IBM PS/2 Model 80 Troubleshooting Guide
This guide documents fault diagnosis for the IBM PS/2 Model 80 (machine type 8580, all submodels). The Model 80 shares its POST architecture with the IBM PS/2 Model 70 (same planar family) but has 8-slot MCA, server-class ESDI configurations and Type 1 / Type 2 planar differences that affect troubleshooting.
Reference Diskette and Diagnostics
The Model 80 requires the Model 80-specific Reference Diskette. The Type 1 planar (8580-041 / 071 / 111 / 311) uses one Reference Diskette image; the Type 2 planar (8580-A21 / A31) uses a different Reference Diskette image. Use of the wrong Reference Diskette will refuse to boot or will mis-configure the planar.
Boot Options:
- F1 โ boot the Reference Diskette.
- Ctrl-A from the Reference Diskette menu โ Advanced Diagnostics.
POST Sequence
The Model 80 POST runs in this order:
- Reset; CPU register check (80386 includes paging and protected mode tests).
- ROM checksum.
- CMOS / RTC battery check.
- Planar RAM count.
- Onboard VGA initialisation.
- Floppy controller and drive seek.
- MCA adapter ID scan (each card returns a 16-bit ID; up to 8 cards).
- ADF lookup against CMOS configuration record.
- ESDI controller initialisation.
- Boot device selection.
Beep Codes
| Beeps | Meaning |
| 1 short | POST passed; normal boot. |
| 2 short | Configuration error; numeric error on screen. |
| 1 long, 1 short | Planar fault. |
| 1 long, 2 short | Display adapter fault. |
| Continuous | Power supply or planar fault. |
| None, no display | Planar or PSU fault before video init. |
Numeric POST Codes
The Model 80 shares the same 1xxโ104xx code families with the Model 70. Codes that are identical to the Model 70 are summarised here; refer to IBM PS/2 Model 70 Troubleshooting Guide for the complete tables.
1xx โ Planar / System Board
Same as Model 70. Key codes:
- 104 โ Protected-mode failure. Often planar SMD cap leakage near the CPU.
- 114 โ Paging test failure (80386-specific).
- 161 / 162 / 163 โ CMOS / RTC battery cluster. Replace DS12887.
- 164 โ Memory size mis-match with CMOS. Run SETUP.
- 165 โ MCA adapter ID mismatch. Run Auto Configuration. More common on Model 80 than Model 70 due to higher card count.
- 166 โ MCA arbitration failure.
2xx โ RAM
Same as Model 70. The Type 2 planar (8580-A21 / A31) is more particular about SIMM speed and rejects slower SIMMs with a 201 / 225 cluster.
3xx โ Keyboard
Same as Model 70.
6xx โ Floppy Drive
Same as Model 70.
8xx โ Math Coprocessor
The Model 80 supports the optional 80387DX coprocessor.
- 801 โ Coprocessor test failed.
104xx โ ESDI Fixed Disk Adapter/A
The Model 80 uses the IBM ESDI Fixed Disk Adapter/A (or its later revision for the larger 314 MB drives) for the hard drive subsystem. The 104xx error family is the same as on the Model 70.
See IBM PS/2 Model 60 Troubleshooting Guide for the complete 104xx code table.
Server configurations (8580-311 / A31) with two ESDI drives use:
- 10480 โ Drive 0 fatal error.
- 10481 โ Drive 1 fatal error.
This is the only place the second drive is called out separately in POST.
24xx โ Onboard VGA
Same as Model 70:
- 2401 โ Onboard VGA POST failure.
- 2402 โ VGA video memory failure.
- 2410 โ Planar VGA card failure.
A 24xx on a Model 80 is one of the more common SMD electrolyte leak symptoms.
SMD Electrolyte Leak Diagnostic Workflow
The Model 80 planar's SMD electrolytic capacitors are the leading cause of "the Model 80 won't POST" complaints. The same symptoms apply as on the Model 70:
- 104 (protected mode) โ SMD leak near the CPU.
- 201 (memory) โ SMD leak near the SIMM controller.
- 2401 (VGA) โ SMD leak near the VGA chip.
- Random reboots โ SMD leak on a bus signal.
- No POST at all โ SMD leak shorting a power rail.
If a Model 80 is exhibiting any persistent or intermittent POST fault, inspect the planar for SMD electrolyte leakage before any other diagnosis. Read IBM PS/2 Model 80 Capacitor Replacement Guide for the recap procedure.
The Model 80 has 40โ50 SMD electrolytics (more than the Model 70's ~36โ40) because of the larger MCA bus controller and server-class memory subsystem. The likelihood of at least one SMD cap leaking is correspondingly higher.
MCA-Specific Faults
165 Card-ID Mismatch
With 7 ร 32-bit MCA slots typically populated to 3โ5 cards in a Model 80 (vs. 1โ2 on a Model 70), the 165 fault is more common. Causes and fix are the same as on the Model 70:
- Boot the Reference Diskette.
- Select Set Configuration โ Run Auto Configuration.
- Insert option diskettes as prompted.
- Save and reboot.
If 165 persists, reseat every card, clean edge fingers, and bring the card complement up one at a time to isolate the faulty card.
8-bit Slot Limitations
The Model 80 has one 8-bit MCA slot (in addition to seven 32-bit slots). The 8-bit slot accepts 8-bit MCA cards (rare) but is also wired to accept 16-bit MCA cards in 8-bit mode. Do not plug a 32-bit MCA card into the 8-bit slot โ it will not POST and may damage the card.
