Grandstand TV Game 3600 General Maintenance
AY-3-8500 chip pinout
Pin configuration of General Instrument's AY-3-8500. The TVG 3600's six games and switch settings are the ones this chip provides, but no photograph of a TVG 3600 board has been published, so the chip fitted is not confirmed.
The Grandstand TV Game 3600 (front strip "Adman GRANDSTAND TVG 3600") is the first model of Grandstand's 3600 series: a black six-game Pong console with a pistol, listed by Wikipedia as a colour console made in Hong Kong between 1977 and 1979.[1][2] One example is on record, in the South-West Retro Computing Archive, photographed from the front only.[1] No manual, service information, label or inside photograph has been published, and the later 3600 Mk II and Mk III use a different case,[3] so their opening procedures do not carry over. What can be done with the available evidence is set out below: the TVG 3600's controls, controllers and pistol as the photographs show them, the supply questions to settle before powering one, and what to record when you open one.
Fault-finding is on Grandstand TV Game 3600 Troubleshooting Guide; the electrolytic capacitors are covered on Grandstand TV Game 3600 Capacitor Replacement Guide.
What is known and what is not
TVG 3600: published facts
Part Detail Source
Panel Six slide switches (POWER, SOUND, SPEED, ANGLE, BAT SIZE, SERVE), MANUAL and START buttons, six-position game slider [1]
Sockets One strip on the front of the panel: LEFT PLAYER, PISTOL (two sockets), RIGHT PLAYER [1]
Controllers Two black cylinders with knurled knobs, plugged in on leads [1]
Pistol Black with a brown grip, two plugs [1]
Picture Colour, according to Wikipedia [2]
Game chip, supply, polarity, channel, screws Not published: no base, label or inside view exists in any source found None found
Before you start
  • Turn the console over and read the label on the base before connecting anything. It is the only source for the supply voltage and current.
  • No source gives the TVG 3600's supply. The 3600 Mk II that followed it is labelled for six UM-2 (C) cells or a 9 V 100 mA adaptor,[4] but it is a different design, so treat that only as a guide until your own label confirms it.
  • Remove any cells, and unplug the controllers and the pistol.
  • Tools: a cross-head screwdriver, a camera or phone, isopropyl alcohol, a soft brush, switch cleaner, potentiometer cleaner and a multimeter.
Opening the case
No account of opening a TVG 3600 has been published, and no photograph of its base exists in any source found.[1] Work from what you can see:
  1. Take out the cells and look inside the battery compartment for screws before turning to the rest of the base.
  2. Look for screws under any rubber feet and labels before prising anything; on Grandstand's 3600 Mk II two of the four case screws sit in recesses beside the feet,[5] but the TVG 3600's base may differ.
  3. Lift the case apart slowly. The speaker sits behind the grille in the middle of the panel and the sockets are on their own strip below it,[1] so expect leads between the board, the speaker and the socket strip.
  4. Photograph both sides of the board and every lead before unplugging or desoldering anything.
When you have it open, record what you find: the game chip's markings and date code, the crystal markings, any colour-encoder chip, the RF modulator and any channel marking, the board's printed number, and each electrolytic capacitor's value and voltage. None of this has been published for the TVG 3600.
Cleaning
  • Wipe the black case with a damp cloth and a little washing-up liquid. Keep it off the brushed silver strip across the top and the silver socket strip, whose legends are printed on.[1]
  • The speaker grille is a set of horizontal slots in the panel.[1] Brush the dust out of them; do not wash them, because water would run onto the speaker behind.
  • Clean the board, once open, with isopropyl alcohol and a soft brush.
Switches, slider and buttons
The panel has six slide switches: POWER (ON, OFF), SOUND (ON, OFF), SPEED (H, L), ANGLE ("20°/40°" or "20°"), BAT SIZE (L, S) and SERVE (AUTO, MANU). The yellow MANUAL and blue START buttons sit below them, and the games are chosen with one six-position slider at the right.[1]
If the chip is General Instrument's AY-3-8500, as the games suggest, every setting and every game is chosen by connecting one of its inputs to ground, and GI allows no more than 1 kΩ through a closed contact; START would be the reset input that clears the scores, and MANUAL the manual serve.[6] A dirty switch therefore shows up as a setting that will not change.
  • Spray a little switch cleaner into each slide switch and work it a dozen times.
  • The game slider has six positions. If it rests between two of them, the AY-3-8500 sees no game selected and plays a hidden football variant with a third bat on the right.[7] Clean the slider contacts and check that it clicks into each position.
  • Clean the two button contacts.
