IBM 5151
{Infobox computer peripheral
| name = IBM Monochrome Display
| image =
| caption = IBM monitors, left to right: 5151 monochrome, 5153 colour, 5154 Enhanced Color Display
| manufacturer = IBM
| type = TTL monochrome CRT monitor
| release_date = 1981 (with the original IBM PC)
| interface = TTL digital, 9-pin D-shell (driven by the IBM Monochrome Display Adapter)
| compatible = IBM PC (5150), IBM PC XT (5160), IBM PC AT (5170), MDA- and Hercules-compatible systems
| dimensions = 280 mm H × 380 mm L × 350 mm D
| weight = 7.9 kg (17.3 lb)
| model = 5151
The IBM 5151, which IBM called simply the IBM Monochrome Display, is the green-phosphor TTL monitor sold with the original IBM PC (5150) when it was ordered with the IBM Monochrome Display Adapter (MDA). It displays 80 × 25 text only — it has no graphics capability — but the MDA's large 9 × 14 character box gives an image of 720 by 350 addressable dots, which is why MDA text is visibly sharper than CGA text.
Display Characteristics
IBM's own figures:[1]
- CRT: 28.3 cm (11.5 in) diagonal, 90° deflection.
- Phosphor: P39, high persistence, green. Long persistence suppresses flicker at the 5151's low refresh rate, at the cost of smearing on moving content.
- Screen surface: etched to reduce glare.
- Presentation: 80 characters wide by 25 rows deep, each character defined in a 14 PEL high by 9 PEL wide matrix.
- Vertical drive: screen refreshed at 50 Hz, with 350 lines of vertical resolution and 720 lines of horizontal resolution.
- Horizontal drive: positive-level, TTL-compatible, at 18.432 kHz.
- Video bandwidth: 16.257 MHz maximum at −3 dB.
- Heat output: 325 BTU/hr. Cables: 0.914 m power, 1.22 m signal.
Measured at the adapter, the MDA horizontal sync is an 8 µs positive-going pulse every 54.3 µs and the vertical sync is an 850 µs negative-going pulse every 20 ms.[2]
The 5151 will not work with a CGA card: CGA runs its horizontal scan at 15.75 kHz, well outside the 5151's fixed 18.432 kHz.[2]
Power
The 5151 has no mains cord of its own. It takes both its signal and its power from the system unit: the signal cable comes from the display adapter, and a second cable takes ac power from a non-standard switched socket on the rear of the PC's power supply, so that the system unit's power switch controls the display.[1] That outlet can supply a maximum of 0.75 A and IBM states it is intended only for this display.[3]
Two models were made, a 110 Vac model and a 220/240 Vac model, and IBM's Options and Adapters section carries a separate full schematic for each.[1]
Input Connector
A 9-pin D-shell at standard TTL levels — 0.0 to 0.6 Vdc at down level, +2.4 to 3.5 Vdc at up level.[4]
| Pin | Signal |
| 1 | Ground |
| 2 | Ground |
| 3, 4, 5 | Not used |
| 6 | + Intensity |
| 7 | + Video |
| 8 | + Horizontal sync |
| 9 | − Vertical sync |
Pins 3, 4 and 5 being physically absent from the plug is normal, not damage — they are unused in the MDA standard.[5]
The display's three brightness levels (off, normal, bright) come from the combination of the Video and Intensity lines, not from an analogue video level.[4]
Common Faults
- Stiff brightness and contrast knobs. Known behaviour on a healthy 5151, and probably deliberate. Not a fault.[5]
- Stable raster with the brightness turned up, but no characters. On a 5151 specifically, a stable raster proves the monitor is receiving correct horizontal and vertical sync from the MDA card. Work through: contrast set too low; a faulty MDA card that generates sync but no video; an open video wire in the cable; a poor connection on pin 7 at the plug; then the video path inside the monitor. IC201, an SN7406A, has been reported failed by more than one owner.[5]
- No display at all, not even a raster. The 5151 needs an incoming horizontal sync signal from a working, initialised MDA card to produce any raster at all. Before condemning the monitor, check that the card is present, seated and initialised — motherboard switch settings that select EGA instead of MDA will leave it uninitialised.[5]
- Full or partial vertical collapse. A known symptom with published circuit and waveform references.[5]
- Bright spot or line when switching off. Known behaviour, not a fault.[5]
- Dim or shrunken raster, or geometry that drifts as the set warms up. Points at ageing electrolytics on the analogue board. See Capacitor Failure Symptoms.
