Atari XE Game System Capacitor Replacement Guide
Replacing the original electrolytic capacitors ("recapping") in your Atari XE Game System (XEGS) is essential for long-term reliability and performance. Ageing capacitors can cause power instability, video artefacts, audio noise, or even prevent the system from starting. Proactively replacing these components helps ensure stable operation, protects the delicate custom chipset, and resolves many "mystery" faults common in vintage Atari 8-bit hardware.
The XEGS mainboard is designated C100417 Rev. A and uses predominantly axial electrolytic capacitors, with two non-polar positions.
Before starting, carefully examine all electrolytic capacitors on the mainboard for:
- Bulging or domed tops — Indicates internal gas pressure and imminent failure.
- Leaking electrolyte — Brown, green, or white crust around the base or legs.
- Corroded or stained PCB areas — Suggests past leakage, especially near the power input and around C13 (main filter).
- Random resets, video glitches, or audio hum — Often traceable to dried-out or high-ESR capacitors.
If any capacitor shows signs of failure, it is strongly recommended to replace all electrolytic capacitors on the board.
XEGS Capacitor List
The following table lists all electrolytic capacitors on the XEGS mainboard (C100417 Rev. A). This data is sourced from board examination and the Console5 TechWiki.
Mainboard Electrolytic Capacitors
| Ref. Designator | Capacitance | Voltage Rating | Type | Function / Location |
| C1 | 22 µF | 16 V | Axial polarised | Decoupling / filtering |
| C2 | 22 µF | 16 V | Axial polarised | Decoupling / filtering |
| C3 | 22 µF | 16 V | Axial polarised | Decoupling / filtering |
| C13 | 1000 µF | 16 V | Axial polarised | Main +5 V input filter (primary power smoothing) |
| C25 | 10 µF | 16 V | Axial polarised | Reset circuit timing |
| C28 | 4.7 µF | 35 V | Non-polar (NP) | Audio coupling (video/audio path) |
| C30 | 10 µF | 16 V | Axial polarised | Decoupling / signal path |
| C32 | 4.7 µF | 35 V | Non-polar (NP) | Audio coupling (video/audio path) |
| C48 | 10 µF | 16 V | Axial polarised | Decoupling / signal path |
| C55 | 100 µF | 16 V | Axial polarised | Secondary power filtering (ASIC area) |
Total electrolytic capacitors: 10
Important Notes
- C28 and C32 are non-polar 4.7 µF capacitors. The Console5 cap kit supplies radial non-polar replacements for these positions. Standard polarised electrolytics must not be used here — the signal path is AC-coupled and requires non-polar types.
- C13 (1000 µF) is the main power filter capacitor and is the most critical cap on the board. A failed C13 causes voltage ripple that can damage custom ICs and produce instability.
- SECAM boards may have different capacitor values or additional components. Verify against your specific board before ordering parts.
- The XEGS uses predominantly axial electrolytic capacitors. If replacing with radial types, ensure leads are formed correctly to match the axial pad spacing.
Capacitor Kit Sources
Pre-assembled capacitor kits for the XEGS (C100417) are available from:
- Console5 — Atari XEGS Cap Kit
- Individual capacitors from electronics suppliers (Mouser, Digi-Key, Farnell) — use 105 °C rated, low-ESR parts from reputable manufacturers (Nichicon, Panasonic, Rubycon).
Replacement Procedure
Disassembly
- Disconnect the power supply and all peripherals (keyboard, cartridge, joystick, SIO).
- Remove the screws from the underside of the console (typically 5–6 Phillips screws).
- Carefully lift the top case shell. Note the position of the membrane button assembly — it may be attached to the top case.
- Remove the RF shield screws and lift off the metal shielding.
- Remove the mainboard mounting screws and lift out the PCB.
Desoldering
- Photograph the board before starting — note the orientation (polarity stripe) of each electrolytic capacitor.
- Heat each capacitor lead with a temperature-controlled iron (300–350 °C) and remove solder with a desoldering pump or solder wick.
- Gently rock the capacitor while heating to free it. Do not force — pulling too hard will lift pads.
- For axial capacitors, work one lead at a time.
Pad Preparation
- Clean each pad with solder wick to remove residual solder.
- Inspect for lifted pads or damaged traces — repair with wire jumpers if necessary.
- Clean the PCB area around each capacitor site with isopropyl alcohol (IPA) to remove old flux and any leaked electrolyte. Electrolyte is corrosive and will continue to damage traces if left in place.
Installing New Capacitors
- Observe polarity — the silkscreen on the PCB typically marks the negative end. The capacitor's stripe indicates the negative lead. For axial types, the band is at the negative end.
- C28 and C32 are non-polar — these can be installed in either orientation.
- Insert the capacitor, form the leads to match the pad spacing, and solder with clean, shiny joints.
- Trim excess leads flush with the solder joint.
- Ensure no capacitor exceeds 18 mm height — taller caps will interfere with the RF shield.
Reassembly
- Inspect all joints under magnification — check for solder bridges, cold joints, and correct polarity.
- Reinstall the mainboard, RF shield, and case.
- Reconnect the keyboard and power supply.
Post-Recap Verification
After recapping, verify the voltage rails before connecting peripherals:
| Test Point | Nominal Value | Acceptable Range | Max Ripple (p-p) |
| +5 V (mainboard input / C13 positive) | 5.00 V | 4.85–5.15 V | < 50 mV |
| +5 V at CPU (U1 pin 8) | 5.00 V | 4.85–5.15 V | < 50 mV |
| +5 V at ANTIC (U4 pin 20) | 5.00 V | 4.85–5.15 V | < 50 mV |
| +5 V at DRAM (U10–U13 pin 18) | 5.00 V | 4.85–5.15 V | < 50 mV |
| Audio output (RCA jack) | — | — | No hum or buzz |
If you observe excessive ripple (> 100 mV) or unstable voltages after recapping, recheck your solder joints and consider replacing the external PSU.
Tips and Warnings
- Check the power supply first — a faulty PSU can damage new capacitors and custom chips. Always test PSU output before powering the recapped board.
- Use a current-limited bench supply (5 V / 1 A limit) for the first power-up after recapping to protect against accidental short circuits.
- Double-check polarity before soldering — reversed electrolytic capacitors may explode or leak.
- Clean all leaked electrolyte thoroughly — it corrodes PCB traces over time and can cause open circuits.
- Retain original lead spacing where possible: typically 5 mm for 10–22 µF, 7.5 mm for 100 µF, and 10 mm for 1000 µF.
- Axial-to-radial conversion: If axial capacitors are unavailable, radial types can be used by bending and forming the leads horizontally. See Console5's guide to converting axial to radial capacitors.
- Power up with a fuse in series (1 A fast-blow) as an additional safety measure during first test.
- Atari XE Game System
- Atari XE Game System General Maintenance
- Atari XE Game System Troubleshooting Guide
- Atari 65XE Capacitor Replacement Guide
