]
The 5110 MIM SY31-0550 documents the Diagnostic ROS error codes specific to the 5110 (Section IV).
Customer Acceptance Test
The Customer Acceptance Test (CAT) for the 5110 is documented in SA21-9311-1 (Customer Support Functions). It uses a customer test diskette (on Model 2 or 3) or test tape cartridge (on Model 1) and exercises:
- RAM (full pattern test).
- Tape drive (Model 1).
- Diskette drives (5114, if attached).
- IEEE-488 bus (if cable + terminator present).
- RS-232 channels (loopback or external).
- Communications Adapter (if fitted).
- CRT and keyboard.
PALM Diagnosis
Same as the IBM 5100 โ PALM gate arrays are unobtainium. Reseat the PALM edge connector before suspecting failure. PALM-specific check-stop codes in the MIM identify which gate array has failed when a failure is real.
ROS / RWS Memory Faults
- Garbled banner โ Language ROS bit error.
- Refusal to complete Executable ROS self-test โ Executable ROS bit error or PALM fault.
- RAM size mismatch on banner โ RWS card failure; reseat each 16 KB module.
Tape Drive Faults (Model 1)
Same procedure as IBM 5100 Troubleshooting Guide. Belt, capstan, head, alignment, in that order.
8-Inch Floppy Drive Faults (5114)
- No drive activity โ 5114 PSU dead, or cable to 5110 unseated.
- Drive spins but won't read โ head dirty, alignment drift, drive belt slipping.
- Won't load head โ head load solenoid fatigued or stuck.
- Write errors โ write-protect sensor, head alignment.
- CRC errors โ drive belt aged, oxide shedding from old Diskette 2D media, head dirty.
- Spindle won't spin โ motor brushes worn.
The 5114 MIM SY31-0551 documents per-symptom diagnosis with FRU swap decision tree.
CRT Faults
Same as the IBM 5100 โ flyback, deflection, cathode emission.
IEEE-488 Bus Diagnosis
- Bus hung โ terminator missing or failed.
- Controller initialisation timeout โ PALM IEEE-488 controller card; reseat or replace.
- Single instrument not responding โ instrument address conflict; verify dipswitch settings on the instrument.
- All instruments timing out โ cable, terminator, or 5110 IEEE-488 interface failure.
RS-232 / Async Communications Faults
The Async Communications Feature (SY31-0557) carries common RS-232 faults:
- Wrong baud rate โ verify dipswitch settings on the adapter and target.
- Garbled output โ parity, stop bits, character set mismatch.
- No output โ cable; pin 2 / pin 3 swap.
- Cable wired straight-through vs crossed (null modem) โ verify the target device's pinout.
Common Field Symptoms and Resolutions
- Won't power on โ Mains, fuse, switch, PSU primary.
- Power LED but no display โ PSU bulk filter caps shot; see IBM 5110 Capacitor Replacement Guide.
- Banner appears, system hangs on keystroke โ keyboard or PALM input handling.
- Garbled banner โ Language ROS or socket oxidation.
- Tape works on 5110 but data won't transfer to a 5100 โ EBCDIC vs 5100-specific encoding mismatch (not a fault).
- 5114 floppy not detected โ cable or 5114 PSU.
- Floppy reads OK but writes corrupt โ head alignment; or aged diskette media.
- IEEE-488 instrument not responding โ addressing, terminator, cable.
- Random reboots / hangs โ bulk filter cap ESR rising; recap PSU.
Diagnostic Workflow Summary
- Power on; observe LED, fan, display chain.
- If no power on 5110, suspect 5110 PSU. If no power on 5114, suspect 5114 PSU.
- If power but no display, suspect Executable ROS, PALM, or CRT chain.
- If display but garbled banner, reseat ROS and try the other language.
- Enter Diagnostic ROS and run the documented self-tests.
- Run the Customer Acceptance Test from diskette (Model 2/3) or tape (Model 1).
- Cross-reference any check-stop code against MAP document SY31-0553.
Architecture
The IBM 5110 is built around the IBM PALM (Program All Logic in Microcode) 16-bit processor, with its operating environment (APL and/or BASIC) held in microcode "read-only storage" (ROS). It is not PC-compatible and predates the IBM PC, so PC diagnostics do not apply โ use the routines in the IBM Maintenance Information manual.[3]
This machine uses the internal PSU that converts 115 V AC to the system rails. Confirm every rail (the 5100/5110-type supply produces +12 V, โ12 V, +8.5 V, +5.0 V and โ5.0 V) before chasing logic faults. Ageing electrolytics are the usual failure โ recap and re-check the rails.[3]
Storage and display
The 5110 uses 8-inch floppy drives (internal or external) and has a small built-in CRT. Mechanisms need cleaning and belt/roller service; the IBM Maintenance Information manuals (on Bitsavers) give the full disassembly, adjustment and diagnostic procedures.[3]
- โ http://bitsavers.org/pdf/ibm/5110/
- โ https://en.wikipedia.org/wiki/IBM_5100
- โ 3.0 3.1 3.2 IBM 5100 Power Supply, voidstar; IBM PALM processor, Wikipedia; and the IBM 5110/5120 Maintenance Information manuals on Bitsavers. Source for the PALM architecture, the five-rail PSU, and the 5120 dual power supplies.
Related Pages
- IBM 5110
- IBM 5110 Maintenance Guide
- IBM 5110 Capacitor Replacement Guide
- IBM 5100 Troubleshooting Guide โ most procedures translate directly
- Bitsavers โ IBM 5110 documents.
- IBM 5110 โ Wikipedia.
- IBM PALM processor โ Wikipedia.
- Stuttgart Computermuseum โ IBM 5110.
