Atari ST Capacitor Replacement Guide
| Manufacturer | Atari Corporation |
| Type | Capacitor replacement guide |
| CPU | — |
| Memory | — |
| Storage | — |
| Display | — |
| Sound | — |
| OS / Firmware | — |
This guide provides complete capacitor lists and replacement procedures for the Atari 520ST, 520STM, 520STF, 520STFM, 1040ST, 1040STF, and 1040STFM computers. These machines share common motherboard designs — notably the C070789-001 board which is used in both the 520STFM and 1040STFM. Capacitor lists are organised by board revision, as the component count and values vary between revisions.
For the Atari STE range (520STE / 1040STE), see Atari STE Capacitor Replacement Guide.
When to Recap
With these machines now 35–40 years old, electrolytic capacitors are the most common point of failure. Symptoms of failing capacitors include:
- Unstable or low +5V supply voltage (PSU caps)
- Random crashes or freezes
- Screen dimming when the floppy drive is accessed (PSU peak power)
- Audio distortion, hum, or crackling
- Floppy read/write errors
- Video noise, ghosting, or wavy lines
The PSU should be recapped as a first priority, as failing PSU capacitors can cause symptoms that mimic motherboard faults. Motherboard recapping is a secondary priority — the axial electrolytic capacitors used on ST motherboards (often Wang's brand) have generally proven durable, but replacement is recommended as preventive maintenance.
Safety Warning
The internal PSU (1040ST/STF/STFM models) contains mains-voltage components. Capacitors on the high-voltage side of the PSU can retain lethal charge even after the machine is unplugged. Only qualified individuals should service the PSU. Allow at least 5 minutes after unplugging before touching any PSU components.
Tools Required
- Temperature-controlled soldering iron (chisel tip recommended, 350–370°C)
- Solder sucker and/or desoldering braid
- Quality replacement capacitors (Nichicon, Rubycon, Panasonic recommended; low-ESR types for PSU)
- Digital multimeter for post-recap voltage verification
- Isopropyl alcohol (99%+) and brush for flux cleanup
Motherboard Capacitor Lists
Identify your motherboard revision by the part number printed on the PCB. The following lists cover all known ST/STF/STFM motherboard revisions.[1]
C070243 Rev B (520ST / 520STM)
Early short-case board used in the 520ST and 520STM.
| Ref. Designator | Capacitance | Voltage | Type | Notes |
| C31 | 1 µF | 50V | Electrolytic | |
| C33 | 47 µF | 25V | Electrolytic | |
| C34 | 1 µF | 50V | Electrolytic | |
| C50 | 22 µF | 16V | Electrolytic | |
| C55 | 22 µF | 16V | Electrolytic | |
| — | 470 µF | 16V | Electrolytic | Not designated on silkscreen |
| KBD | 100 µF | 25V | Electrolytic | Keyboard controller board |
C070243 Rev C (520ST)
| C31 | 100 µF | 25V | Electrolytic | |
| C34 | 47 µF | 16V | Electrolytic | |
| C?? | 470 µF | 16V | Electrolytic | Designator unclear on PCB |
| C105 | 22 µF | 16V | Electrolytic | |
| — | 470 µF | 16V | Electrolytic | Not designated |
| KBD | 100 µF | 25V | Electrolytic, axial | Keyboard controller board |
C070243 Rev H (520ST / 520STM)
| C31 | 100 µF | 16V | Electrolytic | |
| C33 | 47 µF | 16V | Electrolytic | |
| C56 | 470 µF | 16V | Electrolytic | May be marked C56 or unmarked |
| C104 | 470 µF | 16V | Electrolytic | |
C070523-001 Rev B / Rev C (1040STF)
Earlier 1040STF-specific board design.
