IBM PS/ValuePoint Capacitor Replacement Guide
Revision as of 15:33, 23 May 2026 by Josh (talk | contribs) (Deep technical PS/ValuePoint pages with verified sources (IBM HMM S61G-1423, kev009 mirror))
This guide documents capacitor diagnosis and replacement for the IBM PS/ValuePoint family — machine types 6381 / 6382 / 6384 / 6387. PS/ValuePoint planars predate the early-2000s capacitor plague that affects the IBM IntelliStation line, and they do not use the soldered barrel NiCd cells that destroy certain PS/2 model 30 / 56 / 57 / 76 / 77 boards. The PS/ValuePoint's main capacitor concern is the floppy drive logic board SMD electrolytic, with secondary concerns being aged 100 / 145 / 200 W PSU electrolytics.
Safety Warning
All PS/ValuePoint PSUs contain mains-rectified bulk capacitors that hold a lethal charge after power-off. Before any PSU work:
  1. Power off and unplug the mains lead.
  2. Wait at least 30 seconds.
  3. Discharge the bulk capacitor through a 1 kΩ / 5 W resistor.
  4. Verify with a multimeter.
Battery — IMPORTANT CLARIFICATION
The PS/ValuePoint planar battery is a standard CR2032 lithium coin cell. It is NOT a barrel NiCd, NOT a Dallas DS1287 / DS1287A integrated RTC module, and NOT a Varta-style rechargeable nickel cell. This means:
  • PS/ValuePoint planars are not affected by the famous Varta / NiCd leakage that destroys certain PS/2 Model 30 / 56 / 57 / 76 / 77, IBM ThinkPad, and Compaq motherboards.
  • Replacement is a tool-free swap from a snap clip at position B1 / BT1.
  • No desoldering is required.
The IBM Product Description repeats "Lithium battery" for every PS/ValuePoint variant including 6381 SX, 6381 DX/DX2, 6382/S, 6384/D, 6384 P60/D, and 6387/T.[1][2]
Although CR2032 cells very rarely leak, they can do so under unusual conditions; restorer field reports document a leaked CR2032 specimen pulled from a 6381-Fxx, with minimal damage to the planar.[3]
If you find a leaked CR2032:
  1. Remove the cell with plastic tweezers (do not short the contacts).
  2. Neutralise the alkaline residue (typical CR2032 leak chemistry is KOH-style) with a small amount of isopropanol followed by a small amount of dilute white vinegar, then a thorough rinse with deionised water on a foam swab.
  3. Dry the area completely with compressed air before refitting a fresh cell.
  4. Check the planar power-supply circuitry around B1 / BT1 for any visible trace damage; repair with 30 AWG enamelled wire if necessary.
Floppy Drive Logic Board — Primary Cap Replacement Target
The most-likely-to-fail capacitor on a PS/ValuePoint system is the Alps floppy drive logic board SMD aluminium electrolytic next to the power connector. Hands-on documentation of a 6381-Fxx specimen reports "The Alps floppy drive has a surface-mount aluminium electrolytic capacitor next to the power connector which may be leaking and in need of replacement."[4]
Symptoms of a failed floppy drive electrolytic:
  • Floppy reads OK but writes are corrupt.
  • Drive intermittent — works cold, fails warm.
  • Brown residue around cap base on the drive logic board.
  • Drive activity LED dim or flickering.
Replacement procedure:
  1. Power off, unplug, discharge.
  2. Remove the floppy drive from the chassis.
  3. Identify the SMD electrolytic next to the drive power connector (usually 47 µF / 16 V or 22 µF / 16 V).
  4. With a hot-air rework station or fine-tipped soldering iron, remove the cap. Lift straight up; do not pry sideways or you may lift the pad.
  5. Clean the pad with solder wick.
  6. Wash the area with isopropyl alcohol.
  7. Fit a replacement 47 µF / 16 V (or 22 µF / 16 V to match the original — read the cap top) SMD low-ESR aluminium electrolytic or through-hole tantalum of equal value.
  8. Verify polarity matches the silkscreen.
Typical Alps floppy logic board cap list:
Alps PS/ValuePoint floppy drive cap replacement summary
Value Voltage Type Position
47 µF 16 V SMD aluminium → tantalum or SMD low-ESR Spindle motor driver / power connector vicinity
22 µF 16 V SMD aluminium → tantalum or SMD low-ESR Power filter (some submodels)
10 µF 16 V SMD aluminium → tantalum or SMD low-ESR Head amp / IC bypass
Planar Capacitor Inspection
PS/ValuePoint planars (1992–1995) are old enough to warrant capacitor inspection but predate the famous early-2000s capacitor plague that takes down IBM IntelliStation M Pro / Z Pro Pentium 4 boards. The PS/ValuePoint planar carries:
  • Through-hole aluminium electrolytic caps in the +5 V and +12 V power input area (typical values 100–470 µF / 16–25 V).
