Atari 800XE Troubleshooting Guide
Revision as of 20:16, 29 March 2026 by Josh (talk | contribs) (Created Atari 800XE Troubleshooting Guide)
This guide covers detailed troubleshooting of the Atari 800XE 8-bit home computer. The 800XE is functionally identical to the Atari 65XE โ€” it uses the same PCB designs, chipset, and architecture โ€” but was marketed under the "800" brand in select European markets, primarily Germany. All diagnostic procedures, pinouts, and component references in this guide apply equally to the 65XE.
Use these procedures to restore a non-booting, unstable, or otherwise faulty 800XE to reliable operation.
Preliminary & Power-up Checks
Begin with basic power and visual checks before suspecting major component failure.
  1. Disconnect all peripherals (cartridges, SIO devices, joysticks, cassette).
  2. Remove the top cover (five screws underneath); inspect for burnt, cracked, or corroded components โ€” especially around the power jack, voltage regulator area, and edge connectors.
  3. Confirm the power supply outputs +5 V DC (measure at the power input or across any major IC's Vcc and GND pins).
  4. Inspect for leaking or bulging electrolytic capacitors, particularly C1 (main input filter) and decoupling caps near the voltage regulator.
  5. Check for loose or oxidised IC sockets (RAM, ROM, custom chips).
  6. Ensure the power switch is not intermittent or oxidised โ€” clean with DeoxIT if necessary.
Power Supply & Voltage Table
The 800XE uses an external +5 V DC power supply (Atari XE PSU brick, centre-positive). Some units may use a regulated 9 V input with an on-board 7805 regulator, depending on region and board revision.
Power Supply Voltage Test Points
Power input jack (centre pin) โ†’ GND +5 V DC (ยฑ5%) Main logic supply (direct 5 V PSU)
7805 regulator input (if fitted, pin 1) +8โ€“12 V DC Only present on boards with on-board regulation
7805 regulator output (if fitted, pin 3) +5 V DC Should be stable under load
Any IC Vcc pin (CPU, RAM, ANTIC, GTIA) +5 V DC Verify supply reaches all major ICs
Common PSU faults:
  • No power-on LED, no video โ€” check PSU output, cable continuity, fuse (if present), and power switch.
  • Repeated resets or random crashes โ€” suspect dried-out filter capacitors (C1) or failing 7805 regulator.
  • Overvoltage (>5.5 V at IC pins) โ€” can rapidly destroy RAM and custom ICs. Disconnect immediately and repair PSU/regulator.
Identifying Your PCB Revision
The 800XE was produced on two distinct motherboard designs. Identify your board before proceeding, as component locations differ:
800XE / 65XE PCB Variants
Board Number RAM Configuration Key Characteristics
C070067 (Rev B/C) 8 ร— 4164 (64Kร—1 bit) DRAM Original XE board; 16 RAM positions (8 populated for 64 KB). Through-hole construction. ICs often socketed.
CA200519 2 ร— 41464 (64Kร—4 bit) DRAM Cost-reduced board; fewer discrete components, some SMD parts. DRAM typically soldered directly.
Display & Boot Diagnostics
The 800XE should display a blue READY screen and produce a brief key-click sound on successful boot (PAL: blue background with white text). If not, use the following table to narrow down the fault:
Boot Symptom Diagnosis
Symptom Likely Cause Action
No video, no sound, power LED off Dead PSU, blown fuse, bad power switch Test/replace PSU; check fuse; clean or replace switch
Black screen, power LED on RAM, CPU, ROM, or custom chip failure Follow "Black Screen" flowchart below
Solid colour screen (no text) ROM failure or severe RAM fault Reseat/replace OS ROM; test RAM
Garbage characters, unstable display RAM fault, oxidised socket, bus contention Swap/test RAM; clean all IC sockets with DeoxIT
Rolling or unsynchronised video Bad GTIA, ANTIC, or crystal oscillator Check clock signal; swap GTIA/ANTIC with known-good
No key-click sound at power-on POKEY failure, speaker fault, or CPU not running Test/replace POKEY; check speaker wiring
Boots with cartridge but not to BASIC BASIC ROM failure Replace BASIC ROM
Distorted or jittery display Failing electrolytic capacitors in video path Recap โ€” see Atari 800XE Capacitor Replacement Guide