| C7 | 22 µF | 16V | Electrolytic | |
| C8 | 22 µF | 16V | Electrolytic | |
| C9 | 47 µF | 16V | Electrolytic | |
| C12 | 1 µF | 50V | Non-polarised | 25V replacement acceptable |
| C14 | 1 µF | 50V | Non-polarised | 25V replacement acceptable |
| C25 | 4.7 µF | 25V | Electrolytic | |
| C27 | 4.7 µF | 25V | Electrolytic | |
| C29 | 4.7 µF | 35V | Non-polarised | 25V replacement acceptable |
| C30 | 4.7 µF | 25V | Electrolytic | |
| C35 | 470 µF | 16V | Electrolytic | |
| C48 | 100 µF | 25V | Electrolytic | |
| C71 | 22 µF | 16V | Electrolytic | |
| C105 | 470 µF | 16V | Electrolytic |
C070523-001 Rev D (1040STF / 520STFM)
Applies to Rev D boards with a large 2200 µF cap at C35.
| C12 | 100 µF | 16V | Electrolytic | |
| C14 | 47 µF | 16V | Electrolytic | |
| C35 | 2200 µF | 16V | Electrolytic | Large axial or radial cap |
| C105 | 470 µF | 16V | Electrolytic | |
| — | 100 µF | 16V | Electrolytic | Add-on above C41 (not soldered to C41 pads) |
C070789-001 Rev C / Rev F (520STFM / 1040STFM)
This is the most commonly encountered board revision. It is shared between the 520STFM and 1040STFM — the only difference is RAM population (512 KB vs 1 MB). Also compatible with Rev B, Rev D, and Rev F2 boards based on board photos.[1]
| C2 | 22 µF | 16V | Electrolytic | |
| C11 | 100 µF | 16V | Electrolytic | |
| C12 | 47 µF | 16V | Electrolytic | |
| C22 | 100 µF | 16V | Electrolytic | |
| C49 | 1000 µF | 16V | Electrolytic | Main bulk decoupling |
| C70 | 100 µF | 16V | Electrolytic | |
| C73 | 100 µF | 16V | Electrolytic | |
| C74 | 4.7 µF | 35V | Non-polarised | Radial replacement provided in kits |
| C75 | 4.7 µF | 35V | Electrolytic | |
| C92 | 100 µF | 16V | Electrolytic | |
| C148 | 100 µF | 16V | Electrolytic | |
| C149 | 4700 µF | 16V | Electrolytic | Large main filter capacitor |
| C215 | 1 µF | 50V | Electrolytic | Audio path |
| C216 | 10 µF | 16V | Electrolytic | Audio path |
| C217 | 10 µF | 16V | Electrolytic | Audio path |
| C218 | 10 µF | 16V | Electrolytic | Audio path |
| C219 | 33 µF | 16V | Electrolytic | Audio path |
| C220 | 100 µF | 16V | Electrolytic | Audio path |
| C221 | 100 µF | 16V | Electrolytic | Audio path |
| C223 | 470 µF | 16V | Electrolytic |
Total: 22 electrolytic capacitors on the motherboard.
C103225 Rev 1 / Rev 2 (1040STFM)
Late-production board.
| C49 | 1000 µF | 16V | Electrolytic | |
| C74 | 4.7 µF | 35V | Non-polarised | |
C103572 Rev 1 (1040STFM)
Final production board. Identical to C103225 but with one additional cap:
| C149 | 4700 µF | 16V | Electrolytic | |
| C190 | 100 µF | 16V | Electrolytic | Additional cap not present on C103225 |
PSU Capacitor Lists
The 1040ST's internal PSU is the most failure-prone component. The 520ST uses an external PSU that is generally more reliable but should still be checked. Below are lists for the most common internal PSU models found in the 1040STF and 1040STFM.
