Grandstand Video Entertainment Computer Troubleshooting Guide
Adman Grandstand Fairchild
Adman Grandstand Video Entertainment Computer (Schnurrikowski, CC BY-SA 4.0)
Fault-finding on the Grandstand Video Entertainment Computer, the UK version of the Fairchild Channel F System II. No Grandstand service information has been found. The symptom table below combines Fairchild's and Luxor's fault tables for the first-generation console, Luxor's circuit diagram of its System II, and repairs reported by owners, and says which console each finding comes from.[1][2][3] Cleaning and voltage checks are covered on Grandstand Video Entertainment Computer General Maintenance, and the electrolytic capacitors on Grandstand Video Entertainment Computer Capacitor Replacement Guide.
Before you start
  • Test with the built-in games first. With no cartridge in the slot, switch on and press RESET. "G?" should appear; press 1 for Hockey, then 4, and the game should start with the players responding to the controllers.[4][5] If the built-in games work, the CPU, the two program storage units, the video circuits and the RAM are at least partly working, and a cartridge fault is more likely to be in the cartridge or the slot.
  • Check the television side. The System II sends both picture and sound through the RF output, so set the TV's tuning and volume before suspecting the console. One owner chasing a blank screen found that the fault was in the TV.[6][7]
  • In Fairchild's and Luxor's fault tables, "P S U" is the 3851 program storage unit, the ROM chip holding the built-in program (SL31253 or SL31254), not the power supply. Forum users have read it both ways.[8][5][7]
  • Keep a circuit diagram to hand. File:Luxor TV Computer Game 1909583 Service Manual.pdf shows the System II processor board and Luxor's mains unit in full, and File:Fairchild Channel F II PAL VHF Schematic 060190-A.jpg is Fairchild's own PAL drawing of the same board. The Grandstand board carries the same main chips.[3][9][10]
Symptom table
Symptoms, causes and actions
Symptom Probable cause Action
Nothing at all: no picture and no power indication Mains adaptor, its lead or plug; power-switch board; on Luxor's version, the 80 mA fuse in the mains unit Measure the adaptor's output with it plugged into the console. Inspect the power-switch board for burnt or leaking capacitors.[3][7]
Green screen, no "G?" prompt +12 V missing: the 12 V regulator Fairchild's table gives "12 volts" as the cause and Luxor's names its 12 V regulator. Measure the 7812's input and output. If +12 V is good, measure -5 V and +12 V on the video RAM pins and +12 V on each 40-pin chip, on the chip pins, and clean oxidised pins.[1][2][11]
No picture information at all +5 V missing Luxor's first-generation table gives a missing 5 V supply. Measure the 7805's input and output.[2]
Vertical green, black and white lines, no sound, power LED on (System II) Failed 7805 regulator On one US System II the 7805 had failed and the CPU was getting too high a voltage; a new regulator cured it. Measure the 7805 output before and after it reaches the chips.[12]
Picture starts with some garbage, then fails or goes blank after seconds to minutes; works again when cold Heat-sensitive part: on two consoles with the custom-chip board, the FCM 9101/N video chip; also a regulator or capacitor Two owners traced this by spraying freezer spray on one part at a time while the fault was present: each time the FCM 9101/N video chip restored the picture. Another owner found the 7812 hot when the picture failed. No source for new video chips is known; a replacement has to come from a donor board.[7]
A capacitor on the power-switch board gets hot or bursts at switch-on; TV buzzes or loses signal Electrolytic fitted backwards by an earlier repair; failed reservoir capacitor Check every electrolytic's polarity against the board markings and an untouched console. Look for bulged capacitors and clean off any electrolyte. Check the adaptor's output.[7]
Moving bands (hum) in the picture Rectifier diode or reservoir capacitors; regulators From Luxor's first-generation table. Check the reservoir capacitors on the power-switch board and the regulators' outputs for ripple; the values are on Grandstand Video Entertainment Computer Capacitor Replacement Guide.[2]
Red or blue dots or "holes" in the picture; stripy, scrambled screen One of the four video RAM chips See #Video RAM. RAM failure is common and usually gives a striped, scrambled screen.[1][2][11]
Whole screen covered in multicoloured dots or bands; console will not reset One of the two program storage units (SL31253, SL31254), or a poor contact at its pins From Fairchild's and Luxor's tables. Clean the chips' pins first. One owner cured graphics corruption by fitting an SL31253 from a donor board.[1][2][5]
Garbage on screen, no game sounds, games will not start; or parts of a cartridge game do not work CPU (SL31291) Luxor's first-generation table points to the CPU when cartridge functions fail. One owner revived a dead console with a CPU from a donor board, and another proved a System II CPU good by trying it in a first-generation console.[2][5][12]
Built-in games work, cartridges do not Dirty cartridge contacts; flat cables to the cartridge connector; bent springs in the cartridge holder Clean the Videocart contacts. Check the flat cables are seated. On Luxor's first-generation console the remedy for bent holder springs was a new holder.[2][3]
