IBM 5120 Troubleshooting Guide
Revision as of 13:06, 16 July 2026 by Josh (talk | contribs) (Add representative photo (Wikimedia Commons, attributed on file page))
IBM 5120. Source: Wikimedia Commons.
This guide documents fault diagnosis for the IBM 5120 Computing System (also designated IBM 5110 Model 3). The 5120 inherits the PALM processor and APL / BASIC ROM environment from the IBM 5100 and IBM 5110, so much of the troubleshooting practice translates directly. The 5120's two built-in 8-inch floppy drives, larger 9-inch CRT, and detached keyboard add their own diagnostic surface.
Reference Documents
  • SY34-0192-0 โ€” IBM 5120 Maintenance Information Manual (MIM), December 1979 โ€” the CE service manual, includes the diagnostic procedures.[1]
  • SY34-0193-0 โ€” IBM 5120 Computing System Logic Manual, December 1979 โ€” gate-level theory of operation, essential for board-level fault isolation.
  • GH30-0232-1 โ€” Joint 5110 / 5120 Bibliography, September 1980.
Initial Diagnosis Workflow
5120 power-on sequence:
  1. Power LED on the front panel illuminates.
  2. Fans spin (CRT and PSU cooling).
  3. PSU rails stabilise.
  4. Executable ROS self-test runs.
  5. Language interpreter loads from Language ROS (front-panel toggle selects APL or BASIC).
  6. Language banner ("BASIC READY" or "APL READY") appears on the 9-inch CRT.
  7. 5120 is ready for keyboard input.
If any of these does not occur, stop and diagnose at that stage.
Stage 1 โ€” No Power
  • Mains lead, switch, fuse on the 5120 PSU.
  • Verify PSU rails at the planar power connector.
  • If the front-panel power LED is dim, suspect 5VSB-equivalent regulator capacitor failure.
Stage 2 โ€” Power But No Display
  • No raster on 9-inch CRT โ€” flyback or horizontal output failure. Check for HV at the CRT anode with an HV probe. No HV โ†’ flyback failure (rare but terminal without a donor).
  • Raster but no characters โ€” Executable ROS or video timing chain failure.
  • Garbled characters โ€” RAM (RWS) failure or Executable ROS bit error. Use Diagnostic ROS to verify.
Stage 3 โ€” Banner Wrong / Garbled
  • Language ROS bit error โ€” reseat Language ROS.
  • Toggle APL / BASIC โ€” if one banner is clean and the other garbled, the failed ROM is isolated.
Stage 4 โ€” System Won't Read / Write Floppies
  • No drive activity at all โ€” drive cable to planar unseated, or PSU spindle rail dead.
  • Drive spins but won't read โ€” head dirty; head alignment; drive belt slipping.
  • Read OK but write produces corrupt diskettes โ€” head alignment; write-protect sensor.
  • CRC errors โ€” belt aged, oxide shedding from old Diskette 2D media, head dirty.
  • Won't load head โ€” head load solenoid fatigued.
Diagnostic ROS
Same keyboard sequence at power-on as the IBM 5100 / IBM 5110; enters Diagnostic ROS for read / write access to RAM, video memory, PALM registers, interrupt vectors and the clock counter.[2] The 5120 MIM SY34-0192 documents the Diagnostic ROS error codes specific to the 5120.
Customer Acceptance Test
The 5120 CAT runs from a customer test diskette. It exercises:
  • RAM (full pattern test).
  • Both built-in 8-inch floppy drives (read / write / verify).
  • The 9-inch CRT (cursor positioning and character set).
  • The detached keyboard.
  • The communications adapter (if fitted).
  • The 5114 (if attached).
A test pattern of garbled characters at the same screen position across multiple tests usually indicates a specific bit position failure in a RAM bank.
PALM Diagnosis
Same as the IBM 5100 โ€” PALM gate arrays are unobtainium. Reseat the edge connector before suspecting failure. PALM-specific check-stop codes in the MIM identify failed gate arrays.
ROS / RWS Memory Faults
  • Garbled banner โ€” Language ROS bit error; reseat ROS modules.
  • Refusal to complete Executable ROS self-test โ€” Executable ROS bit error or PALM fault.
  • RAM size mismatch on banner โ€” RWS card failure; reseat each 16 KB module.
8-Inch Floppy Drive Faults
  • No drive activity โ€” PSU spindle rail (typically 12 V or 24 V), or controller card to drive cable.
  • Drive spins but won't read โ€” head dirty, head alignment, belt slipping.
  • Won't load head โ€” solenoid fatigued or stuck.
