IBM PC AT Troubleshooting Guide
Fault finding on the IBM PC AT (5170) follows IBM's own service sequence: check that the supply fan runs, listen for the beep at the end of the power-on self test (POST), read any error on the screen, and run the Advanced Diagnostics. IBM's 1986 service manual turns each POST indication into a procedure; minuszerodegrees.net documents the causes it has found for each. Supply limits, the battery check and the load resistor are covered in the IBM PC AT Maintenance Guide.
Before you start
[edit | edit source]- IBM's start procedure begins with the power off, all connectors and jumpers checked, the 115/230 V selector set for the local supply, and the configuration confirmed by running SETUP.[1] The AT has no SETUP in ROM; see IBM PC AT Maintenance Guide#SETUP.
- Many POST errors are followed by a prompt to press F1 to continue.[1]
- Unlike the 5150 and 5160, the 5170 POST writes checkpoint codes to I/O port 80h, which a POST card can display. The code is written just before each test, so a card that stops at a code points at the test that failed.[2]
- All of this assumes IBM BIOS ROMs. Third-party BIOS replacements behave differently.[3]
IBM's POST error table
[edit | edit source]IBM's start procedure sends each POST indication to a maintenance analysis procedure (MAP):[1]
| Indication | IBM's action |
| No beep, with a blank display, a blinking cursor, an unreadable display, or even with the machine working | MAP 0020: Power |
| No beep and a 1xx error | MAP 0100: System board |
| 1 long, 1 short beep | Replace the system board |
| 1 long, 2 short or 1 long, 3 short beeps | Display adapter MAP (EGA: MAP 2400) |
| 2 short beeps and a blank, unreadable or distorted display | Display adapter MAP |
| 2 short beeps and an error code | 1xx: MAP 0100; xxxxxx xxxx 201: MAP 0200; 30x or xx30x: MAP 0300; 601: MAP 0600; 17xx: MAP 1700; 30xx and 31xx: PC Network MAPs |
| C8000 ROM error | Replace the fixed disk adapter |
| ROM error | Replace the system board |
| Continuous beep | MAP 0020: Power |
| Repeating short beeps | MAP 0020: Power |
IBM's table of other symptoms sends an incorrect memory size and PARITY CHECK to the memory MAP; display problems to the display adapter MAPs; a flashing cursor only to the coprocessor check and then the diskette MAP; a BASIC screen, a boot from fixed disk or a diskette boot failure to the diskette MAP; and an inability to finish the diagnostic tests to the power MAP.[1]
Beep causes
[edit | edit source]| Indication | Causes |
| 1 long, 1 short | 06/10/85 and 11/15/85 BIOS only. System board speed outside certain bounds, typically after a faster crystal has been fitted. |
| 1 long, 2 short | A faulty video card, a poorly seated card, dirty edge contacts, or interference from another card. An IBM EGA card set up for an MDA or CGA monitor can also produce it when its own ROM finds a fault. |
| 1 long, 3 short | The ROM on an IBM EGA card reporting a fault with itself. |
| Memory count completes, then nothing | On a type 3 board, an MDA card with SW1 in the colour position. Also seen with a faulty Fixed Disk and Diskette Drive Adapter. |
Source: minuszerodegrees' 5170 POST errors page.[3]
On-screen errors
[edit | edit source]| Code | Message or IBM's description | Notes (minuszerodegrees) |
| 101 | Interrupt failure | |
| 102 | Timer failure | |
| 103 | Timer interrupt failure | |
| 104 | Protected mode failure | |
| 105 | Last 8042 command not accepted | |
| 106 | Converting logic test | |
| 107 | Hot NMI test | |
| 108 | Timer bus test | |
| 109 | Low meg chip select test | |
| 161 | System Options Not Set (dead battery) | Replace the battery, then run SETUP; the error stays until SETUP is completed. Also a faulty system board. |
| 162 | System Options Not Set (CMOS checksum error) | Corrupted SETUP, a flat battery on some boards, or a video card that does not match SETUP. |
