IBM 3270 PC Maintenance Guide
Revision as of 22:03, 24 September 2026 by Josh (talk | contribs) (Fix refs so they render; correct BNC twinax and the 75-ohm terminator - it is coax, point to point, no terminator, and IBMs check is <1 ohm at the system unit connector; Model F has no foam pads (capacitive flyplate, not foam and foil); add IBMs coax isolation procedure, the error-code to FRU map, the false 2801 (ECA001, P/N 1497249) and false 8505; remove the unsourced 12-15 kV figure)
This guide documents preventive maintenance for the IBM 3270 PC (machine type 5271, 1983). Because the 3270 PC chassis is mechanically an IBM PC XT (5160), chassis-level maintenance is identical to the XT; the 3270-specific procedures cover the specialist cards (Keyboard Adapter, 3270 PC Display Adapter, APA, PSS, 3278/79 Emulation Adapter), the 5271 Keyboard Element, the 5272 colour display, and the 3270 PC Control Program software environment.
Safety
The system unit's supply is the 5160 XT supply โ€” IBM's parts catalogue states that "all base system parts for the 3270 XT products are the same as 5160 XT base system parts", and that includes the power supply.[1] It is a switching supply with a rectified-mains reservoir on its primary side, so treat every large capacitor on that board as charged until a meter says otherwise, and discharge through a resistor rather than a screwdriver.
  1. Power off and unplug at the wall.
  2. Discharge each bulk capacitor through a resistor.
  3. Verify with a meter before touching anything.
The 5272 and 5151 displays carry extra-high tension on the flyback and the anode. Follow the CRT Discharge Procedure and discharge a second time a few minutes later.
The coaxial cable is a separate hazard, and not the one you expect. IBM warns twice in the maintenance manual: do not connect or disconnect the coaxial cable during an electrical storm.[2] The run to the control unit is often long and sometimes between buildings.
See also Recommended Tools.
Two of these are hosted here, and they are the two to start from:
The rest:
  • IBM G320-9539-0 โ€” IBM 3270 Personal Computer Hints and Tips (June 1986).
  • IBM 1502336 โ€” PC 3278/79 Emulation Adapter Technical Reference (October 1983).
  • IBM SC23-0103-2 โ€” 3270 PC Control Program User's Guide and Reference (July 1984).
  • IBM 84X0982 โ€” 3270 Workstation Program v1.0 User's Guide and Reference (April 1987) โ€” the Control Program's software-only successor.
  • IBM 59X8423 โ€” PC 3270 Emulation Program v2.00 User's Guide (March 1986).
  • IBM 83X9705 โ€” IBM 3270 Connection Technical Reference (April 1987).
Opening the System Unit
Identical to the IBM PC XT (5160) Maintenance Guide:
  1. Power off and unplug all cables (mains, keyboard, video, printer, BNC twinax to controller).
  2. Five Philips #2 screws on the rear panel.
  3. Slide cover forward to release.
The 3270 PC interior is densely populated. A typical full configuration occupies:
  • Hard Disk Adapter (Models 006, 026, 070, 071 only โ€” not 030 or 050, which are diskette-only).
  • Diskette Drive Adapter.
  • 3270 PC Display Adapter, or the 3295 Plasma Display Adapter on Models 024 and 026.
  • All-Points-Addressable card, where fitted.
  • Programmed Symbols card, where fitted.
  • 3278/79 Emulation Adapter โ€” IBM calls it the DFCA, the Distributed Function Communications Adapter.
  • Keyboard Adapter, or the Plasma Keyboard Adapter on Models 024 and 026.
  • Printer/Memory Adapter, or the XMA with 1 MB on Models 031, 051 and 071.
IBM does not publish a fixed slot order for the 5271, so record the as-built configuration before you pull anything. One documented constraint: the XMA jumpered as LPT2 on a 5271 with a fixed disk is not supported โ€” there is an interrupt-level conflict.[1]
Card Inventory at Service Time
For each service visit, verify the card complement and check the as-built ROMs:
  1. Keyboard Adapter โ€” two ROM variants: 6323581 (simple) or 6323582 (complicated, with NMI button and serial port). This card holds the video BIOS for the 3270 PC Display Adapter; without it the video cards do nothing, which is the single most confusing failure mode on this machine.[3] Models 024 and 026 use a Plasma Keyboard Adapter instead.[1]
  2. 3270 PC Display Adapter โ€” SCN2672 PVTC at 0180hโ€“019Bh. Inspect the SCN2672 socket for oxidation.