Mitsumi SR98 / SR118 / 68-4231A (220–240V)
The most common PSU in European 1040STs. Main switching transistor: 2SC2979 (800V, 3A, 40W).[2]
| Ref. Designator | Original Value | Voltage | Recommended Replacement | Notes |
| C104 | 47 µF | 400V | 68 µF 400V | High-voltage primary filter |
| C201 | 2200 µF | 10V | 4700 µF 16V | Secondary filter |
| C202 | 2200 µF | 16V | 4700 µF 16V | Secondary filter |
| C203 | 2200 µF | 10V | 4700 µF 16V | Secondary filter |
| C204 | 1000 µF | 16V | 1500 µF 16V | Secondary filter |
| C205 | 1000 µF | 10V | 1500 µF 16V | Secondary filter |
| C206 | 1 µF | 50V | 1 µF 50V ceramic | Feedback loop; consider ceramic replacement |
Also recommended: Replace the bridge rectifier with a KBU1005 (10A, 600V) or similar higher-rated part. The original 2A rectifier is marginal.[2]
Mitsumi SR97 / 68-4242A (110–120V)
US market PSU.
| C104 | 220 µF | 200V | 220 µF 200V | Primary filter |
| C201 | 2200 µF | 16V | 4700 µF 16V | |
| C202 | 2200 µF | 10V | 4700 µF 16V | |
| C203 | 1000 µF | 16V | 1500 µF 16V | |
| C204 | 2200 µF | 10V | 4700 µF 16V | |
| C205 | 1000 µF | 10V | 1500 µF 16V | |
| C206 | 1 µF | 50V | 1 µF 50V |
ASTEC ASP34 / ASPF34 (220–240V)
Common European PSU with BU508A main transistor. Multiple sub-revisions (Rev 1–6) exist with minor differences.[1]
| C4 | 47 µF | 250V | 47 µF 250V | Primary filter |
| C5 | 47 µF | 250V | 47 µF 250V | Primary filter |
| C7 | 330 µF | 25V (or 35V) | 680 µF 35V | Secondary |
| C9 | 100 µF | 25V | 100 µF 25V | |
| C12 | 2200 µF | 16V | 4700 µF 16V | |
| C13 | 4700 µF | 16V | 4700 µF 16V | |
| C14 | 330 µF | 25V (or 35V) | 680 µF 35V | |
| C15 | 330 µF | 25V (or 35V) | 680 µF 35V |
DVE DSP-508A / DSP-508AA (220–240V)
Uses BU508A transistor. Generally good regulation even with aged caps.[2]
| C3 | 47 µF | 250V | 47 µF 250V | Primary |
| C4 | 47 µF | 250V | 47 µF 250V | Primary |
| C8 | 330 µF | 25V | 680 µF 25V | |
| C9 | 1 µF | 50V | 1 µF 50V | |
| C?? | 100 µF | 25V | 100 µF 25V | In shrinkwrap near safety cap at board top |
| C20 | 330 µF | 25V | 680 µF 25V | |
| C22 | 2200 µF | 16V | 4700 µF 16V | |
| C23 | 330 µF | 25V | 680 µF 25V | |
| C25 | 2200 µF | 16V | 4700 µF 16V |
FPK-N3 5657-B001-1
| Ref. Designator | Capacitance | Voltage | Notes |
| C5 | 220 µF | 200V | Primary |
| C8 | 47 µF | 16V | |
| C9 | 47 µF | 16V | |
| C101 | 470 µF | 25V | |
| C102 | 470 µF | 25V | |
| C103 | 100 µF | 25V | |
| C201 | 2200 µF | 10V | |
| C202 | 2200 µF | 10V | |
| C203 | 470 µF | 10V | |
| C205 | — | — | Empty position on PCB |
| C303 | 1 µF | 50V |
C070091-014 / Model 1103 (520ST External PSU)
Designators not available for this external PSU. Replace by value:
| Capacitance | Voltage | Quantity |
| 4700 µF | 16V | 1 |
| 2200 µF | 25V | 1 |
| 100 µF | 25V | 1 |
| 220 µF | 25V | 1 |
| 10 µF | 25V | 1 |
Internal Floppy Drive Capacitors (1040ST)
The 1040ST's internal floppy drive (commonly the TDK D357 / T41V) also contains electrolytic capacitors that can fail:
| Capacitance | Voltage | Quantity | Notes |
| 22 µF | 16V | 2 | |
| 47 µF | 16V | 2 | |
| 10 µF | 25V | 1 | |
| 4.7 µF | 35V | 1 | |
| 2.2 µF | 50V | 1 | |
| 0.47 µF | 50V | 5 | May be film or ceramic on some drives |
| 3.3 µF | 50V | 1 |
Replacement Procedure
General Tips
- Always note polarity before removing old caps. The negative stripe on the capacitor body and the polarity markings on the PCB silkscreen should match. If the silkscreen is unclear, photograph the board before starting.
