IBM PS/2 Model 25 Troubleshooting Guide
IBM's service procedure for the IBM PS/2 Model 25 (machine type 8525) is in its 1994 Personal System/2 Hardware Maintenance Manual, which covers the Model 25, 25 286 and 25 SX with the other AT-bus PS/2s (Models 25, 30, 33, 35, 40 and 55).[1] It works down to field-replaceable units (FRUs). On the Model 25 the power supply is inside the display assembly, and IBM's FRU for it is the whole display assembly. "Display Assembly (8525)" appears in IBM's lists for power and drive faults.[2][1]
Which machine you have
[edit | edit source]| Machine | Models | Clock and battery | Password jumper |
| Model 25 (8086) | 001, G01, 004, G04, L01, L04 | No real-time clock and no battery | None |
| Model 25 286 | 006, G06, 036, G36 | Dallas DS1287 clock module at ZM35, FRU 8509237 | J13 |
| Model 25 SX | K00, K01, L02 | CR2032 cell at B1, FRU 33F8354 | J2 |
Sources: ardent-tool's board and battery pages and IBM's manual.[3][4][5][6][1] The 8086 machine's BIOS reports "No Real-time clock", so it cannot give battery or clock errors.[7]
General checkout
[edit | edit source]IBM's starting point for all AT-bus PS/2s:[1]
- Switch off the computer and all external devices.
- Check all cables and power cords.
- Make sure there are no diskettes in the drives.
- Switch on the external devices, then the computer.
- If a POST error code appears, go to the symptom-to-FRU index below. If several appear, deal with the first one first; it can cause the others.[8]
Configuration and Advanced Diagnostics run from the model's Reference or Starter Diskette (Ctrl-A at the main menu for Advanced Diagnostics). Power on with the diskette already in the drive: soft-booting it can cause false errors and a false report that a power-on password is set. If the diagnostics do not fail, replacing parts will probably not help.[8]
IBM symptom-to-FRU index
[edit | edit source]Selected entries from IBM's AT-bus index, in IBM's order of FRUs to try:[1]
| Symptom | FRUs, in order |
| No beep, power indicator off, fan not running (check the voltage switch) | Power supply |
| No beep during POST (check the voltage switch) | System board; power supply; display assembly (8525); memory module (8525); any adapter; bus adapter |
| No beep, fan runs, indicator on, hangs in POST with a message | System board; power supply |
| No beep, otherwise working | Speaker assembly |
| One long and two short beeps | System board; display adapter |
| More than one beep | System board; any adapter |
| Continuous beep | System board |
| Repeated short beeps | Keyboard (stuck key?); keyboard cable; system board |
| Symptom or code | FRUs, in order |
| Blank or unreadable display | System board; power supply; display adapter; display assembly; system board video cable |
| Insert-diskette icon, or the system starts BASIC | Diskette drive; system board; diskette cable; network adapter |
| Incorrect memory size, or PARITY CHECK 1 | System board (see memory isolation below) |
| Real-time clock loses time | Bus adapter; clock module; system board (often software; see below) |
| 161, 163, 165 | Set time and date; bus adapter; clock module; battery; system board |
| 162 | Run setup or Automatic Configuration; clock module; system board |
| 1xx | System board |
| 2xx | System board (see memory isolation below) |
| 302 | Keylock locked?; keylock assembly; system board |
| 3xx (other) | Keyboard; system board; keyboard cable |
| 604, 662 | Wrong diskette drive type |
| 663 | Wrong media type |
| 6xx (other) | Diskette drive; external drive adapter; system board; power supply; display assembly (8525); diskette drive cable |
| 17xx | Hard disk drive; system board; hard disk cable; power supply; display assembly (8525) |
| 2401, 2402, if screen colours change | Display |
| 2401, 2402, if screen colours are correct | System board; display |
For 305, a keyboard voltage error, IBM's order is the keyboard port fuse, the keyboard cable, then the system board, and if there is no fuse the system board.[8] The keyboard and mouse fuse is F1 on the Type 2, 286 and SX boards; the Type 1 8086 board has F1 and F2.[3][4][5] IBM's diskette-error note is that most 6xx codes are media errors: try a known-good diskette, and replace the drive if the error comes back.[8]
Dead machine
[edit | edit source]IBM's check for a machine that shows no sign of power: confirm the power cord is in place and has continuity, and that the voltage switch is set correctly. If the cord is good, either the supply is defective or a device is making it shut down; measure the supply voltages, replace the supply if they are wrong, and go to IBM's undetermined-problem procedure if they are right.[1]
Ardent-tool's transcription of IBM's dead-system procedure adds that a short from a device, a badly fitted memory module or a faulty adapter stops the system board presenting Power Good to the supply within 150 ms, and the supply then shuts down. Its listed causes include a SIMM fitted backwards, an adapter not fully seated, an unsupported adapter, and too many drives starting at once. Loose line cords cause intermittent faults and unexpected resets; check both ends.[8]
- Remove all adapters, options and extra memory, and all external connections.
- Switch on and listen for a beep.
- No beep: check the speaker; if it is good, replace the system-board memory and try again; if there is still no beep, measure the supply. Correct voltages mean the system board; wrong voltages mean the supply.