Type 1 vs Type 2 Planar Differences
Diagnosing a fault requires knowing which planar is in front of you:
| Marker | Type 1 (16 / 20 MHz) | Type 2 (25 MHz) |
| Submodels | 041, 071, 111, 311 | A21, A31 |
| CPU speed | 16 or 20 MHz | 25 MHz |
| SIMM speed required | 80 ns or faster | 70 ns or faster |
| Reference Diskette | Type 1 | Type 2 |
A Type 1 Reference Diskette booted on a Type 2 planar will report incorrect memory configuration and may refuse to complete SETUP. A Type 2 Reference Diskette on a Type 1 planar will also misconfigure.
ECA Recalls and Service Bulletins
The Model 80 was affected by several Engineering Change Authorisation (ECA) bulletins:
- ECA 087 โ Reference Diskette compatibility update for newer MCA cards.
- ECA 092 โ Planar fix for one revision of the Model 80.
- ECA 117 โ ESDI controller firmware update (particularly relevant on the 314 MB ESDI drive configurations).
These ECAs apply only to specific FRU part numbers; check the planar / card FRU against the bulletin before applying.
PSU Faults
Symptoms and diagnosis:
- Dead โ no fans, no power: Bulk capacitor or mains rectifier; PSU recap required. See IBM PS/2 Model 80 Capacitor Replacement Guide.
- Fans spin briefly, then click-retry: Power Good not asserted in 150 ms. Could be PSU fold-back or shorted planar tantalum / leaked SMD electrolyte.
- Boots cold, fails when warm: Secondary electrolytics aged.
- Audible whine, smell of fish: RIFA X2 cap is venting.
- Rails low/high: PSU feedback path issue.
The 225 W PSU on the Model 80 has comfortable headroom for the 80386DX, the planar VGA and up to 7 MCA cards. A rail sag on a properly-functioning Model 80 PSU usually indicates an aged secondary electrolytic.
Drive Stiction
ESDI drives in the Model 80, particularly the 314 MB drives, are notoriously prone to spindle stiction after long storage. Same field fix as on the Model 60 / 70:
- Power off.
- Open the chassis. Locate the drive.
- Gently rotate the drive case 45โ90ยฐ around its spindle axis in both directions to free the heads.
- Re-install. Power on.
The 314 MB drive is full-height and heavier than the smaller ESDI drives; handle with care during the stiction-freeing procedure.
After the drive boots, immediately image its contents to a modern disk image file. The drive cannot be trusted to spin up reliably again.
Server Configuration-Specific Faults
The 8580-311 and 8580-A31 ship with the 314 MB ESDI drive in the top bay and a smaller (1.44 MB) floppy in Bay 2. Things to know:
- The 314 MB ESDI drive draws more startup current than the 70 / 115 MB drives. PSU rail sag at boot is more pronounced; if the 225 W PSU has aged caps, the 314 MB submodels will exhibit boot failures before the 111 / 071 / 041 submodels do.
- The dual-drive 8580-311 / A31 configurations require the ESDI controller card to be configured for two drives (via the Reference Diskette SETUP).
- Novell NetWare on the 8580-311 / A31 is sensitive to drive timing โ aged ESDI controller caps produce NetWare-side errors that look like volume corruption.
Keyboard / Mouse Faults
Same as Model 70:
- 301: Keyboard or mouse in the wrong port.
- 305: +5 V fuse on planar blown.
- 365: PS/2 mouse fault.
Memory Faults
- 201 with planar-range address: Planar SIMM failure. Identify the failing bank from the address.
- 201 with MCA Memory Adapter address: Memory adapter card failure.
- 215 / 216: MCA Memory Adapter configuration error.
- 225 on a Type 2 planar: SIMMs too slow.
When to Suspect the Planar
- 1xx errors that persist after CMOS battery replacement and Auto Configuration.
- No video and no beeps after PSU verified known-good.
- Repeated 165 errors after every card removed and reseated.
- Any visible SMD electrolyte leak.
The Model 80's larger SMD cap count makes planar leakage statistically more likely than on the Model 70.
Diagnostic Workflow
- Visually inspect planar for SMD electrolyte leak first. If found, do not power on.
- Confirm Type 1 vs Type 2 planar and use correct Reference Diskette.
- Power on. Listen for beep.
- Note POST screen โ any leading numeric code.
- If 161/162/163 cluster โ replace DS12887 module.
- If 165 โ run Auto Configuration; cards reseated.
- If 104xx โ verify drive type in CMOS; reseat drive cable; consider stiction; consider controller cap failure.
- If 24xx โ planar VGA fault, often SMD electrolyte leak.
- If 104 โ 80386 protected mode fault, often SMD electrolyte leak near CPU.
- If no beep and no video โ PSU first (rail check), then planar SMD inspection.
- Run Advanced Diagnostics (Ctrl-A) once basic POST passes.
Related Pages
- IBM PS/2 Model 80
- IBM PS/2 Model 80 Maintenance Guide
- IBM PS/2 Model 80 Capacitor Replacement Guide
- IBM PS/2 Model 70 Troubleshooting Guide โ desktop sibling, same planar family
- IBM PS/2 Model 60 Troubleshooting Guide โ same tower chassis
- PS/2 Error Codes โ Ardent Tool of Capitalism. Source for the 1xxโ104xx error code tables.
- IBM PS/2 Model 80 โ Ardent Tool Quick Reference. FRU data, planar Type 1 vs Type 2, ECA history.
- IBM, IBM Personal System/2 Hardware Maintenance Manual (S52G-9971-02, October 1994). POST error code reference.
