Atari 600XL Troubleshooting Guide
Atari 600XL
Troubleshooting for the Atari 600XL, built on Atari's 600XL Computer Field Service Manual: its pin-assignment figures, symptom checklist, Super SALT error codes, parts list and schematic.[1]
Power supply and voltage checks
The 600XL has no voltage regulator on the board. The external supply, Atari part CA061982, takes 110 V AC and delivers +5 V DC ±2 %, 1.5 A maximum, through a 7-pin DIN (J4) with +5 V on pins 1, 4 and 6.[1] In volts that is 4.90–5.10 V.
On the board the 5 V passes through the power switch SW1 and splits into three filtered rails, +5A, +5B and +5C. For a black or grey screen Atari's checklist says to "verify all voltages +5A, B, C" on the PCB and to verify the 3.58 MHz frequency at Y1.[1]
Where to measure
Supply pins (Atari figures 1-3 to 1-6)
Device Location VCC pin Ground pin
6502C CPU U10 8 1 and 21
ANTIC U9 21 1
GTIA U17 27 3
POKEY U20 17 1
Pin 40 of the 6502C is RESET, not the supply; it idles high, so a reading there near 5 V says nothing about VCC.[1]
Rail low at the chips but correct at the connector
  1. Inspect the solder joints at J4 and the power switch SW1.
  2. Measure from the connector to the chip supply pins. The rails pass through ferrite beads, L1–L3 and L6–L8 in Atari's parts list.[1]
  3. Check the input reservoirs C95 and C96 (470 µF); see the Atari 600XL Capacitor Replacement Guide.
  4. Look for a short between +5 V and ground caused by a failed IC.
Chip map
Atari 600XL integrated circuits (FSM parts list, p. 5-7)
Location Device Atari part number
U1 74LS138 decoder C061428
U2 MMU 1B memory management unit C061618
U3 OS ROM, 16K × 8 (27128) C061598
U4 BASIC ROM Rev. B, 8K × 8 (2764) C060302
U5, U6 74LS158 multiplexer C014345
U7 74LS08 quad AND C017097
U8 LM358 dual op-amp C061702
U9 ANTIC, Rev. E C021697 (domestic), C021698 (international)
U10 6502C CPU C014806
U11, U12 DRAM, 16K × 4 C061505
U13 Delay module C060472
U14 74LS14 hex inverter C061850
U15 74LS375 latch C060613
U16 74LS51 AND-OR-invert C060474
U17 GTIA C014805
U18 74S32 quad OR C061622
U19 CD4050B hex buffer C010816
U20 POKEY C012294
U21 PIA C014795
U22, U23 CD4051B multiplexer C014336
Every position is socketed, from the 8-pin socket at U8 to the 40-pin sockets at U9, U10, U17, U20 and U21. Y1 is a 3.579545 MHz crystal, R43 the 500 kΩ colour trimpot, SW1 the power switch and SW2 the channel switch.[1]
Symptom checklist
Atari's table, reproduced in full.[1]
Atari 600XL symptom checklist (FSM section 3)
Symptom Possible causes Remedy
Snowy screen Switch box, DC power supply and ON/OFF switch, channel select switch, RF modulator, damaged RF cable Adjust or replace
Black/grey screen +5 V from supply; verify all voltages +5 A, B, C; verify Y1 Troubleshoot the power supply; verify 3.58 MHz at Y1
Green/yellow screen U1–U7, U11–U16 Repair or replace
Solid blue screen U1, U2, U4 Troubleshoot the BASIC ROM and its support circuit
No colour or bad colour U17, U19, Q6, Q1, CR1–CR2, Y1, RF modulator or TV tuner, R43, U8 Adjust or replace; RF modulator or colour adjustment
No power light Power LED, power supply, cables Repair or replace
No grey bars, or a missing bar U17, U19 Repair or replace
Upside-down alphanumerics on the player field U9 Replace
Some keyboard keys fail U20, keyboard, U22, U23, cable Repair or replace
All keyboard keys fail U20, U22, U23 Repair or replace
Tone or tones missing during tone test U20, 4.5 MHz audio carrier frequency, U8, TV volume Repair; adjust 4.5 MHz on the RF modulator
Console game switches will not function U17, switches, cable Repair or replace
ROM test failed U1–U4 Repair or replace
RAM test failed U1, U2, U5–U7, U11–U16, U18 Verify U18 is a 74S32; verify ANTIC is Rev. E (Tech Tip 20)
Video or ANTIC stress fail U7, U9 Repair or replace
I/O port test fail, joystick, paddle U20, U21, Q4, J1, J5, J6 Repair or replace
CPU test fail Y1, Q2, Q3, U10 Verify the 3.58 MHz oscillator frequency
2-way clock fail J1, U20 Repair or replace
External audio J1, U8 Repair or replace
GTIA fail U17 Replace
