IBM 5120 Maintenance Guide
Revision as of 16:42, 23 May 2026 by Josh (talk | contribs) (Deep technical pre-PC IBM page with verified sources (Bitsavers MIM/MAP, Wikipedia, IBM Archives) — honest gap disclosure where IBM did not publish per-board cap values)
This guide documents preventive maintenance for the IBM 5120 Computing System (announced February 1980, also designated IBM 5110 Model 3). The 5120 shares its PALM processor with the IBM 5100 and IBM 5110 but is in a substantially redesigned desktop chassis with a built-in 9-inch CRT, detached keyboard, two built-in 8-inch floppy drives, and a larger linear power supply. The machine is approaching 45 years old at the time of writing; all preventive maintenance is restoration-class work.
Safety Warning
The 5120 PSU is a linear supply with large bulk filter capacitors after the bridge rectifier. The 9-inch CRT carries lethal high voltage. Before any work inside the chassis:
  1. Power off and unplug the mains lead.
  2. Wait at least 30 seconds.
  3. Discharge each PSU bulk filter capacitor through a 1 kΩ / 5 W resistor.
  4. Discharge the CRT anode to chassis ground via a high-voltage probe.
  5. Verify both with a multimeter.
The 5120 carries a 9-inch CRT (vs the 5-inch tube on the 5100 / 5110), so the anode voltage and stored energy are correspondingly higher.
Documentation Set
The IBM service documentation for the 5120 is preserved at Bitsavers:
  • SY34-0192-0 — IBM 5120 Maintenance Information Manual (MIM), December 1979 — the CE service manual.
  • SY34-0193-0 — IBM 5120 Computing System Logic Manual, December 1979 — gate-level logic diagrams. Essential for board-level fault isolation.
  • GH30-0232-1 — Joint 5110 / 5120 Bibliography, September 1980.
The 5120 documentation set is thinner than the 5110's — many user-facing manuals (APL, BASIC) for the 5120 are the 5110 manuals because the language ROMs are essentially the same. Cite the 5110 manuals where applicable.
Opening the System Unit
Tools: Philips #2 screwdriver, T15 / T20 Torx, anti-static strap, high-voltage probe.
  1. Power off and unplug all cables (mains, keyboard, printer, communications).
  2. Remove the cover fasteners around the back of the chassis (typically 4–6 screws).
  3. Lift the cover — the 9-inch CRT and deflection sub-chassis remain attached to the lower chassis, unlike the 5100 / 5110 where the CRT is in the upper shell.
  4. Inside layout (looking from the front):
9-inch CRT centred behind the front bezel; deflection board mounted to the side of the CRT cradle.
2 × 8-inch floppy drives below the CRT, mounted vertically in a drive cage.
Main PSU at the rear left.
PALM board and ROS / RWS cards on a backplane behind the drive cage.
Keyboard connector on the front edge.
Detached Keyboard
The 5120 detached keyboard is a separate unit:
  • Cable connector at the rear connects to the system unit.
  • Keyboard has a palm rest and IBM Model F-class buckling-spring switches on some 5120s.
  • Keycaps are removed with the IBM tool (not pulled by hand).
Inspecting the Chassis
Inspection items in order:
  1. Main PSU bulk filter capacitors — visual inspection. These are the highest-likelihood failure point.
  2. Series-pass regulator transistors — heatsink-mounted; check thermal paste.
  3. 9-inch CRT and deflection board — inspect for cracked solder joints around the flyback transformer.
  4. Phosphor — check for burn-in (static images from years of unattended operation).
  5. 8-inch floppy drive belts — perished urethane is the dominant failure on these drives.
  6. Spindle motor brushes — wear is common after 40+ years.
  7. Head load solenoids — fatigue.
  8. Drive cage carry handles — plastic fatigue reported.
  9. ROS modules — reseat in sockets (oxidised pins).
  10. PALM board edge connector — reseat (most common cause of "dead PALM" symptoms).
Regular Cleaning
  • Soft brush and low-pressure compressed air for the planar, PALM, ROS / RWS cards, drive bays, and PSU vents.
