BBC Master Compact Troubleshooting
Acorn BBC Master Compact rear panel
Rear of the Master Compact keyboard unit (photo: Chris Whytehead, CC BY-SA 3.0)
Fault-finding for the BBC Master Compact, following section 6 of Acorn's Compact service manual. The Compact's custom chips and fault-finding steps resemble the Master 128's, but every IC number is different, and most ICs are soldered to the board.[1][2]
Test points
Acorn put six test points on the board.[3]
Compact test points (service manual section 4)
Point Signal Expect
TP1 MAX232 negative output (serial upgrade fitted) −5 to −10 V, typically −9 V
TP2 MAX232 positive output (serial upgrade fitted) +5 to +10 V, typically +9 V
TP3 CPU NMI Generally 5 V while running; low only during disc and Econet use
TP4 CPU IRQ Not stuck high or low when free running
TP5 CPU SYNC Changing; stuck high or low means the processor has stalled
TP6 CPU read/write Changing frequently between 0 and 5 V
TP1 and TP2 are near IC5 at the north of the board; TP3 to TP6 are south of the CPU IC28. For an oscilloscope ground use the north end of C1 in the north-west corner. The large copper area in the south-west of the board is +5 V, not ground.[3]
Switch-on
Connect an RGB monitor and switch on.[1]
Switch-on symptoms (service manual 6.1)
Symptom Probable cause Action
Noise on the monitor, no beep, keyboard power LED off (6.1.1) No 5 V Check that the supply gives 5 V, centre pin positive; if the supply has failed, see the disc unit below
Power LED lit, nothing else (6.1.2) Board fault Core checks below
Rolling lines or diagonal stripes (6.1.3) CRTC or sync MA lines (IC34 pins 4–17) and RA lines (pins 35–38) to the CRTC multiplexer IC46; VSYNC (IC34 pin 40) every 20 ms; HSYNC (pin 39) every 64 µs; CSYNC at IC10 pin 10 and pin 4 of the RGB socket; CSYNC polarity link PL10
Cursor stuck at top left (6.1.4) Keyboard Keyboard connections and the connector; the TTL ICs IC43, IC44, IC32, IC33 and IC45, which Acorn calls reliable
"Acorn MOS" and "Acorn ADFS" only (6.1.5) ADFS waiting for a disc, or bad configuration CTRL F BREAK, then a formatted disc or *CONFIGURE NODIR; otherwise switch on holding R, then CTRL F BREAK
"BASIC" but no > prompt (6.1.6) IRQ stuck IRQ at IC28 pin 4; address and chip select lines of the system VIA IC25
> prompt, keyboard dead (6.1.7) System VIA, keyboard or IRQ IC25; the keyboard connections; another keyboard; IRQ (IC28 pin 4), which the memory controller IC48, the ACIA (if fitted), the user VIA IC7, IC25 and the expansion connector PL13 all drive. The system VIA interrupts every 1/100 second
Some keys dead (6.1.8) Keyboard matrix tracks Several keys: the connection or a break mid-row or mid-column. One key: a break at the end of its row or column. Individual keys cannot be replaced on this membrane keyboard; if no track fault is found, replace the keyboard
Random dots or characters (6.1.9) Memory system CPU address lines (IC28 pins 9–20 and 22–25) to the multiplexers IC37, IC39 and IC40 at CMOS levels; address stable at least 15 ns after RAS; noise on lows under 500 mV; data bus to the DRAMs
Two or more copies of what you type (6.1.10) CRTC addressing IC34 pins 4–13 and 35–38; MA13 (IC34 pin 17) static in a given mode; IC34 to IC46; C0 and C1 from the 74LS259 IC31 (pins 4 and 5) to IC46 (pins 38 and 39)
Core checks: dead machine
Acorn's sequence for a board that powers up but does nothing (6.1.2):[1]
  1. Check +5 V and 0 V at every IC and make good any dry joints.
  2. Feel for very hot ICs; the 6845, the VIDPROC and the DRAMs always run quite warm. Look for shorted tracks, and replace any IC that got abnormally hot.