The I/O port, 2-way clock, external audio, joystick and paddle tests need the Super SALT extended hardware test module and jumper cables; the keyboard and console switch tests need someone to press the keys.[1]
U18 must be a 74S32, not a 74LS32. Atari's footnote to "RAM test failed" reads "MUST have correct IC's or RAM will fail."[1] Tech Tip 20 (17 August 1983) adds that early international machines, and possibly some domestic ones, were built with the wrong ANTIC and fail the Super SALT RAM test and software that turns the screen off; the international part is C021698 and the domestic part C021697, both at U9.[1]
The 16 KB is two 16K × 4 DRAMs, Atari part C061505, at U11 and U12 in 18-pin sockets.[1] U9 and U10 are ANTIC and the CPU. Atari's checklist widens a RAM failure to U1, U2, U5–U7, U11–U16 and U18, because the address multiplexers (U5, U6), the latch (U15) and the decoding logic are all in the path.[1]
The Atari 1064 memory module expands the 600XL to 64 KB, and some late 600XLs were sold with 64 KB fitted.[2] Software that needs 48 KB or 64 KB will not run on a standard 16 KB machine, so establish how much memory a machine has before treating a load failure as a fault.
Self test and Super SALT
Hold OPTION while switching on, with no cartridge and no powered disk drive, to run the built-in self test. It covers memory (RAM, ROM and ANTIC), audio-visual (ANTIC, GTIA and POKEY) and the keyboard (POKEY and ANTIC).[1]
Atari's field procedure used the Super SALT cartridge and its extended hardware test module, FA100332: a performance test, 2-way clock test, 6502 test, ANTIC stress test, bar and colour bar tests, GTIA diagnostic, I/O port test with a voltage check on each port, OS ROM checksum, RAM test, tone, video and external audio tests, joystick, keyboard and paddle tests and a maintenance mode, each documented screen by screen in section 2.[1] Error summaries are cleared by SYSTEM RESET and at power-up, so do not use SYSTEM RESET to return to the menu if you want accurate error reporting.[1]
Super SALT fatal system error codes (FSM p. 2-31)
Code Test in progress
04 Refresh check on pattern "FF"
05, 06 Address line check (could not get unique addresses using each line)
07 Data line check (one or more stuck high or low)
08 Refresh test in pattern "00"
09 RAM somewhere in page 0 or 1
10, 11 RAM failure in page 0 (about $004D–$007F)
17 RAM failure in page 0 (address $0038)
18 RAM failure in page 0 (address $0019)
97 Not enough stack entries present (same as 98)
98 Stack overflow or underflow
99 RAM error in page 1, or the system has taken a bad branch
Atari notes that codes 97, 98 and 99 relate to address decoding on ROM or RAM or to a bad CPU. Pot line failures in the error summaries decode as A, possible short to +5 V; B, time constant too long; D, time constant too short; E, both A and D.[1]
Parallel Bus Interface
The PBI is a 50-pin edge connector giving an unbuffered, direct connection to the address, data and control signals. Figure 1-12 gives the assignment:[1]
Atari 600XL PBI connector (Atari figure 1-12, looking into the computer)
Pin Signal Pin Signal
1 GND 2 EXTSEL' (external select)
3 A0 4 A1
5 A2 6 A3
7 A4 8 A5
9 A6 10 GND
11 A7 12 A8
13 A9 14 A10
15 A11 16 A12
17 A13 18 A14
19 GND 20 A15
21 D0 22 D1
23 D2 24 D3
25 D4 26 D5
27 D6 28 D7
29 GND 30 GND
31 Bø2 (phase 2 clock, output) 32 GND
33 Reserved 34 RST' (reset output)
35 IRQ (interrupt request input) 36 RDY (ready input)
37 Reserved 38 EXTENB (external decoder output)
39 Reserved 40 REF (refresh output)
41 CAS' (column address strobe output) 42 GND
43 MPD' (math pack disable input) 44 RAS' (row address strobe output)
45 GND 46 LR/W' (latched read/write output)
47 Reserved in figure 1-12; +5 V on the schematic 48 Reserved in figure 1-12; +5 V on the schematic
49 AUDIO IN 50 GND
Figure 1-12 marks pins 47 and 48 as reserved and not connected, but the schematic in the same manual ties both to the +5A rail.[1] The comp.sys.atari.8bit FAQ also lists them as +5 V on the 600XL and not connected on the 800XL.[2] Treat them as live +5 V when connecting or probing a PBI device.