  • Do not use compressed air on a leaking electrolytic.
  • Detach the keyboard for separate cleaning. Wipe with slightly damp microfibre. Remove keycaps with the IBM tool to avoid breaking stems.
  • Clean 8-inch floppy heads with IPA on a foam swab (not cotton).
  • Inspect every diskette before reading. If the oxide is shedding, do not load — it will contaminate the head.
PSU Voltage Checks
The 5120 PSU is larger than the 5100 / 5110 supply because it must drive 2 × 8-inch floppy drives plus the 9-inch CRT. Probe each rail at the planar power connector.
IBM 5120 PSU rail tolerances (typical linear PSU; verify against MIM SY34-0192)
Rail Approximate target Notes
+5 V (logic) +4.75 V to +5.25 V PALM, ROS, RWS
+12 V +11.4 V to +12.6 V Floppy drive logic, deflection
+24 V (typical) ±5% 8-inch floppy spindle motor and head load (may be 12 V on some drives)
−5 V / −12 V ±5% Bias rails
CRT high-voltage anode ~12–15 kV (9-inch CRT) Measure with HV probe only
The 9-inch CRT anode voltage is higher than the 5-inch CRT on the 5100 / 5110 — handle with extra care.
8-Inch Floppy Drive Maintenance
The 5120 has 2 × 8-inch floppy drives built in (typically Shugart-class drives in IBM cosmetics). Maintenance items:
  • Drive belt — urethane perishes. Modern replacements available from the 8-inch floppy restoration community.
  • Head load solenoid — exercise; replace if fatigued.
  • Spindle motor brushes — wear is common. Brushes can be re-sourced from industrial motor suppliers.
  • Read / write head — clean with IPA on a foam swab. Never use cotton — fibres in the head gap cause errors.
  • Head alignment — verify against a known-good diskette using the procedure in the MIM.
  • Oxide shedding from old IBM Diskette 2D media — inspect every diskette; do not load shedding diskettes.
Optional 5114 Diskette Unit
If the 5120 has an external 5114 attached:
  • Service the 5114 separately per the IBM 5110 Maintenance Guide.
  • The 5114 has its own linear PSU with its own bulk filter capacitors.
CRT Maintenance
The 9-inch CRT and its deflection / flyback board are mounted in the lower chassis on a sub-chassis:
  • Always discharge the CRT anode before any work on the deflection board.
  • Inspect the flyback transformer for cracked insulation — visible cracking indicates impending arc-over; flyback replacement requires a donor.
  • Deflection coils — inspect for cracked solder joints at the yoke connector.
  • Phosphor burn-in — if a static image is visible on the inactive screen, the phosphor has been operated for too long with a fixed display; replacement requires a donor CRT.
  • Focus drift — adjust the focus pot on the flyback if accessible; if the CRT cannot focus, the cathode is end-of-life.
ROS and RWS Module Care
Same as the IBM 5100:
  • Static-sensitive — always wear an anti-static strap.
  • Do not flex ROS modules.
  • Reseat ROS cards if banner garbled.
PALM Board Care
Same as the IBM 5100 — 13 bipolar gate arrays are unobtainium. Reseat the edge connector before suspecting failure.
Connector Care
  • Keyboard cable — multi-pin proprietary connector; clean both sides with deoxidising contact cleaner.
  • Mains lead — replace if insulation cracked.
  • Printer cable (IBM 5103) — IBM-specific connector; clean and reseat.
  • Communications connectors — RS-232 DB-25 and SDLC / BSC connectors clean per standard procedure.
  • Philips #2 and T15 / T20 Torx screwdrivers.
  • Anti-static strap.
  • Digital multimeter with HV-rated probe (CRT anode is 12–15 kV).
  • High-voltage probe for CRT discharge.
  • IPA + foam swabs (no cotton).
  • Soldering iron (fine tip) + solder wick.
  • Modern 8-inch floppy drive belt replacement.
  • IBM keycap removal tool.
  • Modern 8-inch head-cleaning supplies.
  • MIM SY34-0192 and Logic Manual SY34-0193 PDFs.
