Amstrad PC1640 Maintenance Guide
Amstrad PC1640 HD20 with keyboard and mouse
PC1640 HD20 with its monitor, keyboard and mouse
The Amstrad PC1640 shares its case, cell tray, floppy drives and supply-in-the-monitor layout with the Amstrad PC1512, and the Amstrad PC1512 Maintenance Guide covers those parts in detail. What differs on the PC1640 is set out below: the display switches, the three monitors and their supply settings, the hard disc models and the internal fourth slot. Amstrad's service manual is the source for the settings below.[1]
Safety
Warning: each monitor holds a mains switch-mode supply for the whole computer and a CRT.
  • Discharge the tube before working inside a monitor; see CRT Discharge Procedure.
  • Amstrad's PC1640 safety tests after servicing are a 1.5 kV RMS flash test for 3 seconds between the mains poles and exposed metal, an insulation test at the same voltage requiring more than 4 MΩ, and an earth continuity test requiring the mains lead to be under 0.5 Ω.[1] The PC1512 manual specifies 3 kV for its monitors.[2]
  • All three monitors use a 3.15 A mains fuse, F501.[1]
Display switches
The ten DIP switches on the back of the system unit, marked "Display selector", configure the internal graphics adaptor and must match the monitor; a PC1640 that runs but shows nothing may simply have its switches set for another display. Amstrad's chart on page 19 of the service manual:[1]
DIP switch settings for each monitor (service manual p. 19)
Monitor 1 2 3 4 5 6 7 8 9 10
PC-MD Off Off On Off On On On Off Off Off
PC-CD Off Off Off On On On On Off Off Off
PC-ECD Off On On Off Off On On On Off Off
The same page names each start-up mode set by SW1–SW5. The DISPLAY command on the system discs accepts these names and can override the switches.[1]
Named modes, SW1–SW5 (service manual p. 19)
Mode SW1 SW2 SW3 SW4 SW5 Display Description
MDTEXT Off Off On Off On PC-MD MDA or Hercules; recommended for the PC-MD
MDMONO Off Off On Off Off PC-MD EGA monochrome
CDMONO Off Off Off On On PC-CD CGA-compatible 80 column; recommended for the PC-CD
CDCOLOR Off Off Off On Off PC-CD EGA-compatible 80 column
ECD200 On On On Off Off PC-ECD EGA, 200 lines
ECD350 Off On On Off Off PC-ECD EGA, 350 lines; recommended for the PC-ECD
For every mode SW8 is on for the PC-ECD and off for the PC-MD or PC-CD, and SW9 and SW10 are off.[1] On the 9-way video plug, SW8 decides whether pin 2 is grounded or carries the secondary red signal.[3] John Elliott's switch page prints CDCOLOR with SW5 on, the same as CDMONO; Amstrad's chart has SW5 off for CDCOLOR.[4] SW10 on disables the internal adaptor, and SW6 and SW7 then tell the BIOS which add-in card is fitted.[4] An owner who could not get a picture after a repair found the switches had been knocked; setting them back for the PC-MD restored the display.[5]
Backup cells and case
The clock and configuration memory run from four AA cells in a tray under the monitor, as on the PC1512.[3] On a Schneider PC 1640, cells left in the tray leaked down onto the main board around the CPU, corroding the CPU and 8087 sockets; the CPU had failed.[6] Remove old cells, clean the tray and check the board under it; see Battery Explosion, Capacitor or Corrosion Damage.
The case opens with seven screws: two under the stand-offs, two under the plate over the card slots and three holding the cards. One owner found the fan under the hard disc with its blades detached.[7] Check that fan on hard disc models. Besides the three slots under the rear cover there is a fourth slot inside the case, intended for a hard card.[8][9]
Floppy and hard discs
The FD-3 drive procedures are on pp. 3–14 of the PC1640 manual, with a Dysan 224/2A CE diskette listed for alignment; the checks are the same as in the PC1512 guide.[1] The floppy cable is soldered to the main board. Drive A: is jumpered DS0 and drive B: DS1, and the motor-on line is shared, so drive A:'s motor turns when B: is used. The built-in controller does not support high-density discs; a Gotek emulator works as drive B: with 720K or 360K images.[10][11]
Hard disc models used a 20 MB drive from Alps (175037) or Tandon (60001); Amstrad says hard disc units must not be opened.[1] To reinstall the system software, page 18 gives HDFORMAT, FDISK, FORMAT C:/S and CONFIG, run from system discs 1 and 4. Amstrad allows one bad sector per megabyte, 200K on a 20 MB disc; CHKDSK reports them and HDFORMAT does not reduce them.[1] DOS Days records the hard disc models as fitted with a hard card, a MiniScribe RLL drive and controller on one card.[11] For a replacement, DOS Days got an XT-CF-Lite working at base address 300h, control block 328h, "2x8-bit" bus type and interrupts disabled, with its ROM at DE00h; see Hard Drive Maintenance and Repair.[10]
Power supply checks
Each monitor sets the computer's rails to the same targets, with its own presets.[1]
Supply adjustments (service manual pp. 40, 41, 47)
Rail Target PC-MD preset PC-CD and PC-ECD preset
+5 V 5.10 V ±0.02 V VR505 VR604
+12 V 12.15 V ±0.02 V VR504 VR603
−5 V 5 V ±0.05 V (magnitude) VR501 VR601
−12 V 12.0 V ±0.05 V (magnitude) VR502 VR602
+12 V protection Trips at 4.5 A through a dummy load VR507 VR606
Monitor +12 V 12.0 V at test point E VR503 –
The rails can be measured at the 14-way DIN plug: +5 V on pins 3 and 5, +12 V on pin 11, −12 V on pin 9, −5 V on pin 13, 0 V on pins 2, 4, 8, 10 and 12.[3] The rest of each alignment table covers that monitor's picture. The PC-ECD has a cooling fan; check that it turns.[8]
Processor upgrade
The 8086 can be replaced with an NEC V30 in the same socket. DOS Days measured an average gain of about 22% across a set of benchmarks at the same 8 MHz clock.[12] John Elliott notes that Windows 3.0's colour drivers need a V30 on the PC1640.[13]
