Atari 520ST+
| Atari 520ST+ with SM124 monochrome monitor | |
| Manufacturer | Atari Corporation |
| Type | Home computer / personal computer |
| Released | January 1, 1986 |
| Discontinued | 1987 (superseded by STF/STFM variants) |
| Intro price | Approximately US$599โUS$799 (varied by bundle and market) |
| CPU | Motorola MC68000 @ 8 MHz |
| Memory | 1 MB RAM |
| Storage | External 3.5-inch floppy drive (Atari SF354 SSDD 360 KB or SF314 DSDD 720 KB); external ACSI hard disks |
| Display | 320ร200 (16 colours), 640ร200 (4 colours), 640ร400 (mono) |
| Sound | Yamaha YM2149F (3 voices + noise) |
| Dimensions | 70 mm ร 476 mm ร 241 mm (2.75 ร 18.75 ร 9.5 in) |
| Weight | โ4.3 kg (9.5 lb) |
| OS / Firmware | Atari TOS 1.00 / 1.02 (192 KB ROM) |
| Predecessor | Atari 520ST |
| Successor | Atari 520STFM |
The Atari 520ST+ (sometimes written 520ST Plus) is a variant of the Atari 520ST home computer that shipped with 1 MB of RAM instead of the standard 512 KB. Introduced in 1986, it was created to differentiate the higher-memory version from the base 520ST, particularly after the 1040STF established 1 MB as the standard for the ST line.
The 520ST+ retained the original "short-case" form factor with an external power supply and no internal floppy drive, making it physically identical to the standard 520ST. The "+" suffix was Atari's way of indicating the doubled RAM without changing the model number entirely. It was sold primarily in European markets.
History
[edit | edit source]When the ST line launched in 1985, the 520ST shipped with 512 KB of RAM and the 260ST had 256 KB. By 1986, Atari had introduced the 1040STF with 1 MB of RAM and an internal floppy drive, at a price point that made the 512 KB 520ST look less competitive.
Rather than discontinue the short-case design entirely, Atari upgraded some 520ST units to 1 MB of RAM and marketed them as the "520ST+". This allowed retailers to offer a 1 MB machine at a lower price point than the 1040STF (which included the internal floppy drive and, in some models, an internal power supply).
The 520ST+ was not a distinct hardware design โ it used the same motherboard as the 520ST with additional or different RAM chips installed to provide 1 MB. The naming convention simply distinguished it from the 512 KB models in dealer and consumer documentation.
Architecture
[edit | edit source]The 520ST+ is architecturally identical to the Atari 520ST, differing only in RAM capacity:
- CPU: Motorola MC68000P8 or MC68000FN8 @ 8.00 MHz
- Architecture: 16/32-bit (32-bit internal, 16-bit external data bus, 24-bit address bus)
- RAM: 1 MB, using 16ร 256kร4 or equivalent DRAM configuration
- ROM: 192 KB TOS (TOS 1.00 in 6ร 32 KB ROMs, or TOS 1.02 in 2ร 128 KB ROMs on later units)
- Custom ICs: Shifter (C025914), GLUE (C025915), MMU (C025912), DMA (C025913) โ identical to standard ST
Major ICs
[edit | edit source]| Function | Part Number | Notes |
| CPU | MC68000P8 / MC68000FN8 | 8 MHz, DIP-64 or PLCC-68 |
| Video Shifter | C025914-38 | Pixel serialiser |
| GLUE | C025915-38A | Bus timing, address decode |
| MMU | C025912-38 / C100109 | DRAM controller; later revision on some boards |
| DMA Controller | C025913-38 | ACSI/floppy DMA |
| FDC | WD1772-00-02 | Floppy disk controller |
| MFP | MC68901 | Timers, interrupts, UART |
| ACIA (ร2) | MC6850 | Keyboard/IKBD and MIDI |
| Sound/PIO | YM2149F | 3-voice PSG + I/O |
| RS-232 drivers | MC1488 / MC1489 | Serial port level conversion |
Connectors
[edit | edit source]Identical to the Atari 520ST:
- Video/Monitor: 13-pin DIN (analog RGB, mono, sync, audio)
- Serial (Modem): DB-25 male, RS-232C
- Parallel (Printer): DB-25 female
- MIDI In/Out: Two 5-pin DIN connectors
- External Floppy: 14-pin DIN
- ACSI (Hard Disk): DB-19 female
- Cartridge: 40-pin edge connector
- Joystick/Mouse: Two DE-9 male ports
- Power: 7-pin DIN (external PSU: +5V, +12V, โ12V)
Display
[edit | edit source]Same three display modes as all ST-family machines:
- Low resolution: 320ร200, 16 colours from 512-colour palette, ~50/60 Hz
- Medium resolution: 640ร200, 4 colours, ~50/60 Hz
- High resolution (mono): 640ร400, monochrome, ~71.2 Hz (requires SM124/SM125)
Sound
[edit | edit source]- PSG: Yamaha YM2149F โ 3 square-wave channels + noise, 5-bit envelope
- MIDI: Built-in MIDI In/Out at 31.25 kbaud
- Audio output: Mono line-level on monitor DIN connector
Comparison with Other ST Models
[edit | edit source]| Feature | 260ST | 520ST | 520ST+ | 520STFM | 1040STF |
| RAM | 256 KB | 512 KB | 1 MB | 512 KB / 1 MB | 1 MB |
| Internal Floppy | No | No | No | Yes (DSDD) | Yes (DSDD) |
| RF Modulator | No | No | No | Yes | No |
| Internal PSU | No | No | No | Yes | Yes |
| Case Style | Short | Short | Short | Long | Long |
Service and Repair
[edit | edit source]The 520ST+ shares all service procedures with the standard ST family:
[edit | edit source]- Atari 260ST โ 256 KB entry-level model
- Atari 520ST โ Standard 512 KB model
- Atari 520STM โ 520ST with RF modulator
- Atari 520STFM โ 520ST with floppy and RF modulator
- Atari 1040ST โ 1 MB with internal floppy
