IBM PS/2 Model 70
Revision as of 17:32, 23 May 2026 by Josh (talk | contribs) (Reduce infobox badge size from 250px to 150px)
IBM Personal System/2 Model 70
IBM PS/2 Model 70 (8570) low-profile desktop
ManufacturerIBM
TypeDesktop personal computer
ReleasedJune 2, 1988
Discontinuedc. 1992
CPUIntel 80386DX @ 16 MHz (8570-E61); 20 MHz (8570-121); 25 MHz (8570-A21 / A61); Intel 80486DX @ 25 MHz via Power Platform daughtercard (8570-B21 / B61). Optional Intel 80387DX coprocessor on 386-based submodels (built into 80486 on Power Platform)
Memory2 MB stock (E61); 4 MB stock (121 / A21 / B21); 4 ร— 72-pin proprietary PS/2 SIMM sockets on planar; 16 MB max on planar, expandable further via MCA Memory Adapter cards
Storage1.44 MB 3.5" diskette + 60 MB ESDI (E61 / A61 / B61) or 120 MB ESDI (121 / A21 / B21) via IBM ESDI Fixed Disk Adapter/A
DisplayIntegrated VGA on planar (256 KB VRAM, 15-pin DSUB); supports IBM 8503 / 8512 / 8513 / 8514 displays
SoundPC speaker
Dimensions421 W ร— 421 D ร— 144 H mm
Weight~9.5 kg
OS / FirmwareIBM PC DOS 3.30 / 4.00 / 5.00; IBM OS/2 1.x / 2.x / Warp 3; IBM AIX PS/2; Windows 3.0 / 3.1
PredecessorIBM PS/2 Model 50 (286-class desktop sibling)
SuccessorIBM PS/2 Model 90 XP 486 (32-bit MCA 486 desktop)
Model no.8570
The IBM PS/2 Model 70 (IBM machine type 8570) was a 32-bit, 80386DX-based desktop introduced in June 1988 as the high-end desktop member of the IBM Personal System/2 family. The Model 70 paired the planar architecture of the Model 60 with a 32-bit Micro Channel implementation and a full 80386DX with paging, protected mode and 32-bit data path, in the same desk-friendly low-profile chassis as the Model 50.
The Model 70 is the desktop counterpart to the IBM PS/2 Model 80 tower. The two share the 32-bit MCA bus, the 80386DX-family processor, and (in 16 / 20 MHz submodels) most of the planar topology โ€” but the Model 70 has only three MCA slots and a single 5.25" / two 3.5" drive cage in the low-profile desktop chassis, while the Model 80 is the eight-slot tower.
The Model 70 is well known for two engineering features: the optional Power Platform 486 upgrade module (a daughtercard that replaced the 80386DX socket on the planar with an Intel 80486-based daughtercard), and the on-planar VGA (no separate display adapter card needed). It is equally well known to restorers for the surface-mount aluminium electrolyte leakage on the 8570 planar, which is now considered the classic PS/2 failure mode and is documented in IBM PS/2 Model 70 Capacitor Replacement Guide.
Submodels
Model 70 submodels
Submodel CPU Speed HDD Notes
8570-E61 80386DX 16 MHz 60 MB ESDI Entry submodel, June 1988
8570-121 80386DX 20 MHz 120 MB ESDI 20 MHz, larger ESDI
8570-A21 80386DX 25 MHz 120 MB ESDI 25 MHz top-end; planar revisions differ from E61/121
8570-A61 80386DX 25 MHz 60 MB ESDI 25 MHz with smaller HDD
8570-B21 80486-DX (via Power Platform) 25 MHz 120 MB ESDI Power Platform-equipped Model 70 โ€” 80486 daughtercard replaces 80386DX socket
8570-B61 80486-DX (via Power Platform) 25 MHz 60 MB ESDI As B21 with smaller HDD
The 80386DX in the Model 70 includes paging and full protected mode; the planar exposes the full 32-bit MCA data path. The 16/20/25 MHz submodels boot OS/2 1.x and 2.x, AIX PS/2 and PC DOS 3.30 / 4.00 / 5.00.
