Atari 1200XL
Revision as of 20:09, 29 March 2026 by Josh (talk | contribs) (Creating article: Atari 1200XL)
Atari 1200XL
Atari 1200XL home computer
ManufacturerAtari, Inc.
TypeHome Computer
ReleasedDecember 1982 (announced); March 1983 (shipped)
DiscontinuedJune 1983
Intro priceUS$899 (launch), reduced to US$299
CPUMOS Technology 6502C (SALLY) @ 1.79 MHz (NTSC only)
Memory64 KB RAM, 16 KB ROM (two 8 KB ร— 8 ROMs)
StorageExternal cassette tape (Atari 1010), optional 5.25" floppy disk drive (Atari 1050)
Display320ร—192 pixels (max), 40ร—24 text, 16 colours (ANTIC/GTIA)
SoundPOKEY: 4 voices, 8-bit mono
Dimensions47 cm ร— 25.4 cm ร— 7.6 cm (18.5" ร— 10" ร— 3")
Weight2.7 kg (6 lbs)
OS / FirmwareAtari OS Rev. 10 / Rev. 11 (no built-in BASIC)
PredecessorAtari 800
SuccessorAtari 800XL
CodenameSweet-16 (derived)
Model no.CX5-1200
The Atari 1200XL is a home computer manufactured by Atari, Inc., announced on December 13, 1982, and shipped in March 1983.[1] It was the first model in Atari's XL series, intended to replace the Atari 800. The 1200XL introduced a redesigned low-profile case styled by industrial designer Regan Cheng, four programmable function keys (F1โ€“F4), a dedicated HELP key, two status indicator LEDs, and a built-in self-test diagnostic.[2]
Despite its improved aesthetics, the 1200XL was commercially unsuccessful. Software incompatibilities caused by the revised Rev. 10 operating system ROM, the reduction from four to two joystick ports, the lack of a Parallel Bus Interface (PBI), and the absence of built-in BASIC all drew criticism.[3] The +12V pin on the SIO port was disconnected, preventing some older peripherals from operating. The chroma signal was not connected to the monitor jack, limiting composite monitor output quality.
The 1200XL was sold only in North America (NTSC); no PAL version was produced. After poor sales, the price dropped from US$899 to US$299 over the course of 1983. Atari discontinued the 1200XL in June 1983 and replaced it with the Atari 600XL and Atari 800XL.[4]
The 1200XL uses the MOS Technology 6502C (SALLY variant) microprocessor, running at 1.79 MHz (NTSC). The SALLY variant includes a HALT input (pin 35) that allows the ANTIC display processor to halt the CPU and take control of the address and data buses for direct memory access during display generation.[5]
The CPU is supported by four custom Atari chips:
  • ANTIC (C012296) โ€“ Alphanumeric Television Interface Controller. A programmable display microprocessor with its own instruction set for graphics generation. Controls bus access, RAM refresh, and generates display lists.
  • GTIA (C014805) โ€“ Graphics Television Interface Adaptor. Generates colour and luminance signals from display data received from ANTIC. Handles player/missile (sprite) graphics, collision detection, console switches, and keyboard click output.
  • POKEY (C012294) โ€“ POT Keyboard Integrated Circuit. Provides four-channel audio generation, serial I/O (SIO) control, paddle controller scanning, random number generation, and keyboard matrix scanning.
  • PIA (6520-equivalent) โ€“ Peripheral Interface Adaptor. General-purpose parallel I/O chip handling joystick port inputs, LED control outputs, motor control, and command signals.
Memory and Storage
The 1200XL contains:
  • 64 KB RAM โ€“ organised as eight 64Kร—1 DRAM chips (4164-type), one per data line (U1โ€“U9, with U7 as address decoding). 48 KB is directly available to programs, with the remaining 16 KB shared with ROM and I/O address space, accessible via bank switching controlled by the MMU.
  • 16 KB ROM โ€“ two 8Kร—8 ROM chips (U12, U13) containing the operating system. Atari OS Rev. 10 shipped initially; some later units received Rev. 11 with partial compatibility fixes.
BASIC is not included in ROM. Users must load BASIC from a cartridge, cassette, or disk.
Storage options:
  • Atari 1010 Program Recorder โ€“ cassette tape drive, connected via SIO.
