IBM PS/2 Model 80 Capacitor Replacement Guide
This guide documents capacitor diagnosis and replacement for the IBM PS/2 Model 80 (machine type 8580, all submodels), covering the planar, the 225 W PSU, the IBM ESDI Fixed Disk Adapter/A, the floppy and ESDI drive logic boards, and notes on the Type 1 vs Type 2 planar differences.
The Model 80 planar shares the famous surface-mount aluminium electrolytic failure mode with the IBM PS/2 Model 70. Recapping a Model 80 planar is a more substantial undertaking than recapping a Model 70 — the larger SMD cap count and the dense layout near the MCA bus controller make the work harder.
Safety Warning
The 225 W PSU contains mains-rectified bulk capacitors that hold a lethal charge after power-off. Before any PSU work:
- Power off and unplug the mains lead.
- Wait at least 30 seconds.
- Discharge the bulk capacitor through a 1 kΩ / 5 W resistor.
- Verify with a multimeter.
The Model 80's PSU bulk capacitor is the same value as the Model 60 225 W PSU's (220 µF / 200 V).
Planar SMD Electrolytic Leakage — Primary Failure Mode
The Model 80 planar carries 40–50 surface-mount aluminium electrolytic capacitors (the exact count varies between Type 1 and Type 2 planars; Type 2 has slightly more). After 30+ years the rubber bung seal at the base of these caps degrades and the corrosive aluminium electrolyte leaks onto the planar.
The failure progression is the same as on the Model 70 (see IBM PS/2 Model 70 Capacitor Replacement Guide):
- Discolouration of solder mask near the cap base.
- Crusty deposits on adjacent vias and traces.
- First intermittent POST faults — system passes cold, fails warm.
- Permanent loss of specific functional blocks (VGA, RTC, MCA bus controller).
- Dead planar with corroded traces and lifted pads.
Detection
- Power off, unplug, discharge PSU.
- Remove the planar from the chassis floor (drive cage and MCA riser must be lifted first).
- Inspect both sides under a USB microscope or magnifier with bright lighting.
- Photograph every cap location for reference.
If any SMD cap shows leakage, all of them should be replaced.
Replacement Procedure
- Photograph the planar from both sides at high resolution. Record every cap's location, value, orientation.
- Remove every SMD electrolytic with a hot-air rework station (set to 320 °C, 30 seconds per cap).
- Clean each pad with solder wick.
- Wash the planar with isopropyl alcohol (90%+). For severely contaminated planars, an ultrasonic cleaner with planar-safe detergent. Dry thoroughly.
- Inspect every pad for damage. Repair lifted pads or corroded traces with 30 AWG enamelled wire or a UV-cure trace repair kit.
- Fit replacements: through-hole 10 µF / 16 V tantalum (preferred) or SMD low-ESR aluminium 10 µF / 16 V; through-hole 47 µF / 16 V or equivalents.
- Verify polarity on every cap before soldering.
Capacitor Locations on the Planar
The Model 80 planar carries SMD electrolytics in these typical locations (counts approximate, vary by planar revision):
- Near the 80386DX socket — 10 µF / 16 V bypass × 4–6.
- Near the VGA chip and VRAM — 10 µF / 16 V bypass × 6–8.
- Near the SIMM sockets — 47 µF / 16 V bulk × 4 (one per SIMM slot).
- Near the MCA bus controller — 10 µF / 16 V bypass × 4–6 (more than Model 70 due to 8-slot vs 3-slot bus).
- Near the floppy controller — 10 µF / 16 V bypass × 1–2.
- Near the RTC (DS1287) — 10 µF / 16 V bypass × 1.
- Near each MCA slot rear — 10 µF / 16 V bypass × 1 per slot (8 total).
- Near the power-input filter — 47 µF / 16 V bulk × 2–3.