Chassis and Layout
The Model 70 chassis is the same low-profile desktop as the Model 50:
  • Width ร— depth ร— height (chassis): approx 421 ร— 421 ร— 144 mm.
  • Weight (without HDD): approx 9.5 kg.
  • Two thumbscrews at the rear top corners hold the cover. Cover slides back 10 mm and lifts off.
  • Three MCA slots (all 32-bit) on a vertical riser at the rear.
  • One 5.25" half-height bay at the top (often empty or used for tape backup).
  • Two 3.5" half-height bays below it (one for floppy, one for the ESDI hard drive).
  • PSU on the left-front: 132 W on the Model 70.
  • Planar on the chassis floor, with the 80386DX socket near the front-right.
  • Power switch on the front-right.
  • Onboard VGA (15-pin Mini-D-Sub on the rear bracket of the planar).
  • PS/2 keyboard and mouse (Mini-DIN-6).
  • Serial port (DB-25 male) and parallel port (DB-25 female).
Planar
The Model 70 planar carries:
  • CPU: 80386DX, PGA-132, socketed. The socket is shared between the discrete 80386 (in E61 / 121 / A21 / A61) and the Power Platform daughtercard (in B21 / B61).
  • Optional 80387DX coprocessor in a socket adjacent to the 80386DX.
  • Memory: 4 ร— 72-pin SIMM sockets accepting 1, 2 or 4 MB modules. Maximum 16 MB (4 ร— 4 MB) on planar. PS/2 72-pin SIMMs are proprietary to IBM PS/2 โ€” they have a different pinout and parity convention from later PC 72-pin SIMMs.
  • RTC: Dallas DS1287 / DS12887 (24-pin DIP marked "DALLAS") with integrated lithium cell.
  • Onboard VGA: IBM VGA implementation with 256 KB of dedicated VRAM. VGA controller chip and VRAM are on the planar.
  • MCA bus controller: 32-bit MCA implementation, providing three 32-bit MCA slots.
  • Floppy controller integrated on the planar with single-cable interface.
  • Surface-mount aluminium electrolytic capacitors for IC bypassing throughout the planar. These are the famous PS/2 SMD caps that leak after 30+ years and cause the Model 70 to die slowly.
SMD Electrolyte Leakage โ€” The Famous PS/2 Plague
The Model 70 (and the Model 80) planar uses surface-mount aluminium electrolytic capacitors (SMD electrolytics) โ€” typically 10 ยตF / 16 V or 47 ยตF / 16 V โ€” scattered across both sides of the planar for IC supply rail bypassing. The aluminium electrolyte inside these caps is corrosive and the rubber bung seal degrades over decades, allowing the electrolyte to leak onto the planar.
Symptoms of SMD electrolyte leakage:
  • Brown / green residue near a SMD cap base.
  • Crusty deposits on nearby PCB traces.
  • Intermittent POST faults; system passes POST cold but fails when warm.
  • Random reboots.
  • Specific functional area (e.g., onboard VGA, RTC, serial port) becomes intermittent before failing.
  • Eventually, planar dies completely.
The leak is cumulative. Once electrolyte is on the planar surface, it continues to corrode traces and ICs even after the PSU is unplugged. Restoration requires complete SMD cap removal, planar wash (IPA or laboratory cleaning), trace repair where necessary, and recap with modern equivalents.
The Model 70 SMD leak is the single most common cause of an apparently-dead 8570. See IBM PS/2 Model 70 Capacitor Replacement Guide for the full recap procedure.
Power Platform
The IBM Power Platform is an upgrade daughtercard that replaces the 80386DX socket on the Model 70 planar with an Intel 80486-based daughterboard. The Power Platform was offered as both a factory-fitted option (the 8570-B21 / B61) and as a field upgrade kit (FRU 64F8011).
Power Platform key characteristics:
  • CPU: Intel 80486DX (or 80486SX on some Power Platform variants).
  • Cache: 8 KB on-die in the 80486; no L2 cache on the Power Platform.
