Atari Portfolio
Revision as of 15:16, 30 March 2026 by Josh (talk | contribs)
Atari Portfolio
Atari Portfolio palmtop computer
ManufacturerAtari Corporation (designed by DIP Research Ltd.)
TypePalmtop Computer
ReleasedJune 1989
Discontinued1993
Intro priceUS$399.95
CPUIntel 80C88 @ 4.9152 MHz
Memory128 KB RAM (expandable to 640 KB), 256 KB ROM
StorageInternal RAM disk (C:), removable memory cards (A:) up to 4 MB
Display240 ร— 64 pixel monochrome LCD (no backlight), 40 characters ร— 8 lines
SoundPiezo speaker (DTMF tones, key clicks, beeps)
Dimensions20 cm ร— 10.5 cm ร— 2.5 cm (7.5" ร— 4" ร— 1.25")
Weight505 g (17.5 oz)
OS / FirmwareDIP DOS 2.11 (MS-DOS 2.11 compatible)
The Atari Portfolio is the world's first IBM PC-compatible palmtop computer, released by Atari Corporation in June 1989. Roughly the size of a VHS cassette tape when folded, the Portfolio brought DOS computing to a truly pocket-sized form factor and became an iconic piece of computing history.
History and Development
The Portfolio was designed by DIP Research Ltd., a company based at the Surrey Research Park in Guildford, Surrey, UK. DIP was founded by David Frodsham, Ian Cullimore, and Peter Baldwin โ€” all former employees of Psion. The name DIP officially stood for "Distributed Information Processing."
DIP developed the first MS-DOS compatible palmtop PC, the DIP Pocket PC, and released a prototype in early 1989. Atari Corporation recognised the market opportunity, licensed the electronics and software design from DIP, and applied its own production engineering to create a consumer version with a redesigned case and keyboard.
The product was marketed as the Atari Portfolio in the US and UK. In Germany, Italy, and Spain it was initially sold as the PC Folio due to trademark restrictions. Atari later acquired the Portfolio name in Germany and Spain, though it remained the PC Folio in Italy throughout its life.
DIP continued to evolve the hardware and ROM software throughout the production cycle, supplying updates to Atari. DIP Research also went on to develop the Sharp PC-3000/3100 before being acquired by Phoenix Technologies in 1994.
Technical Specifications
Atari Portfolio Technical Specifications
Component Specification
Processor Intel 80C88 (CMOS) @ 4.9152 MHz
RAM 128 KB (expandable to 640 KB with Memory Expander+ modules)
ROM 256 KB (contains BIOS, DIP DOS 2.11, and built-in applications)
Display 240 ร— 64 pixel monochrome supertwist LCD (no backlight)
Text Mode 40 characters ร— 8 lines
Keyboard 63 keys, QWERTY layout
Sound Piezo speaker with DTMF tone generation
Power 3ร— AA alkaline batteries (~100 hours life); optional AC adapter
Dimensions 20 cm ร— 10.5 cm ร— 2.5 cm (7.5" ร— 4" ร— 1.25")
Weight 505 g (17.5 oz)
Expansion Right-side expansion port for peripherals; left-side memory card slot
Operating System DIP DOS 2.11 (MS-DOS 2.11 compatible)
Memory Architecture
The 128 KB of RAM is divided between system memory and a local storage partition (the C: drive), configurable using the FDISK command. 4 KB is reserved as video RAM. The Memory Expander+ (HPC-104) adds 256 KB per unit, with up to two units stackable for a maximum of 640 KB total system RAM. The first Memory Expander+ unit also provides a second memory card slot (B: drive).
Display
The supertwist monochrome LCD has no backlight but offers good readability in ambient light. Contrast is adjustable via a small screw accessible beneath the display window bezel, or through keyboard shortcuts (Fn+cursor keys on some ROM versions).
Operating System and Built-in Software
The Portfolio runs DIP DOS 2.11, a custom operating system compatible with MS-DOS 2.11 at the BIOS level. Most text-based DOS applications will run on the Portfolio provided they do not access PC-compatible I/O ports directly, as the Portfolio's hardware is not I/O port-compatible with the IBM PC.