  • Atari 1050 Floppy Disk Drive โ€“ external 5.25" floppy drive, connected via SIO.
  • Cartridge slot โ€“ single left-side slot (30-pin edge connector) for ROM cartridges up to 16 KB.
Memory Management
Address decoding uses a Hard Array Logic (HAL) chip, a 3-to-8 decoder, and supporting gates. The inputs are address lines A8โ€“A15 and control signals including ROM enable (from PIA) and Refresh. The outputs provide chip selects for GTIA, POKEY, PIA, OS ROM, RAM, and cartridge, plus COMM A, COMM B, and COMM C signals.
Display and Graphics
Graphics are handled by the ANTIC and GTIA chips:
  • Resolution: up to 320ร—192 pixels (bitmap mode)
  • Text: 40 columns ร— 24 rows (default)
  • Colours: up to 16 on screen, from a palette of 256 hues across 16 luminance levels
  • Player/Missile Graphics: 4 players (sprites) and 4 missiles, with collision detection and priority control
  • Graphics modes 12โ€“15: GTIA-specific modes available via BASIC on the 1200XL
  • Smooth scrolling and fine control over display lists, enabling split-screen and mixed-mode graphics
The 1200XL's video output circuit provides enhanced chroma for a more colourful RF image. However, the chroma line is not connected to the 5-pin DIN monitor jack, limiting monitor output to composite video and luminance only. The monitor connector pinout is:
Pin Signal
1 Composite luminance
2 Ground
3 Audio output
4 Composite video
5 Ground
Sound Capabilities
Audio is generated by the POKEY chip (C012294):
  • 4 independent voices (channels), each with 8-bit resolution
  • Programmable frequency, volume, and distortion per channel
  • White noise generation for percussion and sound effects
  • Audio output is routed to the RF modulator and to the monitor jack (pin 3)
  • Keyboard click sound is output through the TV/monitor speaker (via GTIA S3 line), unlike the Atari 800 which used an internal speaker
Input/Output and Expansion
The 1200XL provides the following interfaces:
Serial I/O (SIO) Port
A 13-pin connector for daisy-chaining peripherals (disk drives, printers, modems, cassette drives). Maximum baud rate: 19,200. The +12V pin (pin 12) is not connected on the 1200XL, which prevents RS-232 adapter devices that relied on this voltage from functioning without an external power source.
Controller Jacks
Two 9-pin D-type connectors (reduced from four on the Atari 800). Compatible with Atari joysticks and paddle controllers. Each port provides four digital directional inputs, a trigger input, and two analogue (pot) inputs.
Cartridge Slot
A single 30-pin edge connector on the left side of the case (moved from the top on the 800). Supports 8 KB and 16 KB ROM cartridges.
Monitor Jack
5-pin DIN connector providing composite video, luminance, audio, and ground. Chroma is not connected (see Display section).
RF Output
Switchable between channel 2 and channel 3 via a rear-panel slide switch (SW3). RF cable is detachable.
Absent Interfaces
The 1200XL lacks:
  • Parallel Bus Interface (PBI) โ€“ present on the later 600XL and 800XL
  • Composite chroma output on the monitor jack
  • +12V on the SIO bus
Design and Features
The 1200XL's case was designed by Regan Cheng and uses a low-profile aluminium and smoked plastic construction. It contains a single motherboard (replacing the multi-board design of the 400/800), with upper and lower RF shields secured by push rivets.
Keyboard
A full-stroke 62-key keyboard with mylar membrane contact layer. The keyboard connects to the motherboard via a 15-conductor ribbon cable with a Molex connector. Keys include standard alphanumeric characters, special characters, and controls.
Function Keys
Eleven function keys are arranged above the keyboard on brushed aluminium nameplates:
  • RESET โ€“ interrupts and restarts the operating system or cartridge
  • START โ€“ starts a game or program
  • SELECT โ€“ selects different games or options
  • OPTION โ€“ chooses among program variations
  • F1โ€“F4 โ€“ four user-programmable function keys (default: cursor movement in BASIC)
  • HELP โ€“ displays the built-in self-test options
  • INVERSE VIDEO (labelled "S") โ€“ toggles inverse video
  • BREAK โ€“ program interrupt
Status LEDs
Three LEDs behind a translucent plexiglass strip above the function keys:
  • POWER โ€“ lit when the unit is powered on
  • L1 โ€“ lights when the keyboard is disabled (F1 function)
  • L2 โ€“ lights when the international character set is selected (F3 function)
The LED board connects to the motherboard via a 5-conductor ribbon cable.