  • Speed: 25 MHz internal, with the planar MCA bus running at the same speed it did under the 80386DX.
  • Compatibility: Power Platform requires planar BIOS update; the BIOS update is on the Reference Diskette for the B21 / B61 submodels.
The Power Platform is a sought-after period upgrade for Model 70 restorers because it brings the desktop chassis up to 80486-class performance without resorting to MCA accelerator cards.
Display
Like the Model 50 and Model 60 (but unlike earlier PS/2 models), the Model 70 has VGA on the planar. The VGA chip and 256 KB of dedicated VRAM are on the planar; no display adapter card is required.
Supported monitors:
  • IBM 8503 โ€” 12" monochrome VGA.
  • IBM 8512 โ€” 14" colour VGA, 640 ร— 480 max.
  • IBM 8513 โ€” 12" colour VGA.
  • IBM 8514 โ€” 16" high-resolution display (1024 ร— 768 with the matching IBM 8514/A MCA card; standard VGA without it).
The on-planar VGA cannot do 1024 ร— 768 โ€” that requires an IBM 8514/A or compatible MCA display adapter.
Drive Architecture
The Model 70 uses the PS/2 single-cable drive interface for the floppy drive (1.44 MB DSHD 3.5" half-height) and the IBM ESDI Fixed Disk Adapter/A for the hard drive. The 8570 ESDI controller is on an MCA card; the drive's data and power cables connect directly to the rear of the controller card, not to the planar.
ESDI drives in the 8570 are 60 MB (E61 / A61) or 120 MB (121 / A21 / B21).
Reference Diskette
The Model 70 requires a Model 70-specific Reference Diskette. The Reference Diskette is used for:
  • SETUP (drive types, date, time, memory size).
  • MCA Auto Configuration.
  • Advanced Diagnostics (Ctrl-A from Reference Diskette menu).
  • Reading and writing CMOS configuration.
The Reference Diskette is not interchangeable with the Model 50 / 60 / 80 Reference Diskette. The Power Platform-equipped Model 70 (B21 / B61) uses a different Reference Diskette image with BIOS extensions for the 80486 daughtercard.
Software
  • PC DOS 3.30 was the launch OS in 1988.
  • PC DOS 4.00 followed shortly after.
  • PC DOS 5.00 (1991) was the contemporary final DOS.
  • OS/2 1.x (and IBM's later OS/2 2.0 / 2.1 / Warp 3) โ€” the Model 70 is one of the best 80386-class platforms for OS/2 2.x.
  • AIX PS/2 โ€” IBM's Unix for PS/2.
  • Windows 3.0 / 3.1 run on DOS on the Model 70.
Common Faults
Specifications Summary
Model 70 stock specifications
Spec E61 121 A21 B21
CPU 80386DX-16 80386DX-20 80386DX-25 80486DX-25 (Power Platform)
RAM stock 2 MB 4 MB 4 MB 4 MB
RAM max 16 MB 16 MB 16 MB 16 MB
FDD 1.44 MB 3.5" 1.44 MB 3.5" 1.44 MB 3.5" 1.44 MB 3.5"
HDD 60 MB ESDI 120 MB ESDI 120 MB ESDI 120 MB ESDI
Coprocessor 80387DX (opt.) 80387DX (opt.) 80387DX (opt.) Built into 80486DX
Video Onboard VGA Onboard VGA Onboard VGA Onboard VGA
PSU 132 W 132 W 132 W 132 W
MCA slots 3 (all 32-bit) 3 (all 32-bit) 3 (all 32-bit) 3 (all 32-bit)
Bays 1 ร— 5.25", 2 ร— 3.5" 1 ร— 5.25", 2 ร— 3.5" 1 ร— 5.25", 2 ร— 3.5" 1 ร— 5.25", 2 ร— 3.5"
Pricing
Launch pricing (1988):
  • 8570-E61: $7,995 USD.
  • 8570-121: $9,995 USD.
These are 1988 prices for high-end IBM business desktops. The Model 70 was sold primarily to corporate customers running OS/2, AIX PS/2 or DOS-based business applications.