- Use quality replacement capacitors. Panasonic FR series, Nichicon, and Rubycon are recommended. Avoid cheap unbranded capacitors, particularly for the PSU — poor ESR characteristics can cause the PSU to malfunction or even damage components.
- Axial to radial conversion: Many ST motherboard caps are axial (leads from each end). Modern replacements are commonly radial (both leads from the same end). Radial caps can be used in axial positions by bending the leads appropriately, or by mounting them upright.[1]
- Non-polarised (NP) capacitors: Several positions (notably C74 on the C070789-001 board and C29 on the C070523-001 board) require non-polarised electrolytic capacitors. These can be replaced with bipolar/non-polarised electrolytics or with appropriately rated film capacitors.
PSU Recap Procedure (1040ST)
- Unplug the machine and wait at least 5 minutes.
- Remove the top case and disconnect the PSU from the motherboard.
- Remove the PSU from the case (typically held by screws and/or clips).
- Remove the metal PSU shield (if present) — usually held by bent tabs.
- Photograph the PCB before starting, noting all capacitor polarities and positions.
- Desolder each capacitor one at a time, clean the pads, and solder in the replacement.
- For the bridge rectifier replacement: The replacement may have a different pinout. Triple-check the + and − markings match the PCB before powering on. An incorrectly installed rectifier will destroy the PSU.
- Reassemble the PSU shield and reinstall in the case.
Motherboard Recap Procedure
- With the machine open and PSU disconnected, work through each capacitor position.
- Desolder the old cap, clean the pads with desoldering braid, and solder in the replacement.
- Pay attention to the large C149 (4700 µF on C070789-001 boards) — this is a physically large cap and removing it cleanly requires adequate desoldering.
- After completing all replacements, clean the board with IPA to remove flux residue.
Post-Recap Voltage Checks
After recapping, verify the following before reconnecting any peripherals:
| Test Point | Expected Value | Tolerance | Notes |
| +5V at motherboard power header | 5.00V | ±0.25V | Measure with machine powered on and under normal load. Adjust PSU trim pot if available. |
| +12V at motherboard power header | 12.0V | ±1.0V | Needed for floppy and RS-232. |
| +5V ripple (oscilloscope) | <200 mV pk-pk | — | Indicates healthy PSU caps. >500 mV indicates a problem remains. |
| +5V at CPU VCC pin | 4.90V – 5.10V | — | Check for excessive voltage drop from power header to CPU. |
If the PSU has a voltage adjustment trimmer (present on some Mitsumi and ASTEC models), set the +5V output to 5.00V–5.10V under load. Do not exceed 5.25V.
Sourcing Capacitor Kits
Pre-assembled capacitor kits for specific board revisions are available from:
- Console5 (console5.com) — Kits for most ST motherboard and PSU revisions
- exxos (exxosforum.co.uk/atari/store2) — PSU recap kits and replacement PSU boards
When sourcing individual capacitors, use reputable suppliers (Farnell/Element14, Mouser, Digikey, RS Components) to avoid counterfeit or low-quality parts.
Related Pages
- Atari 520ST
- Atari 1040ST
- Atari ST General Maintenance
- Atari ST Troubleshooting Guide
- Atari STE Capacitor Replacement Guide