Some controller movements do nothing Broken wire in the controller lead; broken contact spring in the controller; the input buffer Swap the two controllers between their sockets: if the fault follows the controller, repair the controller (see Grandstand Video Entertainment Computer General Maintenance#Controllers). If it stays with the socket, check the socket and the input buffer: on the System II the controller lines pass through the 9102 audio/buffer chip; on the first-generation console they pass through 74368 and 7404 logic chips.[2][3][5]
No colour Crystal, colour choke or trimmer out of adjustment From Luxor's first-generation table (4.43 MHz crystal, choke, trimmer capacitor). On the System II the crystal has a 3-15 pF trimmer beside it; adjust it only after checking the TV and the crystal.[2][3]
Picture drifts or is lost; the TV cannot hold the channel RF lead or connection Fairchild's table gives the RF cable as the cause of "out of frequency". Check the lead and its plugs, and the console's channel switch where fitted.[1]
Power rails
The System II's rails, from Luxor's diagram, are +12 V from a 7812, +5 V from a 7805, a +14 V line from a 78L12 and a -5 V supply made on the board for the video RAM.[3] Measured values from US consoles and the measuring points are tabled on Grandstand Video Entertainment Computer General Maintenance#Power supply and voltage checks.
  1. Measure the 7812 and 7805 inputs. Low or missing input points to the adaptor, the power-switch board or its capacitors.
  2. Measure the outputs. Good input and missing output means a failed regulator.[12][11]
  3. Measure at the chips: +12 V and -5 V on the video RAM (pins 8 and 9, and pin 1), and +12 V and +5 V at the 40-pin chips.[3][11]
  4. If a rail is low only at one chip, look for a cracked joint, a damaged track or, on socketed chips, oxidised pins.[11]
Video RAM
The picture is held in four 4096 × 1-bit DRAMs. On the scanned Grandstand board they are Mostek MK4015N; US System II boards have been reported with SCM90004C chips and Luxor's diagram labels them "330470".[10][12][3]
Finding the bad chip
The two bits of each pixel are stored in different chips, so a faulty chip shows as dots, holes or stripes in one colour. Fairchild's test cartridge for the first-generation console showed red and blue sweep bars and tied holes in the blue bar to RAM D9 or D10 and holes in the red bar to D7 or D8; Luxor's first-generation table gives E9 or E10 for red dots and E7 or E8 for blue.[1][2] The board positions differ on the System II, where Luxor's diagram labels the four chips EVEN 0, ODD 0, EVEN 1 and ODD 1.[3] Where the chips are socketed, swapping them round shows whether the fault moves with a chip.[13]
Choosing a replacement
The two generations of board feed their RAM differently, and a substitute that suits one may not suit the other.
  • VESwiki gives MK4027-compatible DRAM for the first-generation board and MK4015N-compatible DRAM for the second generation, which includes the System II.[14]
  • Luxor's diagram of the System II board shows -5 V on pin 1 and +12 V on both pins 8 and 9 of each RAM chip.[3]
  • On a second-generation board, an MK4027N-3 gave a black screen and became very hot within seconds. A RAM chip taken from a first-generation console worked in the same position.[13]
  • On a first-generation console, one owner had to replace all four chips with MK4027 at once: a mixture of old and new chips gave glitches and resets.[13]
  • VESwiki describes fitting 4164 DRAMs, which run from +5 V alone, with pin 8 lifted and joined to pin 9 and a 1 nF capacitor from pin 14 to ground, in what it calls the "System Fairchild unit"; it does not say which generation of board that was. The change relies on pin 9 carrying +5 V, as on the MK4027 pinout. On the System II, Luxor's diagram puts +12 V on both pins 8 and 9, so a 4164 fitted that way would receive +12 V. Do not fit 4164s to a System II without working out the supplies first.[14][3]
Custom and programmed chips
Chips that can only be replaced from a donor board
Chip Function Notes
SL31291 (3850) CPU A System II's CPU has been tested in a first-generation console, so the two take the same part[12]
SL31253 and SL31254 (3851) Program storage units with the built-in program Mask-programmed ROM; cannot be reprogrammed with an EPROM programmer[5][15]
FCM 9102 Controller input buffer and tone output Not on the first-generation (standard logic) board[3][2]
FCM 9101/N or FCM 9111 (Luxor diagram: 9111; Fairchild PAL drawing: 9101) Video Not on the first-generation (standard logic) board. Reported heat-sensitive on two consoles; VESwiki's author warns that a failed one is very hard to replace[7][11][9]
Clean and reseat the pins of a suspect chip, and check its supplies, before condemning it. VESwiki's author cautions that a chip which seems faulty may only have oxidised pins or a poor socket contact.[11][5]
First-generation fault tables
Fairchild's and Luxor's own fault tables were written for the first-generation console, which builds the video circuits from standard logic chips. The supply, RAM, program storage unit, CPU, cartridge holder and controller entries carry over to the System II; the entries for individual logic chips do not, because the System II replaces those chips with its two custom chips.[6][3]
Luxor service bulletin No. 5, 15 February 1979, for the first-generation console type 190 9574 (translated from Swedish)
Symptom Cause given Applies to System II?