Hand controllers
The two black cylindrical controllers plug into the LEFT PLAYER and RIGHT PLAYER sockets on the strip below the speaker grille.[1] In the AY-3-8500's reference circuit each bat is set by a potentiometer feeding an R-C network, with 1 MΩ potentiometers and a 10 kΩ resistor in series;[6] the values in the Grandstand controllers have not been published.
  • A bat that jumps usually means a dirty potentiometer track. Open the controller, spray potentiometer cleaner into the track and turn the knob end to end.
  • Because both controllers plug in, swapping them over tells a controller fault from a socket or console fault.
  • Clean the plugs and sockets, and check each lead where it enters the cylinder.
Pistol
The archive's TVG 3600 has a black pistol with a brown chequered grip and a long barrel with a cap at the muzzle. Its lead ends in two plugs, which go into the pair of sockets marked PISTOL, one small and one larger, between the two controller sockets.[1] It is not the Thundercolt Super Marksman 304 supplied with the later Mk II.[8]
  • Keep the lens behind the muzzle clean, and check the trigger switch and the lead.
  • Clean both plugs and both PISTOL sockets; a dirty contact in either can stop the shooting games working.
  • The pistol responds to light from a cathode-ray tube television. Test it on a CRT set, not a flat-panel one.
Power
  • Read the supply and current from the base label.
  • Measure the polarity of the adaptor socket against the battery terminals before connecting an adaptor. No source gives it for the TVG 3600.
  • A Grandstand-branded adaptor found with a 3600 Mk II is rated 9 V 150 mA with the tip of its 3.5 mm plug positive, and has a polarity-reversing connector in its lead;[9] check how any such connector is set before use.
  • The Grandstand Universal Mains Adaptor sold for Grandstand's handheld and tabletop games has a polarity switch,[10] and the tabletop leaflets set it to negative.[11] Check its setting with a meter before using it on a TV game.
  • An original mains adaptor is the only part that carries mains voltage. Check its case and lead for cracks before plugging it in.
  • Remove the cells for storage; see Battery Explosion, Capacitor or Corrosion Damage if they have leaked.
RF output
No source gives the TVG 3600's channel. General Instrument's application notes for the AY-3-8500 give UHF channel E36 (591.25 MHz) as one of the two standard modulator channels,[12] so start the search there on an analogue UHF tuner; a television with only a digital tuner will not show the picture.
If your console has a colour circuit, as Wikipedia's listing suggests,[2] it will need a 4.43 MHz colour subcarrier held within ±50 Hz of 4.433619 MHz, which GI's notes give as the limit for an average colour set.[12] Do not turn any trimmer or adjustable coil near a crystal without marking its position first and measuring the result with a frequency counter.
Wearing parts
What wears on a TVG 3600
Part Check
Six slide switches and the game slider Clean and work each one; check the slider seats in each position
MANUAL and START buttons Clean the contacts
Hand controllers and their leads Clean the potentiometers; swap to compare
LEFT PLAYER, PISTOL and RIGHT PLAYER sockets Clean; check for loose sockets
Pistol Lens, trigger, lead and both plugs
Electrolytic capacitors Not documented; see Grandstand TV Game 3600 Capacitor Replacement Guide
Battery contacts Remove cells for storage
  • Remove the cells.
  • Unplug the controllers and the pistol and coil their leads loosely.
  • Keep the console dry and out of direct sun.
  1. Read the base label, then measure the adaptor and the socket's polarity.
  2. Clean the six slide switches, the game slider and the two buttons.
  3. Clean the potentiometer in each hand controller, then swap the two over and compare.
  4. Clean the pistol, its two plugs and the PISTOL sockets.
  5. Tune an analogue television and try all four bat-and-ball games, then both shooting games with the pistol on a CRT set.
  6. If you open the case, photograph the board and record the chip, crystals and capacitor values.
  1. ↑ 1.00 1.01 1.02 1.03 1.04 1.05 1.06 1.07 1.08 1.09 1.10 1.11 1.12 South-West Retro Computing Archive (University of Plymouth), "Adman Grandstand TVG 3600", item 265 (retrieved 2026-10-19). Record with no description yet ("TBC"); three photographs examined at the largest size offered show the front and top of the console only: a black case with a brushed silver strip printed "Adman GRANDSTAND TVG 3600"; slide switches POWER (ON/OFF), SOUND (ON/OFF), SPEED (H/L), ANGLE (20°/40° or 20°), BAT SIZE (L/S) and SERVE (AUTO/MANU); a yellow MANUAL and a blue START button; a speaker grille of horizontal slots in the middle; a silver strip below it with LEFT PLAYER, PISTOL (a small and a larger socket) and RIGHT PLAYER; a six-position slider marked TENNIS, FOOT BALL, SQUASH, PRACTICE, SHOOTING 1, SHOOTING 2; two black cylindrical hand controllers with knurled knobs plugged in on black leads; and a black pistol with a brown chequered grip and a long barrel with a muzzle cap, connected by two plugs.