  3. APA card (where fitted) โ€” adds CGA modes + 3270-PC graphics modes.
  4. PSS card (where fitted) โ€” Programmed Symbol Set, RAM-loaded fonts.
  5. 3278/79 Emulation Adapter โ€” I/O at 2D0hโ€“2D6h (older) or 2D0hโ€“2D7h (newer). BNC twinax to controller.
What IBM's Error Codes Mean
The 5271 posts codes that a plain XT does not, and IBM maps each range to a field-replaceable unit:[1]
  • 28XX โ€” the DFCA (3278/79 Emulation Adapter).
  • 32XX โ€” Display Adapter, Programmed Symbols Adapter, All-Points-Addressable Adapter, or the Top Card Connector.
  • 44XX โ€” Display Attachment Unit (on the /G and /GX, not the base 5271).
  • 45XX โ€” IEEE Interface Adapter card.
Two of these lie to you:
  • A false 2801. If a long DFCA has been replaced with the newer short card, the Keyboard Timer Adapter may need changing too. Press F1 to continue after POST; if the host session then establishes normally, the 2801 is false. ECA001 directs the engineer to order P/N 1497249 (one EPROM) and replace the pluggable EPROM on the Keyboard Timer Adapter.[1]
  • A false 8505. The XMA diagnostic tests D000–DFFF; any other adapter with RAM or ROS in that range produces an 8505 that is not a real fault.[1]
A plain 83-key XT keyboard in place of the 5271 Keyboard Element produces POST error 302 โ€” press F1 to continue.[3]
Keyboard Adapter Dongle
A small external "dongle" cable splits the keyboard adapter card's DE-9 connector at the rear of the chassis into two 5-pin DIN connectors:
  • One for the 122-key 5271 Keyboard Element.
  • One that passes through to the standard XT keyboard port on the planar.
The dongle is a known service item โ€” it can be lost, worn, or pin-damaged. Pinout is documented at seasip.info and is reproducible by a competent hobbyist with a soldering iron and the right connector shells.
PSU Voltage Checks
Same as the standard XT โ€” see IBM PC XT (5160) Maintenance Guide.
A fully populated 3270 PC has almost every slot occupied and, on some models, a fixed disk as well, so it sits closer to the supply's rated output than a stock XT does. Rail sag under load that clears when cards are removed points at the supply rather than at any one card โ€” see IBM 3270 PC Capacitor Replacement Guide.
5271 Keyboard Element Maintenance
IBM's parts catalogue lists the keyboard as part 6110344 in Figure 7 of the maintenance manual.[2]
A correction worth making before you take one apart: the Model F has no foam pads. It is a capacitive buckling-spring design โ€” the spring buckles and throws a flyplate against the sensing pads on the PCB. There is no foam-and-foil layer to degrade, and searching for one will cost you an afternoon. What does go wrong:
  • Flyplate and barrel wear โ€” a key that needs excessive force or stops registering is usually mechanical, at the barrel or the spring, not a dead sense pad.
  • Corrosion on the sense PCB โ€” the capacitive pads are exposed to whatever has been spilled on the keyboard over forty years.
  • Cable strain relief โ€” the cable is heavy and the harness fails at the entry point.
  • Keycap removal โ€” use the tool. The stems are easily damaged by pulling.
IBM's own note in the Service Information Manual gives P/N 1389098 as the replacement keyboard part, "for either the metal bottom or the plastic bottom keyboard".[1] Both bottom types exist and both take the same replacement.
Display Maintenance
IBM 5272 Color Display
  • Follow the CRT Discharge Procedure. This wiki has not found an IBM-published anode voltage for the 5272; the "12โ€“15 kV" figure that used to appear here had no source and has been removed. Treat it as lethal and discharge it whatever the number is.
  • Inspect flyback for cracked insulation.
  • Pin 4 of the DE-9 selects mono vs colour. If the display does not show colour, verify pin 4 is being correctly asserted by the host.
  • Color timings: hsync 24 kHz negative, vsync 63 Hz negative. Out-of-spec timings produce display drift / rolling.
IBM 5151 Monochrome Display
  • Standard IBM 5151 maintenance โ€” see standard IBM PC documentation.
IBM 3295 Plasma Monitor
  • Fitted only to Models 024 and 026, which also carry the Plasma Keyboard Adapter rather than the standard one.[1]
  • Plasma panels of this era can develop cell failures. Severely affected panels are not field-repairable.
