IBM 5100 Capacitor Replacement Guide
This guide documents capacitor diagnosis and replacement for the IBM 5100 Portable Computer. The 5100 uses a linear power supply — a 50/60 Hz mains transformer, bridge rectifier, large bulk filter capacitors and linear series-pass regulators. Linear PSUs fail differently from later switching PSUs: bulk filter caps see lower ripple frequency (100/120 Hz) so they bulge slowly rather than venting suddenly, but their ESR rises with age and feeds 100/120 Hz hum into the rails. After 45+ years all electrolytics in the 5100 PSU should be considered out of specification.
Important Caveat
[edit | edit source]Per-board exact capacitor values for the IBM 5100 are NOT published in surviving IBM documentation that this guide author has been able to locate. The Maintenance Information Manual SY31-0405-3 documents the PSU as block diagrams without per-component values; the Parts Catalog S131-0599-3 lists capacitors by IBM part number, not by capacitance / voltage / type. This guide therefore documents the typical linear-PSU practice that applies to recapping the 5100, with categories of capacitor and representative value ranges. Each restorer should pull each board, identify caps in situ by their printed markings, and replace with same-or-higher voltage and same capacitance.
The categories below are honest about what is and is not from IBM-published per-board data.
Safety Warning
[edit | edit source]The IBM 5100 PSU contains mains-rectified bulk capacitors that hold a lethal charge after power-off. Before any PSU work:
- Power off and unplug the mains lead.
- Wait at least 30 seconds.
- Discharge each bulk filter capacitor through a 1 kΩ / 5 W resistor.
- Verify with a multimeter.
The internal 5-inch CRT carries high voltage on the flyback transformer and anode. Discharge the CRT anode to chassis ground via a high-voltage probe before any work on the deflection / flyback board.
Linear PSU Topology
[edit | edit source]The 5100 PSU is a single linear supply board with:
- Mains input section — input fuse, X2 line-suppression capacitor (replace if RIFA-branded), mains transformer.
- Rectifier section — bridge rectifier diodes on the secondary.
- Bulk filter section — large axial-can aluminium electrolytics smoothing the rectified DC. These are the primary recap target on the 5100.
- Series-pass regulator section — bipolar pass transistors on a heatsink, plus regulator caps on input and output.
- Output filtering — smaller electrolytics at the rail output to the planar.
Bulk Filter Capacitor Recap — Primary Target
[edit | edit source]The bulk filter capacitors after the bridge rectifier are by far the most likely failure point on a 45+ year old linear PSU. Typical values found on linear PSUs of this class (representative, not IBM-published):
| Value | Voltage | Type | Position | Quantity (approx) |
| 2200–4700 µF | 25–50 V | Axial-can aluminium electrolytic, 105 °C | +5 V rail bulk after bridge | 1 |
| 2200–4700 µF | 25–50 V | Axial-can aluminium electrolytic, 105 °C | +12 V / −12 V rail bulk × 2 | 2 |
| 1000–2200 µF | 16–35 V | Axial-can aluminium electrolytic, 105 °C | Auxiliary rail bulk | 1–2 |
When recapping, verify the printed value and voltage on each cap before ordering replacements. The lead spacing is fixed by the PSU board layout — use radial-to-axial adapter leads or modern axial replacements with the correct lead pitch.
Series-Pass Regulator Capacitor Recap
[edit | edit source]Around the series-pass regulator transistors on the heatsink:
| 47–470 µF | 25–35 V | Aluminium electrolytic, 105 °C | Series-pass input / output | 4–6 |
| 0.1–1 µF | 50 V | Film or tantalum bypass (typically still good — inspect only) | Series-pass bypass | 4–6 |
Mains Suppression Capacitor
[edit | edit source]Inspect the X2 mains suppression capacitor on the primary side of the PSU. If it is:
- RIFA-branded (the brand most associated with venting failure), or
- Cracked or bulging, or
- Producing a fishy odour,
replace immediately with a modern X2-class 0.1 µF / 275 VAC capacitor.
The "fish" smell is the polymer impregnation of the RIFA cap venting; it is a fire hazard.
CRT Deflection / Flyback Board
[edit | edit source]The 5-inch CRT deflection and flyback board carries small electrolytics around the vertical / horizontal oscillator and high-voltage rectifier filtering. Typical values:
| 1–10 µF | 16 V | Aluminium electrolytic | Oscillator bypass |
| 10–47 µF | 35 V | Aluminium electrolytic | Vertical deflection driver |
| 100–470 µF | 35 V | Aluminium electrolytic | +12 V deflection bulk |
| 0.01–0.1 µF | 1 kV–2 kV | Ceramic disc (HV) | Snubber on flyback collector |
The high-voltage HV snubber capacitors are ceramic and rarely fail. Aluminium electrolytics on the deflection board can leak and corrode the board over time — inspect under magnification.