  3. Check the 16 MHz oscillator at IC10 pin 2 and that it reaches the VIDPROC at IC16 pin 8: about 4 V peak-to-peak. The oscillator is half of IC10 with crystal XL1.
  4. Check 1, 2, 4 and 8 MHz from the VIDPROC at IC16 pins 4, 5, 6 and 7; replace IC16 if any is missing or not clean.
  5. Check 2 MHz at the CPU, IC28 pin 37.
  6. Check that the system ROM is in its socket.
  7. Check the buses for shorts to each other, to +5 V and to ground.
  8. Check RAS (pin 5) and CAS (pin 16) at the DRAMs IC35 and IC41: 4 MHz square waves. RAS comes from the D-type IC8 pin 9; CAS from 2 MHz through IC10, a NAND gate in IC18 and another in IC27.
  9. Check the DRAM address lines (pins 6–8 and 10–14 of IC35 and IC41) switch after RAS with about 20 ns hold time.
Warning: if the 16 MHz clock fails, RAS and CAS can be held low and the DRAMs overheat and fail. Do not leave the machine on for more than 30 seconds at a time while the clock is dead.[1]
Continuous tone and no picture
This is the common Compact fault reported on stardot, and on several machines it has been the DRAMs:
  • One owner who found the VIDPROC clocks and the RAS and CAS signals present, and the 6522, 6845 and WD1772 not responsible, cured it by replacing the RAM.[4]
  • Another needed two DRAMs, a new MOS socket (some pins were not making contact) and a new configuration EEPROM; his remaining instability was the external 5 V supply he was testing with.[5]
  • Socket the replacement DRAMs; they are 4464 64K × 4 parts, 120 ns.[6][5]
A Compact that worked on the bench but failed once screwed into its case was traced to a case stand-off pressing on two pins of IC22, the I/O controller.[7]
Configuration memory
The 128-byte EEPROM IC24 replaces the battery-backed CMOS RAM of the Master 128. Acorn's checks (6.11):[8]
  1. Try a replacement PCD8572 in IC24 (it is socketed).
  2. Check 5 V at IC24 pin 8 and 0 V at pins 1, 2, 3 and 4.
  3. Check that IC24 pin 6 connects to the system VIA IC25 pin 15, and pin 5 to IC25 pin 14.
  4. Check the system VIA IC25 and change it if necessary.
  5. Finally check the RC timing circuit R1 and C2.
The EEPROM has a limited number of write cycles, which is why Acorn socketed it.[8] Because there is no clock chip, the date is always 31 December 1999 unless the machine gets the time over Econet; that is not a fault.[9] If the machine starts at a * prompt with "This is not a language", type *CONFIGURE LANG 14 and *INSERT 14.[9]
Video
Connect both an RGB and a composite monitor.[1]
Video faults (service manual 6.3)
Symptom Check
Picture rolls vertically VSYNC at IC34 pin 40 through the exclusive-OR gates IC20; on one output only, PL10, or R51 to R54 for composite
Picture broken into diagonal lines HSYNC at IC34 pin 39 through IC20
No colour on RGB RGB from the VIDPROC IC16 pins 14, 12, 10; in modes 7 and 135 only, from the SAA5050 IC15 pins 24, 23, 22 to IC16 pins 13, 11, 9
Only modes 7 and 135 fail 6 MHz into IC15 pin 19 from IC20 and IC21 (no part narrower than about 40 ns); pull-ups R29 to R31; data bus to the PBC IC26 pins 21–28; VSYNC for half-height text
Interfaces
Interface faults (service manual 6.4 to 6.10)
Interface Checks
Joystick port Continuity from PL8 to the user VIA IC7; 5 V at PL8 pin 7 and 0 V at pin 8; software that sets port B of IC7 to outputs (writes to &FE62); another joystick; IC7 last
Serial port The basic machine has no serial interface: check that the upgrade was fitted correctly; TP1 and TP2 voltages, then the supply to the MAX232
