IBM PS/2 Model 50 Capacitor Replacement Guide
Revision as of 21:51, 21 September 2026 by Josh (talk | contribs) (Verification drive: flag unverified component data pending check against a primary source)
This guide documents capacitor diagnosis and replacement for the IBM PS/2 Model 50 (machine type 8550, both the 8550-021 original and the 8550-031 / 061 Model 50 Z), covering the planar, the 94 W PSU, the IBM Fixed Disk Adapter/A (ST-506 controller) and ESDI Fixed Disk Adapter/A (ESDI controller), the floppy and hard drive logic boards.
Safety Warning
The 94 W PSU contains mains-rectified bulk capacitors that hold a lethal charge after power-off. Before any PSU work:
  1. Power off and unplug the mains lead.
  2. Wait at least 30 seconds.
  3. Discharge the bulk capacitor through a 1 kΩ / 5 W resistor.
  4. Verify with a multimeter.
No CRT in the system unit.
Planar Capacitors
The Model 50 / 50 Z planar carries through-hole 10 µF / 16 V tantalum capacitors for IC supply rail bypassing. The Model 50 is less affected by surface-mount aluminium electrolytic leakage than the IBM PS/2 Model 70 / 80 (whose SMD electrolyte leakage is the famous PS/2 failure mode), but planar tantalum shorts and through-hole electrolytic ageing both occur in field service.
IBM did not publish a unified silkscreen reference for the Model 50 / 50 Z planar. Inspect every orange or yellow bead-style tantalum on the planar.
Failure Mode
Tantalums on the Model 50 are commonly marked "106 16V" (10 µF, 16 V working voltage), polarised. Two failure modes:
  • Short circuit — pulls +5 V or +12 V down. The PSU folds back (Power Good not asserted in 150 ms); system shows "click then nothing" or repeated click-retry.
  • Open circuit — no immediate symptom; decoupling degraded; system noise-sensitive.
Diagnostic Procedure
  1. Discharge the PSU bulk capacitor.
  2. Remove the planar from the chassis (4 screws to chassis floor).
  3. Set multimeter to diode test or 200 Ω resistance.
  4. Probe each tantalum in-circuit: black probe to ground, red probe to the rail side. Good cap reads as open / high resistance after a brief charge pulse; a failed (shorted) cap reads close to 0 Ω.
  5. Where a short is found, remove the cap to confirm out-of-circuit; other components on the same rail can give false-short readings.
  6. Replace with a fresh 10 µF / 16 V tantalum (preferred) or a 10 µF / 25 V low-ESR ceramic (acceptable substitute).
Removal and Replacement
  1. Mark polarity with a paint pen or photograph.
  2. Apply fresh solder + flux to both leads from the underside.
  3. Heat one pad, lever the cap up with tweezers. Heat the other pad and lift clear.
  4. Clean both holes with solder wick.
  5. Insert the new cap matching the silkscreen polarity (+ on cap to + on silkscreen).
  6. Solder both leads from the underside. Inspect for a clean fillet.
  7. Trim leads flush.
The Model 50 planar pads are not very tolerant of repeated heating. Use a temperature-controlled iron at no more than 350 °C; limit each desolder cycle to 5–7 seconds.
Power Supply Recap (94 W)
The Model 50 94 W PSU is a single-board switching supply with the standard primary / secondary topology:
  • Primary side: bridge rectifier, X2 line suppression cap on the mains input, bulk capacitor (typically 220 µF / 200 V), switching transistor, switching transformer.
  • Secondary side: rectifier diodes, smoothing electrolytics, output filter chokes, feedback optocoupler.
After 30+ years the secondary electrolytics commonly need replacement. Symptoms include sagging rails under load, audible whine, PSU refusing to start when warm.
Common Cap Values
Model 50 94 W PSU capacitor replacement summary
Value Voltage Type Typical position Notes
1000 µF 16 V Low-ESR aluminium electrolytic, 105 °C +5 V smoothing × 2 Critical for stable +5 V under load
470 µF 35 V Low-ESR aluminium electrolytic, 105 °C +12 V smoothing × 1
220 µF 35 V Aluminium electrolytic, 105 °C −12 V smoothing × 1
100 µF 16 V Aluminium electrolytic, 105 °C Bypass / feedback × 2–3
47 µF 50 V Aluminium electrolytic, 105 °C Primary auxiliary × 1–2
220 µF 200 V Aluminium electrolytic, 105 °C Primary bulk × 1 Lethal charge — discharge before work
0.1 µF 275 VAC X2 class Mains suppression × 1 Replace if RIFA-branded
Recap Procedure
  1. Discharge the bulk capacitor; verify with a multimeter.
  2. Remove the PSU from the chassis (typically 4 screws).
  3. Open the PSU housing. The Model 50 PSU is normally screwed (not ultrasonically welded).
  4. Photograph the board before any work. Mark each electrolytic's polarity with a paint pen.
  5. Desolder each electrolytic. Use solder wick on each lead.
  6. Fit replacements: low-ESR, 105 °C rated, equal capacitance, equal or higher voltage rating.
  7. Inspect the X2 mains suppression capacitor. If RIFA-branded or showing cracking, bulging or fluid leakage, replace with a modern X2 cap of equal value. RIFA X2 caps from this era are well known to vent and smoke.