Planar Capacitors Summary
| Value | Voltage | Type | Quantity | Notes |
| 10 µF | 16 V | SMD aluminium (original) → tantalum / SMD low-ESR replacement | ~35–40 | IC bypass throughout, MCA slot bypass × 8 |
| 47 µF | 16 V | SMD aluminium (original) → tantalum / SMD low-ESR replacement | ~8–10 | Bulk filtering near SIMM sockets and power input |
| 22 µF | 16 V | SMD aluminium (original) → SMD low-ESR replacement | ~2–4 | On some planar revisions (Type 2 typically) |
The exact count depends on planar revision. Type 1 and Type 2 planars have different layouts; Type 2 has slightly more caps near the SIMM controller.
225 W PSU Recap
The Model 80 225 W PSU is electrically very close to the Model 60 8560-071's 225 W PSU. The cap list is essentially the same:
| Value | Voltage | Type | Typical position | Notes |
| 2200 µF | 16 V | Low-ESR aluminium electrolytic, 105 °C | +5 V smoothing × 2 | Critical for +5 V stability |
| 2200 µF | 25 V | Low-ESR aluminium electrolytic, 105 °C | +12 V smoothing × 1 | Drive motor rail (sized for 314 MB drive) |
| 470 µF | 35 V | Aluminium electrolytic, 105 °C | +12 V auxiliary × 1 | |
| 220 µF | 35 V | Aluminium electrolytic, 105 °C | −12 V smoothing × 1 | |
| 100 µF | 50 V | Aluminium electrolytic, 105 °C | Primary auxiliary × 2 | |
| 100 µF | 16 V | Aluminium electrolytic, 105 °C | Bypass / feedback × 2–3 | |
| 47 µF | 50 V | Aluminium electrolytic, 105 °C | Primary startup × 1 | |
| 220 µF | 200 V | Aluminium electrolytic, 105 °C | Primary bulk × 1 | Lethal charge — discharge before work |
| 0.1 µF | 275 VAC | X2 class | Mains suppression × 1 | Replace if RIFA-branded |
Recap Procedure
- Discharge the bulk capacitor; verify with a multimeter.
- Remove the PSU from the top of the chassis (4 screws).
- Open the PSU housing. The Model 80 PSU shell is normally screwed.
- Photograph the board. Mark each electrolytic's polarity.
- Desolder each electrolytic with solder wick.
- Fit low-ESR, 105 °C replacements, equal capacitance, equal or higher voltage rating.
- Inspect the X2 mains suppression cap. If RIFA-branded or cracked / bulging, replace.
- Reassemble. Verify rails on the bench with a multimeter under a 1 A resistive load before refitting to the chassis.
ESDI Fixed Disk Adapter/A Capacitors
The IBM ESDI Fixed Disk Adapter/A drives the 44 / 70 / 115 / 314 MB ESDI drives on the 8580. The 314 MB drive on the server configurations (-311 / A31) uses a slightly different revision of the controller card with the same cap values:
- 10 µF / 16 V (multiple positions) — IC bypassing.
- 22 µF / 16 V (one or two positions) — sector buffer power.
- 47 µF / 16 V (one position) — on-card 5 V regulation.
If the ESDI controller reports a 10455 or 10463 on a known-good drive, recap the controller card capacitors before condemning the card.
ESDI Drive Logic Board
The 44 / 70 / 115 / 314 MB ESDI drives carry their own drive logic board with aluminium electrolytics. Typical values:
- 47 µF / 16 V — near the spindle motor driver.
- 10 µF / 25 V — near the head-amp section.
- 22 µF / 16 V — sector buffer.
The 314 MB drives have additional power filtering caps (the spindle motor drive is larger) — inspect for additional electrolytics on the drive PCB.
Floppy Drive Logic Board
Same as Model 70 / 60. The PS/2 1.44 MB floppy drives carry 47 µF / 16 V (motor driver) and 10 µF / 25 V (head amplifier) electrolytics. Recap with 105 °C low-ESR equivalents. The Mitsubishi MF355C family also needs a 54 × 1 mm flat rubber drive belt at the same time.
MCA Memory Card Capacitors
A heavily-configured Model 80 may have one or more MCA Memory Adapter cards. The IBM 2-8 MB MCA Memory Adapter and the IBM 4-16 MB MCA Memory Adapter carry through-hole electrolytics that age but rarely fail. Inspect for leaked electrolyte if a memory card is fitted and the system reports 201 / 215 / 216 errors on it.