A self-inflicted fault worth knowing about
Because of the way the 5151 is designed, an improper horizontal sync signal can damage it — and software alone is enough to produce that situation by reprogramming the 6845 on the MDA card outside MDA timings.[5] Do not run 6845 timing experiments, Hercules-mode software or untested demos against a 5151 you care about.
CRT Safety
The 5151's CRT retains a lethal anode charge after the set is switched off and unplugged, and its mains-derived circuitry sits at line potential while it is running. Discharge the tube before working inside it — see CRT Discharge Procedure.
- โ 1.0 1.1 1.2 IBM, IBM Monochrome Display, Options and Adapters section, Personal Computer Hardware Reference Library — hosted on this wiki as File:IBM Options and Adapters - IBM Monochrome Display (5151).pdf. "Description" and "Specifications": the two-cable arrangement with power taken from the system unit, the 28.3 cm (11.5 in) diagonal 90-degree-deflection CRT, P39 high-persistence green phosphor with an etched anti-glare surface, 80 characters by 25 rows in a 14 PEL high by 9 PEL wide matrix, maximum video bandwidth 16.257 MHz at −3 dB, 50 Hz vertical refresh with 350 lines vertical and 720 lines horizontal resolution, positive-level TTL horizontal drive at 18.432 kHz, and the physical specifications quoted here. Also documented here as IBM Options and Adapters - IBM Monochrome Display.
- โ 2.0 2.1 IBM: MDA / CGA / EGA, minuszerodegrees.net. Source for the side-by-side 9-pin assignments and for the measured sync pulse shapes: MDA, an 8 us positive-going horizontal pulse every 54.3 us and an 850 us negative-going vertical pulse every 20 ms; CGA, a 4 us positive-going horizontal pulse every 63.7 us and a 190 us positive-going vertical pulse every 16.7 ms.
- โ IBM, IBM 5150 Technical Reference — hosted on this wiki as File:IBM PC 5150 Technical Reference.pdf and documented as IBM PC 5150 Technical Reference. Section 1 "System Board" for the ROM and RAM subsystems; Section 3 "Power Supply", pages 3-3 to 3-6, for the 63.5 W continuous rating, the four dc outputs and their load and regulation figures, the −5 V dynamic-memory bias role, the switched 0.75 A ac outlet provided only for the IBM Monochrome Display, the overvoltage and overcurrent behaviour, the five-second minimum off time and the under- and over-voltage sense levels; Section 4 "Keyboard" for the capacitive keyboard, its Intel 8048, the permanently attached coiled five-wire cable, the 83-key layout, the scan-code protocol and the keyboard's own power-on self test.
- โ 4.0 4.1 IBM, IBM Monochrome Display and Printer Adapter, Options and Adapters section, Personal Computer Hardware Reference Library — hosted on this wiki as File:IBM Options and Adapters - IBM Monochrome Display and Printer Adapter.pdf. Source for the Motorola 6845 CRT controller, the 4 KB display buffer with no parity, the two-bytes-in-553 ns fetch giving 1.8 MB/s, the 8 KB character generator holding 256 codes, the 9 PEL by 14 PEL character box carrying a 7 PEL by 9 PEL character, the 18 kHz monitor requirement, the statement that the adapter does not support a light pen with a P39-phosphor display, the register map, the 9-pin connector pin assignments and TTL signal levels, and the printer-adapter half with its 12 latched outputs and 5 steady-state inputs. Also documented here as IBM Options and Adapters - IBM Monochrome Display and Printer Adapter.
- โ 5.0 5.1 5.2 5.3 5.4 5.5 5.6 IBM 5151 — Known Problems/Issues, minuszerodegrees.net. Source for the stiff brightness and contrast controls being normal, the raster-but-no-video diagnosis, the reported IC201 (SN7406A) failures, the vertical collapse and switch-off bright line notes, the statement that pins 3, 4 and 5 are absent from the connector by design, and the warning that an improper horizontal sync signal can damage the 5151.
Related Pages
- IBM Monochrome Display Adapter — the adapter that drives the 5151
- IBM 5153 — the colour equivalent
- IBM PC (5150) · IBM PC XT (5160) · IBM PC AT (5170)
- IBM Options and Adapters - IBM Monochrome Display — IBM's own specification, hosted here
- CRT Discharge Procedure · Capacitor Failure Symptoms
