IBM System/23 Datamaster Maintenance Guide
This guide documents preventive maintenance for the IBM System/23 Datamaster (Model 5322 all-in-one desktop and Model 5324 tower variant), announced by IBM on 28 July 1981. The Datamaster's hardware is the direct architectural ancestor of the IBM PC (5150) and uses the same 9-bit parity DRAM, 62-pin expansion bus (with only 5 signals changed), 8253 PIT, 8259 PIC, capacitive Model F keyboard mechanism and Power Good signal. Restoration of a Datamaster is therefore closely related to PC-era practice โ with the major exception that the linear PSU and 8-inch floppy drives belong to the older 5120 / 5110 generation.
Safety Warning
The 5322 PSU is a linear supply (50/60 Hz transformer + bridge + linear regulators) with large bulk filter capacitors. The integrated CRT carries lethal high voltage on the flyback transformer and anode. Before any work inside the chassis:
- Power off and unplug the mains lead.
- Wait at least 30 seconds.
- Discharge each PSU bulk filter capacitor through a 1 kฮฉ / 5 W resistor.
- Discharge the CRT anode to chassis ground via a high-voltage probe before any work on the deflection / flyback board.
- Verify both with a multimeter.
Documentation Set
The complete IBM service documentation set for the System/23 is preserved at Bitsavers:
- SY34-0171-0 โ IBM 5322 Computer Service Manual, December 1980. The primary CE document; covers diagnostics, power supply, drives, board layouts, schematics. Indispensable for any Datamaster restoration.[1]
- SY34-0241-1 โ IBM 5324 Computer Service Manual, May 1982.[2]
- 6841631 โ System/23 Diagnostic User Guide, April 1982 (complete PID-1200 test ID list).[3]
- SA34-0107-3 โ System/23 Setup Instructions (5322), June 1982.
- ZA38-0016-0 โ Commonly Used Systems Parts Handbook, July 1988 (p. 119 lists 5322 / 5324 motherboard parts).
Download all of these for any serious Datamaster work.
Opening the System Unit
Tools: Philips #2 screwdriver, T15 / T20 Torx, anti-static strap, high-voltage probe.
A distinctive feature of the 5322 chassis: both the power supply and the motherboard slide out from the rear without removing the main cover.[4] This is unusual for the era and means most service operations can be performed without disturbing the integrated CRT cradle.
- Power off and unplug all cables (mains, keyboard, printer, communications, external diskette unit cable).
- Rear cover plate โ held by Philips screws around the perimeter.
- Motherboard sled โ slides out horizontally from the rear once retaining screws are removed.
- PSU sled โ slides out similarly from a separate rear bay.
- The integrated 9-inch (or possibly 12-inch โ see Verification Note below) CRT and its deflection sub-chassis remain in the main chassis.
- Drive cage โ accessed by removing the front bezel and lifting the drive sled.
Verification Note on CRT Size
Wikipedia describes the Datamaster CRT only as "green phosphor" without specifying a diagonal. One search snippet referred to a "12-inch green phosphor CRT" but this could not be verified against IBM primary sources. Most restorer references describe a 9-inch tube similar to the IBM 5120. Confirm the tube diagonal against your specific unit โ the SY34-0171-0 front matter should specify it.
Detached Keyboard
The 5322's keyboard is a separate unit connecting to the system via a multi-pin cable:
- 83-key capacitive Model F (or rather, the pre-Model F mechanism โ the Datamaster keyboard is often cited as the earliest production version of the design).
- Intel 8048 microcontroller inside the keyboard with Datamaster-specific firmware. Critical: the 8048's firmware is unique to the Datamaster โ IBM PC keyboard 8048 firmware is not interchangeable. A failed 8048 means the keyboard cannot be made to work with another Datamaster unless you have a donor keyboard.
- Interface to the motherboard is parallel (driven by an 8255 PPI port). The IBM PC moved the same keyboard mechanism to a serial interface.
Inspecting the Chassis
Inspection items (in order):
- PSU bulk filter capacitors โ visual check for bulging tops, leaked electrolyte, discolouration. Linear PSU caps at 40+ years old are the highest-likelihood failure point.
- Series-pass regulator transistors โ heatsink-mounted; check thermal paste; replace if dried out.