  • Tantalum decoupling caps around the CPU socket, video chip, and chipset (10 µF / 16 V typical).
  • Surface-mount aluminium electrolytic caps on some submodels (6384 /D and 6387 /T are most common).
Failure modes:
  • Tantalum short circuit — pulls down +5 V; system will not POST.
  • Aluminium electrolytic leakage — corrodes traces; intermittent fault.
  • Both are uncommon on this generation but should be inspected.
Diagnostic procedure (tantalum short):
  1. Set multimeter to diode test.
  2. Probe each tantalum in-circuit: black probe to ground, red probe to rail side. Good cap reads as open / high resistance; failed (shorted) cap reads close to 0 Ω.
  3. Remove the cap to confirm out-of-circuit.
  4. Replace with a fresh tantalum or low-ESR ceramic of equal value, equal or higher voltage rating.
Representative planar cap list (varies by submodel):
PS/ValuePoint planar capacitor replacement summary (representative)
Value Voltage Type Quantity (approx) Notes
10 µF 16 V Tantalum ~10–20 IC bypass around CPU, video, chipset
22 µF 16 V Tantalum ~4–6 Memory bank decoupling
100 µF 16 V Aluminium electrolytic, 105 °C low-ESR 2–3 Power input filtering
220 µF 16 V Aluminium electrolytic, 105 °C low-ESR 1–2 Power input filtering
470 µF 16 V Aluminium electrolytic, 105 °C low-ESR 1–2 Bulk filter near power connector
PSU Recap
PS/ValuePoint PSUs are AT-style (5-pin + 6-pin power connector, not ATX). Three power levels:
  • 100 W — 6381-Si entry boards.
  • 145 W — 325T and original 1992 6384.
  • 200 W — 6382 /S, 6384 /D, 6384 P60/D, 6387 /T.
Common topology: single-board switching supply with primary / secondary stages.
  • Primary side — bridge rectifier, X2 mains suppression cap, 220 µF / 200 V (100 W / 145 W) or 470 µF / 200 V (200 W) primary bulk, switching transistor, switching transformer.
  • Secondary side — rectifier diodes, smoothing electrolytics, output chokes, optocoupler feedback.
100 W / 145 W PSU Cap Values (Typical)
PS/ValuePoint 100 W / 145 W PSU capacitor replacement summary (typical)
Value Voltage Type Typical position
2200 µF 16 V Low-ESR aluminium, 105 °C +5 V smoothing × 1
1000 µF 16 V Low-ESR aluminium, 105 °C +5 V auxiliary
470 µF 35 V Aluminium electrolytic, 105 °C +12 V smoothing
220 µF 35 V Aluminium electrolytic, 105 °C −12 V smoothing
100 µF 16 V Aluminium electrolytic, 105 °C Bypass / feedback × 2
100 µF 50 V Aluminium electrolytic, 105 °C Primary auxiliary
47 µF 50 V Aluminium electrolytic, 105 °C Primary startup
220 µF 200 V Aluminium electrolytic, 105 °C Primary bulk (lethal-charge component)
0.1 µF 275 VAC X2 class Mains suppression — replace if RIFA-branded
200 W PSU Cap Values (Typical)
PS/ValuePoint 200 W PSU capacitor replacement summary (typical)
2200 µF 16 V Low-ESR aluminium, 105 °C +5 V smoothing × 2
1000 µF 25 V Low-ESR aluminium, 105 °C +12 V smoothing
470 µF 35 V Aluminium electrolytic, 105 °C +12 V auxiliary
100 µF 50 V Aluminium electrolytic, 105 °C Primary auxiliary × 2
100 µF 16 V Aluminium electrolytic, 105 °C Bypass / feedback × 2–3
470 µF 200 V Aluminium electrolytic, 105 °C Primary bulk (lethal-charge component)
Recap Procedure
  1. Discharge the bulk capacitor; verify with a multimeter.
  2. Remove the PSU from the chassis (4 screws typically).
  3. Open the PSU housing.
  4. Photograph the board. Mark each electrolytic's polarity.
  5. Desolder each electrolytic with solder wick.
  6. Fit low-ESR, 105 °C replacements, equal capacitance, equal or higher voltage rating.
  7. Inspect the X2 mains suppression cap. If RIFA-branded or cracked / bulging, replace.
  8. Reassemble. Verify rails on the bench with a multimeter under a 1 A resistive load before refitting to the chassis.
Video Card / Riser Capacitors
The PS/ValuePoint video is on-planar (Cirrus / Tseng / S3 / ATI Mach32); there is no removable video card on most submodels. The video subsystem decoupling caps are inspected as part of the planar inspection (above).