| 163 | Time & Date Not Set (clock not updating) | Invalid date or time, SETUP started and not finished, or a clock circuit fault. |
| 164 | Memory Size Error | RAM added without running SETUP, wrong amounts entered, or faulty RAM. |
| 201 | Memory Error | Shown as AAAAAA BBBB 201: AAAAAA is the hexadecimal address of the failing word and BBBB the failing bits. The address is sometimes one word beyond the fault. A BBBB with many F digits, such as FFFE, usually means RAM that is not there is being tested, for example SETUP set for 640 KB with 512 KB fitted. |
| 202, 203 | Memory Address Error | Address bits 0 to 15 (202) or 16 to 23 (203). |
| 301 | Keyboard Error | A preceding byte identifies a stuck key. Otherwise no keyboard, a PC/XT keyboard, a faulty keyboard or faulty keyboard circuitry on the system board. The 5170 has no keyboard fuse. |
| 302 | System Unit Keylock is Locked | The keylock is locked, the keylock switch is faulty, or the keyboard controller misreads it. Unplug J20: if the error goes, the keylock is the cause. |
| 303 | Keyboard Or System Unit Error | Remove the keyboard and power on. If 303 goes, the keyboard is faulty; if it stays, the system board. |
| 304 | Keyboard Or System Unit Error (keyboard clock line high) | As 303. |
| 401 | CRT Error | A CGA card with SW1 in the monochrome (rear) position. |
| 501 | CRT Error | An MDA card with SW1 in the colour (front) position. |
| 601 | Diskette Error | See #Diskette faults. |
| 602 | Diskette Boot Record Error | The boot sector was read but its contents were not as expected. |
| 1780, 1781 | Disk 0 Failure, Disk 1 Failure | See #Fixed disk faults. |
| 1782 | Disk Controller Failure | |
| 1790, 1791 | Disk 0 Failure, Disk 1 Failure |
The messages and IBM's descriptions are as minuszerodegrees quotes them from the IBM BIOS.[3]
Memory and parity errors
[edit | edit source]The BIOS always follows PARITY CHECK with 1 (system board RAM) or 2 (RAM on an expansion card). Below it is the failing address, or five question marks if it cannot be found. A PARITY CHECK with no number is not from the IBM BIOS; the Parity_Boot virus is known to display it.[3] IBM's service manual decodes the parity and 10-character memory error codes to a bank and a module; see IBM PC AT (5170)#Memory errors.[4]
When a memory error cannot be placed, IBM's procedure is to remove all Memory Expansion Adapters, run SETUP, repeat the failing test, and then refit the adapters one at a time, running SETUP each time.[4]
A fault in the first 64 KB of bank 0 shows as "000000 xxxx 201" with an MDA or CGA card, but as a dead system board with EGA or VGA. A POST card then shows DD. Reseat the bank 0 chips first; the fault may be a poor contact. On a type 1 board, swapping the bank 0 and bank 1 chips turns the dead board into a 201 error if a bank 0 chip was at fault.[5]
No beep, fan not running
[edit | edit source]IBM's start procedure:[1]
- Check that the power cord is in a working, properly earthed outlet.
- Switch off, unplug, and check the power cord for continuity. Replace it if it is open.
- Reconnect and power on. Check for 2.4 to 5.2 V between pins 1 and 5 (ground) of power supply connector P8. If Power Good is present, replace the supply; if not, go to the power procedure below.
Power procedure
[edit | edit source]IBM's power MAP for the AT, in order:[6]
- Check that the 115/230 V selector matches the supply. Disconnect all cables and external devices except the display, and power on. If the symptom goes, reconnect the devices one at a time, powering off before each, until it returns.
- Remove the cover, reseat the power connectors, and check Power Good (2.4 to 5.2 V between P8 pins 1 and 5).
- If Power Good is present, check the system board and drive connector voltages; see IBM PC AT Maintenance Guide#Voltage checks. A machine with no fixed disk needs the load resistor on P10 or P11. If any voltage is wrong, replace the supply.