- A beep: refit the removed items one at a time until the fault returns.[8]
Supply voltages
[edit | edit source]Measure at J7 on the system board with the machine switched on. Pin 1 is towards the rear.[9][1]
| Rail | − lead | + lead | Minimum | Maximum |
| +5 V | J7-5 | J7-10 | +4.8 V | +5.2 V |
| −5 V (leads reversed) | J7-9 | J7-5 | +4.5 V | +5.4 V |
| +12 V | J7-5 | J7-3 | +11.5 V | +12.6 V |
| −12 V (leads reversed) | J7-4 | J7-8 | +10.8 V | +12.9 V |
Power Good (J7-1) should read +3.5 to +5 V on a working machine. If it does not, remove all adapters, cables and extra memory and try again; if Power Good is then correct, refit the devices one at a time to find the one causing the short.[9] The supply's voltage switch must be set to the 100–125 V or 200–240 V range before the cord is plugged in.[9]
For the 8086 machine, IBM's under-voltage sense levels are +3.2 V, −2.4 V, +10.5 V and −8.6 V on the +5, −5, +12 and −12 V outputs, and Power Good is active at 2.4 to 5.25 V.[2] Ardent-tool's shared 8525/8530 power page gives +4.5, −4.3, +10.8 and −10.2 V, which are the figures in IBM's Model 30 Technical Reference.[9][10]
Memory isolation (8086 machine)
[edit | edit source]IBM's procedure for the 8086 Model 25:[1]
- PARITY CHECK 1 means system-board memory has failed. With 512 KB fitted, replace the memory module packages. With 640 KB fitted and an address below 20000 shown under the message, replace the optional memory modules; otherwise replace the memory module packages.
- PARITY CHECK 2 means adapter memory has failed.
- Memory errors appear as AAAAAA BB CCCC 20X. For a 205 error, each non-zero digit of CCCC points at a module: from left to right U35, U34, U22 and U16. If CCCC is 0000, the sixth digit of AAAAAA decides: odd (1, 3, 5, 7, 9, B, D, F) means ZM1, otherwise ZM2.
Display
[edit | edit source]The 2401 and 2402 entries above use the screen colours to split display from system board.[1] On the 8086 machine, intermittent wrong characters or unexpected underlining in applications that load more than one font are covered by IBM's ECA 023: boards with a gate array marked 72X8300 at U11 were replaced with system board FRU 96F7390.[11]
Clock, battery and password
[edit | edit source]- The Model 25 286 keeps its clock and configuration in the DS1287 module. Ardent-tool lists the DS12887 and DS12887+ as replacements, and the 'A'-suffix parts as usable; it warns against the DS12C887, which uses the century byte differently and apparently does not work in a PS/2.[6]
- The Model 25 SX uses a CR2032. Measure it out of the holder: it should be 2.5 to 3.7 V, and it should be replaced below 2.5 V. Low voltages can corrupt CMOS bits.[6]
- A weak battery loses all the setup information; if only part is lost, the battery is probably not the cause.[8] IBM notes that the time-of-day clock is interrupt-driven and drifts with interrupt activity; check the time in the Reference Diskette's Set Features menu, and if it is right the problem is software.[1]
- To remove a forgotten power-on password on the 286 (J13) or SX (J2): switch off, unplug, remove the cover, move the jumper to join the centre pin and the pin at the other end, and switch on. The password is erased, and the jumper does not need to be moved back. Reset the date, time and configuration afterwards.[1]
[edit | edit source]- ↑ 1.00 1.01 1.02 1.03 1.04 1.05 1.06 1.07 1.08 1.09 1.10 IBM, Personal System/2 Hardware Maintenance Manual, S52G-9971-02, October 1994, hosted as IBM Personal System 2 Hardware Maintenance Manual (S52G-9971-02, October 1994). General Checkout (AT Bus), p. 3; Memory Problems (8086 Computers), pp. 6 to 8; Symptom-to-FRU Index (AT Bus), pp. 12 to 17; power supply connector, p. 138; Real-Time Clock Problems, p. 150; Removing a Power-On Password, p. 376; Model 25 parts, pp. 223 to 225.
- ↑ 2.0 2.1 IBM, IBM Personal System/2 Model 25 Technical Reference, June 1987, section 3, "Power Supply", pp. 3-3 to 3-6, hosted as IBM PS2 Model 25 Technical Reference (June 1987).
- ↑ 3.0 3.1 Ardent Tool of Capitalism, "8525 Planar", based on content by William R. Walsh. 8086 board designators and known problems.
- ↑ 4.0 4.1 Ardent Tool of Capitalism, "8525-286 Planar".
- ↑ 5.0 5.1 Ardent Tool of Capitalism, "8525 SX Planar", based on content by William R. Walsh.
- ↑ 6.0 6.1 6.2 Ardent Tool of Capitalism, "PS/2 RTC/CMOS Batteries", based on content by Bob Eager and Peter H. Wendt.
- ↑ IBM, IBM Personal System/2 Model 25 Technical Reference, June 1987, p. 5-45, hosted as IBM PS2 Model 25 Technical Reference (June 1987).
- ↑ 8.0 8.1 8.2 8.3 8.4 8.5 8.6 Ardent Tool of Capitalism, "PS/2 Error Codes" and the linked code lists (e.g. 300-999). Transcriptions of IBM's error lists, Reference Diskette notes and the dead-system procedure.
- ↑ 9.0 9.1 9.2 9.3 Ardent Tool of Capitalism, "8525 / 8530 Power". J7 measurement limits for the Models 25, 25 SX and 25-286, Power Good reading, and the voltage switch warning.
- ↑ IBM, IBM Personal System/2 Model 30 Technical Reference, January 1987, Figure 3-3, hosted as IBM PS2 Model 30 Technical Reference (January 1987).
- ↑ Ardent Tool of Capitalism, "MCGA", "Erroneous/False Display Characters (ECA 023, M/T 8525)".
[edit | edit source]- IBM PS/2 Model 25
- IBM PS/2 Model 25 Maintenance Guide
- IBM PS/2 Model 25 Capacitor Replacement Guide
- IBM PS/2 Model 30 Troubleshooting Guide
- Capacitor Failure Symptoms
