Atari 600XL Capacitor Replacement Guide
| Atari 600XL home computer | |
| Manufacturer | Atari, Inc. |
| Type | Home Computer |
| Released | 1983 |
| Discontinued | 1984 |
| CPU | MOS Technology 6502C (SALLY) @ 1.79 MHz (NTSC) / 1.77 MHz (PAL) |
| Memory | 16 KB RAM (expandable to 64 KB), 24 KB ROM |
| Storage | — |
| Display | — |
| Sound | — |
| OS / Firmware | Atari OS Rev. 1, Atari BASIC Rev. B (in ROM) |
| Predecessor | Atari 400 |
| Successor | Atari 800XL |
This guide provides a complete electrolytic capacitor replacement reference for the Atari 600XL home computer. All electrolytic capacitors should be replaced as part of a preventive recapping to ensure continued reliability. The original capacitors are now over 40 years old and are prone to drying out, leaking, or losing capacitance, which can cause instability, audio issues, video distortion, and complete system failure.
Before You Begin
Tools Required
- Temperature-controlled soldering iron (recommended 350°C / 660°F)
- Solder wick (desoldering braid) and/or solder sucker
- Fresh solder (60/40 or 63/37 leaded solder recommended for vintage PCBs)
- Isopropyl alcohol (IPA, 99%) for cleaning
- Multimeter with capacitance measurement capability
- Magnifying glass or loupe for solder joint inspection
- Anti-static wrist strap
Replacement Capacitor Recommendations
- Use high-quality electrolytic capacitors from reputable manufacturers: Nichicon, Rubycon, Panasonic, or Elna.
- Match or exceed the original voltage rating. Higher voltage ratings are acceptable and may improve longevity.
- Match the original capacitance value. Do not use significantly higher capacitance values without understanding the circuit requirements.
- For non-polarised (NP/bipolar) capacitors, ensure replacements are also non-polarised (bipolar) electrolytic types.
- Use capacitors rated for 105°C operation where possible for improved lifespan.
Observe correct polarity when installing electrolytic capacitors. Reversed polarity can cause immediate failure, including capacitor rupture. The negative terminal is marked on the capacitor body with a stripe; the positive pad on the PCB is typically marked with a "+" symbol. |
Capacitor List — NTSC (Chelco Rev. 8A)
| Ref Des | Capacitance | Voltage | Type | Circuit Function |
| C1 | 22 µF | 16V | Polarised electrolytic | Power supply decoupling / input filtering |
| C6 | 22 µF | 16V | Polarised electrolytic | Power rail filtering near custom chips |
| C13 | 22 µF | 16V | Polarised electrolytic | Power rail decoupling |
| C44 | 47 µF | 10V | Polarised electrolytic | POKEY audio output coupling / power filtering |
| C64 | 22 µF | 16V | Polarised electrolytic | Power rail decoupling near RAM |
| C79 | 22 µF | 16V | Polarised electrolytic | Power rail filtering |
| C83 | 10 µF | 16V | Polarised electrolytic | Signal coupling / filtering |
| C95 | 470 µF | 16V | Polarised electrolytic | Main power supply bulk filter capacitor |
| C100 | 4.7 µF | 35V | Non-polarised (NP/bipolar) | RF modulator / video output signal coupling |
| C101 | 10 µF | 16V | Polarised electrolytic | Audio output stage filtering |
| C102 | 4.7 µF | 35V | Non-polarised (NP/bipolar) | Video signal coupling (chroma/luma) |
| C103 | 4.7 µF | 35V | Non-polarised (NP/bipolar) | Video signal coupling (composite output) |
| C115 | 10 µF | 16V | Polarised electrolytic | Voltage regulator output filtering |
Total: 13 electrolytic capacitors
Capacitor List — PAL (Rev A)
Total: 12 electrolytic capacitors (PAL Rev A lacks C79 compared to the NTSC Chelco Rev. 8A)
Differences Between Revisions
| Capacitor | NTSC Chelco Rev. 8A | PAL Rev A |
| C79 (22 µF / 16V) | Present | Absent |
| All others | Identical | Identical |
Other board revisions (e.g., NTSC Rev D, Chelco Rev 3) may have additional differences. If your board revision is not listed here, visually inspect and document all electrolytic capacitors before ordering replacements.
