IBM 5110 Maintenance Guide
This guide documents preventive maintenance for the IBM 5110 Computing System (announced January 1978). The 5110 shares its PALM processor, integrated 5-inch CRT, and core architecture with the IBM 5100 โ€” much of the maintenance practice translates directly. The 5110 adds external diskette support via the IBM 5114 Diskette Unit, IEEE-488 (HP-IB), RS-232 channels, and EBCDIC character encoding, all of which add their own maintenance surface.
Safety Warning
The 5110 PSU is a linear supply with large bulk filter capacitors that hold a charge after power-off. The 5114 Diskette Unit has its own separate linear PSU. Before any work inside either chassis:
  1. Power off and unplug the mains lead.
  2. Wait at least 30 seconds.
  3. Discharge each bulk filter capacitor through a 1 kฮฉ / 5 W resistor.
  4. Verify with a multimeter.
The internal 5-inch CRT carries high voltage on the flyback transformer and anode. Discharge the CRT anode to chassis ground via a high-voltage probe before any work on the deflection / flyback board.
Documentation Set
  • SY31-0550-2 โ€” IBM 5110 Computer Maintenance Information Manual (MIM), February 1979 โ€” the CE service manual.[1]
  • SY31-0553-2 โ€” IBM 5110 System Maintenance Analysis Procedures (MAP), January 1979.
  • SY31-0551-1 โ€” IBM 5114 Diskette Unit Maintenance, January 1979.
  • SY31-0557-0 โ€” IBM 5110 Async Communications, January 1978.
  • SA21-9311-1 โ€” Customer Support Functions, October 1978 (operator-level procedures).
  • GH30-0232-1 โ€” IBM 5110 / 5120 Bibliography, September 1980 โ€” master reference list.
Download all of these for any serious 5110 restoration.
Opening the System Unit
Tools: Philips #2 screwdriver, T15 / T20 Torx, anti-static strap, high-voltage probe.
The 5110 chassis is the same as the IBM 5100:
  1. Power off and unplug all cables.
  2. Remove the cover fasteners on the rear and bottom.
  3. Lift the upper shell carefully โ€” the 5-inch CRT and deflection board are mounted in the upper shell.
  4. Inside layout matches the 5100: PSU at left rear, PALM board centre, ROS / RWS cards behind, DC300 drive (Model 1) at front.
Opening the 5114 Diskette Unit
The 5114 is a separate enclosure with:
  • Linear PSU for diskette spindle and head-load electronics.
  • 1 or 2 ร— 8-inch floppy drives (typically Shugart-class drives in IBM cosmetics).
  • Drive controller card.
  • Cable to the 5110 main unit.
  1. Power off and unplug the 5114 mains lead.
  2. Wait 30 seconds and discharge the 5114 PSU bulk caps.
  3. Remove the cover screws on the 5114 enclosure.
  4. Lift cover to expose the drives, PSU and controller card.
Inspecting the Chassis
Items in order:
  1. Main PSU bulk filter capacitors โ€” visual inspection for bulging, leaks, discolouration.
  2. Series-pass regulator transistors โ€” heatsink-mounted; check thermal paste.
  3. Flyback / deflection board โ€” inspect for cracked solder joints.
  4. DC300 tape drive belt (Model 1) โ€” replace if perished.
  5. Keyboard โ€” IBM beam-spring; foam pads may have degraded.
  6. CRT โ€” inspect for emission loss.
  7. ROS modules โ€” reseat in their sockets (oxidised pins).
  8. PALM board edge connector โ€” reseat (most common cause of "dead PALM" symptoms).
For the 5114:
  1. Diskette spindle motor brushes โ€” inspect through brush holders.
  2. Drive belt on the 8-inch floppy drives โ€” replace if perished.
  3. Head load solenoid โ€” verify operation.
  4. Drive logic board electrolytics โ€” inspect.
Regular Cleaning
Same procedures as the IBM 5100:
  • Soft brush and compressed air for the planar, PALM board, ROS / RWS cards, and PSU vents.
