Atari ST Book General Maintenance
This article covers general maintenance procedures for the Atari ST Book notebook computer. The ST Book's ultra-compact design, non-backlit LCD, and battery-powered operation introduce maintenance requirements distinct from both desktop ST models and the heavier Atari Stacy.
Safety precautions
- Disconnect the AC adapter and remove all batteries before opening the case or performing any internal work.
- Use an anti-static wrist strap when handling the motherboard or ICs.
- The ST Book's components are tightly packed โ work carefully to avoid damaging ribbon cables and connectors.
- Dispose of spent NiCd battery packs as hazardous waste according to local regulations.
Battery care
AA alkaline batteries
The ST Book operates on seven AA alkaline batteries in a removable battery tray.
- Remove batteries during long-term storage. Alkaline batteries can leak potassium hydroxide, which corrodes battery contacts and can reach the motherboard.
- Inspect the battery compartment for corrosion before inserting fresh batteries.
- Clean corroded contacts with white vinegar on a cotton swab, followed by isopropyl alcohol.
- Do not mix old and new batteries or batteries of different brands/types.
Rechargeable NiCd battery pack
An optional rechargeable NiCd battery pack provides extended run time (up to 10 hours).
- NiCd packs manufactured in the early 1990s are prone to leaking โ inspect regularly.
- If the NiCd pack shows any sign of swelling, discolouration, or leakage, remove it immediately.
- The NiCd pack can be replaced with a modern NiMH pack of equivalent voltage and form factor for improved capacity and reduced leakage risk.
- If building a replacement pack from individual cells, match the original voltage (typically 8.4V โ seven 1.2V cells in series).
RTC lithium battery
A lithium coin cell maintains the real-time clock. This battery is not rechargeable and should be replaced every 5โ10 years. It is typically a CR2032 or equivalent, accessible after opening the case.
Opening the case
The ST Book's slim case requires careful disassembly:
- Remove all batteries and disconnect the AC adapter.
- Place the unit upside down on a soft, non-conductive surface.
- Remove the screws from the bottom case (small Phillips head โ note different screw lengths and positions).
- Carefully separate the case halves. The motherboard, hard disk, and keyboard are mounted in the base.
- Take extreme care with ribbon cables connecting the keyboard and LCD to the motherboard.
- The 2.5-inch IDE hard disk is mounted in a carrier and connects via a short ribbon cable.
LCD care
The ST Book's LCD panel is fragile and requires careful handling. The lack of a backlight makes the display unusable in low-light conditions but eliminates the CCFL or inverter board failure modes found in the Atari Stacy.
Cleaning
- Clean the LCD surface with a microfibre cloth dampened with distilled water only.
- Do not use ammonia-based cleaners โ ammonia damages polarising films.
- Do not press on the LCD surface. Passive matrix LCDs develop permanent marks from pressure.
- Do not store the ST Book with heavy objects on top of it โ the thin form factor provides minimal protection for the LCD panel.
Common LCD issues
- Fading or low contrast โ The passive matrix display may lose contrast with age. The contrast can be adjusted, but there is no electronic fix for degraded LCD fluid.
- Dead pixels or lines โ Individual row/column driver failures can cause lines on the display. These are a function of age and are difficult to repair.
- Polariser damage โ The external polarising film can become scratched, clouded, or delaminated. Replacement polariser film can be carefully applied if the original is damaged.
Floppy drive
The ST Book has no internal floppy drive. The optional external 3.5-inch drive connects via the combined ACSI/FDD port.
- Keep the external drive stored in a clean, dry environment when not in use.
- Clean floppy drive heads with IPA and a lint-free swab before use if the drive has been in storage.
- The ACSI/FDD port cable is proprietary โ protect it from damage, as replacements are extremely difficult to source.
Hard disk maintenance
The internal 2.5-inch IDE hard disk is 30+ years old in all surviving units.
- Back up all data โ mechanical failure is inevitable with drives of this age.
- Listen for clicking, grinding, or failure-to-spin sounds โ these indicate imminent drive failure.
- The IDE interface in the ST Book is non-standard in the Atari ST context (most other ST models use ACSI/SCSI). Replacement drives must be IDE.
- CompactFlash-to-IDE adapters can be used as solid-state replacements. These draw less power and generate no heat, both beneficial for the ST Book's tight, battery-powered enclosure. Verify compatibility, as some CF adapters may require specific jumper settings or formatting.
- The maximum drive size may be limited by the IDE/BIOS implementation. 40 MB, 80 MB, and 120 MB drives are known-good configurations.
Keyboard maintenance
- The 84-key keyboard uses scissor-type key mechanisms.
- Clean between keys with compressed air.
- Individual keycaps can be removed carefully for cleaning โ take note of the scissor mechanism orientation before removal.
- The keyboard connects to the motherboard via a ribbon cable. Inspect for oxidation or damage if keys become unresponsive.
Vector Pad maintenance
The Vector Pad is a touch-sensitive cursor controller. If it becomes unresponsive or erratic:
- Clean the Vector Pad surface with a damp microfibre cloth.
- Check the connection between the Vector Pad and the motherboard.
- The Vector Pad is not easily replaceable โ no aftermarket equivalents exist.
Storage and preservation
Given the extreme rarity of the ST Book (estimated 1,000โ1,200 units produced), preservation is a priority:
- Store in a cool, dry environment away from direct sunlight.
- Remove all batteries during long-term storage.
- Use a padded case or bag to protect the thin enclosure.
- Store the LCD closed to protect the screen surface.
- Keep the external floppy drive, AC adapter, and cables together with the unit โ these accessories are nearly impossible to source separately.
Related maintenance pages