Built-in Applications
  • Text Editor โ€” Simple ASCII text editor for note-taking and document creation
  • Spreadsheet โ€” Lotus 1-2-3 compatible spreadsheet application
  • Address Book โ€” Contact manager with DTMF dialing (hold a telephone handset against the speaker to speed-dial)
  • Diary โ€” Calendar/scheduler with alarm functionality
  • Calculator โ€” Standard calculator application
  • Setup โ€” System configuration utility
Memory Cards
The Portfolio uses Mitsubishi Bee Card format memory cards for removable file storage, inserted into a slot on the left side of the unit. These cards predate the PCMCIA/PC Card standard and are not compatible with it. Cards use the DOS FAT file system and are accessed as drive A:.
Available Memory Cards
Atari Portfolio Memory Cards and ROM Cards
Part Number Description
HPC-201 32 KB RAM card
HPC-202 64 KB RAM card
HPC-203 128 KB RAM card
HPC-204 512 Kbit OTPROM card
HPC-205 1 Mbit OTPROM card
HPC-701 ROM card โ€” Utility Pack
HPC-702 ROM card โ€” Finance Manager
HPC-703 ROM card โ€” Science Pack
HPC-704 ROM card โ€” File Manager
HPC-705 ROM card โ€” Power BASIC
HPC-709 ROM card โ€” Instant Spell
HPC-750 ROM card โ€” Chess
Third-party RAM cards were later available in capacities up to 4 MB. RAM cards are backed by a replaceable coin-cell battery (typically CR2016 or CR2025) which lasts approximately one to two years.
Accessories and Expansion
Atari Portfolio Accessories
HPC-101 Smart Parallel Interface (for file transfer and printing)
HPC-102 Serial Interface (RS-232C, 110โ€“9600 baud)
HPC-104 Memory Expander+ (256 KB RAM expansion, adds B: drive)
HPC-301 PC Card Drive (ISA card reader for desktop PCs)
HPC-401 AC adapter (120V, US)
HPC-402 AC adapter (230V, international)
HPC-406 Parallel cable
HPC-407 Serial cable
HPC-408 Parallel printer cable
HPC-409 Null modem cable
HPC-803 Portfolio system carrying case
ROM Versions
Four major ROM revisions were released over the Portfolio's production cycle:
Atari Portfolio ROM Versions
Version Notes
1.030 Initial production release (ROMs dated 22 May 1989). English, French, and German only. Limited units shipped. Known software bugs.
1.052 Second production release. English, French, and German. Some bugs remained.
1.07x Mainstream production release, generally bug-free. Sub-versions: 1.072 (EN/FR/DE), 1.073 (EN/IT/ES), 1.074 (EN/SV/DA), 1.075 (EN/Swiss FR/Swiss DE).
1.13x Final production release. Bug fixes for large memory cards. Sub-versions: 1.130 (EN/FR/DE), 1.131 (EN/IT/ES), 1.132 (EN/SV/DA), 1.133 (EN/Swiss FR/Swiss DE).
Atari/DIP also provided a utility called UPDATE.COM that applied run-time fixes for serious bugs without requiring a ROM replacement.
Keyboard Variants
Atari Portfolio Keyboard Variants
Part Number Layout
HPC-004 English (QWERTY)
HPC-005 French (AZERTY)
HPC-006 German (QWERTZ)
HPC-007 Italian
HPC-008 Spanish
HPC-009 Swedish/Danish
HPC-010 Swiss French/Swiss German
Pop Culture
The Atari Portfolio is perhaps best known for its prominent appearance in the 1991 film Terminator 2: Judgment Day, where the character John Connor uses it to crack ATM PINs and bypass a security door. This iconic appearance cemented the Portfolio's status as a cult collectible.
Easter Egg
A developer credits easter egg is hidden within the Portfolio. To access it: launch the Setup application, set the language to English, select Help, and from within a help screen press Alt+[ (Alt plus left square bracket).
For detailed maintenance practices including battery care, memory card maintenance, LCD cleaning, and keyboard upkeep, refer to the dedicated Atari Portfolio General Maintenance page.
For a comprehensive troubleshooting guide covering power issues, display problems, memory card detection, and interface diagnostics, see the Atari Portfolio Troubleshooting Guide.
Capacitor Replacement
For detailed capacitor identification and replacement procedures, see the Atari Portfolio Capacitor Replacement Guide.
  • HP 95LX โ€” Hewlett-Packard's palmtop PC (released 1991)
  • Poqet PC โ€” Another early palmtop competitor
  • Sharp PC-3000 โ€” Also designed by DIP Research
External Resources
