IBM PC XT/370 Maintenance Guide
This guide documents preventive maintenance for the IBM PC XT/370 (1983) โ IBM's hardware-emulation S/370 workstation built on the IBM PC XT (5160) chassis with three large 370PC emulation cards. The chassis-level maintenance is identical to the standard XT; XT/370-specific maintenance is centred on the three emulation cards (370PC-P, 370PC-M, PC3277-EM) and on the VM/PC operating system.
Safety Warning
[edit | edit source]The XT/370 PSU is the standard IBM 130 W switching supply used in the 5160 XT, containing mains-rectified bulk capacitors that hold a lethal charge after power-off. Before any work inside the chassis:
- Power off and unplug the mains lead.
- Wait at least 30 seconds.
- Discharge each PSU bulk filter capacitor through a 1 kฮฉ / 5 W resistor.
- Verify with a multimeter.
Display: standard CRT (IBM 5151 monochrome or 5153 CGA) โ discharge the CRT anode separately before any work on the deflection / flyback board.
Documentation Set
[edit | edit source]- IBM SA38-0037-00 โ Personal Computer Family Service Information Manual (July 1989). The single most useful service document; Chapter 6 specifically covers the XT/370. Available on Bitsavers.[1]
- IBM 6137739 โ Virtual Machine/Personal Computer User's Guide (December 1984).
- Kozuh, F. P., Livingston, B., Spillman, R. J. โ "System/370 capability in a desktop computer," IBM Systems Journal 23(3):245, 1984. Engineering reference.
- Standard IBM PC XT documents โ SY27-2522 (XT Technical Reference, 1986) โ same chassis service procedures apply.
Opening the System Unit
[edit | edit source]The XT/370 chassis opens the same way as a standard IBM PC XT (5160):
- Power off and unplug all cables (mains, keyboard, video, printer, 3270 host-connect coax).
- Five screws on the rear panel (Philips #2).
- Slide the cover forward to release.
Inside, the three 370PC cards occupy three contiguous full-length 8-bit ISA slots. The remaining slots typically carry:
- Standard IBM XT Floppy / Hard Disk Adapter (in the slot reserved for it).
- IBM Monochrome Display & Printer Adapter or IBM CGA card.
- Optional Game Adapter, Async Adapter, etc.
The Three 370PC Cards
[edit | edit source]The cards must be removed and re-inserted as a matched set. They communicate over a proprietary card-to-card backplane connector on the rear edge of the cards, in addition to the standard ISA bus.
370PC-P (Processor Card)
[edit | edit source]- Carries the two modified Motorola 68000s (Micro/370) and the modified Intel 8087.
- Heatsink-mounted on the 68000 packages โ verify thermal paste integrity at each service interval.
- Card cannot be repaired if a Micro/370 or modified 8087 fails โ these are custom IBM/Motorola/Intel parts.
370PC-M (Memory Card)
[edit | edit source]- Carries 512 KB dual-ported DRAM.
- Communicates with the 370PC-P via the dedicated rear-edge connector.
- Adds 384 KB to the XT host's 256 KB to give 640 KB total host RAM.
- DRAMs on the M card are standard 64K ร 1 DRAM packages of the era; failed DRAMs are replaceable if the failure is identified to a specific chip.
PC3277-EM (3270 Emulation Adapter)
[edit | edit source]- Earlier-production XT/370s carry the dedicated PC3277-EM card.
- Later-production XT/370s replaced it with the standard 3278/79 Emulation Adapter (same card as on the IBM 3270 PC).[2]
- Connects to the IBM 3174 or 3274 cluster controller via BNC twinax.
Card-Backplane Connector
[edit | edit source]The rear-edge connector between the 370PC-P and 370PC-M cards is a known service item:
- Clean the connector with deoxidising contact cleaner at every service interval.
- If the system fails to boot VM/PC but the XT host POSTs normally, reseating the 370PC-P / 370PC-M backplane connector is the first diagnostic step.
- The connector is mechanically delicate โ handle with care.
PSU Voltage Checks
[edit | edit source]Standard IBM PC XT PSU (130 W switching). Rail tolerances:
| Rail | Acceptable range |
| +5 V | +4.75 V to +5.25 V |
| +12 V | +11.4 V to +12.6 V |
| −5 V | −4.75 V to −5.25 V |
| −12 V | −11.4 V to −12.6 V |
The XT/370 with all three cards installed plus a 10 MB ST-412 drive draws close to the PSU's 130 W capacity. Rail sag under load indicates aged PSU electrolytics โ see IBM PC XT/370 Capacitor Replacement Guide.
Floppy and Hard Drive Maintenance
[edit | edit source]The XT/370 uses the standard XT 5.25" 360 KB DSDD floppy and 10 MB ST-412 hard drive. Maintenance is identical to the IBM PC XT (5160) Maintenance Guide:
- Clean the floppy head with IPA on a foam swab.
- Replace the drive belt if intermittent.
- The 10 MB ST-412 drive is end-of-life on most surviving units; data migration to a modern XT-IDE / CompactFlash adapter is the practical restoration path.
VM/PC Maintenance
[edit | edit source]- VM/PC system diskettes are increasingly rare. If you have a working VM/PC installation, image the system files immediately.
- CMS minidisks live as DOS files in the format USER.NNN (user name + minidisk number). They are accessible from DOS once VM/PC has been booted at least once and a minidisk has been formatted.
- EXPORT / IMPORT commands transfer between CMS and PC DOS with automatic EBCDICโASCII conversion. Use these to move files to/from a modern host before any extended use.
- VM/PC version 2 (November 1985) added page-cache support โ upgrade if you have v1 only.
Keyboard
[edit | edit source]Standard IBM PC XT 83-key Model F keyboard. Maintenance is identical to the IBM PC XT (5160) Maintenance Guide โ buckling-spring mechanism, IBM tool for keycap removal.
Recommended Tools
[edit | edit source]- Philips #2 screwdriver, T15 / T20 Torx.
- Anti-static strap.
- Digital multimeter.
- IPA + foam swabs.
- Soldering iron (fine tip) + solder wick.
- Deoxidising contact cleaner for the card-to-card backplane connector.
- Spare CR2032 (where the planar uses a battery-backed Dallas RTC; not all XT/370 planars do).
- SA38-0037-00 PDF.
- CMS Reference Manual (mainframe-CMS-compatible).
Related Pages
[edit | edit source]- IBM PC XT/370
- IBM PC XT/370 Troubleshooting Guide
- IBM PC XT/370 Capacitor Replacement Guide
- IBM PC XT (5160) Maintenance Guide โ shared chassis procedures
- Recommended Tools
[edit | edit source]- IBM SA38-0037-00 PC Family Service Information Manual (July 1989). Authoritative XT/370 service manual.
- Kozuh, Livingston, Spillman (1984), IBM Systems Journal.
- PC-based IBM mainframe-compatible systems โ Wikipedia.
