Apple 12" Monochrome Display General Maintenance
Adjustment and care of the Macintosh 12" Monochrome Display. The targets and procedures are Apple's, from the Service Source for the display.[1] The display was sold from 1990 to 1993, so any survivor is now over 30 years old.[2]
Safety
[edit | edit source]The CRT holds a charge after the display is switched off and unplugged. Follow the CRT Discharge Procedure before reaching inside. Apple's own rules for its monitors include: do not work alone; remove jewellery; wear safety goggles; never wear a grounding wrist strap or work on a grounded mat while discharging the tube or making live adjustments; keep one hand in a pocket or behind your back when working on a live monitor; never touch the anode connector or anode aperture; and never lift a CRT by its neck.[2] Apple discharges the anode to the metal part of the bezel and then leaves a clip lead from the bezel to the anode aperture, because the anode can recover some charge.[2]
The geometry and video controls are adjusted with the display running. When adjusting from behind, watch the screen in a mirror and do not reach round the cabinet. Use a plastic screwdriver. Apple says not to attempt yoke adjustments on this display; they are set at the factory.[1]
When to adjust
[edit | edit source]Apple calls for the geometry adjustments whenever the main board is replaced, and the video adjustment whenever the CRT or its video board is replaced; other module changes may also need the video adjustment.[1] Test patterns come from Apple's Display Service Utility, which runs on any Macintosh with System 7.0 or later.[3]
Geometry and focus
[edit | edit source]| Order | Control | Pattern | Target |
| 1 | H-SIZE | All-White Screen or Crosshatch II | Raster 8 7/16 in (213.5 mm) wide, ± 1/8 in (± 2 mm) |
| 2 | H-CENT | All-White Screen | Raster in the approximate centre of the screen |
| 3 | V-HEIGHT | All-White Screen | Raster 6 5/16 in (159.5 mm) high, ± 1/8 in (± 2 mm) |
| 4 | V-CENT | All-White Screen | Raster centred; recheck the height and repeat 3 and 4 if needed |
| 5 | Focus | Focus | Contrast at maximum, brightness at its detent; Focus pattern as clear as possible |
Height and width affect each other, so recheck both after either is changed.[1]
Video adjustment
[edit | edit source]- Set the Monitors control panel to 16 greys. Set the contrast knob to maximum and the brightness knob to its centre detent.
- Display the Gray Bars pattern. Adjust the sub-brightness control until the left bar is black and the next bar is barely distinguishable from it. If the bar edges look dashed or ragged, sub-brightness is too high: turn it down about a quarter turn and repeat.
- Display the All-White Screen. With a light meter against the middle of the screen, adjust the sub-contrast control for 33 foot-lamberts ± 3.[1]
| Meter | Reading |
| R77 (Apple 076-0310) | 25 on the bottom (10-50 fc) scale, with the 10X multiplier plate removed |
| L-248 | Middle of the 10 scale, side switch up |
| 246 | 25 on the red scale, white lens with the red dot fitted |
Apple warns that the three meters read differently, that dropping a meter can spoil its accuracy, and that a doubtful meter should be checked against a known-good meter or photometer. The R77 carries a four-digit date stamp (0398 is March 1998).[1]
[edit | edit source]- Apple 12" Monochrome Display
- Apple 12" Monochrome Display Troubleshooting Guide
- Macintosh 12 Monochrome Service Source
- CRT Discharge Procedure
- Recommended Tools
[edit | edit source]- ↑ 1.0 1.1 1.2 1.3 1.4 1.5 1.6 1.7 Apple Computer, Macintosh 12" Monochrome Display (Service Source), hosted as File:12 monochrome display.pdf. Adjustments: geometry and focus pp. 1-8 (PDF pp. 38-45); video pp. 9-16 (PDF pp. 46-53); light meter set-up pp. 17-22 (PDF pp. 54-59).
- ↑ 2.0 2.1 2.2 Apple Computer, Macintosh Displays and Video Cards service guide, September 1996, hosted as File:Apple Macintosh Displays and Video Cards Service Guide (September 1996).pdf. CRT safety rules and discharge procedure pp. 2-3 (PDF pp. 20-21); dates introduced and discontinued, Table 2, p. 13 (PDF p. 31).
- ↑ Macintosh Displays and Video Cards service guide (1996), Diagnostics, Display Service Utility, p. 9 (PDF p. 27).