DC300 Tape Drive Logic Board
[edit | edit source]The DC300 1/4-inch cartridge tape drive carries a small drive electronics board. Typical capacitors:
- 47 µF / 16 V — spindle motor driver.
- 10 µF / 25 V — head amp.
- 22 µF / 16 V — sector buffer.
Recap with 105 °C low-ESR equivalents if the drive becomes unreliable.
ROS / RWS Card Capacitors
[edit | edit source]The Executable ROS, Language ROS, and RWS (RAM) cards carry small SMD or through-hole tantalum decoupling capacitors. These rarely fail but tantalum short circuit is the canonical failure mode.
Diagnostic procedure (tantalum short):
- Set multimeter to diode test.
- Probe each tantalum in-circuit: black probe to ground, red probe to rail. Good cap reads open / high resistance; failed (shorted) cap reads close to 0 Ω.
- Remove the cap to confirm out-of-circuit.
- Replace with a fresh tantalum or low-ESR ceramic of equal value, equal or higher voltage rating.
Recommended Modern Replacements
[edit | edit source]For all electrolytic replacements, choose:
- Manufacturer — Panasonic FR / FM / FC, Nichicon HE / HZ (post-2007 date codes), Rubycon ZLH / ZLJ / YXJ, United Chemi-Con KZH / KZE. Avoid general-purpose Chinese-brand electrolytics for PSU rebuild.
- Temperature rating — 105 °C even where the IBM original was 85 °C (small price premium, much longer life).
- Voltage rating — equal to or higher than the original.
- Capacitance — equal to original (do not overshoot — increased capacitance can stress the bridge rectifier).
- Lead spacing — verify before ordering; many original 5100 caps are axial, but modern replacements are typically radial.
Recap Procedure
[edit | edit source]- Discharge the PSU bulk capacitors; verify with a multimeter.
- Discharge the CRT anode if working on the deflection board.
- Remove the PSU board from the chassis (typically 4–6 screws plus connectors).
- Photograph the board from both sides at high resolution. Record every cap's location, value, polarity, lead pitch.
- Desolder each electrolytic with solder wick on each lead. Limit each desolder cycle to 5–7 seconds at no more than 350 °C.
- Clean each pad with solder wick.
- Fit replacements matching the silkscreen polarity (− on cap stripe to − on silkscreen).
- Solder both leads from the underside; inspect for clean fillets; trim flush.
- Reassemble. Verify rails on the bench with a multimeter under a 1 A resistive load before refitting to the chassis.
Post-Recap Verification
[edit | edit source]- Power on with no peripherals (no tape cartridge, no external printer).
- Probe each rail at the planar power connector — verify within tolerance.
- Verify the language banner appears clean.
- Run Diagnostic ROS (keyboard sequence at power-on) — verify PALM registers and RAM.
- Run the Customer Acceptance Test cartridge if available.
If any test fails after recap, re-inspect the polarity of every replaced cap before suspecting another fault — reversed polarity is the most common error.
Polarity Reference
When Not to Recap
[edit | edit source]If the 5100 powers on cleanly, all rails are within tolerance, the language banner is clean, Diagnostic ROS runs, and there is no visible cap failure, the caps are within tolerance. However, given the machine's age (50 years at time of writing), planned recap before any extended use is strongly recommended to avoid bulk filter cap failure damaging downstream circuitry.
Always recap if:
- Visible cap failure (bulged top, leaked electrolyte) anywhere.
- PSU smoke, fishy odour or audible whine.
- Rails out of tolerance.
- RIFA-branded X2 mains suppression cap present (replace as preventive measure).
- System unstable when warm but stable when cold (typical of ESR rise in bulk filter caps).
Related Pages
[edit | edit source]- IBM 5100
- IBM 5100 Maintenance Guide
- IBM 5100 Troubleshooting Guide
- IBM 5110 Capacitor Replacement Guide — sibling machine; same linear PSU caveats
- IBM 5120 Capacitor Replacement Guide — sibling machine
- Capacitor Failure Symptoms
[edit | edit source]- Bitsavers — IBM 5100 documents. MIM SY31-0405, Parts Catalog S131-0599-3.
- IBM 5100 — Wikipedia.
- Commonly Failing Electronic Components — minuszerodegrees.net.
- Dave Dunfield's IBM 5100 collection page. Community restoration notes including PSU recap experience.
