IBM PC XT/370
The IBM PC XT/370 is a desktop System/370 workstation released by IBM in October 1983 as a follow-on to the IBM 5100's PALM-microcode-based mainframe emulation. The XT/370 is mechanically an IBM PC XT (5160) but with three large add-in cards that emulate IBM System/370 mainframe instructions in hardware, allowing the XT to run a modified single-user version of VM/CMS called VM/PC.[1][2]
The XT/370 is the architectural successor to the IBM 5100 / IBM 5110 / IBM 5120's use of the IBM PALM processor's System/360 emulator microcode to run an IBM-mainframe-flavoured interpreter (APLSV) as a self-contained personal computer.
The XT/370 was withdrawn in April 1987, simultaneously with its big sibling the IBM AT/370.[3] Its eventual successor was the IBM 7437 VM/SP Technical Workstation (1987โ1988), then the P/370 MCA card for PS/2 systems (~1989), then the R/390 for RS/6000 (mid-1990s).
Launch and Reception
Launch pricing was approximately $3,790 for the three emulation cards alone, or $8,995 to $12,000 for a complete configuration including the XT base unit.[4]
BYTE (Fall 1984, Ernest Sabine) called it "a qualified success." It was a slow seller โ Computerworld (25 November 1985) reported sales below IBM's expectations. The XT/370 was withdrawn in April 1987 along with the AT/370.
The Three 370PC Cards
The XT/370 is defined by three full-length 8-bit ISA cards that occupy three of the XT's eight expansion slots:
370PC-P (Processor Card)
The processor card carries:
- Two modified Motorola 68000s โ IBM had Motorola rewrite the 68000 microcode to directly execute most System/370 fixed-point and non-floating-point instructions. When the 68000 encounters an opcode it does not recognise as native S/370, the instruction traps and is handled by a software interpreter running on the unmodified 68000. The custom 68000 is sometimes called the Micro/370.[5][6]
- A modified Intel 8087 โ IBM had Intel modify the 8087 floating-point unit to implement IBM System/370 floating-point arithmetic (excess-64 hexadecimal floating-point, not the IEEE 754 binary floating-point the standard 8087 implements).
- Glue logic to bridge the 370PC-P to the host XT's ISA bus and to the 370PC-M memory card via a dedicated back-edge connector.
370PC-M (Memory Card)
- 512 KB of dual-ported RAM, shared between the 370PC-P card and the XT host through a back-edge connector unique to the 370PC card pair.
- Of the 512 KB, 416 KB is usable for S/370 applications; the remainder is reserved for the emulator runtime.
- The card also contributes 384 KB to the XT host, bringing the host's RAM from 256 KB to the full 640 KB.[7]
PC3277-EM (3277 Emulation Adapter)
- 3270 terminal emulation adapter โ required for the XT/370 to download VM/PC system software from a host mainframe, and for connecting CMS to mainframe-resident files.
- Late-production XT/370s replaced this with the standard 3278/79 Emulation Adapter (same card used by the IBM 3270 PC).[8]
Performance
- S/370 performance โ approximately 0.1 MIPS sustained, when the working set fits in the 416 KB of usable S/370 RAM.
- When the working set exceeds 416 KB, VM/PC pages out to the XT's hard disk, supporting up to 4 MB of virtual memory but with a heavy performance penalty.
- In contemporary terms, the XT/370 is comparable to a low-end System/4341 mainframe channel of the era for compute-intensive single-stream CMS workloads.[9]
Operating Environment: VM/PC
The XT/370 boots PC DOS 2.10 first, then loads VM/PC (Virtual Machine/Personal Computer). VM/PC presents a single-user CMS environment that closely mirrors mainframe VM/CMS:
- CMS "virtual disks" (minidisks) are stored as PC DOS files. User FRED's minidisk 101 becomes the PC DOS file FRED.101.
- EXPORT and IMPORT commands transfer files between CMS and PC DOS, with automatic EBCDICโASCII conversion.
- CMS commands, EXEC scripts, and most CMS applications run unchanged.
- No multi-user support โ VM/PC is single-user only.
VM/PC version 2 (November 1985) added page-cache support to reduce hard-disk paging overhead.
The IBM AT/370 ships an updated VM/PC for PC DOS 3.0, with the wider 16-bit 370PC-P2 and 370PC-M2 cards (still 512 KB on the M2 card, with 32 KB reserved for microcode).
Hardware Configuration
The XT/370 is a stock IBM PC XT (5160) chassis with:
- 8088 host CPU at 4.77 MHz.
- 256 KB on planar (XT standard), expanded to 640 KB by the 370PC-M card.
