IBM PC XT/370 Capacitor Replacement Guide
This guide documents capacitor diagnosis and replacement for the IBM PC XT/370. Because the XT/370 is mechanically an IBM PC XT (5160) chassis with three add-in 370PC cards, the capacitor topology is identical to a stock XT for chassis-level work — the canonical XT failure points (RIFA mains-suppression caps in the PSU and through-hole tantalum bypass caps on the planar) are the primary targets. The three 370PC cards each carry their own through-hole electrolytics that should be inspected separately.
Important Caveat
[edit | edit source]Per-board exact capacitor parts lists for the 370PC-P, 370PC-M, and PC3277-EM cards are not transcribed in any publicly accessible source that this guide author has located. The XT/370 cards are unique IBM products and their service documentation (SA38-0037-00 chapter 6) describes FRU-level replacement only — IBM expected service engineers to replace whole cards rather than re-component them. This guide therefore documents the typical late-1970s / early-1980s ISA card practice for capacitor recap; verify printed values on each cap before ordering replacements.
Safety Warning
[edit | edit source]The XT/370 uses the standard IBM 130 W switching PSU (Astec / Zenith) with mains-rectified bulk capacitors that hold a lethal charge after power-off. Before any PSU work:
- Power off and unplug the mains lead.
- Wait at least 30 seconds.
- Discharge each bulk capacitor through a 1 kΩ / 5 W resistor.
- Verify with a multimeter.
The integrated 5151 monochrome or 5153 CGA display (if a 5151-style cabinet is fitted) carries high voltage on the flyback transformer. Discharge the CRT anode to chassis ground via a high-voltage probe before any work on the deflection / flyback board.
Chassis-Level Capacitor Work
[edit | edit source]Identical to the IBM PC XT (5160) Capacitor Replacement Guide:
- RIFA-branded X / Y class mains-suppression capacitors in the PSU. These are the canonical failure target on any IBM PC family system of this era — replace immediately as a preventive measure regardless of visible condition. They vent over time, producing smoke, a fishy odour, and on rare occasions a small fire.
- PSU bulk filter electrolytics — 30+ years old; replace with 105 °C low-ESR equivalents.
- PSU secondary-side electrolytics — same.
- Planar through-hole tantalum bypass caps — diode-test each in-circuit; remove any showing close to 0 Ω.
For the full XT PSU and planar cap list refer to IBM PC XT (5160) Capacitor Replacement Guide.
370PC-P (Processor Card) Capacitors
[edit | edit source]The processor card carries the modified Motorola 68000 pair and the modified Intel 8087, plus glue logic. Typical capacitor types:
| Value | Voltage | Type | Position |
| 10 µF | 16 V | Tantalum bypass | Around the 68000 packages (multiple positions) |
| 10 µF | 16 V | Tantalum bypass | Around the modified 8087 |
| 47 µF | 16 V | Aluminium electrolytic | Card-edge +5 V bulk filter |
| 22 µF | 16 V | Tantalum bypass | Glue-logic ICs |
Failure mode of concern: tantalum short circuit. A shorted tantalum near the 68000 will pull down the +5 V rail and prevent the card from being detected by VM/PC. Diagnostic procedure:
- Multimeter on diode test.
- Probe each tantalum in-circuit: black to ground, red to +5 V rail.
- Good cap reads open / high resistance; shorted cap reads close to 0 Ω.
- Remove the shorted cap to confirm.
- Replace with a fresh tantalum or low-ESR ceramic of equal value, equal or higher voltage rating.
370PC-M (Memory Card) Capacitors
[edit | edit source]The 512 KB dual-ported memory card has more capacitance per board than the P card because of the DRAM array. Typical cap inventory:
| Value | Voltage | Type | Position | Quantity (approx) |
| 0.1 µF | 25 V | Ceramic decoupling | One per DRAM (32 positions for 32-chip 512 KB) | ~32 |
| 10–47 µF | 16 V | Tantalum or aluminium electrolytic | Bulk DRAM array decoupling | 4–6 |
| 100 µF | 16 V | Aluminium electrolytic | Card-edge +5 V bulk | 2 |
| 22 µF | 16 V | Tantalum bypass | Glue-logic ICs | 4–6 |
The per-DRAM ceramic caps rarely fail. The card-edge bulk caps and tantalum bypass caps are the more likely failure points after 40+ years.
