IBM 3270 PC/GX Troubleshooting Guide
This guide documents fault diagnosis for the IBM 3270 PC/GX (machine type 5371). POST is identical to the IBM 3270 PC and IBM 3270 PC/G โ standard XT 1xxโ19xx codes plus 28xx (3278/79 Emulation Adapter) and 32xx (Display Adapter / APA / PSS). PC/GX-specific failures manifest in the IBM 5378 Display Attachment Unit, the IBM 5379 19" Color Display, or the Graphics Control Program (GCP) layer.
Reference Documents
[edit | edit source]- IBM GA33-3141-0 โ Introducing the IBM 3270 Personal Computer/G and /GX Workstations (May 1984).
- IBM SA38-0037-00 โ Personal Computer Family Service Information Manual (July 1989), Chapter 10.
- IBM 1502336 โ PC 3278/79 Emulation Adapter Technical Reference (October 1983).
Initial Diagnosis Workflow
[edit | edit source]A working PC/GX boots:
- Standard IBM PC XT POST.
- Keyboard Adapter exposes the Display Adapter's video BIOS.
- Standard 3270 PC Display Adapter output is routed through the 5378 to the 5379.
- IBM PC DOS 2.0 / 2.1 boots.
- Graphics Control Program (GCP) loads.
- GCP initialises the 5378.
- Mainframe sessions render on the 5379 at 1024 ร 1024 APA resolution.
POST Codes
[edit | edit source]Identical to the IBM 3270 PC Troubleshooting Guide:
- 1xxโ19xx โ standard XT chassis.
- 28xx โ 3278/79 Emulation Adapter.
- 3201โ3250 โ Display Adapter.
- 3261โ3279 โ PSS card.
- 3280โ3289 โ APA card.
The 5378 is not POST-tested (it operates downstream of the Display Adapter); 5378 faults present as GCP errors or no display on the 5379 rather than POST codes.
5378 Attachment Unit Diagnosis
[edit | edit source]The 5378 is larger and more complex than the /G's 5278, and is the most likely PC/GX-specific failure point:
- No display on 5379 but POST passes โ 75-pin cable between 5378 and 5379 disconnected or with pin damage; or 5378 internal PSU dead.
- 5378 PSU dead โ 5378 has its own mains lead and internal PSU. Verify the mains lead is connected, the rear-panel power switch is on, and the 5378's status LEDs (if any) are illuminated.
- CGA-compatible mode works but 1024 ร 1024 APA does not โ the 5378's high-resolution vector graphics processor or extended frame buffer has failed; CGA-compatible mode comes through the Display Adapter directly.
- Mainframe graphics rendered correctly but very slowly โ 5378's local processor may be running in fallback mode (e.g. host-side rendering instead of local pan / zoom).
5379 19" Display Diagnosis
[edit | edit source]- No raster on 5379 โ flyback failure (high anode voltage means flyback insulation is the most common end-of-life mechanism on 19" 5379s); horizontal output transistor failure; PSU dead.
- Raster but no characters / graphics โ video signal from 5378 not arriving; check 75-pin cable.
- Visible phosphor burn-in โ display has been used for sustained periods on static graphics. No field repair; replacement requires a 5379 donor.
- Convergence drift (colour misregistration) โ adjustment via the 5379 service controls; if unfixable, replacement.
- Geometry distortion (pincushion / barrel) โ deflection coil or yoke issue.
Graphics Control Program (GCP) Diagnosis
[edit | edit source]Same as the IBM 3270 PC/G Troubleshooting Guide โ GCP runs on PC DOS, loads after standard 3270 PC Control Program init, and manages the 5378's local processor via the system unit's Display Adapter card.
GCP-specific failures on the /GX:
- GCP loads but reports "Display Attachment Unit not found" โ 5378 not detected. Verify the cable between the 5371 and 5378 (different connector from the 75-pin cable to the 5379).
- GDDM application crashes when sending high-resolution graphics โ 5378 frame buffer issue; reseat the frame buffer RAM modules in the 5378.
- Mouse not tracked correctly โ IBM 5277 cable issue or GCP misconfiguration.
Common Field Symptoms
[edit | edit source]- POST passes but no 5379 display โ 5378 PSU or 75-pin cable.
- POST passes, DOS boots, GCP fails โ version mismatch (GCP for /GX is a different image from GCP for /G).
- Graphics work in DOS but not in mainframe sessions โ 5378 vector graphics processor failure.
- Random reboots when warm โ PSU caps aged (any of the three PSUs: 5371, 5378, 5379); recap.
- Smell of fish from any unit โ RIFA X2 mains-suppression cap venting; power off immediately.
- Severe phosphor burn-in on 5379 โ CRT end-of-life.
- Display geometry distortion appears gradually โ deflection-board electrolytic ageing; recap the 5379 deflection board.
Diagnostic Workflow Summary
[edit | edit source]- Power on; observe POST.
- If POST fails, treat as standard 3270 PC chassis fault.
- If POST passes but no 5379 display, check 5378 (PSU, cable to 5379, cable from 5371).
- If 5379 shows DOS text but no high-resolution graphics, suspect 5378 vector graphics processor or expanded frame buffer.
- If GCP fails to load, verify version matches /GX configuration.
- If 5379 shows convergence drift or burn-in, suspect CRT end-of-life; donor required.
Related Pages
[edit | edit source]- IBM 3270 PC/GX
- IBM 3270 PC/GX Maintenance Guide
- IBM 3270 PC/GX Capacitor Replacement Guide
- IBM 3270 PC/G Troubleshooting Guide โ smaller-display sibling, very similar workflow
- IBM 3270 PC Troubleshooting Guide โ chassis-level codes
[edit | edit source]- IBM SA38-0037-00 (July 1989), Chapter 10.
- IBM GA33-3141-0 (May 1984).