- Check the speaker for continuity with its cable off the system board.
- Unplug the power connector from each drive in turn. If the symptom goes, that drive is at fault.
- Remove the option adapters one at a time, leaving the Fixed Disk and Diskette Drive Adapter and the display adapter.
- Remove the math coprocessor, if fitted.
- Remove the Fixed Disk and Diskette Drive Adapter (expect a 601), then the display adapter (expect one long and two short beeps).
- Power off, wait 10 seconds, power on and check Power Good again. If it is missing, replace the supply, then the system board; if it is present, replace the system board, then the supply.
Other causes of a machine that will not start:
- A diskette-only machine without its load resistor: the +12 V output is below its 2.5 A minimum load. The 5170 may or may not start with its hard drive removed.[5][7]
- A coprocessor fitted the wrong way round. Some 5170 system boards were made with the coprocessor socket's notch to the rear; a coprocessor fitted to match it gives a blank display and no beep. Fit it with its notch to the front of the board.[4]
- An XT-class supply: a type 1 board with the 01/10/84 BIOS may not start at all, and other boards may start intermittently or lose SETUP.[5]
- Bank 0 RAM with an EGA or VGA card (see above).
- A supply that fails after two or more hours and works again once cool. IBM's instruction is to replace it.[4]
Diskette faults
[edit | edit source]A 601 has several causes: the POST cannot find the diskette part of the Fixed Disk and Diskette Drive Adapter; a hard disk-style twisted cable used in place of the diskette cable; drive A faulty, without +5 V or +12 V, wrongly jumpered, or a model that does not work in the 5170.[3]
With the 06/10/85 and 11/15/85 BIOS, replacing IBM's adapter with a third-party controller can produce a 601 at POST, because those revisions look for the IBM adapter. The boot continues after an F1 prompt, although diskette operation may be affected. The 01/10/84 BIOS does not do this. Fixes are a controller the POST takes for IBM's, such as the Western Digital WD1003A-WA2 (the WD1002-WA2 and WD1003-WA2 may also work), a patched IBM BIOS, or a third-party BIOS.[8]
- Corrupted diskettes: a 1.2 MB drive must generate DISK CHANGED on pin 34. A 360 KB drive that puts READY on pin 34 also causes trouble; disconnect pin 34 when fitting a 360 KB drive.[5]
- 360 KB diskettes that other machines cannot read: a 160/180 KB or 320/360 KB diskette written in the high-capacity drive can afterwards be read only in a high-capacity drive.[9] IBM offered the optional 360 KB drive for writing disks for 360 KB machines.[10]
- No boot from drive B: the POST does not boot from B.[11]
- 1.44 MB drives are fully supported only by the 11/15/85 BIOS.[8]
Fixed disk faults
[edit | edit source]The POST tests a fixed disk configured in SETUP in the order 1782, 1780, 1781, 1790, 1791.[3]
- 1782: the controller failed its internal diagnostic or did not answer within a minute. The controller is missing, unseated, dirty at the edge connector, faulty, wrongly jumpered, or an XT-class controller.[3]
- 1780 (1781 for drive D): the controller passed but the recalibrate command failed. Check the 34-pin control cable (missing, unseated, faulty, on J1 instead of J5, or reversed on J5), the drive select jumper, the cable type, the drive's power, the drive, the controller, and that the controller is in a 16-bit slot.[3]
- 1790 (1791 for drive D): the recalibrate passed but a read failed. Check the 20-pin data cable (on J4 for drive C, not J3), the low-level format after fitting a new drive, and that the drive has at least as many cylinders and heads as the SETUP type says. Minuszerodegrees also lists +12 V missing at the controller and a controller without −12 V.[3]
The first hard drive IBM supplied in the 5170 was the 20 MB CMI 6426-S (also seen as CM-6426). Its very high failure rate led IBM to move to the Seagate ST-4026.[12] In SETUP, IBM's 20 MB drives are type 2 and its 30 MB drives type 20; type 20 needs diagnostics at level 2.0 or later and a BIOS that supports it.[4] Controllers with their own BIOS ROM, such as SCSI and XT-IDE cards, usually ignore the SETUP type.[11]
Cards
[edit | edit source]- Some cards designed for the 5150 and 5160 do not work in a 5170, partly because the slot timing differs, and some cards designed for the 6 MHz 5170 do not work in the 8 MHz model.[5]
- IBM notes that interrupt conflicts do not always make the diagnostics fail, and that a card isolated as the cause of a fault is not necessarily defective: it may be incompatible with the other cards in the machine.[4]
[edit | edit source]The supply's mains suppression capacitors tend to rupture with age. Old RIFA parts do so with smoke and a strong smell, and may leak fluid that should not be touched. A replacement must match the capacitance and class (X2 for X2, Y2 for Y2) with an AC voltage rating at least as high.[13] Opening the supply can expose hazardous voltages, and minuszerodegrees warns not to assume they disappear soon after it is unplugged.[14] See also IBM PC AT Capacitor Replacement Guide.