Checklist for a newly acquired PC1640
  1. Remove the AA cells and inspect the tray and the board beneath it.
  2. Note the DIP switch settings before touching anything, and check them against the monitor fitted.
  3. Open the monitor, discharge the tube and inspect the supply area; see the Amstrad PC1640 Capacitor Replacement Guide.
  4. Measure the rails at the DIN plug.
  5. On hard disc models, check the fan under the hard disc.
  6. Clean the floppy heads and check the drive select jumpers.
  1. ↑ 1.00 1.01 1.02 1.03 1.04 1.05 1.06 1.07 1.08 1.09 Amstrad plc, PC1640 Personal Computer, PC-MD Monochrome Display, PC-CD Colour Display, PC-ECD Enhanced Colour Display Service Manual. Hosted as File:Amstrad PC1640 Service Manual.pdf, described at Amstrad PC1640 Service Manual. Safety tests p. 2; servicing note p. 3; FD-3 maintenance pp. 3–14; hard disc installation p. 18; switch settings p. 19; bad sectors and RP5-2 p. 20; monitor alignment instructions pp. 40, 41 and 47.
  2. ↑ Amstrad plc, PC1512 Personal Computer, PC-MM Monochrome Monitor, PC-CM Colour Monitor Service Manual. Hosted as File:Amstrad PC1512 Service Manual.pdf, described at Amstrad PC1512 Service Manual. Safety test p. 2.
  3. ↑ 3.0 3.1 3.2 Amstrad, PC1640 Technical Reference Manual, section 1, transcribed by John Elliott: seasip.info. Retrieved 2026-10-02. Section 1.9 (clock and four AA cells), 1.20 (9-way video connector and switch 8), 1.21 (power connector).
  4. ↑ 4.0 4.1 John Elliott, "PC1640 DIP switches", seasip.info, 12 April 2003. Retrieved 2026-10-02. SW1–SW5 combinations including secondary-adapter modes, SW6–SW7 fonts, SW8 monitor type, SW9 32K EGA ROM, SW10 disabling the internal adaptor.
  5. ↑ jarcher1701, austfox, modem7 and others, "Amstrad PC1640 – Faulty Floppy Disk Controller or Disk Drive", Vintage Computer Federation Forums, October–December 2023. Retrieved 2026-10-02. Community repair thread: the floppy controller error traced to C124 and R181, the LK1–LK3 bypass, a blank screen after the repair cured by resetting the DIP switches for the PC-MD.
  6. ↑ Wobblestone, "Amstrad 1640 (germany: Schneider PC 1640) with battery damage, works 'a little', has address problems", Vintage Computer Federation Forums, November–December 2024. Retrieved 2026-10-02. Community repair report: AA cell leakage onto the CPU area, corroded sockets, a dead CPU, and a later address-line fault after the socket was replaced.
  7. ↑ weedeewee, reply in "How to withdraw hard disk from amstrad pc1640", VOGONS, 25 November 2021. Retrieved 2026-10-02. Community instructions: seven case screws and lifting the top half; the fan under the hard disc with its blades fallen off.
  8. ↑ 8.0 8.1 DOS Days, "Amstrad PC1512 and PC1640". Retrieved 2026-10-02. The fourth internal ISA slot for a hard card, the AA cell tray, the drive select jumpers, the 14-pin DIN pinout.
  9. ↑ John Elliott, "Amstrad XTs: Models", seasip.info, 19 April 2013. Retrieved 2026-10-02. Four full-sized ISA slots on the PC1640, one hidden inside the case.
  10. ↑ 10.0 10.1 DOS Days, "The Amstrad PC1640 Project – Part 2", 18 August 2026. Retrieved 2026-10-02. The soldered floppy cable, the Gotek as drive B:, the shared motor line, no high-density support, the XT-CF-Lite configuration that worked, memory parity errors.
  11. ↑ 11.0 11.1 DOS Days, "The Amstrad PC1640 Project – Part 1", 17 August 2026. Retrieved 2026-10-02. Drive A: jumpered DS0 and drive B: DS1, the Amstrad-branded drive boards, the main board revisions.
  12. ↑ DOS Days, "The Amstrad PC1640 Project – Part 3", 20 August 2026. Retrieved 2026-10-02. The V30 fitted in place of the 8086 and the benchmark comparison, the clock arrangement with the 24 MHz crystal, the 16.25 MHz dot clock.
  13. ↑ John Elliott, "Amstrad XTs: Questions and answers", seasip.info, 26 June 2019. Retrieved 2026-10-02. Windows versions on Amstrad XTs and the V30 requirement for colour drivers, NVR, system discs.
