IBM PS/2 Model 30
| IBM PS/2 Model 30 (8530) | |
| Manufacturer | IBM |
| Released | 2 April 1987 (Model 30, 8086); 13 September 1988 (Model 30 286) |
| Discontinued | c. 1992 |
| CPU | Intel 8086-2 @ 8 MHz, 0 wait states; Intel 80286 @ 10 MHz on the Model 30 286 |
| Memory | 640 KB (8086); 512 KB to 4 MB on the board (286) |
| Storage | One or two 3.5" diskette drives; optional IBM fixed disk drive with its controller on the drive |
| Display | MCGA (8086) or VGA (286), integrated on the planar |
| Sound | PC speaker; earphone jack |
| OS / Firmware | IBM PC DOS 3.3 and later; IBM OS/2 1.x on the 286 |
| Predecessor | IBM PC XT (5160) |
| Successor | IBM PS/1; IBM PS/ValuePoint |
| Model no. | 8530 |
The IBM Personal System/2 Model 30 (machine type 8530) is one of the four original PS/2 systems announced on 2 April 1987, alongside the IBM PS/2 Model 50, IBM PS/2 Model 60 and IBM PS/2 Model 80. It was the lowest-end of the four and was aimed squarely at replacing the PC and PC XT. Unlike the other three, it keeps an ISA expansion bus rather than Micro Channel.
Two generations were sold:
- Model 30 (8530-002, -021) — Intel 8086-2 at 8 MHz with MCGA video and three 8-bit ISA slots, from April 1987.[1]
- Model 30 286 (8530-E01, E21, E31, E41) — 80286 at 10 MHz with VGA and 16-bit ISA, from September 1988.[2]
Both share the case, the single-cable drive arrangement and the PS/2 Mini-DIN keyboard and pointing-device ports. The all-in-one Model 25 is its close relative: the 8086 planars of the two machines use largely the same reference designators.[3]
Submodels
| Submodel | CPU | RAM | Diskette | Fixed disk | Video | Bus |
| 8530-002 | 8086-2, 8 MHz | 640 KB | 2 × 720 KB | none | MCGA | ISA 8-bit |
| 8530-021 | 8086-2, 8 MHz | 640 KB | 1 × 720 KB | 20 MB with integrated controller | MCGA | ISA 8-bit |
| 8530-E01 | 80286, 10 MHz | 512 KB (4 MB max) | 2 × 1.44 MB | none | VGA | ISA 16-bit |
| 8530-E21 | 80286, 10 MHz | 1 MB (4 MB max) | 1 × 1.44 MB | 20 MB | VGA | ISA 16-bit |
| 8530-E31 | 80286, 10 MHz | 1 MB (4 MB max) | 1 × 1.44 MB | 30 MB | VGA | ISA 16-bit |
| 8530-E41 | 80286, 10 MHz | 1 MB (4 MB max) | 1 × 1.44 MB | 45 MB | VGA | ISA 16-bit |
The 8530-002 and -021 configurations are IBM's own, from the announcement letter.[1]
Telling the two generations apart
| Marker | Model 30 8086 | Model 30 286 |
| Machine types | 8530-002, -021 | 8530-E01, E21, E31, E41 |
| CPU | Intel 8086-2 at 8 MHz, planar U10 | 80286 at 10 MHz, socket ZM36 |
| Chipset | IBM gate arrays | VLSI VL82CPCAT-QC at ZM2–ZM6 |
| Video | MCGA | VGA |
| Riser | three 8-bit ISA slots | 16-bit ISA |
| Extra bus power connector | absent | present (J14, 4-pin) |
| Real-time clock | NS MM58167AN at U16; battery on the riser card | Dallas DS1287 module at ZM35, cell sealed inside |
| Diskette as shipped | 720 KB | 1.44 MB |
| Power supply | 70 W, internal sensing, no voltage switch | 90 W, dual voltage, switch on the rear |
Sources: the planar designator maps,[3][4] IBM's announcement letters[1][2] and IBM's Technical Reference.[5]
Architecture
Model 30 8086 planar
The board exists as the original "P-PLANAR" P/N 61X8823 and two later Greenock builds, P/N 33F4888 and FRU P/N 33F8474 (P/N 33F4871). The layouts look nothing like each other, but the reference designators are largely consistent — and consistent with the 8086 Model 25 planars too.[3]
| Designator | Device |
| U10 | Intel 8086-2 CPU, 8 MHz |
| U13 | 8087 coprocessor socket |
| U8 | Intel P8253-5 timer |
| U5 | Inmos IMSG171S RAMDAC |
| U16 | NS MM58167AN real-time clock |
| U17, U20 | ROM BIOS (even / odd) |
| U18 | NEC uPD765AC diskette controller |
| U19 | 8237A DMA controller |
| U27 | NS8250AV UART |
| J1 / J2 | Mouse / keyboard connectors |
| J6 | Riser slot |
| J7, J9 | Power connectors |
| J11 | 44-pin fixed-disk connector |
| J12 | 40-pin diskette connector |
| J13 | Dual 30-pin SIMM socket |
| F1 / F2 | Mouse and keyboard fuses |
| Y1 / Y2 / Y3 | 14.31818 / 25.175 / 48.000 MHz oscillators |
| Y4 | 32.768 kHz crystal (real-time clock) |
The 8086 Model 30 does have a real-time clock. IBM lists "real-time clock with battery" among the system board's integrated functions, gives it IRQ2 and I/O addresses hex 00B0–00BF and 00E0–00EF, and the planar carries the MM58167AN at U16 with its own 32.768 kHz crystal at Y4.[5][3] The cell is not on the planar — it is a 3 V lithium Panasonic BR-2/3A at B1 on the riser card (riser P/N 61X8864 or 61X8910).[3] That is the part to look for when the clock will not hold time, and it is easy to miss because it is not where a PC-compatible battery usually is.
