Atari 1200XL Capacitor Replacement Guide
This is the capacitor list and recapping procedure for the Atari 1200XL. Every value, voltage rating and part number below is from the parts list in Atari's field service manual for the machine.[1] The hosted scan of that manual does not include the schematics, so the list gives each part's value but not its place in the circuit.
The 1200XL takes 9 V AC from an external transformer and rectifies and regulates it on the main board, so unlike the 600XL and 800XL it has a large filter capacitor and two regulators of its own.[1] See Atari 1200XL General Maintenance#Power supply for the supply.
Visual inspection
[edit | edit source]Before removing anything, look for:
- bulging or split ends on the electrolytics;
- dried electrolyte or brown staining on the board around their leads;
- corroded or broken leads;
- heat discolouration around the regulators A1 and A2 and the bridge rectifier CR8.
A capacitor can have lost capacitance or gained ESR without any visible sign. An ESR meter finds these. See Capacitor Failure Symptoms.
Before replacing anything, measure the transformer on the AC range and the output of each regulator (see Checks after recapping); a fault in the supply shows there first. On his Atari Projects site Jason Moore reports that the original electrolytics in Atari 8-bit computers do not fail often, though some do.[2]
Electrolytic capacitors
[edit | edit source]Atari's parts list has thirteen electrolytic capacitors on the main board, in four values. The list is for PCB/RFI shield assembly CA061074 and names no board revision, and Atari notes that "minor variations in design may be encountered depending upon the production date of the console".[1]
| Designators | Value | Rating | Description in the parts list | Atari part number |
| C39 | 10,000 µF | 16 V | Cap. 10000uF (16V) | C060603 |
| C7, C51, C52 | 47 µF | 10 V | Cap. Alum Elec Axial | 24-100476 |
| C40, C41, C54, C93, C99, C102, C155 | 22 µF | 16 V | Cap. Alum Elec Axial | C014393 |
| C115, C162 | 10 µF | 16 V | Cap. Alum Elect Axial | C014371 |
The parts list does not describe C39's construction. The 47 µF, 22 µF and 10 µF parts are axial.
Between C1 and C162 the parts list has no entry for C6, C33, C38, C43–C46, C49, C50, C53, C62, C69–C71, C92, C94, C101, C107, C108, C146 or C156–C161. Without the schematic the scan does not show whether those positions are empty on the board or simply missing from the list, so check the board before ordering.[1]
Other capacitors
[edit | edit source]The rest of the board's capacitors are ceramics and small non-electrolytic parts. They rarely need replacing but are listed for board-level repair.[1]
| Designators | Value | Rating | Description | Atari part number |
| C1 | 68 pF | not stated | Ceramic axial | C014179-12 |
| C2–C5, C8, C10–C12, C14–C25, C30–C32, C34, C48, C55–C59, C68, C95, C100 | 0.1 µF | 25 V | Ceramic axial | C014181-03 |
| C9, C98 | 270 pF | 25 V | Type not stated | C061336-02 |
| C13, C35, C64–C67, C72–C91, C103–C106, C109–C114, C120–C145, C147, C148, C151–C154 | 0.001 µF | 25 V | Ceramic axial | C014181-01 |
| C26–C29 | 0.047 µF | 25 V | Ceramic axial | C014180-09 |
| C36, C37, C149, C150 | 0.01 µF | 100 V | Type not stated | C061337-01 |
| C42, C47 | 0.01 µF | 25 V | Ceramic axial | C014181-02 |
| C60, C118 | 100 pF | 25 V | Ceramic axial | C014179-19 |
| C61 | 150 pF | 25 V | Ceramic axial | C014179-09 |
| C63 | 390 pF | 25 V | Ceramic axial | C014180-10 |
| C96, C97 | 820 pF | 25 V | Ceramic (see tech tip 15 below) | C061336-03 |
| C116 | 6800 pF | 25 V | Ceramic axial | C014180-12 |
| C117 | 1500 pF | 25 V | Ceramic axial | C014180-15 |
| C119 | 3.9 pF | 25 V | Type not stated | C061336-01 |
Atari's changes to the capacitor list
[edit | edit source]Two of Atari's tech tips for the 1200XL change capacitors. Both apply only to machines showing the fault.[1]
- Tech tip 15 (7 June 1983) deals with audio frequency drift. Where the sound is poor, missing, or needs constant readjustment, replace the ceramic 820 pF capacitors C96 and C97 in the audio oscillator with polystyrene 820 pF 25 V parts (Atari C018261, alternate C010821).
- Tech tip 19 (15 August 1983) deals with machines that show no picture with the Star Raiders cartridge, because the reset timing to the 6502 is wrong for that cartridge. Solder a 0.001 µF NPO 50 V capacitor (C014181-01) between pins 3 and 7 of U16.
A machine that has been through Atari service may already have these changes.
Replacement procedure
[edit | edit source]- Unplug the transformer and wait a few minutes for the board to discharge.
- Turn the console upside down and remove the six screws holding the bottom cover to the top cover. Lift out the bottom cover with the board and turn it right side up.[1]
- Remove the six screws holding the board, and lift the board and cartridge connector out of the bottom cover.[1]
- Remove the eleven push rivets from the shields, then separate the top and bottom shields and the fish paper, taking care not to damage the board.[1]
- Photograph the board and note the polarity mark of every electrolytic before removing anything. On axial parts the band marks the negative lead.
- Desolder one part at a time, clean the holes, and fit the replacement with the same polarity. Use the same capacitance and an equal or higher voltage rating, and check that the new C39 fits under the shield.
- Inspect every joint, then check with a meter that there is no short between +5 V and ground before applying power.
- Reassemble in reverse: top shield upside down on the bench, board upside down on it, fish paper in the bottom shield, then the bottom shield on top, keeping the adjustment holes clear; eleven rivets, then the board into the bottom cover with six screws.[1]
[edit | edit source]Atari specifies the supply as 9 V AC in, 31 VA, and 5 V ±5 % (1.7 A maximum) at the output of each regulator.[1]
| Test point | Expected |
| Transformer output, meter on AC | 9 V AC |
| Output of regulator A1 | 4.75–5.25 V DC |
| Output of regulator A2 | 4.75–5.25 V DC |
| 6502 (U21) pin 8, VCC, to pin 1 or 21, ground | +5 V |
Then run the self test: press HELP while the power-on logo is on screen, with no cartridge fitted, and run the Memory, Audio Visual and Keyboard tests.[1] If the colour or sound has shifted, VR1 (colour) and the sound adjustment can be reached through the top or bottom cover.[1]
[edit | edit source]- Atari 1200XL
- Atari 1200XL General Maintenance
- Atari 1200XL Troubleshooting Guide
- Capacitor Failure Symptoms
- Recommended Tools
[edit | edit source]- ↑ 1.00 1.01 1.02 1.03 1.04 1.05 1.06 1.07 1.08 1.09 1.10 1.11 1.12 Atari, Inc., 1200XL Home Computer Field Service Manual, FD100217, Rev. 01, February 1983. Section 1 (power supply specification and 6502 pin assignments), section 2 (p. 2-1, schematics "attached to the front cover" and the note on production variations), section 4 (disassembly and adjustments), section 5 (parts list, pages 5-2 to 5-4), section 6 (tech tips 15 and 19). Hosted on this wiki as Atari 1200XL Field Service Manual (PDF).
- ↑ Jason H. Moore, "Replace Faulty Capacitors on Your Atari 8-Bit Computer Circuit Board", Atari Projects, 6 October 2024: the capacitors in 1970s and early-1980s Atari 8-bit computers "don't seem to fail too often".