Controller jacks
Both jacks are 9-pin D-type male connectors and are functionally and electrically identical.[1]
Atari 600XL controller jack (Atari figure 1-10)
Pin Function Pin Function
1 Joystick forward input 6 Trigger input
2 Joystick back input 7 +5 volts
3 Joystick left input 8 Ground
4 Joystick right input 9 A potentiometer input
5 B potentiometer input
Pin 7 is the only +5 V on the jack, so a joystick that stops the machine when it is plugged in is shorting that pin to ground.
Outside the computer
Rule these out before opening the case:
  • The power supply. Measure it unloaded, then under load if possible.
  • The SIO chain. Unplug everything from SIO and retest.
  • A cartridge. A cartridge in the slot takes precedence over the built-in BASIC by hardware, so dirty cartridge contacts can give blank screens and lock-ups. With the slot empty, a working 600XL starts in Atari BASIC Rev. B.[1]
  • The TV switch box and RF cable, which Atari's checklist puts first for a snowy screen.[1]
  • The monitor socket. North American 600XLs have none; PAL 600XLs have one, without separate luminance and chrominance.[2]
Sockets
Every IC in the 600XL is in a socket.[1] Before replacing anything, remove each socketed IC, clean the pins and reseat it, checking orientation.
Disassembly
Atari's sequence:[1]
  1. Turn the unit upside down and remove the four screws from the bottom cover.
  2. Turn it upright and tip the cover by raising the left side to reach the keyboard cable. Remove the keyboard cable from its socket and set the top aside.
  3. With a magnetic screwdriver, remove the screw reached through the RF shield at the top left.
  4. Remove the four remaining screws and lift out the PCB and RF shield together.
  5. Remove the six bolts and nuts from the RF shield.
  1. ↑ 1.00 1.01 1.02 1.03 1.04 1.05 1.06 1.07 1.08 1.09 1.10 1.11 1.12 1.13 1.14 1.15 1.16 1.17 1.18 1.19 1.20 1.21 1.22 Atari, Inc., ATARI 600XL Computer Field Service Manual, Rev. 1, FD100610, October 1983: section 1 (theory of operation and pin-assignment figures 1-3 to 1-12), section 2 (self test, Super SALT, error summaries and fatal error codes, pp. 2-1 to 2-31), section 3 (symptom checklist), section 4 (disassembly), section 5 (schematic and parts list) and section 6 (Tech Tip 20). Hosted on this wiki: Atari 600XL Field Service Manual (PDF).
  2. ↑ 2.0 2.1 2.2 Michael D. Current (ed.), comp.sys.atari.8bit Frequently Asked Questions, last modified 29 November 2009, sections 1.5, "What is the Atari 600XL?", and 1.16, port pinouts, faqs.org. Community reference for the PBI pins 47 and 48, the 1064 module, the 64K late machines and the monitor socket on PAL machines.