[edit | edit source]- ↑ 1.0 1.1 1.2 1.3 1.4 IBM, Hardware Maintenance Service, 6280087, Revised Edition (March 1986), MAP 0000 "Start (AT)": checks before starting p. 0000-1; power cord and Power Good p. 0000-11; POST error table p. 0000-13; failure symptom table p. 0000-14. Hosted as File:IBM Hardware Maintenance Service 6280087 MAP 0000 Start (AT).pdf, described at IBM Hardware Maintenance Service (March 1986).
- ↑ IBM 5170 – POST – Codes, minuszerodegrees.net.
- ↑ 3.0 3.1 3.2 3.3 3.4 3.5 3.6 3.7 3.8 IBM 5170 – POST – Some errors (on-screen, and otherwise), minuszerodegrees.net.
- ↑ 4.0 4.1 4.2 4.3 4.4 4.5 IBM, IBM Personal Computer Family Service Information Manual, SA38-0037-00 (July 1989), Chapter 9: power supply failures p. 9-8, coprocessor socket p. 9-9, memory error isolation and parity checks pp. 9-10 and 9-11, fixed disk types p. 9-7. Hosted as File:IBM Personal Computer Family Service Information Manual SA38-0037-00.pdf, described at IBM Personal Computer Family Service Information Manual.
- ↑ 5.0 5.1 5.2 5.3 5.4 IBM 5170 – Known Problems/Issues, minuszerodegrees.net.
- ↑ IBM, Hardware Maintenance Service, 6280087, Revised Edition (March 1986), MAP 0020 "Power (AT)", pp. 0020-1 to 0020-7. Hosted as File:IBM Hardware Maintenance Service 6280087 MAP 0020 Power.pdf.
- ↑ IBM, Technical Reference, Personal Computer AT, First Edition (September 1985), Section 3 "Power Supply", pp. 3-4 and 3-5. Hosted as File:IBM PC AT 5170 Technical Reference Sep85.pdf.
- ↑ 8.0 8.1 IBM 5170 – BIOS Revisions, minuszerodegrees.net.
- ↑ IBM, IBM Personal Computer Family Service Information Manual, SA38-0037-00, Chapter 9, "High-Capacity Diskette Drive", p. 9-2.
- ↑ 360K Floppy in 1.2M Drive, minuszerodegrees.net.
- ↑ 11.0 11.1 IBM 5170 – Basics, for 5170 beginners, minuszerodegrees.net.
- ↑ IBM 5170 – Failures of the CMI 6426 Hard Drive, minuszerodegrees.net.
- ↑ Commonly Failing Electronic Components (in vintage computers), minuszerodegrees.net, section "Line Suppression Capacitor".
- ↑ IBM 5170 – Power Supply Unit (PSU), minuszerodegrees.net.
[edit | edit source]- IBM PC AT (5170)
- IBM PC AT Maintenance Guide
- IBM PC AT Capacitor Replacement Guide
- IBM PC XT Troubleshooting Guide
- IBM PC (5150) Troubleshooting Guide