  8. Reassemble. Verify rails on the bench with a multimeter under a 1 A resistive load before refitting to the chassis.
ESDI Fixed Disk Adapter/A Capacitors
The IBM ESDI Fixed Disk Adapter/A drives the 60 MB ESDI hard drive on the 8550-061. The card carries small aluminium electrolytics that age:
  • 10 µF / 16 V (multiple positions) — IC bypassing.
  • 22 µF / 16 V (one or two positions) — sector buffer power.
  • 47 µF / 16 V (one position) — on-card 5 V regulation.
If the ESDI controller reports a 10455 (controller failure) or 10463 (read/write sector error) on a known-good drive, recap the controller card capacitors before condemning the card.
Fixed Disk Adapter/A (ST-506) Capacitors
The IBM Fixed Disk Adapter/A on the 8550-021 and 8550-031 carries similar through-hole electrolytics in similar positions (10 µF / 22 µF / 47 µF on +5 V bypassing). Recap if 1701 / 1702 errors appear on a known-good drive.
ESDI Drive Logic Board
The Maxtor / Miniscribe / Western Digital 60 MB ESDI drives in the 8550-061 carry their own drive logic board with aluminium electrolytics. Typical values:
  • 47 µF / 16 V — near the spindle motor driver.
  • 10 µF / 25 V — near the head-amp section.
  • 22 µF / 16 V — sector buffer.
Symptoms of aged drive caps include the drive not spinning up reliably, CRC errors on reads, and the drive becoming unreliable when warm. Recap with 105 °C low-ESR equivalents.
Floppy Drive Logic Board
The PS/2 1.44 MB floppy drives (ALPS, Mitsubishi MF355C, Sony, YE-Data) carry:
  • 47 µF / 16 V — motor driver.
  • 10 µF / 25 V — head amplifier.
Leak symptoms include brown crust around the cap base and corroded PCB traces. Clean with IPA and replace with 105 °C low-ESR equivalents.
The Mitsubishi MF355C family also needs a 54 × 1 mm flat rubber drive belt at the same time.
MCA Memory Card Capacitors
The IBM 2-8 MB MCA Memory Adapter and the AST Advantage/2 carry through-hole electrolytics that age but rarely fail. Inspect for leaked electrolyte if a memory card is fitted and the system reports 201 / 215 / 216 errors on it.
Replacement Parts Summary
Model 50 system-wide cap replacement summary
Value Voltage Type Where
10 µF 16 V Tantalum or low-ESR ceramic Planar bypass, ESDI / ST-506 card bypass
22 µF 16 V Tantalum or low-ESR aluminium ESDI sector buffer, planar bypass
47 µF 16 V Aluminium electrolytic, low-ESR, 105 °C Drive logic board motor driver; ESDI card +5 V regulation
100 µF 16 V Aluminium electrolytic, low-ESR, 105 °C PSU bypass / feedback
220 µF 35 V Aluminium electrolytic, 105 °C PSU −12 V smoothing
220 µF 200 V Aluminium electrolytic, 105 °C PSU primary bulk (lethal-charge component)
470 µF 35 V Low-ESR aluminium electrolytic, 105 °C PSU +12 V smoothing
1000 µF 16 V Low-ESR aluminium electrolytic, 105 °C PSU +5 V smoothing
0.1 µF 275 VAC X2 class PSU mains suppression
Polarity Reference
The Model 50 planar silkscreen marks the + (positive, rail) side of each electrolytic with a small "+". The cap body shows the negative side with a stripe and "−". Match these conventions.
Polarity reference for IBM motherboard tantalum capacitors. The convention applies to the Model 50 planar and ESDI controller card. (Image: minuszerodegrees.net)
A failed tantalum often shows no visible damage.
Failed tantalum on an IBM motherboard. The small hole on the body is often the only visual indication. (Image: minuszerodegrees.net)
Post-Recap Verification
  1. Bench-test the planar with a known-good PSU and no peripherals.
  2. Verify rails at the planar power connector.
  3. Refit; boot the Reference Diskette.
  4. Run Auto Configuration if any MCA cards changed.
  5. Run Advanced Diagnostics (Ctrl-A) and walk through each test.
  6. Run a memory test pass for several hours under DOS to confirm planar memory reliability.
If any test fails after a recap, re-inspect the polarity of every replaced cap before suspecting another fault — reversed polarity is the most common error.
When Not to Recap
If the Model 50 boots, POSTs cleanly and runs reliably with no diagnostic errors, the caps are within tolerance.
Always recap if:
  • Fluid leak visible from any electrolytic.
  • PSU smoke, fishy odour or audible whine.
  • Diagnostic procedure identifies a shorted tantalum.
  • ESDI controller reports 10455 / 10463 on a known-good drive.
  • Drive becomes unreliable when warm.