The ISA / VLB / PCI riser card carries no electrolytic capacitors (passive interconnect only) and does not require recap.
L2 Cache Module Capacitors
The optional 128 KB or 256 KB L2 cache module that fits the 486 boards carries SMD ceramic decoupling caps only — no electrolytic caps. No recap is required.
Hard Drive Logic Board Capacitors
PS/ValuePoint era IDE drives (Conner CFA-170A, IBM WD-style, Quantum ProDrive, Maxtor 7245, etc.) carry SMD electrolytics that age. Typical values on the drive logic board:
  • 47 µF / 16 V — spindle motor driver.
  • 10 µF / 25 V — head amp.
  • 22 µF / 16 V — sector buffer.
Modern alternative: replace the original IDE drive with a CompactFlash-to-IDE or XT-IDE / IDE2SD adapter — no recap needed, fast, reliable.
Replacement Parts Summary
PS/ValuePoint system-wide cap replacement summary
Value Voltage Type Where
10 µF 16 V Tantalum or SMD low-ESR Planar IC bypass
22 µF 16 V Tantalum or SMD low-ESR Planar memory bank, drive sector buffer
47 µF 16 V Tantalum or SMD low-ESR aluminium Alps floppy drive logic board — primary failure position
100 µF 16 V Aluminium electrolytic, 105 °C Planar power input
100 µF 50 V Aluminium electrolytic, 105 °C PSU primary auxiliary
220 µF 16 V Aluminium electrolytic, 105 °C Planar power input
220 µF 35 V Aluminium electrolytic, 105 °C PSU −12 V smoothing
220 µF 200 V Aluminium electrolytic, 105 °C 100 W / 145 W PSU primary bulk
470 µF 16 V Aluminium electrolytic, 105 °C Planar bulk filter near power connector
470 µF 35 V Aluminium electrolytic, 105 °C PSU +12 V smoothing
470 µF 200 V Aluminium electrolytic, 105 °C 200 W PSU primary bulk
1000 µF 16 V / 25 V Low-ESR aluminium, 105 °C PSU +5 V / +12 V smoothing
2200 µF 16 V Low-ESR aluminium, 105 °C PSU +5 V smoothing × 1–2
47 µF 50 V Aluminium electrolytic, 105 °C PSU primary startup
0.1 µF 275 VAC X2 class PSU mains suppression
Polarity Reference
The PS/ValuePoint planar silkscreen marks the + (positive, rail) side of each tantalum with a small "+". Aluminium electrolytic caps show the negative side with a stripe and "−" on the can. Match these conventions.
Polarity reference for IBM motherboard tantalum capacitors. The convention applies to the PS/ValuePoint planar. (Image: minuszerodegrees.net)
A failed tantalum often shows no visible damage.
Failed tantalum on an IBM motherboard. (Image: minuszerodegrees.net)
Post-Recap Verification
  1. Bench-test the planar with a known-good PSU and no peripherals.
  2. Verify rails at the planar power connector.
  3. Refit; power on; observe POST beep and memory count.
  4. Press F1 during memory count to enter Setup; verify all expected hardware (memory size, drive types) is detected.
  5. Run the Advanced Diagnostics Diskette for full system self-test.
  6. Run a sustained DOS or Windows session under load for several hours to confirm stability.
If any test fails after a recap, re-inspect the polarity of every replaced cap before suspecting another fault — reversed polarity is the most common error.
When Not to Recap
If the PS/ValuePoint boots, POSTs cleanly, runs reliably with no errors and visual inspection shows no cap failure, the caps are within tolerance. PS/ValuePoint planars typically do not require recap unless:
  • Floppy drive symptoms point to the Alps SMD electrolytic.
  • PSU symptoms (random reboots under disk load, audible whine, smell of fish from venting RIFA X2) indicate aged secondaries.
  • Visible electrolyte leakage on the planar.
  • Bulged or leaking electrolytic anywhere visible.
