Atari 800 General Maintenance
Revision as of 22:21, 22 September 2026 by Josh (talk | contribs) (Rebuild from Atari 400/800 Field Service Manual (hosted): C98-C103 'filter caps' do not exist; '+12V at 4050 pin 1' and '-5V at 4050 pin 8' are wrong (4050 runs on +5V, pin 8 is ground); the 400/800 have no OPTION-key self test. Added Atari's Section 6 symptom checklist, interlock switch S201, module-bay cooling change, Rev A/B ROM warning; cited throughout)
Atari 800
The Atari 800 is the high-end half of Atari's 1979 pair and the only 8-bit Atari with a four-slot modular memory bay and a right-hand cartridge slot.[1] That modularity is the machine's great strength for a restorer — almost everything is a plug-in board — and also its most common fault, because every one of those boards depends on an edge connector that has been oxidising since 1979.
Designators, part numbers and voltages on this page come from Atari's own field service manual.[2]
Regular cleaning
Case and keyboard
  • Wipe the case with a damp microfibre cloth and mild soap; avoid solvents.
  • The 800 has a full-stroke keyboard. Keycaps lift off vertically for cleaning; clean the plungers and contacts with 99 % isopropyl alcohol and let everything dry fully.
  • Inspect the keyboard ribbon where it flexes. Broken conductors in the ribbon, not failed switches, are the usual cause of a dead row.
Internal cleaning
  • Unplug the adaptor and allow a few minutes for C207 and C208 (4700 µF each) on the supply board to discharge.
  • Lift the module bay cover and remove the ROM and RAM modules. Remove the shield casting to reach the motherboard.
  • Blow out dust with compressed air or brush it away with an anti-static brush.
  • Reseat every module and socketed chip to wipe oxidised contacts.
Power supply and voltage checks
The 800 is powered by an external transformer — Atari part C014319, shared with the Atari 400 — supplying 9 V AC. It is not a DC supply; rectification and regulation happen inside the machine on the power supply PCB (CA014171).[2]
  • Measure the adaptor with the meter on AC volts. A reading near 9 V AC unloaded is what you expect.
  • The ON/OFF switch S202 opens the 9 V AC input, not a DC rail.[2]
  • CR206–CR209 (MR501) are the rectifier diodes; the regulators are A202 (5 V, C014348) and A201 (12 V, C014349) on heatsink assembly CA014708.[2]
The rails
Atari states that the power supply PCB "receives 9 VAC from an external power adaptor (transformer) and provides +5 Vdc, +12 Vdc, and −5 Vdc for the Console system":[3]
Atari 800 supply rails
Rail Purpose
+5 V A Supply voltage for the logic PCBs
+5 V B Specially filtered supply for the video circuitry
+12 V Supply for the dynamic RAM chips, and SIO pin 12
−5 V Supply for the dynamic RAM chips
Atari's manual does not print a test-point table of expected rail voltages for the 800. Measure at the regulator tabs and at the large filter capacitors on the power supply PCB rather than at arbitrary logic pins; published "test point" tables for this machine that name a CD4050 pin as the +12 V or −5 V point are wrong, because the 4050 runs from +5 V and its pin 8 is ground.
What Atari does specify is the clock chain:[4]
Clock check points (Atari Table 5-1)
Point Board Frequency (MHz)
Pin 21 of J101 CPU card 1.789
Pin 37 of A303 (6502) CPU card 1.140
Pin 35 of A302 (ANTIC) CPU card 3.579
Pin 29 of A301 (GTIA) CPU card 3.579
Collector of Q102 Motherboard 3.579
Pin 7 of A101 (POKEY) Motherboard 1.789
Pin 25 of A102 (PIA) Motherboard 1.789
The interlock switch
S201 is a power interlock switch on the power supply PCB: it breaks power to the system when the top panel is opened to fit or remove cartridges.[2] An 800 that is dead on the bench with the lid open, or that cuts out when the lid is disturbed, is very often this switch. Check it before the supply.
