Acorn Stork
Revision as of 05:01, 2 October 2026 by Josh (talk | contribs) (New page: Stork sub-notebook prototype from ART datasheet DS009 and Chris's Acorns; not the A4 (design name Perth))
Acorn Stork
Chris Whytehead's Stork, serial STK14, with the monochrome screen (photo: Chris Whytehead, CC BY-SA 3.0)
ManufacturerAcorn Risc Technologies (Acorn Computers)
TypeSub-notebook computer (technology demonstrator)
Released1996 (prototype)
CPUARM7500 at 32 MHz
MemoryTwo SO-DIMM sockets (8 MB in Chris Whytehead's machine)
Storage2.5-inch IDE hard disc; external floppy drive on the parallel port
Display9.5-inch 640 × 480 16-grey STN LCD, or 10.4-inch colour TFT (VGA or SVGA)
Sound—
ROM4 MB, RISC OS 3.6
PowerExternal 18 V DC supply and charger; NiCd (1400 mAh) or NiMH (1800 mAh) battery pack
Dimensions266 × 192 × 36 mm (monochrome), 42 mm high (colour)
WeightAbout 1.8 kg
OS / FirmwareRISC OS 3.6
The Acorn Stork is a sub-notebook computer built by Acorn Risc Technologies (ART), a division of Acorn Computers, in 1996. It was a technology demonstrator: ART offered the design for licence, as samples, sub-assemblies or custom variants, to companies that would brand and sell it. No licensee took it up, and only a few were made.[1][2] Chris Whytehead estimates that fewer than 50 were built and records that the Acorn A4 remained Acorn's only portable computer.[2]
The Stork is a different machine from the A4 of 1992: the A4 is an ARM3 machine whose design name in Acorn's parts lists is Perth.[3]
Specification
Stork specification (ART datasheet DS009, July 1996)
Item Specification
Processor 32 MHz ARM7500 with 4 KB cache, about 29 MIPS (Dhrystone 2.1) peak; integrated I/O, MMU and video
Memory Two SO-DIMM sockets, up to 128 MB each; 4 MB ROM; 240 bytes of battery-backed CMOS RAM; 48-bit unique identifier
Software RISC OS 3.6 in ROM; Freeze Mode suspends the machine for up to five days on a full NiCd battery
Display 9.5-inch 16-grey 640 × 480 STN LCD, 10.4-inch 640 × 480 colour TFT or 10.4-inch 800 × 600 colour TFT; external monitors up to 1280 × 1024
Storage 2.5-inch IDE hard disc (425 MB standard); external 2 MB 3.5-inch floppy drive on the parallel port
Expansion PCMCIA type 1, 2 or 3 slot with hot insertion; 50-way docking connector; optional infra-red
Ports 9-pin RS232 serial; 25-pin parallel and floppy port; 18 V DC input; 3.5 mm stereo output
Input 77-key keyboard with numeric keypad overlay; built-in trackerball with three buttons
Power External switched-mode supply and charger, 110 to 240 V AC, 18 V DC 1.2 A output; NiCd (1400 mAh) or NiMH (1800 mAh) battery
ART's datasheet prints the NiCd battery life as "up to 21 hours" and the NiMH life as up to 3¼ hours. Chris Whytehead gives 2.5 hours for the NiCd pack and 3.5 hours for the NiMH option.[1][2]
Underside with the cover plate removed: two memory modules, the ROM daughterboard and the hard disc (photo: Chris Whytehead, CC BY-SA 3.0)
Chris Whytehead's Stork, serial STK14, has a VLSI VY27073B ARM7500 at 32 MHz, 8 MB in two 4 MB modules, a 262 MB Seagate ST9300AG hard disc, a 9.5-inch monochrome screen and an Olivetti MFD SB314 external floppy drive. Its RISC OS 3.60 ROMs are dated 13 April 1995, and an electrical test sticker on the base carries a 1996 date.[2]
A panel on the underside, held by three screws, gives access to the two memory modules, the daughterboard carrying the RISC OS ROMs, and the hard disc. The battery pack is removed with a catch at the left-hand front corner; Chris Whytehead's pack is labelled 12 V DC 1400 mAh NiCd. The serial, parallel and video/replicator ports are under a flap at the back, with the 18 V DC input beside them. The PCMCIA slot is on the left side, and the audio socket and a recessed reset button are on the right.[2]
Condition and repair
Chris Whytehead describes the Stork as never finished as a product and "reportedly temperamental". His machine does not work, and nobody he asked could repair it; he was told that the jigs and tools needed were no longer available.[2] ART published no service manual, and no circuit diagram has been found on Chris's Acorns or archive.org.
  1. ↑ 1.0 1.1 1.2 Acorn Risc Technologies, Stork, datasheet DS009/ART/PF/AF, July 1996. Hosted on this wiki: File:Acorn Risc Technologies Stork datasheet (DS009).pdf. Features; technical overview (processor, memory, unique reference, system software, audio, video, expansion, mass storage, ports, physical, electrical).
  2. ↑ 2.0 2.1 2.2 2.3 2.4 2.5 Whytehead, Chris. "Acorn Stork", Chris's Acorns, The Centre for Computing History (retrieved 2026-10-02). Produced by ART in mid-1996 as a technology demonstrator; probably fewer than 50 made; temperamental; his non-working machine, serial STK14, with photographs and specification (ARM7500 VY27073B at 32 MHz, 8 MB, Seagate ST9300AG 262 MB, Olivetti MFD SB314 external floppy, RISC OS 3.60 of 13 April 1995); 12 V 1400 mAh NiCd pack and NiMH option; the A4 remained Acorn's only portable.
  3. ↑ Acorn Computers, Acorn A4 Technical Reference Manual, part no. 0490,058, issue 1, February 1993. Hosted on this wiki: Acorn A4 Technical Reference Manual. Parts lists (pp. 2-1 to 2-12): main board, display unit and keyboard named as "Perth" assemblies.