Coaxial Cable to the Control Unit
The 3270 PC attaches to an IBM 3274 (later 3174) control unit over coaxial cable. It is coax, not twinax โ€” twinax is the midrange 5250 attachment and will not work here โ€” and the link is point to point, one control-unit port per workstation, with no terminator at either end.[2][1]
IBM's own isolation procedure, which is worth following in order because it costs nothing:[2]
  1. With the machine powered off, swap the coaxial cable with one from a known-working 3270 PC and repeat the connection test. If your machine now connects, the cable or the control-unit port is at fault, not the workstation.
  2. If it still does not connect, reconnect both machines to their own cables and rerun the DFCA diagnostic. If the other machine now fails, the problem is external to your workstation.
  3. If neither of those resolves it: power off, disconnect the coaxial cable at the system unit, and measure the resistance at the system unit's coaxial connector. It should be less than 1 ohm. If it is not, IBM's instruction is to replace the DFCA.
Clean both connectors with a contact cleaner, and verify the control-unit port is configured for a 3278 or 3279 โ€” the workstation presents itself to the control unit as a 3278.
Do not connect or disconnect the coaxial cable during an electrical storm. IBM says this twice.[2]
3270 PC Control Program Maintenance
The Control Program is on diskette (Models 2 / 4 / 24) or pre-installed on the hard drive (Models 6 / 26 / 30 / 50 / 70). Service items:
  • Image the Control Program diskettes immediately if you have an original set โ€” they are increasingly rare and the install procedure required mainframe sysprog assistance in period.
  • Control Program v3.0 is required for Models 31/51/71 and all P-models. Earlier versions will not boot on these.
  • If a Control Program install fails on a P-model, verify the keyboard is a 101-key Enhanced AT-style โ€” the P-models do not work with the 122-key 5271 Keyboard Element.
Floppy and Hard Drive Maintenance
Standard IBM PC XT 5.25" 360 KB DSDD floppy and 10 MB ST-412 (Model 6) or 20 MB hard drive (Models 30 / 50 / 70). Maintenance is identical to the IBM PC XT (5160) Maintenance Guide.
  • Philips #2 and T15 / T20 Torx screwdrivers.
  • Anti-static strap.
  • Digital multimeter with HV-rated probe.
  • High-voltage probe for CRT discharge.
  • IPA + foam swabs.
  • Soldering iron (fine tip) + solder wick.
  • Deoxidising contact cleaner.
  • IBM keycap removal tool (for the 5271 Keyboard Element).
  • A spare coaxial patch cable โ€” the fastest way to prove the link is not the machine's fault.
  • IBM 3270 PC Maintenance Information and IBM Personal Computer Family Service Information Manual, both hosted here.
  • 1502336 PC 3278/79 Emulation Adapter Technical Reference PDF.
  1. โ†‘ 1.00 1.01 1.02 1.03 1.04 1.05 1.06 1.07 1.08 1.09 IBM, IBM Personal Computer Family Service Information Manual, SA38-0037-00, July 1989 — hosted on this wiki as IBM Personal Computer Family Service Information Manual. Chapter 10, "3270 PC Products", is the source for the system-unit and display combinations, the full 5271, 5371 and 5373 model lists, the 5371 and 5373 slot allocations, the unit specifications for the 5371, 5278, 5279, 5378 and 5379, the statement of which unit powers which, the 3270 unique error code to FRU indication table, the diagnostic tips and the ECA history. Chapter 18, "Personal Computer Parts Catalog", is the source for the 5271, 5371 and 5373 FRU part numbers and for IBM's note that "all base system parts for the 3270 XT products are the same as 5160 XT base system parts".
  2. โ†‘ 2.0 2.1 2.2 2.3 2.4 2.5 IBM, IBM 3270 Personal Computer Maintenance Information, SY27-2567-2, third edition, October 1984 — hosted on this wiki as IBM 3270 PC Maintenance Information. The safety inspection checklist; the problem isolation charts, including the coaxial cable connection test and the coaxial cable resistance check; section 4, locations, including the system board diagram; section 5, removal, replacement and adjustments; and section 7, the illustrated parts catalogue for the 5271 system unit, the 5161 Expansion Unit, the 5151 Monochrome Display, the 5272 Color Display and the keyboard.
  3. โ†‘ 3.0 3.1 John Elliott, The IBM 5271 (aka 3270 PC), seasip.info. A community technical reference built from a working machine: the card complement and what each card does, the video BIOS living in the keyboard controller ROM (part 6323581 for the "simple" controller and 6323582 for the "complicated" one), the error codes 3201, 3202, 3203 and 2801, the 5272 display timings, and the statement that the case, motherboard, drives and power supply are all identical or very similar to the XT.