Recapping Procedure
Step 1: Preparation
- Power off the unit and disconnect all cables.
- Remove the four screws from the bottom case (Phillips head).
- Carefully separate the top and bottom case halves.
- Disconnect the keyboard ribbon cable from the motherboard.
- Remove the motherboard mounting screws and lift the board free of the case.
- Photograph the board to document the original capacitor locations and orientations.
Step 2: Capacitor Removal
- Identify each capacitor by its reference designator (printed on the PCB next to the component).
- Note the polarity orientation of each capacitor before removal — the negative stripe on the capacitor body should align with the PCB markings.
- Apply the soldering iron to one pad at a time while gently pulling the capacitor from the opposite side.
- Use solder wick or a solder sucker to remove excess solder from the through-holes.
- Clean the pad area with IPA to remove any flux residue or electrolyte leakage.
Step 3: Capacitor Installation
- Insert the new capacitor into the correct position, observing the correct polarity (positive lead to the "+" marked pad).
- For axial capacitors, ensure the leads are properly aligned with the pad spacing.
- Solder each lead with a clean, shiny joint. Avoid excessive heat — hold the iron to the pad for no more than 3 seconds.
- Trim excess leads flush with the solder joint.
- Visually inspect each joint for cold solder (dull, grainy appearance) or solder bridges.
Step 4: Post-Recapping Verification
- Visual inspection: Check all solder joints under magnification for cold joints, bridges, or lifted pads.
- Continuity test: Verify there are no short circuits between +5V and GND using a multimeter in continuity mode.
- Power-on test: Connect the power supply and verify the system boots normally.
- Voltage verification: Measure +5V at the CPU (pin 40 of U1) to confirm the power rail is clean and within spec.
- Audio test: Run the built-in self-test (hold OPTION during power-on) and verify the POKEY audio test produces clean tones.
- Video test: Check for clean, stable video output with correct colours.
Critical Capacitors
C95 — Main Bulk Filter (470 µF / 16V)
This is the most critical capacitor on the board. It filters the incoming +5V supply, smoothing out ripple and providing current reserve for transient loads. A failed C95 will cause:
- Voltage sag under load, leading to random crashes
- Increased ripple on the +5V rail, causing video noise (horizontal lines or "jail bars")
- System failing to boot entirely if the capacitor is shorted
Replacement recommendation: Use a 470 µF, 25V (or higher) capacitor rated for 105°C and low ESR.
C100, C102, C103 — Non-Polarised Video Coupling (4.7 µF / 35V NP)
These three non-polarised (bipolar) electrolytic capacitors are in the video output signal path. Failed capacitors here cause:
- Loss of colour output (black and white image)
- Weak or washed-out video
- No composite or RF video output
Important: These must be replaced with non-polarised (bipolar) electrolytic capacitors, not standard polarised types. Using polarised capacitors in these positions will result in degraded video quality and premature failure.
C44 — POKEY Audio Coupling (47 µF / 10V)
This capacitor is associated with the POKEY chip's audio output. A failed C44 causes:
- No audio output or very quiet audio
- Distorted or "buzzy" sound
- Clicking or popping from the speaker/audio output
Pre-Made Cap Kits
Pre-assembled capacitor kits for the Atari 600XL / 800XL are available from specialist suppliers such as Console5. These kits contain all necessary electrolytic capacitors pre-sorted by reference designator, using high-quality Nichicon, Rubycon, or Panasonic components.
When ordering, specify your board revision (NTSC Chelco Rev. 8A, PAL Rev A, etc.) to ensure the correct parts are included.
Related Pages