Built-in Self Test
Accessed by pressing HELP during the power-on logo display. Tests include:
  • Memory Test โ€“ tests ROM (two 8K bars) and RAM (48 blocks of 1 KB each). Green = pass, Red = fail.
  • Audio Visual Test โ€“ plays a six-note sequence across all four POKEY channels, with musical staff display.
  • Keyboard Test โ€“ displays a keyboard graphic; pressed keys highlight in inverse video.
  • All Tests โ€“ runs all three tests in sequence.
Easter Egg
During the keyboard self-test in "All Tests" mode, the test spells out "Michael Colburn," the programmer's name. This was removed in the later 600XL and 800XL.
Power Supply
The 1200XL uses a linear power supply with the regulator electronics on the motherboard. An external step-down transformer (the "ingot" power adaptor, part CA017964) converts 115 VAC mains to 9 VAC, which enters through a rear-panel power jack. On the motherboard, the 9 VAC is rectified by a bridge rectifier (CR8, MDA 990-2) and regulated by two 78M05 voltage regulators (A1, A2) to produce a single +5 VDC rail at 1.7 A maximum.
The DC output specification is +5V ยฑ5% (4.75Vโ€“5.25V). Input power consumption is 31 VA.
Unlike the Atari 800 (which provided +5V and +12V), the 1200XL generates only +5V.
For detailed maintenance practices including cleaning, connector care, and common failure points, refer to the dedicated Atari 1200XL General Maintenance page.
A comprehensive troubleshooting guide addressing power, video, RAM, and keyboard issues with component-level diagnostics is available on the Atari 1200XL Troubleshooting Guide page.
Detailed capacitor replacement guidelines with a full component list and post-recap voltage verification procedures can be found on the Atari 1200XL Capacitor Replacement Guide page.
Sub-system Specification (Atari 1200XL, 1983)
CPU MOS Technology 6502C (SALLY) @ 1.79 MHz
Bus width 8-bit data โ€ข 16-bit address (64 KB addressable)
ROM 16 KB (two 8K ร— 8 ROMs, OS Rev. 10/11)
RAM 64 KB (eight 4164 64Kร—1 DRAMs)
Video ANTIC C012296 + GTIA C014805, up to 320ร—192, 256-colour palette
Sound POKEY C012294, 4 voices, 8-bit mono
I/O PIA (6520), HAL (MMU)
Storage External SIO (cassette, floppy), cartridge slot
Ports SIO ร— 1, Joystick ร— 2, Cartridge ร— 1, Monitor (DIN-5), RF out
Power +5 VDC only (1.7 A max), 9 VAC input via external transformer
Key IC Locations
Atari 1200XL Motherboard IC Map
Location Component Function
U1โ€“U9 (excl. U7) 4164 DRAM 64 KB RAM (one chip per data line, D0โ€“D7)
U12, U13 8K ร— 8 ROM Operating System
U14 HAL Memory Management / Address Decoding
U19 GTIA (C014805) Graphics / Colour Generation
U20 ANTIC (C012296) Display Processor
U22 6502C (SALLY) CPU
U23 PIA (6520) Peripheral Interface
U24 POKEY (C012294) Audio / Keyboard / Serial I/O
A1, A2 78M05 +5V Voltage Regulators
A3 RF Modulator TV Signal Output
CR8 MDA 990-2 Bridge Rectifier
  1. โ†‘ Atari 1200XL computer, OldComputers.netโ€”link(accessed 2026-03-29)
  2. โ†‘ Atari 8-bit computers, Wikipediaโ€”link(accessed 2026-03-29)
  3. โ†‘ Atari 1200XL - the New Computer, ANTIC Magazine, February 1983โ€”link(accessed 2026-03-29)
  4. โ†‘ Atari 1200XL Home Computer Field Service Manual Rev 01, Atari, Inc., February 1983โ€”link(accessed 2026-03-29)
  5. โ†‘ Atari 1200XL Field Service Manual โ€“ Theory of Operation, Atari, Inc., February 1983โ€”link(accessed 2026-03-29)