Connector and socket corrosion
The 800's modular design means it lives or dies by its connectors:
  • Module bay slots. Slot 1 takes the ROM personality module; the other three take RAM modules. Clean the module edge fingers with isopropyl alcohol and a lint-free cloth, then reseat several times.
  • Cartridge slots, left and right. The right slot is unique to the 800.[1]
  • SIO port — J204, 13-pin, on the power supply PCB.[2]
  • Monitor socket — J205, a DIN socket on the power supply PCB.[2]
  • Four controller jacks. The 400 and 800 are the only 8-bit Ataris with four.[1]
  • Power jack J206, and the keyboard ribbon connector.
  • IC sockets on the CPU card (A301–A303, 40-pin) and the ROM and RAM modules.
Capacitors
Ten aluminium electrolytics exist in an 800. Eight are on the power supply PCB — C201, C202 (470 µF 16 V), C204, C205 (2200 µF 16 V), C207, C208 (4700 µF 16 V) and C210, C211 (10 µF 16 V) — and two on the motherboard, C179 and C199, both 10 µF 16 V.[2] The CPU card, ROM module and RAM modules contain none at all. Everything else is ceramic, mylar or polyester film.
Full designator table with packages, part numbers and a note on the revision difference in C207/C208's voltage rating: Atari 800 Capacitor Replacement Guide.
Common failure points
Atari's own symptom checklist for the 400 and 800. A1xx/Z1xx designators are on the motherboard, A2xx/C2xx on the power supply PCB, A3xx on the CPU card and A4xx on the ROM personality module.[5]
Atari 400/800 symptom checklist (Atari Section 6)
Symptom Possible cause
Snowy screen Switch box, AC adaptor, channel select switch, modulator adjustment, RF cable damage
Black/grey screen Verify +5 V, −5 V and +12 V supplies; CR201–CR209, C201–C205, C210, A201, A302, A303, A301, A103, A111, Z103–Z105, Q103–Q104, X101
Green/yellow screen Z103–Z105, A103, Z303, Z304 — all on the ROM board
Solid blue screen A101 (POKEY), Q107, X101
No colour or bad colour bars R309 adjustment, A301–A302 on the CPU card; A111, Q107 on the motherboard; X101, Q103, Q104
No grey bars A301, A111, Q107; R309 adjustment; X101, Q103, Q104; modulator
Upside-down alphanumerics or player field A302 on the CPU card, A301, A111, Q107
Some keyboard keys fail Keyboard failure
All keyboard keys fail A101 (POKEY), Z103, Z104
Tones missing during sound or games A101, R160, R161, R166, R170, C164, C179, C184, Q105, L101, Q106, L118, A203
Console (game) switches will not function A301 on the CPU card, R119–R122, C121–C124
ROM test failed A401–A403 on the ROM board, Z403
RAM test failed See Atari's RAM test matrix, Figure and Table 5-2
Hand controllers will not work See Atari's Port Test matrix, Table 5-3
Memory and ROM modules
Slot 1 holds the CX801 (NTSC) or CX801.P (PAL) 10 KB ROM personality module; the remaining three slots take CX852 8 KB or CX853 16 KB RAM modules.[1] Boot errors, random crashes and self-test memory errors are far more often a dirty module edge or a tired slot than a failed DRAM. Clean, reseat, and swap modules between slots to see whether the fault follows the module or stays with the slot.
Atari prints a RAM test matrix (Figure and Table 5-2) that maps each failing bit reported by the SALT II cartridge to a specific chip position on the 8 KB and 16 KB cards; use it rather than guessing.[6]
Heat and the module bay
Early 800s shipped with plastic cases around the ROM and RAM modules and two thumb tabs on the bay cover. On later machines, which had 48 KB as standard, Atari removed the module cases to improve cooling, fitting instead a small plastic strip across the tops of the cards to hold them in position, and replaced the thumb tabs with screws.[1] If you have a late machine, that bare-card appearance is correct and original, not a previous owner's bodge. The 800 has no fan and relies on passive airflow through the case and the shield castings, so keep the vents clear and do not run one in a closed cabinet.
