Atari STE Capacitor Replacement Guide
Atari 1040STE
Capacitor replacement for the Atari 520STE and Atari 1040STE, which use the same main board.[1] For the earlier ST, STF and STFM see Atari ST Capacitor Replacement Guide; for diagnosis see Atari STE Troubleshooting Guide.
Warning: the internal power supply runs from mains voltage, and its primary reservoir capacitor holds a dangerous charge after the machine is unplugged. Discharge it and check it with a meter before touching the primary side.
Sources
Two lists exist for the main board. Atari's parts list in the STE field service manual names the bare board C300779-001.[1] The hosted copy of that manual is a 2017 retyped edition by jer/eightbitter, so its values were typed by hand and not scanned. Console5's list, a community list read from boards, is headed "CA300779-001 Rev 5.1 RGB / CA401177 / CA4003290 RGB".[2] The two agree on every position except the voltage of the four non-polarised parts and the value of C433. Check those two against the parts on your board.
Main board electrolytics
STE main board electrolytics
Position Atari parts list Mounting (Atari) Console5 Notes
C100 10 µF 35 V Radial 10 µF 35 V
C102 22 µF 16 V Axial 22 µF 16 V Console5: may be 10 µF 35 V on some revisions
C103 4700 µF 16 V Axial 4700 µF 16 V
C107 100 µF 16 V Not stated 100 µF 16 V
C110 100 µF 16 V Not stated 100 µF 16 V
C202 4.7 µF 25 V Axial, non-polarised 4.7 µF 35 V non-polarised
C204 4.7 µF 25 V Axial, non-polarised 4.7 µF 35 V non-polarised
C205 4.7 µF 25 V Axial, non-polarised 4.7 µF 35 V non-polarised
C215 4.7 µF 25 V Axial, non-polarised 4.7 µF 35 V non-polarised
C216 470 µF 35 V Axial 470 µF 35 V
C415 470 µF 16 V Radial 470 µF 16 V
C416 47 µF 16 V Radial 47 µF 16 V
C417 100 µF 16 V Radial 100 µF 16 V
C423 100 µF 16 V Radial 100 µF 16 V
C433 10 µF 50 V Not stated 1 µF 50 V The two lists disagree
C508 47 µF 16 V Axial 47 µF 16 V
C520 47 µF 16 V Axial 47 µF 16 V
C525 47 µF 16 V Axial 47 µF 16 V
C529 47 µF 16 V Axial 47 µF 16 V
C535 47 µF 16 V Axial 47 µF 16 V
C537 47 µF 16 V Axial 47 µF 16 V
C541 47 µF 16 V Axial 47 µF 16 V
C542 10 µF 35 V Radial 10 µF 35 V
C543 47 µF 16 V Axial 47 µF 16 V
C544 47 µF 16 V Axial 47 µF 16 V
C546 47 µF 16 V Axial 47 µF 16 V
C547 47 µF 16 V Axial 47 µF 16 V
C558 100 µF 16 V Not stated 100 µF 16 V
C561 100 µF 16 V Not stated 100 µF 16 V
C564 100 µF 16 V Not stated 100 µF 16 V
C566 47 µF 16 V Radial 47 µF 16 V
C567 47 µF 16 V Radial 47 µF 16 V
C600 100 µF 16 V Not stated 100 µF 16 V
Sources: Atari's parts list[1] and Console5.[2] That is 33 electrolytics. Atari's list also has three 15 µF 25 V tantalum capacitors, C420, C424 and C426, which Console5 does not include.[1]
C202, C204, C205 and C215 must be non-polarised (bipolar) parts.[1][2] Mark them on the board before starting.
C100 and C102 time the power-on reset. exxos traces an STE that will not start until the reset button is pressed to these two parts, and fits a new 22 µF at C102 and a 47 µF part at C100 in place of the 10 µF; a 22 µF part soldered across the old C100 has the same effect.[3]
Atari's parts list identifies the STE's supply only by assembly number (CA070059-003 for the US and Canadian 110 V supply).[1] exxos lists recapping the supply as a mandatory fix for every ST, having seen STEs that would not start with 4 MB of RAM fitted because the supply had aged, and warns that some supplies have a capacitor fitted backwards from the factory.[4] Identify the supply from its label and use the matching list on Atari ST Capacitor Replacement Guide#Power supply capacitors. Atari's figures for the STE supply are +5 V and +12 V, rated 3 A and 0.9 A, set to 5.1 V, with a 2 A fuse.[5]
Floppy drive
For the TDK D357 drive see Atari ST Capacitor Replacement Guide#Floppy drive capacitors. The US 1040STE in Atari's parts list has a Sony 1 MB drive (C103704-001).[1]
Procedure
  1. Open the case as Atari describes (see Atari STE Troubleshooting Guide#Disassembly): six screws in the square holes for the top case, three in the round holes for the drive, then the supply shield and the main assembly.[6]
  2. Remove the SIMMs.
  3. Photograph the board and note the polarity of every electrolytic, and which positions are non-polarised.
  4. Replace one capacitor at a time. Many of the 47 µF parts in the C500 group are axial.[1]
  5. Use parts of the same value and at least the same voltage rating.
  6. Clean off flux, refit the SIMMs and reassemble.
After recapping
Set the supply to 5.1 V, as Atari specifies.[5] Check that the on-board supplies work: the TL497A at U204 makes about ±12 V for the RS-232 drivers and U205 makes −5 V for the audio section.[5] Atari's diagnostic cartridge audio test, or playing a DMA sound sample, checks the audio path.
  1. ↑ 1.0 1.1 1.2 1.3 1.4 1.5 1.6 1.7 Atari Corporation, Atari STe 520/1040 Computer Field Service Manual, C302481-001 Rev A, August 1991, section 7, "Parts List", pp. 52–55. The hosted copy is the retyped edition by jer/eightbitter (May 2017) with redrawn schematics: File:520ste.pdf, described at Atari 520STE/1040STE Field Service Manual.
  2. ↑ 2.0 2.1 2.2 "Atari ST", Console5 TechWiki, list "CA300779-001 Rev 5.1 RGB / CA401177 / CA4003290 RGB", https://wiki.console5.com/wiki/Atari_ST (retrieved 2026-10-01). Community source: list read from boards.
  3. ↑ exxos, "STE no reset on power up issue fix", exxos's Atari, Amiga & retro forum, 25 September 2019. Community source.
  4. ↑ exxos, "MANDATORY FIXES", exxos's Atari, Amiga & retro forum, 31 January 2019, item 1. Community source.
  5. ↑ 5.0 5.1 5.2 Atari Corporation, Atari STe 520/1040 Computer Field Service Manual, C302481-001 Rev A, sections 1.3, "Power Supply", and 1.4, "Negative Supplies", p. 3 (retyped 2017 edition, File:520ste.pdf).
  6. ↑ Atari Corporation, Atari STe 520/1040 Computer Field Service Manual, C302481-001 Rev A, section 4.1, "STE Disassembly", pp. 43–44 (retyped 2017 edition, File:520ste.pdf).