  • No compressed air over leaking electrolytics.
  • Wipe keyboard with microfibre; remove keycaps with the IBM tool.
  • Clean DC300 tape head with IPA on a foam swab.
  • Clean 8-inch floppy heads with IPA on a foam swab.
PSU Voltage Checks
Probe each rail at the planar power connector. Tolerances (typical linear PSU):
IBM 5110 PSU rail tolerances
Rail Approximate target
+5 V (logic) +4.75 V to +5.25 V
+12 V +11.4 V to +12.6 V
−5 V / −12 V As marked in MIM SY31-0550
CRT high-voltage anode ~9โ€“11 kV (5-inch CRT)
Out-of-tolerance rails after recapping bulk caps suggest a series-pass regulator transistor failure.
The 5114 has its own PSU with rails appropriate for the 8-inch floppy drives:
  • +5 V for drive logic.
  • +12 V or +24 V for spindle motor and head load solenoid (depends on drive vendor).
  • −5 V bias rail.
Verify per the 5114 MIM SY31-0551.
DC300 Tape Drive Maintenance (Model 1)
Same procedure as the IBM 5100 Maintenance Guide:
  • Drive belt replacement (urethane perishes).
  • Capstan rubber clean or replace.
  • Head clean and alignment.
  • Erase head clean.
5114 Diskette Drive Maintenance
  • Drive belt on 8-inch floppy โ€” replace if perished. Modern replacements available from the 8-inch floppy restoration community.
  • Head load solenoid โ€” exercise it; replace if fatigued.
  • Spindle motor โ€” brush wear is the main failure mode; brushes can be re-sourced from industrial motor suppliers.
  • Read / write head โ€” clean with IPA on foam swab. Never use cotton โ€” fibres in the head gap cause errors.
  • Head alignment โ€” verify against a known-good diskette using the procedure in the 5114 MIM.
  • Oxide shedding from old diskettes โ€” period IBM Diskette 2D media may have lost binder integrity. Inspect every diskette before reading; if oxide is shedding, do not load it (will contaminate the head).
EBCDIC Note
The 5110 uses EBCDIC encoding throughout, which makes its software at the byte level partially incompatible with the 5100's. If you are loading data from a 5100, format-shift it first; the 5110 cannot directly read 5100 5100-specific-code data.
IEEE-488 Bus Maintenance
The 5110 carries an IEEE-488 (GP-IB / HP-IB) bus connector. Maintenance items:
  • Clean the connector with deoxidising contact cleaner.
  • Verify the bus terminator if present.
  • Test with a known-good IEEE-488 instrument before suspecting the 5110 bus interface.
ROS and RWS Module Care
Same as the IBM 5100:
  • Static-sensitive โ€” always wear an anti-static strap.
  • Do not flex ROS modules.
  • Reseat ROS cards if intermittent โ€” oxidised socket pins cause garbled language banners.
PALM Board Care
Same as the IBM 5100: 13 bipolar gate arrays are unobtainium. Reseat the PALM board edge connector if intermittent before suspecting gate array failure.
CRT Maintenance
Same as the IBM 5100 โ€” 5-inch internal CRT and deflection / flyback board mounted in the upper shell.
  • Philips #2 and T15 / T20 Torx screwdrivers.
  • Anti-static strap.
  • Digital multimeter with HV-rated probe.
  • High-voltage probe for CRT discharge.
  • IPA + foam swabs.
  • Soldering iron (fine tip) + solder wick.
  • DC300 cartridge head-cleaning kit (Model 1).
  • 8-inch floppy head-cleaning supplies (5114).
  • Modern QIC-class replacement belt for the DC300 drive.
  • Modern 8-inch floppy drive belt replacement.
  • MIM SY31-0550 and SY31-0551 PDFs.