- Memory daughter card decoupling caps โ community references specifically flag these as failure points. A shorted decoupling cap on the RAM rails will brick the system; recommended triage is to remove the bypass caps as a first test before suspecting the RAM itself.[5]
- Flyback / deflection board โ inspect for cracked solder joints.
- Phosphor โ check for burn-in.
- 8-inch floppy drive belts โ perished urethane is the dominant failure on these drives.
- Spindle motor brushes โ wear is common after 40+ years.
- Mostek MK36000 ROS modules โ visually inspect for moisture damage / bulging package. These ROMs are a documented Datamaster failure mode.
- Keyboard 8048 โ confirm operational before any other keyboard work.
Regular Cleaning
- Soft brush and low-pressure compressed air for the motherboard, ROS sockets, RAM daughter cards, drive bays, and PSU vents.
- Do not use compressed air over a leaking electrolytic โ it spreads electrolyte across the board.
- Detach the keyboard for separate cleaning; wipe with slightly damp microfibre.
- Remove keycaps using the IBM tool (the Datamaster uses the same capacitive-Model-F mechanism that became the IBM PC AT / Model F keyboard).
- Clean 8-inch floppy heads with isopropyl alcohol on a foam swab (not cotton โ cotton fibres in the head gap cause CRC errors).
- Inspect every diskette before reading. Old IBM 8-inch media may have lost binder integrity; if oxide is shedding, do not load.
PSU Voltage Checks
The 5322 linear PSU outputs +5 V, +12 V, +24 V, โ5 V, โ12 V plus the Power Good signal that the 8085 / 8259 / DMA logic uses for orderly start-up. The +24 V rail powers the 8-inch floppy drive spindle motors and head loads; the โ5 V and โ12 V rails are bias supplies for older logic and for the RS-232 USART.[6]
The Power Good signal is the direct ancestor of the PC's PG signal โ connector pinout and signal semantics carried over unchanged into the IBM PC (5150).
| Rail | Approximate target | Notes |
| +5 V | +4.75 V to +5.25 V | Main logic supply (8085, 8259, 8253, 8255, RAM, ROS) |
| +12 V | +11.4 V to +12.6 V | RS-232 USART positive bias, drive logic |
| +24 V | +22.8 V to +25.2 V | 8-inch floppy spindle motor + head load |
| −5 V | −4.75 V to −5.25 V | Bias (legacy) |
| −12 V | −11.4 V to −12.6 V | RS-232 USART negative bias |
| Power Good | TTL high once all rails are within tolerance | |
| CRT anode | ~12โ15 kV (9-inch CRT) | Measure with HV probe only |
Out-of-tolerance rails after recapping bulk caps suggest a series-pass regulator transistor failure.
ATX PSU Substitution (Bench-Test)
It is documented community practice to substitute a modern ATX PSU as a bench-test power source once the original Molex pinout is matched.[7] The +24 V rail must be supplied separately (an ATX supply does not include +24 V); restorers commonly use a small standalone +24 V brick for floppy spindle power.
This is suitable for board-level diagnostics but is not a permanent replacement โ the integrated CRT deflection board requires the original PSU's +12 V and high-voltage primary feed.
8-Inch Floppy Drive Maintenance
The 5322 has 0, 1 or 2 ร built-in 8-inch floppy drives (typically Shugart-class in IBM cosmetics). Maintenance:
- Drive belt โ perished urethane. Modern replacements available from the 8-inch floppy restoration community.
- Head load solenoid โ exercise; replace if fatigued.
- Spindle motor โ brush wear is the main failure. Brushes can be re-sourced from industrial motor suppliers.
- Read / write head โ clean with IPA on a foam swab.
- Head alignment โ verify against a known-good diskette using the procedure in SY34-0171-0.
- Oxide shedding from old IBM media โ inspect every diskette before loading. Do not load shedding diskettes.
Optional External Storage
- IBM 5246 Diskette Unit โ external 1 or 2 ร 8-inch floppy drive enclosure. Service procedures match the internal drives.
- IBM 5247 Winchester Disk Unit โ 15.4 MB or 30.8 MB 8-inch hard drive. Has its own linear PSU and disk controller card. If the 5247 is shared between multiple Datamaster hosts, verify the host-selection cabling per the 5247 manual before any service work.