Green screen, no game (G?) prompt Q6, 12 V regulator faulty Yes: the 12 V supply
No information on the screen Q5, 5 V missing Yes: the 5 V supply
Colour fault (no colour) The 4.43 MHz crystal or choke L4; check trimmer capacitor C25 and adjust if needed In principle; part numbers differ
Moving bands (hum) Faulty rectifier diode or electrolytic C4, C5, and Q5 and Q6 Yes: rectifier, reservoir capacitors and regulators
Dots visible on the screen (blue or red) ICs E9, E10 for red; E7, E8 for blue Yes: video RAM, at different positions
Whole screen covered in multicoloured dots or bands C10 (SL31254), C8 (SL31253) Yes: program storage units
No sync, picture looks overdriven D1 (7486) No: logic chip not on the System II
Intermittent sync fault (heat fault) F8 (7493) No: logic chip not on the System II
Some functions of a cartridge do not work Check C7 (SL31291) Yes: CPU
No information from the cartridge Springs in the cartridge holder bent upwards; replace the whole holder Possibly: holder design not documented for the System II
Horizontal bands (green, blue, red, usually only two) E6 (7400) No: logic chip not on the System II
Some typical functions of a hand controller do not work Break in the cable or a broken contact spring; also check A10 (CTS 7715), A9 and A8 (74368), A7 (7404) Cable and contacts yes; on the System II the buffering is in the 9102
Translated from File:Luxor TV Computer Game 1909574 Service Manual.pdf;[2] System II comparison from Luxor's System II diagram.[3]
Fairchild's own "Analysis Aid" for the original console gives four conditions, "no reset" (PSU), "green screen" (12 volts), "weak sound" (speaker binding) and "out of frequency" (RF cable), followed by eighteen numbered photographs of faulty screens with their causes, which range from the PSU, the RAM and the CPU to colour and frequency adjustment; several are marked as needing detailed analysis.[1] Wikipedia says the System II has no internal speaker, but Luxor's System II has a loudspeaker in its parts list and circuit diagram, so the speaker entry may apply to some versions.[6][3]
  1. ↑ 1.0 1.1 1.2 1.3 1.4 1.5 1.6 Fairchild, Service Manual for the Video Entertainment System, c. 1976. Hosted here as File:Fairchild Video Entertainment System Service Manual.pdf: test cartridge RAM test ("holes" in the blue bar: RAM D9 or D10; in the red bar: D7 or D8); "Analysis Aid": no reset, PSU; green screen, 12 volts; weak sound, speaker binding; out of frequency, RF cable; pictures 100 to 117 with causes.
  2. ↑ 2.00 2.01 2.02 2.03 2.04 2.05 2.06 2.07 2.08 2.09 2.10 2.11 2.12 Luxor, Service Manual, TV Computer Game, type 1909574, August 1978, with Servicemeddelande No. 5, 15 February 1979, "Servicetips TV-datorspel typ 190 9574". Hosted here as File:Luxor TV Computer Game 1909574 Service Manual.pdf: first-generation fault table (in Swedish), translated in full in the table above.
  3. ↑ 3.00 3.01 3.02 3.03 3.04 3.05 3.06 3.07 3.08 3.09 3.10 3.11 3.12 3.13 3.14 3.15 Luxor, Service Manual, TV Computer Game, type 190 9583, May 1980. Hosted here as File:Luxor TV Computer Game 1909583 Service Manual.pdf: System II processor board diagram: U1 3850 (SL31291), U2 and U3 3851 (SL31254, SL31253), U4 9111 video, U5 9102 audio/buffer with the controller lines, U6-U9 RAM "330470" (EVEN 0, ODD 0, EVEN 1, ODD 1) with -5 V on pin 1 and +12 V on pins 8 and 9, Y1 crystal with C18 3-15 pF trimmer, 7805, 7812 and 78L12 regulators, -5 V generator; flat cables to the cartridge connector; mains unit with 80 mA fuse.
