IBM 5120 Troubleshooting Guide
This guide documents fault diagnosis for the IBM 5120 Computing System (also designated IBM 5110 Model 3). The 5120 inherits the PALM processor and APL / BASIC ROM environment from the IBM 5100 and IBM 5110, so much of the troubleshooting practice translates directly. The 5120's two built-in 8-inch floppy drives, larger 9-inch CRT, and detached keyboard add their own diagnostic surface.
Reference Documents
- SY34-0192-0 โ IBM 5120 Maintenance Information Manual (MIM), December 1979 โ the CE service manual, includes the diagnostic procedures.[1]
- SY34-0193-0 โ IBM 5120 Computing System Logic Manual, December 1979 โ gate-level theory of operation, essential for board-level fault isolation.
- GH30-0232-1 โ Joint 5110 / 5120 Bibliography, September 1980.
Initial Diagnosis Workflow
5120 power-on sequence:
- Power LED on the front panel illuminates.
- Fans spin (CRT and PSU cooling).
- PSU rails stabilise.
- Executable ROS self-test runs.
- Language interpreter loads from Language ROS (front-panel toggle selects APL or BASIC).
- Language banner ("BASIC READY" or "APL READY") appears on the 9-inch CRT.
- 5120 is ready for keyboard input.
If any of these does not occur, stop and diagnose at that stage.
Stage 1 โ No Power
- Mains lead, switch, fuse on the 5120 PSU.
- Verify PSU rails at the planar power connector.
- If the front-panel power LED is dim, suspect 5VSB-equivalent regulator capacitor failure.
Stage 2 โ Power But No Display
- No raster on 9-inch CRT โ flyback or horizontal output failure. Check for HV at the CRT anode with an HV probe. No HV โ flyback failure (rare but terminal without a donor).
- Raster but no characters โ Executable ROS or video timing chain failure.
- Garbled characters โ RAM (RWS) failure or Executable ROS bit error. Use Diagnostic ROS to verify.
Stage 3 โ Banner Wrong / Garbled
- Language ROS bit error โ reseat Language ROS.
- Toggle APL / BASIC โ if one banner is clean and the other garbled, the failed ROM is isolated.
Stage 4 โ System Won't Read / Write Floppies
- No drive activity at all โ drive cable to planar unseated, or PSU spindle rail dead.
- Drive spins but won't read โ head dirty; head alignment; drive belt slipping.
- Read OK but write produces corrupt diskettes โ head alignment; write-protect sensor.
- CRC errors โ belt aged, oxide shedding from old Diskette 2D media, head dirty.
- Won't load head โ head load solenoid fatigued.
Diagnostic ROS
Same keyboard sequence at power-on as the IBM 5100 / IBM 5110; enters Diagnostic ROS for read / write access to RAM, video memory, PALM registers, interrupt vectors and the clock counter.[2] The 5120 MIM SY34-0192 documents the Diagnostic ROS error codes specific to the 5120.
Customer Acceptance Test
The 5120 CAT runs from a customer test diskette. It exercises:
- RAM (full pattern test).
- Both built-in 8-inch floppy drives (read / write / verify).
- The 9-inch CRT (cursor positioning and character set).
- The detached keyboard.
- The communications adapter (if fitted).
- The 5114 (if attached).
A test pattern of garbled characters at the same screen position across multiple tests usually indicates a specific bit position failure in a RAM bank.
PALM Diagnosis
Same as the IBM 5100 โ PALM gate arrays are unobtainium. Reseat the edge connector before suspecting failure. PALM-specific check-stop codes in the MIM identify failed gate arrays.
ROS / RWS Memory Faults
- Garbled banner โ Language ROS bit error; reseat ROS modules.
- Refusal to complete Executable ROS self-test โ Executable ROS bit error or PALM fault.
- RAM size mismatch on banner โ RWS card failure; reseat each 16 KB module.
8-Inch Floppy Drive Faults
- No drive activity โ PSU spindle rail (typically 12 V or 24 V), or controller card to drive cable.
- Drive spins but won't read โ head dirty, head alignment, belt slipping.
- Won't load head โ solenoid fatigued or stuck.
- Write errors but no read errors โ write-protect sensor; or head alignment offset from write to read.
- CRC errors โ belt aged; oxide shedding from old media; head dirty.
- Drive A: works, Drive B: doesn't (or vice versa) โ drive select jumper or cable; check the position of the terminating resistor pack at the end of the daisy-chain (only the last drive should have the terminator).
The 5120 MIM SY34-0192 has a per-symptom decision tree for the 8-inch floppy subsystem.
CRT Faults
- No raster โ flyback or horizontal output transistor failure.
- Raster but no characters โ video timing chain (PALM video output).
- Dim raster โ cathode emission loss; CRT end-of-life.
- Single horizontal line โ vertical deflection failed.
- Single vertical line โ horizontal deflection failed (usually accompanied by flyback failure).
- Bright spot โ both deflections failed; immediately power off to avoid phosphor burn.
- Phosphor burn-in (static image on inactive screen) โ CRT has been operated for too long with fixed display; replacement requires donor.
The 9-inch CRT carries higher anode voltage than the 5-inch CRT on the 5100 / 5110; flyback failures are correspondingly more dramatic.
Keyboard Faults
- No keyboard response โ cable unseated; clean the keyboard connector with deoxidising contact cleaner.
- Repeating characters / sticky keys โ buckling-spring or capacitive switch contamination; remove and clean.
- Specific key dead โ switch contact contamination.
- All keys produce wrong characters โ keyboard scan controller failure.
Communications and RS-232 Faults
If a Communications Adapter or RS-232 channel is fitted:
- Verify cable.
- Verify baud / parity / stop bits.
- Test with a known-good target.
Common Field Symptoms and Resolutions
- Won't power on โ mains lead, switch, fuse, PSU primary.
- Power LED but no display โ PSU bulk filter caps; see IBM 5120 Capacitor Replacement Guide.
- Banner appears but system hangs on keystroke โ keyboard cable or PALM input handling.
- Garbled banner โ Language ROS or socket oxidation.
- Drive A: reads but Drive B: doesn't โ drive select jumper or cable terminator.
- Both drives spin but won't read โ head clean, then alignment, then belt.
- Random reboots / hangs โ bulk filter cap ESR rising; recap PSU.
- Smell of fish from PSU โ RIFA X2 mains-suppression capacitor venting; replace immediately.
- CRT loses focus after warm-up โ flyback transformer insulation breakdown; replacement requires donor.
Diagnostic Workflow Summary
- Power on; observe LED, fan, display chain.
- If no power, suspect PSU.
- If power but no display, check CRT anode HV first, then Executable ROS / PALM.
- If display but garbled banner, reseat ROS modules; try the other language.
- Enter Diagnostic ROS (keyboard sequence at power-on); verify PALM, RAM, ROS.
- Run the Customer Acceptance Test from diskette.
- If diskette won't load, check drive belt, head, alignment.
- Cross-reference any check-stop code against MIM SY34-0192 and Logic Manual SY34-0193.
Related Pages
- IBM 5120
- IBM 5120 Maintenance Guide
- IBM 5120 Capacitor Replacement Guide
- IBM 5110 Troubleshooting Guide โ sibling machine
- IBM 5100 Troubleshooting Guide โ PALM / ROS diagnosis translates directly
- Bitsavers โ IBM 5120 documents. MIM SY34-0192, Logic Manual SY34-0193.
- IBM 5120 โ Wikipedia.
- IBM PALM processor โ Wikipedia.