- 5.25" 360 KB DSDD floppy.
- 10 MB ST-412 hard drive.
- IBM 5161 Expansion Chassis support for a second hard drive.
- IBM 5151 monochrome or IBM 5153 CGA display.
- IBM XT 83-key Model F keyboard.
Service Documents
- IBM SA38-0037-00 โ Personal Computer Family Service Information Manual (July 1989), Chapter 6 covers the XT/370, Chapter 9 covers the AT/370.
- IBM 6137739 โ Virtual Machine/Personal Computer User's Guide (December 1984).
- Kozuh, F. P., Livingston, B., Spillman, R. J. โ "System/370 capability in a desktop computer," IBM Systems Journal 23(3):245, 1984. The canonical engineering paper.
Common Faults
The XT/370 chassis is identical to the IBM PC XT (5160), so chassis faults are:
- RIFA mains-suppression capacitors in the PSU โ vent and produce smoke / fish odour. Replace immediately as a preventive measure.
- Tantalum bypass cap shorts on the planar โ pull the +5 V rail and prevent POST.
- Dallas DS1287 RTC battery on the planar (where fitted).
XT/370-specific faults:
- The three 370PC cards are effectively unobtainium. The modified 68000s, the modified 8087, and the dual-ported memory backplane are not reproducible by current technology. A surviving XT/370 with all three cards is a museum-grade machine.
- Card-to-card backplane connector between 370PC-P and 370PC-M can develop oxidation; cleaning restores function in most cases.
- VM/PC system diskette โ the install diskettes are increasingly rare and the install procedure requires a working PC3277-EM card connected to a 3174 / 3274 controller, which is itself increasingly rare.
Architectural Significance
The XT/370 sits in IBM's long lineage of S/360- and S/370-emulation-in-a-personal-computer products:
- IBM 5100 / IBM 5110 / IBM 5120 (1975โ1980) โ PALM microcode S/360 emulator running APLSV.
- IBM PC XT/370 (1983) โ modified 68000 + modified 8087 hardware S/370 emulator running VM/PC.
- IBM PC AT/370 (1984) โ 16-bit cards (370PC-P2, 370PC-M2) on the AT chassis.
- IBM 7437 VM/SP Technical Workstation (1987โ88) โ separate enclosure, channel-attached.
- P/370 (~1989) โ MCA card for PS/2 Model 60/70/80.
- R/390 (mid-1990s) โ RISC PCI card for RS/6000.
- S/390 Integrated Server (1998).
- Eventually superseded by software emulators (Hercules, zPDT) on commodity hardware.
Related Pages
- IBM PC XT/370 Maintenance Guide
- IBM PC XT/370 Troubleshooting Guide
- IBM PC XT/370 Capacitor Replacement Guide
- IBM PC XT (5160) โ base chassis
- IBM 3270 PC โ contemporary XT-derived mainframe-connect workstation
- IBM 5100 โ direct PALM-era ancestor
- IBM PALM processor โ the earlier emulation approach
- PC-based IBM mainframe-compatible systems โ Wikipedia.
- Kozuh, F. P., Livingston, B., Spillman, R. J. "System/370 capability in a desktop computer." IBM Systems Journal 23(3):245, 1984. DOI 10.1147/sj.233.0245.
- The CPU Shack โ IBM Micro/370.
- The Chip Letter โ Motorola, Intel, IBM Make A Mainframe in a PC.
- IBM SA38-0037-00 Personal Computer Family Service Information Manual (July 1989).
- Computer Business Review โ "IBM Gives Up on the Personal XT/, AT/370".
- IT History Society โ IBM Personal Computer XT/370.
- Computerworld 25 November 1985.
- โ https://en.wikipedia.org/wiki/PC-based_IBM_mainframe-compatible_systems
- โ Kozuh, F. P., Livingston, B., Spillman, R. J. "System/370 capability in a desktop computer." IBM Systems Journal 23(3):245, 1984.
- โ Computer Business Review, "IBM Gives Up on the Personal XT/, AT/370", April 1987.
- โ IT History Society, "IBM Personal Computer XT/370".
- โ https://www.cpushack.com/2013/03/22/cpu-of-the-day-ibm-micro-370/
- โ https://thechipletter.substack.com/p/motorola-intel-ibm-make-a-mainframe
- โ Mueller, S. Upgrading & Repairing PCs, 2nd edition, 1992, pp. 73โ75, 94.
- โ IBM SA38-0037-00 Personal Computer Family Service Information Manual, July 1989, ยง6-17.
- โ Kozuh et al., 1984, IBM Systems Journal.
