Acorn R140
Acorn R140
An R140 running RISC OS, with its PC-style keyboard (photo: Chris Whytehead, CC BY-SA 3.0)
ManufacturerAcorn Computers
TypeUnix workstation
Released1989
Intro price£3,949 ex VAT with Ethernet; £3,500 ex VAT without (June 1989)
CPUARM2 (4/8 MHz)
Memory4 MB (32 KB MEMC pages)
Storage60 MB (unformatted) ST506 hard disc; 3.5-inch floppy drive, 800 KB formatted
DisplayUp to 1152 × 900 monochrome; 640 × 480 in 16 colours from 4096
Sound—
ROM512 KB (RISC OS 2)
Power198 to 264 V AC, 70 VA
OS / FirmwareRISC iX (4.3BSD Unix), booted from RISC OS 2
SuccessorAcorn R260
Model no.UNX01 (base system); UNX01/AKA25 (with Ethernet)
The Acorn R140 is Acorn Computers' first Unix workstation, sold from early 1989.[1] It runs RISC iX, Acorn's port of Berkeley 4.3 Unix with System V extensions and the X Window System, on the hardware of the Archimedes 440/1: an ARM2, 4 MB of RAM, a 60 MB ST506 hard disc and a 3.5-inch floppy drive.[2][3] RISC OS 2 in ROM starts the machine and then loads RISC iX from the hard disc.[4]
The R140 uses the main board, case and power supply of the Archimedes 400/1 series (the first R140s were built on a slightly adapted A440), and Acorn serviced both from one manual.[4][3] The board-level procedures are in the Acorn Archimedes 400/1 Series Maintenance Guide, Acorn Archimedes 400/1 Series Troubleshooting Guide and Acorn Archimedes 400/1 Series Capacitor Guide; the sections below cover what is particular to the R140.
History
Acorn's January 1989 leaflet describes the R140 as "the first in a series of personal workstations running the UNIX operating system".[2] By June 1989 Acorn listed the workstation with Ethernet (UNX01/AKA25) at £3,949 ex VAT and the base system without the Ethernet card (UNX01) at £3,500, with twelve months' on-site maintenance included.[5] Chris Whytehead compares this with £2,299 ex VAT for the A440 at its launch, and records that the first R140s were built on a slightly adapted A440 and later ones on the A440/1.[4]
Wikipedia records a 1990 offer bundling the R140 with Ethernet and a monitor at £2,999 ex VAT, an upgrade to RISC iX 1.2 for R140 owners from £349, and the ARM3-based Acorn R260 and Acorn R225 that followed in 1990.[1] The Acorn A680 was the earlier, unreleased RISC iX development machine.[4]
Specification
R140 specification (Acorn leaflets APP214 and APP221, service manual)
Item Specification
Processor ARM 32-bit RISC processor; the service manual gives 4/8 MHz and typically 4 MIPS for the 400/1 and R140
Memory 4 MB RAM, 32 KB pages; 512 KB ROM
Storage 60 MB (unformatted) ST506 hard disc; 1 MB (unformatted) 3.5-inch floppy drive; a second external Winchester can use the internal ST506 controller
Expansion Four expansion card slots (three free on the Ethernet model); internal Econet module that does not use a slot
Keyboard and mouse 103-key "enhanced PC" style keyboard; three-button mouse
Interfaces Serial, parallel; Ethernet and thin Ethernet (Cheapernet) on the AKA25 card
Display 1152 × 900 monochrome (144 × 45 or 96 × 32 characters); 640 × 480 colour, grey-scale or monochrome with 16 colours from 4096
Software RISC iX (4.3BSD with SVID extensions, two-user licence), ANSI C compiler, X11 release 2 with awm, twm and uwm, X.desktop, NFS 3.2 and Yellow Pages, RISC OS, and MS-DOS through the PC Emulator
Sources: leaflets APP214 and APP221; processor figures from the service manual's technical specification.[2][5][3]
R140 options (APP221, June 1989; prices ex VAT)
Code Option Price
AKA20 Floating point expansion card with a WE32206 co-processor £599
AKA25 Ethernet expansion card, thick and thin (Cheapernet) Ethernet £449
AKA30 SCSI adapter card, up to seven devices £299
AKA42 PC Emulator £99
ADF10 Econet module £49
An R140 with the top cover removed. This machine has been upgraded with an ARM3, an IDE card and an Atomwide Ethernet card (photo: Chris Whytehead, CC BY-SA 3.0)
The main board is the Acorn Universal Board used in the 400/1 series. Chris Whytehead's R140 carries board 283,000 issue 2 on the four-slot backplane 0283,040, the same backplane as the A410, A440 and A680.[4] Acorn's service manual gives the R140's memory as 4 MB with a 32 KB page size, the same as the A440/1, and its functional test disc reports an R140 as an A440/1.[3]
The differences from an A440/1 are in what Acorn fitted and supplied: the 60 MB hard disc, the 103-key PC-style keyboard, the three-button mouse, the Ethernet card on the UNX01/AKA25 model and the RISC iX software.[2][5] Wikipedia notes that an A440/1 with 4 MB and a suitable hard disc can also run RISC iX.[1]
Rear panel
Acorn's operations guide lists these connections on the back of the system unit:[6]
  • Mono and Sync sockets for a high-resolution monochrome monitor; with a low-resolution monitor the Mono socket carries the whole signal.
