Atari 1200XL Capacitor Replacement Guide
Replacing aged electrolytic capacitors (recapping) in the Atari 1200XL helps restore stable voltage regulation, clean audio output, and reliable operation. Unlike many vintage computers that use surface-mount electrolytics prone to leaking, the 1200XL uses through-hole axial electrolytic capacitors, which are less prone to catastrophic leakage but still degrade over time (40+ years).
This guide provides the complete capacitor list from the Atari 1200XL Field Service Manual parts list, along with post-recap voltage verification procedures.[1]
Capacitor Inspection
[edit | edit source]Before recapping, inspect the existing capacitors for signs of failure:
- Bulging or split vents – the top or bottom of the capacitor is no longer flat, indicating internal gas build-up.
- Electrolyte leakage – dried brown or dark residue around the capacitor leads or on the PCB.
- Corrosion or PCB staining – discolouration of the PCB surface or copper traces near the capacitor.
- Detached leads – leads that have corroded through or separated from the capacitor body.
- ESR out of specification – use an ESR meter to check equivalent series resistance. High ESR indicates a degraded capacitor even if it appears physically intact.
Pay particular attention to C39 (10000 µF / 16V, main power filter) and the C7/C51/C52 group (47 µF / 10V) as these are the most critical electrolytics for power stability and audio quality.
Atari 1200XL Electrolytic Capacitor List
[edit | edit source]The following table lists all electrolytic capacitors on the 1200XL motherboard. These are the capacitors most likely to require replacement due to age-related degradation.
| Ref Designator(s) | Capacitance | Voltage | Type | Quantity | Purpose / Circuit Area |
| C39 | 10000 µF | 16V | Aluminium Electrolytic Axial | 1 | Main power supply filter capacitor (post-bridge rectifier) |
| C7, C51, C52 | 47 µF | 10V | Aluminium Electrolytic Axial | 3 | Power rail decoupling / audio circuit filtering |
| C40, C41, C54, C93, C99, C102, C155 | 22 µF | 16V | Aluminium Electrolytic Axial | 7 | Power rail decoupling, voltage regulation smoothing |
| C115, C162 | 10 µF | 16V | Aluminium Electrolytic Axial | 2 | Signal coupling / decoupling |
Total electrolytic capacitors: 13
Full Capacitor Reference (All Types)
[edit | edit source]For completeness, the following table lists all capacitors on the 1200XL motherboard, including ceramics and film types. Ceramic and film capacitors rarely need replacement but are included for reference during board-level repair.
| Ref Designator(s) | Capacitance | Voltage | Type | Qty | Atari Part Number |
| C1 | 68 pF | — | Ceramic Axial | 1 | C014179-12 |
| C2–C5, C8, C10–C12, C14–C25, C30–C32, C34, C48, C55–C59, C68, C95, C100 | 0.1 µF | 25V | Ceramic Axial | 35 | C014181-03 |
| C7, C51, C52 | 47 µF | 10V | Aluminium Electrolytic Axial | 3 | 24-100476 |
| C9, C98 | 270 pF | 25V | Ceramic | 2 | C061336-02 |
| C13, C35, C64–C67, C72–C91, C103–C106, C109–C114, C120–C145, C147, C148, C151–C154 | 0.001 µF (1 nF) | 25V | Ceramic Axial | 60 | C014181-01 |
| C26–C29 | 0.047 µF | 25V | Ceramic Axial | 4 | C014180-09 |
| C36, C37, C149, C150 | 0.01 µF | 100V | Film | 4 | C061337-01 |
| C39 | 10000 µF | 16V | Aluminium Electrolytic | 1 | C060603 |
| C40, C41, C54, C93, C99, C102, C155 | 22 µF | 16V | Aluminium Electrolytic Axial | 7 | C014393 |
| C42, C47 | 0.01 µF | 25V | Ceramic Axial | 2 | C014181-02 |
| C60, C118 | 100 pF | 25V | Ceramic Axial | 2 | C014179-19 |
| C61 | 150 pF | 25V | Ceramic Axial | 1 | C014179-09 |
| C63 | 390 pF | 25V | Ceramic Axial | 1 | C014180-10 |
| C96, C97 | 820 pF | 25V | Ceramic | 2 | C061336-03 |
| C115, C162 | 10 µF | 16V | Aluminium Electrolytic Axial | 2 | C014371 |
| C116 | 6800 pF (6.8 nF) | 25V | Ceramic Axial | 1 | C014180-12 |
| C117 | 1500 pF (1.5 nF) | 25V | Ceramic Axial | 1 | C014180-15 |
| C119 | 3.9 pF | 25V | Ceramic | 1 | C061336-01 |
[edit | edit source]Tools Required
[edit | edit source]- Temperature-controlled soldering iron (adjustable, 300–370°C / 570–700°F)
- Desoldering pump (solder sucker) or desoldering braid/wick
- Fine leaded solder (0.5–0.8 mm, 63/37 or 60/40 tin-lead)
- Isopropyl alcohol (99%) and ESD-safe brush
- Flush cutters / side cutters
- Multimeter with capacitance measurement (and ESR meter if available)
- Anti-static wrist strap and ESD mat
- Safety glasses
Procedure
[edit | edit source]- Disconnect power – unplug the external transformer and allow the unit to sit for several minutes.