  4. ↑ Fairchild Video Products, Channel F System II: Playing Tennis / Playing Hockey. Hosted here as File:Fairchild Channel F System II Built-in Games Instructions.pdf: RESET gives "G?"; 1 selects Hockey; 4 starts at once.
  5. ↑ 5.0 5.1 5.2 5.3 5.4 5.5 5.6 AtariAge Forums, "Fairchild Channel F Repair - Help Request", October 2016 to May 2017 (retrieved 2026-10-18): Hockey started by pressing 1 then 4 as a test; a dead console revived with an SL31291 from a donor board; graphics corruption cured by an SL31253 from the donor; the program storage units cannot be reprogrammed; "PSU" in the service manual read as the program storage unit; e5frog's caution that swapped chips may only have had oxidised pins or a poor socket; controller lead repair.
  6. ↑ 6.0 6.1 6.2 Wikipedia, "Fairchild Channel F" (retrieved 2026-10-18), for framing: the System II sends its sound through the television instead of an internal speaker, and two custom chips replace the first generation's standard logic chips.
  7. ↑ 7.0 7.1 7.2 7.3 7.4 7.5 AtariAge Forums, "Explosive Fairchild Channel F problems", August 2018 to June 2020, two pages (retrieved 2026-10-18): US System II with reversed and bulged capacitors on the power-switch board, a 7812 hot when the picture failed, and "PSU" in the service manual read as the power supply; a blank screen traced to the TV; two owners (one with a first-generation console fitted with the custom-chip board) whose fading picture was restored each time by freezer spray on the FCM 9101/N chip.
  8. ↑ VESwiki (channelf.se), "F8" (retrieved 2026-10-18): the 3851 program storage unit (PSU), 1 KB of ROM.
  9. ↑ 9.0 9.1 Fairchild Camera and Instrument, Video Products Division, drawing 060190-A, "IC PAL VHF Schematic". Hosted here as File:Fairchild Channel F II PAL VHF Schematic 060190-A.jpg (from VESwiki, where it is published as the SABA Videoplay 2 schematic): U1 3850 CPU; U2 and U3 3851 PSUs; U4 9101 video; U5 9102 audio/buffer; U6-U9 "330470" RAM; Y1 8.867238 MHz with C18 3-15 pF trimmer; Q4 7805 with C50 47 µF on +5 V; Q5 7812 with C52 100 µF on +12 V; -5 V at 800 µA.
  10. ↑ 10.0 10.1 Incog88, scan of the Grandstand Video Entertainment Computer main board, from Wikimedia Commons (CC BY-SA 3.0), read at full size: 3850 SL31291, SL31253, SL31254, FCM 9102, four Mostek MK4015N DRAMs, an unmarked 40-pin ceramic chip.
  11. ↑ 11.0 11.1 11.2 11.3 11.4 11.5 11.6 AtariAge Forums, "Fairchild Channel F Green Screen", October 2020 (retrieved 2026-10-18): green screens on first-generation consoles, one with a 78M12 regulator giving no output; advice from e5frog (Fredric Blåholtz, author of VESwiki) to check 12 V, then -5 V on the RAM and 12 V on each 40-pin chip at the pins, that oxidised pins can cause poor socket contact, that RAM failure is common and usually gives a striped, scrambled screen, and that a failed custom (VLSI) chip on a Channel F II is very hard to replace.
  12. ↑ 12.0 12.1 12.2 12.3 12.4 AtariAge Forums, "Fairchild Channel F System 2 Chip", February 2020 to November 2021 (retrieved 2026-10-18): System II with power LED on, vertical green, black and white lines and no sound, cured by replacing the 7805 after high voltage was found at the CPU; its SL31291 tested good in a first-generation console; chips on the board including four SCM90004C RAMs and the FCM 9101/N video chip.
  13. ↑ 13.0 13.1 13.2 AtariAge Forums, "Fairchild Channel F Model 2 - RAM type?", December 2019 to November 2021 (retrieved 2026-10-18): bad RAM located by swapping chips round; MK4027N-3 overheating with a black screen on a second-generation board while a first-generation console's RAM worked; on a first-generation console all four RAMs had to be replaced with MK4027 together.
  14. ↑ 14.0 14.1 VESwiki, "VRAM" (retrieved 2026-10-18): MK4027-compatible RAM in the first generation and MK4015N-compatible in the second; MK4027/MK4015 pinout (pin 1 -5 V, pin 8 +12 V, pin 9 +5 V); 4164 substitution for the "System Fairchild unit" with pin 8 lifted and tied to pin 9 and a 1 nF capacitor from pin 14 to pin 16.
  15. ↑ MAME source, channelf.cpp (commit 774a180): the built-in program held in SL31253 and SL31254.