  • Analogue RGB socket, not suitable for TTL RGB monitors.
  • Serial port and parallel printer port.
  • Headphone socket for a 3.5 mm stereo jack, mainly for RISC OS.
  • An Econet socket, blanked off if the Econet module is not fitted.
  • Four expansion card positions behind the blanking panel, for four single or two double cards, and the Ethernet card where fitted.
  • Mains input, mains output for a monitor, and the rocker on/off switch.
The 400/1 manual rates the unswitched mains outlet at 3 A continuous and the inlet at 70 VA.[3]
RISC iX
RISC OS 2 starts first. RISC iX can then be booted from the RISC OS desktop or set to start automatically; halt -RISCOS, typed as root, closes RISC iX down and returns to the RISC OS command line or desktop.[6] Close RISC iX down properly before switching off. To stop the machine from RISC OS, use *Shutdown, which also parks the hard disc heads.[6]
Acorn recommended a level zero dump backup of the filesystem as soon as the system was installed.[6] RISC iX was supplied pre-installed or installed on site from tape by Granada Microcare, and the core system could be backed up to three floppy discs.[1] Chris Whytehead restored a minimal RISC iX to his R140 from the three recovery floppies (one ADFS, two in the Unix UFS format), but a full installation also needs a tar archive of RISC iX 1.15 on media the machine can read.[4]
Warning: Acorn's dealer test disc includes a hard disc formatter, verifier and soak test. Running these tests destroys the data on the disc, which on an R140 means the RISC iX installation.[3] Back up the disc before running them.
Maintenance
The general procedures for the board, power supply, drives and expansion cards are in the Acorn Archimedes 400/1 Series Maintenance Guide. Acorn's operations guide adds these R140 user tasks.[6]
Backup batteries
Two AA (LR6) alkaline cells in a battery nest power the clock and the configuration memory. Acorn's guide says to change them once a year.[6] Old cells leak and corrode the holder and board; see Battery Explosion, Capacitor or Corrosion Damage and the battery section of the 400/1 maintenance guide.
  1. Log in as root, close RISC iX down with halt -RISCOS, type *STATUS and write down the configuration, which will be lost.
  2. Type *Shutdown to park the hard disc, then switch off and unplug.
  3. Remove the three screws at the top of the back panel and the screws on each side, then slide the top cover back far enough to expose the front half of the machine.
  4. The battery nest is at the front right-hand corner as seen from the back. Leave its flying lead to the main board connected. Fit the new cells the right way round; the nest will accept them reversed.