Three 62-pin card-edge sockets on the vertical riser extend the I/O channel to three ISA slots.[5]
Model 30 286 planar
The 286 board uses the VLSI VL82CPCAT-QC chipset, in a ZM-prefixed designator scheme: ZM2 VL82C100 peripheral controller, ZM3 VL82C102A memory controller, ZM4 VL82C103A address buffer, ZM5 VL82C104 data buffer, ZM6 VL82C101B system controller, ZM9 VL16C451 parallel port and UART, ZM19 uPD765AC-2 diskette controller, ZM33 8042/8742 keyboard controller, ZM35 Dallas DS1287 RTC/CMOS, ZM36 the 286 CPU (PGA on early boards, PLCC later, FRU P/N 34F0046). Power arrives at J7 and J14; J13 is the password-override jumper.[4]
The DS1287 has its lithium cell sealed inside the module. Replacing it means desoldering and fitting a fresh DS12887 or equivalent — or cutting into the original case to reach the cell and fitting an external holder.[4]
Memory
- Model 30 8086 — the machine ships at the 640 KB architectural ceiling, using the dual 30-pin SIMM socket at J13 alongside the on-board DRAM.[3]
- Model 30 286 — 512 KB minimum, 4 MB maximum on the planar, using 30-pin parity SIMMs with the IBM pinout. Standard PC/AT 30-pin SIMMs may fit physically but are not recognised.
Display
The 8086 Model 30 has MCGA, the same integrated subsystem as the 8086 Model 25: all the standard CGA modes plus 640 × 480 in two colours and 320 × 200 in 256 colours, from a 256-entry 18-bit palette driving three 6-bit DACs. It is analogue only and will not drive a TTL CGA or MDA monitor.
The Model 30 286 has full VGA integrated on the planar.
Diskette
Power and data reach the drive on a single cable from the planar's 40-pin connector; there are no Molex leads in this machine.[6] The 8086 Model 30's BIOS supports 720 KB natively; specific Sony 1.44 MB drives are known to work, and a "1.44MB" marking on the eject button is the usual field identifier.[6] The Model 30 286 supports 1.44 MB properly.
PS/2 3.5-inch drives are direct drive — the Mitsubishi MF355C specification states a DC brushless motor coupled straight to the spindle at 300 rpm, with no belt.[7] What fails on these drives is the surface-mount electrolytics on the logic board and the corrosion they leave behind.[8]
Fixed disk
The Model 30's fixed-disk interface is not ST-506, ESDI or any other standard drive interface. IBM's Technical Reference describes the planar's connector as a dedicated I/O channel "for the connection of the IBM Personal System/2 20MB Fixed Disk Drive and Controller, or similar attachment", carrying ordinary I/O-channel signals plus a disk card-select, a disk-installed signal and three address lines that select a register inside the controller.[5] The controller is part of the drive assembly, and it plugs into the 44-pin connector at J11.[3][6]
The practical consequence is the one owners run into: the Reference Diskette offers no drive-type list, because there is no drive-type table to choose from. Only drives built for this interface will work, and the drive sits in a caddy.[6]
Keyboard and Mouse
The Model 30 uses the 6-pin Mini-DIN keyboard and pointing-device connectors. On the 8086 machine the two interfaces are identical and IBM states the keyboard and pointing device may "plug into either of the two 6-pin connectors at the rear of the system".[5] The 286 planar uses a discrete 8042/8742 at ZM33 instead.[4]
Each port is fuse-protected on the planar (F1 and F2, combined into F1 on the later Greenock board).[3] A 305 at POST is a keyboard voltage error and IBM's first suggested FRU is that fuse.[9]
Power Supply
Two supplies, 70 W and 90 W. There is no 80 W Model 30 supply.