CPU card
A301 is the video chip, A302 is ANTIC and A303 is the 6502. Early machines have the CTIA (C012295) at A301; most have the GTIA (C014805). Atari's Upgrade Bulletin 1 covers the swap and notes that GTIA-specific software will not display correctly on a CTIA machine.[7] Late-production 800s use a revised CPU board carrying Atari's SALLY 6502.[1]
Operating system ROMs — do not mix revisions
The same bulletin tells the technician to replace the ROM pair if a printer "overprints (hiccups)".[8]
Faults that are not the computer
  • The adaptor. A transformer that has been plugged in for forty years.
  • The SIO cable or a peripheral. Unplug everything from SIO and retest before opening the case.
  • A cartridge. Dirty cartridge contacts produce lock-ups and garbage screens that look exactly like board faults. With no cartridge and no powered disk drive, an 800 should come up in Memo Pad mode.[1]
  • The TV switch box and RF cable. Atari's checklist puts these first for a snowy screen, ahead of anything inside the machine.[5]
Diagnostics
The 400 and 800 have no built-in self test; holding OPTION at power-on does nothing on these models, because that is XL-series behaviour. Atari's field procedure is the SALT II diagnostic cartridge, and Sections 3 and 7 of the field service manual are written around it — colour bar, grey bar, keyboard, tone, console switch, ROM verify, RAM and port tests, each with a flowchart.[2] With no cartridge and no powered drive attached, a healthy 800 boots to Memo Pad.[1]
See Recommended Tools. Specific to this machine: a meter that reads AC volts for the adaptor, contact cleaner for the module slots, and a load resistor for discharging C207 and C208.
  1. Test the adaptor on the AC range.
  2. Check and clean the interlock switch S201 and the power switch S202.
  3. Reseat the ROM and RAM modules and clean their edge fingers.
  4. Clean both cartridge slots and the SIO connector.
  5. Replace the power supply PCB electrolytics if they are original (see Atari 800 Capacitor Replacement Guide).
  6. Inspect the keyboard ribbon for cracked conductors.
  7. Keep the vents clear; the 800 has no fan.
  1. 1.0 1.1 1.2 1.3 1.4 1.5 1.6 1.7 Michael Current (ed.), comp.sys.atari.8bit Frequently Asked Questions, sections 1.2 and 1.3. Archived text. Community reference; used here for model differences, module types, production history and the late-production cooling change, not for component values.
  2. 2.0 2.1 2.2 2.3 2.4 2.5 2.6 2.7 2.8 Atari, Inc., ATARI Home Computer Field Service Manual 400/800, June 1982. Hosted on this wiki: File:Atari 400 800 Field Service Manual June 82.pdf. Sections 1 (theory of operation), 6 (symptom checklist), 7 (800 diagnostic flowcharts), 9 (800 parts list) and 10 (service bulletins).
  3. Atari, Inc., ATARI Home Computer Field Service Manual 400/800, June 1982, page 1-6, "Power Supply".
  4. Atari, Inc., ATARI Home Computer Field Service Manual 400/800, June 1982, Table 5-1, "Clock Circuit", page 5-36.
  5. 5.0 5.1 Atari, Inc., ATARI Home Computer Field Service Manual 400/800, June 1982, Section 6, "Symptom Checklist", pages 6-1 and 6-2.
  6. Atari, Inc., ATARI Home Computer Field Service Manual 400/800, June 1982, Figure and Table 5-2, "Defective RAM Identifier", page 5-39.
  7. Atari, Inc., Consumer Product Service Upgrade Bulletin number 1, "GTIA Chip", 28 May 1982, reproduced in Section 10 of the ATARI Home Computer Field Service Manual 400/800.
  8. Atari, Inc., Consumer Product Service Tech Tip number 2, "Revision B, Operating System ROMS", 28 May 1982, reproduced in Section 10 of the ATARI Home Computer Field Service Manual 400/800.