Disc Signal and power connectors home; another drive; select inputs of the 1772 (IC6 pin 1) and 74LS174 (IC1 pin 1), driven by IC22 pins 1 and 4; Read Data at IC6 pin 19; pull-ups R9 to R12; 8 MHz at IC6 pin 18 from IC19 pin 8 and IC16 pin 7; DRQ (IC6 pin 27) pulsing every 32 µs and inverted at the CPU NMI (IC28 pin 6); INTRQ (IC6 pin 28). Corrupt catalogue entries: C10 (220 pF) from IC6 pin 27 to 0 V, and only one drive with termination resistors. Wrong data: memory controller IC48 address inputs (pins 21–28). Unreliable writing: WD and WG at IC6 pins 22 and 21. If *CAT only clicks and the drive does not spin, Sprow's fix is *CONFIGURE FILE 13 and *INSERT 13
Printer Strobe pulse at the user VIA IC7 pin 39 for every character; inverted at pin 11 and true at pin 8 of the 7438 IC3
Expansion connector Does the machine work without the peripheral? Check external hardware and software carefully; no shorts on the edge connector; the plug the right way round; worn gold plating
Sound Speaker connected to PL1 and not blown; more than four envelopes use serial buffer space; strange sounds are usually software writing the sound buffer directly
Econet Both module connectors fitted (the longer one has two spare pins to its left); NMI at IC28 pin 6 not held low
Sources: Acorn's service manual and Sprow.[1][9]
Disc unit and power
Acorn's monitor-stand guide limits dealers to first-line work: check the plug fuse (5 A) and the mains lead, the mains switch, the mains fuse (anti-surge 3.15 A HBC 250 V, type T), the 5 V lead (under 100 mΩ per wire at full load) and the disc data cable, and replace the supply board or the drive as a unit.[10] Repeated disc errors are a reason to try another data cable.[10]
Supply faults reported by repairers
Supply takes a minute or more to come up The supply board's start-up capacitor C10 (220 µF; not the main board's C10, a 220 pF ceramic) lost value, or its charging resistors drifted high Replace C10; measure the resistors of 100 kΩ or more that charge it[11]
Fast clicking from the supply and the power LED flashing in step Short or overload on an output, a failed start-up capacitor, or a shorted output rectifier Disconnect the floppy drive and test again; replace the start-up capacitor; measure the outputs for a short with the power off; check the 115/230 V wire link[12]
Smoke and a smell from the disc unit Failed RIFA X2 capacitor Replace it; see BBC Master Compact Capacitor Guide[13]
To test the keyboard unit away from the disc unit, owners use any regulated 5 V supply of 2 A or more with the centre pin positive.[14][15]
  1. ↑ 1.0 1.1 1.2 1.3 1.4 1.5 Acorn Computers, British Broadcasting Corporation Master Series Compact Microcomputer Service Manual, part no. 0458,002, issue 1, October 1986, hosted as File:Acorn BBC Master Compact Service Manual 0458,002.pdf, 6 "Fault finding", printed pp. 26–38: switch-on symptoms 6.1.1 to 6.1.10, sideways RAM, video, joystick port, serial port, disc interface, printer port, expansion connector, sound, Econet and non-volatile memory.
  2. ↑ stardot.org.uk, "Master Compact Repair Help/Continuous Tone of Death" (January 2014, retrieved 2026-10-02). AndyGarton: most ICs soldered; continuous tone and no display, then display and prompt but dead keyboard apart from BREAK; the keyboard worked in another computer and the NVRAM chip had been swapped. 1024MAK: BREAK is only a reset; how to test /IRQ with a scope, logic probe or meter. hoglet: the system VIA IC25 is not socketed. Secondary source.
  3. ↑ 3.0 3.1 Acorn Computers, Master Series Compact Microcomputer Service Manual, 0458,002, 4 "Selection links and test points", printed pp. 9–10 (PL7, PL9 to PL12, VR1, FS1, L1 and L2; TP1 to TP6), and 7 "Hints and Tips", p. 39.