PC3277-EM Card Capacitors
[edit | edit source]The 3277 Emulation Adapter is the smallest of the three cards and carries the BNC twinax interface to the host controller. Typical capacitor inventory:
| 10 µF | 16 V | Tantalum bypass | IC bypass throughout |
| 47 µF | 16 V | Aluminium electrolytic | Card-edge +5 V bulk |
| 22 µF | 16 V | Tantalum bypass | BNC interface circuit |
Recommended Modern Replacements
[edit | edit source]Same as for any IBM PC era restoration:
- Manufacturer: Panasonic FR / FM / FC, Nichicon HE / HZ (post-2007 date codes), Rubycon ZLH / ZLJ / YXJ, United Chemi-Con KZH / KZE.
- Avoid generic Chinese-brand electrolytics.
- 105 °C rated.
- Voltage equal or higher than original.
- Capacitance equal to original.
For tantalums:
- Vishay 593D / 595D or KEMET T491 / T494 — modern high-reliability tantalum.
- OR substitute with a low-ESR ceramic (X7R or X5R) of the same value — ceramics do not fail short and are a safer long-term choice for low-current bypass positions.
Recap Procedure
[edit | edit source]- Discharge the PSU bulk capacitors.
- Remove the chassis cover (5 rear screws, slide cover forward).
- Remove the three 370PC cards as a matched set — the backplane connector between 370PC-P and 370PC-M is sensitive; do not force.
- Photograph each card from both sides at high resolution.
- Mark each cap's polarity before desoldering.
- Desolder with solder wick. Limit each cycle to 5–7 seconds at no more than 350 °C.
- Fit replacements matching the silkscreen polarity.
- Solder both leads; inspect for clean fillets; trim flush.
- Reinsert cards as a matched set, ensuring the rear-edge backplane connector is fully seated.
Post-Recap Verification
[edit | edit source]- Power on with the original (uncapped) PSU first to verify chassis still POSTs cleanly.
- Once XT POST passes, reseat the three 370PC cards.
- Boot PC DOS 2.10.
- Load VM/PC.
- Verify VM/PC initialises the 370PC-P card (initialisation message).
- Verify VM/PC sees the 370PC-M card's full 512 KB (initialisation message).
- Connect to host mainframe; verify CMS prompt appears.
If any test fails after recap, re-inspect the polarity of every replaced cap before suspecting another fault.
Polarity Reference
When Not to Recap
[edit | edit source]If the XT/370 POSTs cleanly, DOS boots, VM/PC initialises the cards, host connection succeeds and CMS runs reliably with no instability, the caps are within tolerance.
Always recap if:
- RIFA-branded X / Y mains-suppression cap present in the PSU (preventive replacement).
- Visible cap failure on the planar, any 370PC card, or the PSU.
- PSU smoke, fishy odour or audible whine.
- System unstable when warm but stable when cold.
- 370PC card fails to be detected by VM/PC and reseating did not help (suspect a shorted tantalum on the card).
Related Pages
[edit | edit source]- IBM PC XT/370
- IBM PC XT/370 Maintenance Guide
- IBM PC XT/370 Troubleshooting Guide
- IBM PC XT (5160) Capacitor Replacement Guide — chassis-level cap work
- Capacitor Failure Symptoms
[edit | edit source]- IBM SA38-0037-00 (July 1989), Chapter 6.
- Retro Repairs and Refurbs — 1983 IBM PC 5160 (XT) Power Supply Rebuild. PSU rebuild reference applicable to the XT/370.
- Commonly Failing Electronic Components, minuszerodegrees.net.