  5. Refit the cover, hold down R while switching on to reset the configuration to factory settings, then use *STATUS and *CONFIGURE to restore the settings you noted. Reset the date and time.[6]
Fan filter
The cooling fan has a filter beside the battery nest, held by a clamp and two M4 nuts. Acorn's guide says to change it about once a year; the replacement filter is Acorn part 0276,034. Make sure the nuts go back in the right positions and are tight.[6]
Cleaning
Clean the case with a soft, slightly damp cloth. To clean the mouse, remove the ball retainer screw, clean the three rollers with a swab moistened with tape head cleaner, and wipe the ball with a dry, lint-free cloth.[6]
The moulded mains plug takes a 5 A fuse.[6]
Fault finding
Hardware faults are diagnosed as for the 400/1 series, using the Acorn Archimedes 400/1 Series Troubleshooting Guide and the hosted service manual. The operations guide covers what a user sees first:[6]
R140 start-up problems (operations guide pp. 83 to 87)
Symptom Probable cause Action
Nothing happens at power on, no power or hard disc light Mains supply or plug fuse; cables Check the outlet and the 5 A plug fuse; reconnect each cable[6]
Power and keyboard lights on, nothing on the screen Monitor cable, adjustment or monitor; for a low-resolution text-only monitor, the internal links may not have been set Check the cables and brightness; check the monitor type and the links[6]
Fuzzy or jumpy picture Monitor type configured wrongly; alignment; loose signal cable Check the configured monitor type, then the monitor's own adjustments[6]
Powers on, then nothing happens Monitor, or corrupted CMOS RAM settings Check that the H/DISC light flashes intermittently; see the RISC iX System Administrator's Manual for the CMOS settings[6]
RISC iX starts to boot but stops before the login: prompt A one-off error, or a corrupted filesystem if it happens again Restart; if it persists, Acorn says the filesystem is likely to be corrupted[6]
Shuts down without warning Remote shutdown, a failed power supply or a blown plug fuse Restart; if it will not start again, check the fuse and the supply[6]
  • Acorn R140 Documentation: the R140 Operations Guide (0483,710) and Acorn's APP214 and APP221 leaflets.
  • Acorn A400-1 and R140 Service Manual: part 0483,075, issue 1, July 1989, the dealer service manual for the 400/1 series and the R140.
  • Personal Computer World reviewed the R140 in March 1989; Chris's Acorns has the scan.[4]
  1. ↑ 1.0 1.1 1.2 1.3 "RISC iX", Wikipedia (retrieved 2026-10-02). Sections "Distribution" (installation by Granada Microcare from tape; RISC iX 1.2 upgrades from £349 for R140 machines; backup of the core system to three floppy discs), "Hardware" (R140 based on the A440/1; 1990 discount bundle at £2,999 plus VAT; an A440/1 with 4 MB and a suitable disc can run RISC iX) and "Legacy".
  2. ↑ 2.0 2.1 2.2 2.3 Acorn Computers, Acorn R140 Workstation in Commercial and Technical Applications, leaflet APP 214, first edition, January 1989. Hosted on this wiki: File:Acorn R140 Workstation leaflet (APP214).pdf. RISC iX features, standard hardware, keyboard and mouse, interfaces, display monitor support, hardware expansion options, standard software and documentation.
  3. ↑ 3.0 3.1 3.2 3.3 3.4 3.5 Acorn Computers, 400/1 & R140 Service Manual, part no. 0483,075, issue 1, July 1989. Hosted on this wiki: Acorn A400-1 and R140 Service Manual. About this manual p. 5; technical specification p. 7 (RAM by model, ROM options, power inlet and outlet); functional testing p. 26 (an R140 is recognised as an A440/1); hard disc drive tests p. 27.
  4. ↑ 4.0 4.1 4.2 4.3 4.4 4.5 4.6 Whytehead, Chris. "RISC iX Computers", Chris's Acorns, The Centre for Computing History (retrieved 2026-10-02). R140: early machines based on a slightly adapted A440 and later ones on the A440/1; RISC OS 2 in ROM used only to boot the disc-based RISC iX; R140 £3,500 without monitor against £2,299 for the A440; the three RISC iX recovery floppies (one ADFS, two UFS); his upgraded R140 (Acorn Universal board 283,000 issue 2, backplane 0283,040 issue 3, serial 27-KB40-101mmm).
  5. ↑ 5.0 5.1 5.2 Acorn Computers, R140 Computer Systems, leaflet APP221, third edition, June 1989. Hosted on this wiki: File:Acorn R140 Computer Systems price list (APP221).pdf. Descriptions and prices of UNX01/AKA25, UNX01, AKA20, AKA25, AKA30, AKA42, ADF10, SPX02 to SPX04 and UNX02.
  6. ↑ 6.00 6.01 6.02 6.03 6.04 6.05 6.06 6.07 6.08 6.09 6.10 6.11 6.12 6.13 6.14 6.15 6.16 Acorn Computers, R140 Operations Guide, part no. 0483,710, issue 1, December 1988. Hosted on this wiki: Acorn R140 Documentation. Mains plug fuse (p. iii); level zero dump backup (p. 32); close-down commands (p. 45); system unit description (pp. 49 to 51); cleaning (p. 75); replacing the batteries (pp. 78 to 80); changing the fan filter (pp. 81 and 82); if something goes wrong (pp. 83 to 89).