ROS Module Care
The motherboard carries 14 or 16 ร 8 KB ROS modules. These are normally:
- Mostek MK36000 โ most common; now a leading failure mode. Mostek mask ROMs of this era degrade with age. Symptoms: system halts mid-IPL or fails one or more PID-1200 ROS tests.
- Motorola 68366 โ alternative; more reliable.
- Motorola 68766 EPROM โ used on early-production boards because of supply shortages.
If a ROS test fails repeatedly, the canonical community workaround is a ROM-adapter card with re-burned firmware โ restorer-published ROM images exist on the Vintage Computer Federation forums.[8]
RAM Card Care
The 5322 RAM lives on one or two memory daughter cards via 36-pin card-edge connectors. Cards come in 32 KB and 64 KB sizes. Combinations:
- 32 KB total โ 32 KB card in base slot
- 64 KB total โ 64 KB card in base slot, or two 32 KB cards
- 96 KB total โ 64 KB + 32 KB
- 128 KB total โ 64 KB + 64 KB
The base slot must always be populated โ the system will not boot without it.
The DRAMs are TMS4132 โ TI's factory-piggybacked variant of the TMS4116, with two TMS4116-class dies stacked in a single package. This is often mistaken for IBM-soldered redundancy; it is a TI factory part. Failure of either die kills the byte โ to bench-test a TMS4132 you must physically separate the upper die from the lower die. This is normally not worth doing in a hobbyist restoration; replace the whole card with a known-good donor or modern reproduction.
Connector Care
- Keyboard cable โ multi-pin proprietary; clean both sides with deoxidising contact cleaner.
- Serial port (USART) โ current-loop or RS-232 depending on submodel; verify before connecting external equipment.
- Printer ports (up to two) โ IBM-proprietary connector pinout per SY34-0171-0.
- External 5246 / 5247 cable โ IBM-proprietary card-edge cable; clean and reseat both ends.
- Diagnostics probe port (rear) โ 8-bit data plus probe power; cleaned only when in use with a service-engineer probe.
Recommended Tools
- Philips #2 and T15 / T20 Torx screwdrivers.
- Anti-static strap.
- Digital multimeter with HV-rated probe (CRT anode is 12โ15 kV).
- High-voltage probe for CRT discharge.
- IPA + foam swabs.
- Soldering iron (fine tip) + solder wick.
- Modern 8-inch floppy drive belt replacement.
- IBM keycap removal tool (same as Model F PC AT keyboard).
- SY34-0171-0 PDF.
- Service probe with 8-bit LED display (build instructions in SY34-0171-0).
- Modern ROM adapter for replacing failed Mostek MK36000 ROS modules (community-built).
Related Pages
- IBM System/23 Datamaster
- IBM System/23 Datamaster Troubleshooting Guide
- IBM System/23 Datamaster Capacitor Replacement Guide
- IBM 5120 Maintenance Guide โ predecessor with related linear PSU caveats
- IBM PC (5150) Maintenance Guide โ direct architectural successor; common keyboard mechanism
- IBM 5322 Service Manual SY34-0171-0 (December 1980).
- System/23 Diagnostic User Guide 6841631 (April 1982).
- Bits Passats โ IBM System/23 Datamaster. The most thorough community technical reference.
- oldcomputers.net โ IBM 5322 System/23 Datamaster.
- Mark Blair (NF6X) โ IBM 5322 System/23 Datamaster Internals. Restorer's hands-on photos and notes.
- Vintage Computer Federation โ IBM System/23 Datamaster thread.
- VCFed โ IBM 5322 ROM image thread.
- โ http://bitsavers.org/pdf/ibm/system23/fe/SY34-0171-0_IBM_5322_Computer_Service_Manual_Dec80.pdf
- โ http://bitsavers.org/pdf/ibm/system23/fe/SY34-0241-1_IBM_5324_Computer_Service_Manual_May82.pdf
- โ http://bitsavers.org/pdf/ibm/system23/fe/6841631_System_23_Diagnostic_User_Guide_Apr82.pdf
- โ oldcomputers.net, "IBM 5322 System/23 Datamaster".
- โ Bits Passats, "IBM System/23 Datamaster".
- โ SY34-0171-0 p. 30, p. 78.
- โ Bits Passats.
- โ VCFed thread "IBM 5322 System 23 โ help needed, ROM image", https://forum.vcfed.org/index.php?threads/ibm-5322-system-23-help-needed-rom-image.65070/