Replacement Parts Summary
| Value | Voltage | Type | Where |
| 10 µF | 16 V | Tantalum (preferred) or SMD low-ESR | Planar SMD positions, ESDI card bypass |
| 22 µF | 16 V | Tantalum or SMD low-ESR | Planar SMD on some revisions, ESDI sector buffer |
| 47 µF | 16 V | Tantalum or SMD low-ESR | Planar SMD bulk, drive logic board |
| 47 µF | 50 V | Aluminium electrolytic, 105 °C | PSU primary startup |
| 100 µF | 16 V | Aluminium electrolytic, low-ESR, 105 °C | PSU bypass / feedback |
| 100 µF | 50 V | Aluminium electrolytic, 105 °C | PSU primary auxiliary |
| 220 µF | 35 V | Aluminium electrolytic, 105 °C | PSU −12 V smoothing |
| 220 µF | 200 V | Aluminium electrolytic, 105 °C | PSU primary bulk (lethal-charge component) |
| 470 µF | 35 V | Aluminium electrolytic, 105 °C | PSU +12 V auxiliary |
| 2200 µF | 16 V | Low-ESR aluminium electrolytic, 105 °C | PSU +5 V smoothing × 2 |
| 2200 µF | 25 V | Low-ESR aluminium electrolytic, 105 °C | PSU +12 V smoothing (drive rail) |
| 0.1 µF | 275 VAC | X2 class | PSU mains suppression |
Polarity Reference
A failed tantalum often shows no visible damage.
Post-Recap Verification
- Bench-test the planar with a known-good PSU and no peripherals.
- Verify rails at the planar power connector.
- Refit; boot the Reference Diskette (Type 1 or Type 2 as appropriate).
- Run Auto Configuration if any MCA cards changed.
- Run Advanced Diagnostics (Ctrl-A) and walk through each test:
- Protected-mode test.
- Memory test (full pass).
- Onboard VGA test.
- ESDI controller test.
- For 8580-311 / A31, dual-drive test.
- Run a memory test pass for several hours under DOS to confirm planar memory reliability.
If any test fails after a recap, re-inspect the polarity of every replaced cap before suspecting another fault — reversed polarity is the most common error.
When Not to Recap
If the Model 80 boots, POSTs cleanly and runs reliably with no diagnostic errors and visual inspection shows no SMD leakage, the caps are within tolerance. However, given the larger SMD cap count on the Model 80 (40–50 vs. ~36–40 on the Model 70), the probability of at least one cap leaking on a 30+ year old planar is very high. Plan for recap on any Model 80 that is to be returned to regular service.
Always recap if:
- Any SMD electrolyte leak visible on the planar.
- Fluid leak visible from any electrolytic in the PSU or drive logic boards.
- PSU smoke, fishy odour or audible whine.
- ESDI controller reports 10455 / 10463 on a known-good drive.
- Drive becomes unreliable when warm.
- System passes POST cold but fails when warm.
Related Pages
- IBM PS/2 Model 80
- IBM PS/2 Model 80 Maintenance Guide
- IBM PS/2 Model 80 Troubleshooting Guide
- IBM PS/2 Model 70 Capacitor Replacement Guide — desktop sibling, same planar SMD family
- IBM PS/2 Model 60 Capacitor Replacement Guide — same tower chassis and PSU topology
- Capacitor Failure Symptoms
- Commonly Failing Electronic Components, minuszerodegrees.net. Reference for SMD aluminium electrolyte leakage on the Model 70 / 80 planars.
- IBM PS/2 Model 80 — DOS Days. Reference for the 225 W PSU rating and ESDI controller architecture.
- IBM PS/2 Model 80 — Ardent Tool Quick Reference. FRU breakdown and planar Type 1 vs Type 2.
- IBM, IBM Personal System/2 Hardware Maintenance Manual (S52G-9971-02, October 1994).