- Disassemble the console – remove the six bottom screws, six PCB screws, and eleven RF shield push rivets as described in the Field Service Manual (Section 4).
- Document existing capacitors – photograph the board before removal. Note polarity markings (stripe on negative lead for axial electrolytics).
- Remove old capacitors – heat each lead from the solder side of the board while applying gentle pressure or using a desoldering pump. Axial capacitors have leads that pass through the board; work each lead alternately to avoid pad damage.
- Clean the pads – remove residual solder with desoldering braid. Clean the pad area with IPA and an ESD-safe brush. Inspect pads and traces for damage.
- Install replacement capacitors – observe correct polarity. Axial electrolytics have a stripe or band marking the negative (−) lead. Insert into the correct holes, ensuring the polarity matches the PCB silkscreen markings.
- Solder securely – use a temperature-controlled iron. Apply solder to create a smooth, concave fillet around each lead. Avoid cold joints (grainy, dull appearance) and solder bridges.
- Trim leads – cut excess lead length flush with the solder joint using flush cutters.
- Clean and inspect – clean all solder joints with IPA. Inspect under magnification for solder bridges, cold joints, or damaged traces.
- Check for shorts – use a multimeter in continuity mode to verify no shorts exist between the +5V rail and ground before powering on.
Critical Notes
[edit | edit source]- C39 (10000 µF / 16V) is physically large. Ensure the replacement fits within the RF shield clearance. Use a capacitor rated at 16V or higher (25V is acceptable and provides additional margin).
- All electrolytic replacements should be rated at the same or higher voltage than the original.
- The 1200XL uses axial electrolytic capacitors throughout. Radial replacements can be used if the leads are formed appropriately, but axial types provide a cleaner installation.
Voltage Verification After Recap
[edit | edit source]After replacing capacitors, verify the power supply output before installing the RF shield and reassembling:
| Test Point | Expected Value | Tolerance | Notes |
| AC input at J10 | 9.0 VAC | ±10% | From external transformer |
| DC at C39 positive terminal | ~12.7 VDC | — | Rectified, unregulated |
| +5V at A1 output (pin 3) | +5.00 VDC | ±5% (4.75–5.25V) | Primary regulated output |
| +5V at A2 output (pin 3) | +5.00 VDC | ±5% (4.75–5.25V) | Secondary regulated output |
| +5V at U22 pin 8 (CPU Vcc) | +5.00 VDC | ±5% | Verify power reaches CPU |
| Ripple on +5V rail | < 50 mV p-p | — | Measure with oscilloscope AC-coupled. High ripple indicates C39 or regulator issue. |
Functional Testing After Recap
[edit | edit source]- Power on and verify all three LEDs function (Power, L1, L2).
- Press HELP at the power-on logo to enter self-test.
- Run the Memory Test – all RAM and ROM bars should turn green.
- Run the Audio Visual Test – verify all four POKEY channels produce sound.
- Run the Keyboard Test – verify all keys register correctly.
- If available, insert the SALT 2.05 cartridge and run the Color Bar Test and Gray Bar Test to verify GTIA output.
- Connect a joystick and verify both controller ports respond.
Recommended Replacement Capacitors
[edit | edit source]When sourcing replacements, use quality brands such as Nichicon, Panasonic, Rubycon, or United Chemi-Con. Suggested specifications:
| Original Value | Recommended Replacement | Voltage Rating | Type | Notes |
| 10000 µF / 16V | 10000 µF / 25V | 25V (upgraded) | Axial or radial electrolytic | Main filter cap – use highest quality available |
| 47 µF / 10V | 47 µF / 16V | 16V (upgraded) | Axial electrolytic | Audio/power decoupling |
| 22 µF / 16V | 22 µF / 25V | 25V (upgraded) | Axial electrolytic | Power rail smoothing |
| 10 µF / 16V | 10 µF / 25V | 25V (upgraded) | Axial electrolytic | Signal coupling/decoupling |
Upgrading voltage ratings provides additional headroom and longer service life without affecting circuit operation.
[edit | edit source]Related Maintenance Pages