- Model 30 8086 — IBM's announcement letter specifies a "Universal 70W power supply, with internal sensing, for worldwide usage". There is no voltage selector switch to set.[1] IBM's Technical Reference gives the 70 W rating along with the rail currents, regulation tolerances, under-voltage sense levels, power-good characteristics and the P3/P4 pin assignments.[5]
- Model 30 286 — a 90 W dual-voltage supply with a switch on the rear, accepting 90–137 Vac or 180–265 Vac.[2] Set that switch before the cord goes into the wall.[10]
The supply generates 'power good' after the system has been off for five seconds or more, once the minimum under-voltage sense levels are established: +5 V at +4.5 V, −5 V at −4.3 V, +12 V at +10.8 V and −12 V at −10.2 V. Power Good itself should read +3.5 to +5 V on a working machine; if it does not, strip the machine to the planar and add devices back one at a time, because a short on any of them will hold it down.[10]
Measurement limits at the P3/P4 connectors, for a machine that is running:[10]
| − lead | + lead | Minimum | Maximum |
| P3-5 | P4-4 | +4.8 V | +5.2 V |
| P4-3 | P3-6 | +4.6 V | +5.5 V |
| P4-1 | P3-3 | +11.5 V | +12.6 V |
| P3-4 | P4-2 | +10.8 V | +13.2 V |
BIOS and Reference Diskette
Split CBIOS / ABIOS, as on every PS/2. There is no built-in SETUP screen: configuration is done from the model-specific Reference Diskette, which also carries Advanced Diagnostics (Ctrl-A). The 8086 and 286 Reference Diskettes are different and neither works on the other machine or on a Model 25.
Cold-boot the Reference Diskette. A warm boot can produce false errors, including a false indication that a power-on password is set.[9] On the 286, the power-on password is cleared with the J13 jumper, moved between the first-and-second and second-and-third pin positions.[11]
Opening the machine, the captive push-pin fittings, rail checks, the riser battery and connector care are in IBM PS/2 Model 30 Maintenance Guide.
Beep codes, the numeric POST code list, dead-system isolation and the documented IBM retain tips are in IBM PS/2 Model 30 Troubleshooting Guide.
Capacitor Replacement
Planar decoupling, the supply, and the diskette and fixed-disk logic boards are in IBM PS/2 Model 30 Capacitor Replacement Guide.
Gallery
IBM PS/2 Model 30 (8530) system unit
Model 30 286 front view
Model 30 286 with the cover off
8086 front badge
Model 30 286 front badge
- ↑ 1.0 1.1 1.2 1.3 IBM Announcement Letter 187-048, IBM Personal System/2 Model 30 (8530-002, -021), 2 April 1987. Gives the "Universal 70W power supply, with internal sensing, for worldwide usage", the 8530-002 (two 720 KB diskette drives) and 8530-021 (20 MB fixed disk with integrated controller plus one 720 KB drive) configurations, and MCGA graphics.
- ↑ 2.0 2.1 2.2 IBM Announcement Letter 189-035, Personal System/2 Model 30 286 (8530-E01). Gives the 90-watt dual-voltage power supply with a switch on the rear, the 90–137 Vac and 180–265 Vac input ranges, the 10 MHz 80286, VGA graphics and the 1.44 MB diskette drive.
- ↑ 3.0 3.1 3.2 3.3 3.4 3.5 3.6 3.7 Louis Ohland, Tomáš Slavotínek et al., "8530 Planar (8086)", Ardent Tool of Capitalism, https://www.ardent-tool.com/8530/Planar.html. Gives the "P-PLANAR" P/N 61X8823 designator map, the two Greenock planar variants (P/N 33F4888 and FRU P/N 33F8474 / P/N 33F4871), the ROM image list, the riser card part numbers (61X8864, 61X8910) and its B1 3 V lithium battery (Panasonic BR-2/3A), the note that reference designators are largely consistent across all 8086-based Model 30 and Model 25 planars, and IBM retain tips H007157, H043664, H067282 and H094152.