  2. ↑ 2.0 2.1 2.2 Wikipedia, "Grandstand (game manufacturer)", table of integrated Pong consoles (retrieved 2026-10-19): "Adman Grandstand T.V. Game 3600", colour, six games, made in Hong Kong, 1977 to 1979; the row cites no source.
  3. ↑ José Antonio Ortigueira Amor, "Adman Grandstand TV Game 3600 MK II Colour (1978)", Retro Ordenadores Orty (collector's blog, in Spanish), 23 November 2023 (retrieved 2026-10-19): the 3600 series had three models (TVG 3600, Mk II and Mk III); his Mk II has its controller sockets near the front edge of the panel, its adaptor socket on the left side and its gun sockets on the right side.
  4. ↑ Photograph by José Antonio Ortigueira Amor, File:Adman Grandstand 3600 MK II Colour (15).jpg (CC BY 4.0, from Wikimedia Commons): base label of a TVG-3600 Mk II, "BATTERY: UM-2 x 6 OR AC ADAPTOR (9V / 100 MA)".
  5. ↑ Photograph by José Antonio Ortigueira Amor, File:Adman Grandstand 3600 MK II Colour (15).jpg (CC BY 4.0, from Wikimedia Commons): the base of a TVG-3600 Mk II, with a case screw in a recess beside each of the two rubber feet at one end.
  6. ↑ 6.0 6.1 General Instrument Corporation, GIMINI TV Game Circuits, January 1978, pp. 4-7, PDF hosted by Pong-Story (retrieved 2026-10-19). AY-3-8500 data sheet: games and settings are selected by connecting inputs to VSS; control inputs have on-chip pull-ups and need a contact resistance of no more than 1 kΩ; reset (pin 25) is momentarily grounded to reset the scores and start a new game; manual serve (pin 8); bat inputs (pins 11 and 12) fed by R-C networks, "Use a 10K resistor in series with each pot"; reference circuits use 1 MΩ bat potentiometers.
  7. ↑ David Winter, Pong-Story, "PONG in a Chip" (retrieved 2026-10-19): when none of the AY-3-8500's six games is selected it plays an undocumented seventh game, Handicap, a football/hockey variant in which the right-hand player has a third paddle.
  8. ↑ Centre for Computing History, "Adman Grandstand TVG-2600 Mk II", CH22783 (retrieved 2026-10-19): the Mk II-generation light gun, "Thundercolt Super Marksman 304".
  9. ↑ Ian Hill, "Adman Grandstand 3600", Ian's Retro Museum (retrieved 2026-10-19): a TVG-3600 Mk II (front label "TVG-3600 MK II") that came with a Grandstand adaptor, "9V with 3.5mm plug positive tip, this one has a polarity reversing connector in the lead"; adaptor label read from the photograph: "GRANDSTAND A.C. ADAPTOR / AC INPUT: 240v - 50Hz / OUTPUT: 9v - 150mA / Double Insulated / Made in England / MADE BY ADMAN ELECTRONICS HARROGATE".
  10. ↑ Handheld Museum, "Grandstand Universal Mains Adapter" (retrieved 2026-10-19). Collector's entry: model UGT, sold by Grandstand in the UK for its handheld and tabletop games, with a switch that toggles the polarity and turns the output off; 6-9 V DC output.
  11. ↑ Grandstand, Astro Wars instruction leaflet (Adam Leisure Group, 1981), p. 2: the game "can be operated from the mains with a GRANDSTAND Universal Mains Adaptor (not included). Set polarity switch to negative polarity." Hosted here as File:Grandstand Astro Wars Instructions.pdf.
  12. ↑ 12.0 12.1 General Instrument Corporation, GIMINI TV Game Circuits, January 1978, printed p. 81 (page 77 of the PDF), "An alternate colour encoding system", Astec International's application note on PAL colour for the AY-3-8500, PDF hosted by Pong-Story (retrieved 2026-10-19): the subcarrier oscillator "should be aligned to 4.433619MHz with a maximum tolerance of ±50Hz", because "the pull in range of the average colour television subcarrier oscillator is only about 400Hz"; the RF modulator comes in two standard versions, "VHF tuned to CH E3 (55.25MHz)" and "UHF tuned to CH E36 (591.25MHz)".