  • Write errors but no read errors โ€” write-protect sensor; or head alignment offset from write to read.
  • CRC errors โ€” belt aged; oxide shedding from old media; head dirty.
  • Drive A: works, Drive B: doesn't (or vice versa) โ€” drive select jumper or cable; check the position of the terminating resistor pack at the end of the daisy-chain (only the last drive should have the terminator).
The 5120 MIM SY34-0192 has a per-symptom decision tree for the 8-inch floppy subsystem.
CRT Faults
  • No raster โ€” flyback or horizontal output transistor failure.
  • Raster but no characters โ€” video timing chain (PALM video output).
  • Dim raster โ€” cathode emission loss; CRT end-of-life.
  • Single horizontal line โ€” vertical deflection failed.
  • Single vertical line โ€” horizontal deflection failed (usually accompanied by flyback failure).
  • Bright spot โ€” both deflections failed; immediately power off to avoid phosphor burn.
  • Phosphor burn-in (static image on inactive screen) โ€” CRT has been operated for too long with fixed display; replacement requires donor.
The 9-inch CRT carries higher anode voltage than the 5-inch CRT on the 5100 / 5110; flyback failures are correspondingly more dramatic.
Keyboard Faults
  • No keyboard response โ€” cable unseated; clean the keyboard connector with deoxidising contact cleaner.
  • Repeating characters / sticky keys โ€” buckling-spring or capacitive switch contamination; remove and clean.
  • Specific key dead โ€” switch contact contamination.
  • All keys produce wrong characters โ€” keyboard scan controller failure.
Communications and RS-232 Faults
If a Communications Adapter or RS-232 channel is fitted:
  • Verify cable.
  • Verify baud / parity / stop bits.
  • Test with a known-good target.
Common Field Symptoms and Resolutions
  • Won't power on โ€” mains lead, switch, fuse, PSU primary.
  • Power LED but no display โ€” PSU bulk filter caps; see IBM 5120 Capacitor Replacement Guide.
  • Banner appears but system hangs on keystroke โ€” keyboard cable or PALM input handling.
  • Garbled banner โ€” Language ROS or socket oxidation.
  • Drive A: reads but Drive B: doesn't โ€” drive select jumper or cable terminator.
  • Both drives spin but won't read โ€” head clean, then alignment, then belt.
  • Random reboots / hangs โ€” bulk filter cap ESR rising; recap PSU.
  • Smell of fish from PSU โ€” RIFA X2 mains-suppression capacitor venting; replace immediately.
  • CRT loses focus after warm-up โ€” flyback transformer insulation breakdown; replacement requires donor.
Diagnostic Workflow Summary
  1. Power on; observe LED, fan, display chain.
  2. If no power, suspect PSU.
  3. If power but no display, check CRT anode HV first, then Executable ROS / PALM.
  4. If display but garbled banner, reseat ROS modules; try the other language.
  5. Enter Diagnostic ROS (keyboard sequence at power-on); verify PALM, RAM, ROS.
  6. Run the Customer Acceptance Test from diskette.
  7. If diskette won't load, check drive belt, head, alignment.
  8. Cross-reference any check-stop code against MIM SY34-0192 and Logic Manual SY34-0193.
Architecture
The IBM 5120 is built around the IBM PALM (Program All Logic in Microcode) 16-bit processor, with its operating environment (APL and/or BASIC) held in microcode "read-only storage" (ROS). It is not PC-compatible and predates the IBM PC, so PC diagnostics do not apply โ€” use the routines in the IBM Maintenance Information manual.[3]
This machine has two power supplies โ€” one for its pair of disk drives and a second identical to the 5100/5110 supply. Confirm every rail (the 5100/5110-type supply produces +12 V, โˆ’12 V, +8.5 V, +5.0 V and โˆ’5.0 V) before chasing logic faults. Ageing electrolytics are the usual failure โ€” recap and re-check the rails.[3]
Storage and display
The 5120 uses a pair of 8-inch floppy drives and a 12-inch CRT. Mechanisms need cleaning and belt/roller service; the IBM Maintenance Information manuals (on Bitsavers) give the full disassembly, adjustment and diagnostic procedures.[3]
  1. โ†‘ http://bitsavers.org/pdf/ibm/5120/
  2. โ†‘ https://en.wikipedia.org/wiki/IBM_5100
  3. โ†‘ 3.0 3.1 3.2 IBM 5100 Power Supply, voidstar; IBM PALM processor, Wikipedia; and the IBM 5110/5120 Maintenance Information manuals on Bitsavers. Source for the PALM architecture, the five-rail PSU, and the 5120 dual power supplies.