  4. ↑ stardot.org.uk, "Acorn Master Compact - blank screen and beep" (February–March 2019, retrieved 2026-10-02). nekroskop: no display, endless beep, power LED lit, Caps Lock flashing; VIDPROC clocks present on pins 4 to 7 (1, 2, 4, 8 MHz), RAS and CAS present on IC35 and IC41; removing the 6522 and WD1772 changed nothing; fixed by replacing the RAM. Secondary source.
  5. ↑ 5.0 5.1 stardot.org.uk, "Master Compact - Faulty - FIXED" (December 2023 – February 2024, retrieved 2026-10-02). DaveLecky: two DRAMs, a MOS socket with dead contacts and the configuration EEPROM replaced; the last fault was his bench supply, cured by using another 5 V supply. maniacminer: a dead Compact whose RAM had failed, probably after RAS and CAS were held low. tom_seddon: the Compact MOS appears to boot with default settings if the EEPROM does not acknowledge. Secondary source.
  6. ↑ Acorn Computers, Master Series Compact Microcomputer Service Manual, 0458,002, parts list, printed pp. 43–47: 4464 DRAM 120 ns IC35, IC36, IC41, IC47; PCD8572 IC24 (socketed); system ROM IC49 (socketed).
  7. ↑ stardot.org.uk, "BBC Master Compact - faulty when in case [SOLVED"] (December 2024, retrieved 2026-10-02). dsdf323: the board worked out of the case but failed consistently once seated in the bottom case; a stand-off was crushing two pins of IC22. Secondary source.
  8. ↑ 8.0 8.1 Acorn Computers, Master Series Compact Microcomputer Service Manual, 0458,002, "Non volatile memory", printed pp. 19–20, and 6.11, p. 38.
  9. ↑ 9.0 9.1 9.2 Sprow, "The most common beeb power on problems", Sprow's webpages, updated 9 November 2010 (retrieved 2026-10-02). Community source: the Compact's fixed time of 31 December 1999; *CONFIGURE LANG 14 for BASIC; *CONFIGURE FILE 13 and *INSERT 13 for DFS on the Compact; the ADFS mount hang.
  10. ↑ 10.0 10.1 Acorn Computers, Master Series Compact Microcomputer Service Manual, 0458,002, section 2, monitor stand service guide, PDF pp. 50–58: first-line servicing; mains lead, switch, auxiliary output and input; mains fuse; changing the supply; the +5 V lead and DC cable assembly; the disc data cable (try a known working cable if disc errors keep occurring); changing the drive (Sony F6 3W set as drive 0).
  11. ↑ stardot.org.uk, "BBC Master Compact PSU very slow to start" (January 2022, retrieved 2026-10-02). C10 measured 65 µF and caused a one- to two-minute start; a new 220 µF part cured it. 1024MAK: also check the high-value resistors that charge it. Secondary source.
  12. ↑ stardot.org.uk, "Master compact disk unit power supply" (August 2025, retrieved 2026-10-02). turboman: clicking about ten times a second, LED flashing in time, unchanged after a recap, computer fine on another 5 V supply. 1024MAK: disconnect the floppy drive; the primary start-up capacitor is a common failure. JonnoW and 1980s_john: usually a short on the output; one had a shorted output rectifier diode; check the 115 V/230 V jumper wire. Secondary source.
  13. ↑ stardot.org.uk, "Refurb process for Master Compact Base Unit PSU" (February–March 2025, retrieved 2026-10-02). 1024MAK's supply after "the white smelly smoke"; C1 0.1 µF 275 V AC X2. Secondary source.
  14. ↑ stardot.org.uk, "BBC Master Compact Power Supply?" (February–March 2023, retrieved 2026-10-02). 1024MAK: 2 A at 5 V regulated is enough; egel: the original is printed 5V 2A; jgharston: a 5 V 2.5 A adaptor, tip +5 V. Secondary source.
  15. ↑ Acorn Computers, Master Series Compact Microcomputer Service Manual, 0458,002, connector pinouts, printed p. 41: PL2 power input, outer 0 V, inner +5 V.