- ↑ 4.0 4.1 4.2 4.3 Louis Ohland, Tomáš Slavotínek et al., "8530 286 Planar", Ardent Tool of Capitalism, https://www.ardent-tool.com/8530/Planar_286.html. Gives the full 8530-286 planar designator map (VLSI VL82CPCAT-QC chipset at ZM2–ZM6, VL16C451 at ZM9, DS1287 RTC/CMOS at ZM35, 8042/8742 keyboard controller at ZM33, 286-10 at ZM36), the old PGA and new PLCC planar builds with FRU P/N 34F0046, the J13 password-override jumper, and IBM retain tip H036143.
- ↑ 5.0 5.1 5.2 5.3 5.4 5.5 IBM, IBM Personal System/2 Model 30 Technical Reference, January 1987. File:IBM PS2 Model 30 Technical Reference Jan87.pdf. Section 1 lists the system board's integrated I/O functions, including "Real-time clock with battery", the I/O address map (real-time clock at hex 00B0–00BF and 00E0–00EF), and the diskette and fixed-disk connector pin assignments. Section 3 "Power Supply", pages 3-3 to 3-6, gives the 70 W rating, rail currents, regulation tolerances, under-voltage sense levels, power-good characteristics and the P3/P4 pin assignments.
- ↑ 6.0 6.1 6.2 6.3 "IBM PS/2 Model 30", DOS Days, https://www.dosdays.co.uk/computers/IBM%20PS2%20Model%2030/ibm_ps2_model_30.php. Source for the single-cable drive interface with no Molex connectors, the extra 4-pin bus power connector added on the Model 30 286, the statement that the fixed-disk interface is neither ESDI nor standard MFM, the drive caddy, and the Sony 1.44 MB drive compatibility note including the "1.44MB" marking on the eject button.
- ↑ Mitsubishi Electric, 3.5 inch Flexible Disk Drive Standard Specifications, MF355C, document UGD-0527A, February 1987. File:Mitsubishi MF355C 3.5 inch Diskette Drive Specifications (UGD-0527A, Feb 1987).pdf. Section 3 states that the disk rotation mechanism uses a DC brushless direct-drive motor to rotate the spindle directly at 300 rpm; the drive has no belt.
- ↑ PS/2 Surface Mount Capacitors, ibmfiles.com. Community teardown source; documents surface-mount electrolytic failure and pad corrosion on PS/2 Mitsubishi diskette drives and on the DBA hard-drive logic boards, and the technique of fitting through-hole parts to the surface-mount pads.
- ↑ 9.0 9.1 "PS/2 Error Codes", Ardent Tool of Capitalism, https://www.ardent-tool.com/trouble/ps2error.html, with the error code listings at https://www.ardent-tool.com/trouble/error_02.html (160–199) and https://www.ardent-tool.com/trouble/error_04.html (300–999). Gives the beep codes, the 161/162/163/167/168 battery and clock cluster with IBM's FRU order and the lithium battery caution, the 301–307 keyboard cluster including 305 "keyboard voltage error" with the keyboard port fuse as first FRU, the diskette cluster including 604 "unsupported drive or cable" and 662/663 wrong drive and media type, the dead-system isolation procedure, and the warning that soft-booting the Reference Diskette can produce false errors.
- ↑ 10.0 10.1 10.2 Louis Ohland, Tomáš Slavotínek et al., "8525 / 8530 Power", Ardent Tool of Capitalism, https://www.ardent-tool.com/8530/Power.html. Transcribes IBM's Hardware Maintenance Service data for the 8525 and 8530: the J7 connector measurement limits for the Models 25, 25 SX and 25-286, the minimum under-voltage sense levels, the power-good range and the dead-system isolation procedure, and the warning that the manually-switchable supply must be set before the cord is plugged in.
- ↑ IBM, Personal System/2 Model 30 286 Guide to Operations, first edition, September 1988. File:IBM PS2 Model 30 286 Guide to Operations.pdf. "Cover Removal", page 2-2, and "Power-on Password Reset", pages 3-4 and 3-5, which locate the J13 jumper on the system board and describe moving it between the first-and-second and second-and-third pin positions.
Related Pages
- IBM PS/2 Model 30 Maintenance Guide · IBM PS/2 Model 30 Troubleshooting Guide · IBM PS/2 Model 30 Capacitor Replacement Guide
- IBM PS/2 Model 25 — the all-in-one sibling
- IBM PS/2 Model 50 · IBM PS/2 Model 60 · IBM PS/2 Model 80
- IBM PC XT (5160) — the machine it replaced
- IBM PS2 Model 30 Technical Reference (January 1987) — IBM's own reference, hosted here