"Black Screen" (No Boot) Diagnostic Flowchart
  1. Verify +5 V at the CPU, ANTIC, GTIA, and RAM Vcc pins.
  2. Listen for a brief click or beep at power-on. If present, the CPU and OS ROM are likely executing code.
  3. Check the system clock โ€” probe pin 39 of the 6502C (Sally) for the 1.77 MHz PAL clock signal using an oscilloscope or frequency counter.
  4. Check the RESET line โ€” CPU pin 40 should pulse LOW briefly at power-on, then remain HIGH (+5 V). If stuck LOW, check reset circuit components.
  5. Swap or reseat GTIA, ANTIC, CPU (6502C), and POKEY in turn (if socketed).
  6. Reseat or substitute OS ROM and BASIC ROM.
  7. Test RAM chips (see RAM Fault Diagnosis below).
  8. Inspect for shorted decoupling capacitors, burnt resistors, or cracked traces near the power input and bus lines.
Clock & Reset Signal Diagnostics
System Clock
The master clock is generated by the crystal oscillator and distributed through the ANTIC and GTIA chips:
Clock Signal Test Points
Signal Test Point Expected Value Notes
CPU clock (ฮฆ2) 6502C pin 39 1.77 MHz (PAL) / 1.79 MHz (NTSC) Main processor clock; derived from ANTIC
Crystal oscillator Y1 14.18750 MHz (NTSC) / 14.18718 MHz (PAL) Master clock source (4ร— colour burst)
ANTIC clock out ANTIC pin 21 1.77 MHz (PAL) Directly drives 6502C
No clock signal:
  • Check crystal Y1 for damage or cold solder joints.
  • Check ANTIC โ€” if the ANTIC chip has failed, no clock will be generated for the CPU.
  • Verify +5 V at ANTIC Vcc pin.
Reset Circuit
Signal Test Point Expected Behaviour Notes
/RESET 6502C pin 40 Pulses LOW at power-on, then stays HIGH (+5 V) If stuck LOW, CPU cannot start
Reset RC network Board-specific Capacitor charges through resistor to release reset Check timing capacitor and pull-up resistor
Reset stuck LOW:
  • Check the reset timing capacitor and associated pull-up resistor for open/short faults.
  • Inspect the reset button (if fitted) for a short circuit.
  • A failed FREDDIE or MMU can hold the reset line low.
Voltage Test Points at IC Pins
Use the following table to verify that +5 V reaches all critical ICs. Measure with respect to board ground.
IC Voltage Test Points (active HIGH = +5 V DC ยฑ5%)
IC Part Number Vcc Pin GND Pin Notes
CPU (Sally) 6502C Pin 8 Pin 1, Pin 21 Main processor
ANTIC CO21698 (PAL) / CO21697 (NTSC) Pin 40 Pin 20 Display list processor; generates CPU clock
GTIA CO14889 (PAL) / CO14805 (NTSC) Pin 24 Pin 12 Video output and colour generation
POKEY CO12294 Pin 23 Pin 12 Sound, keyboard, serial I/O, random number
PIA CO14795 / 6520 Pin 20 Pin 1 Joystick ports, peripheral control
FREDDIE CO61991 / CO61922 Pin 28 Pin 14 Memory controller and DRAM timing
OS ROM 27128 or equivalent Pin 28 Pin 14 16 KB operating system
BASIC ROM 2364 / 27C64 equiv. Pin 28 Pin 14 8 KB Atari BASIC Rev. C
RAM (4164) 4164 (C070067 board) Pin 8 Pin 16 64Kร—1 DRAM (8 chips)
RAM (41464) 41464 (CA200519 board) Pin 18 Pin 9 64Kร—4 DRAM (2 chips)
RAM Fault Diagnosis
RAM failure is the single most common cause of boot problems in the XE series. The 800XE uses either eight 4164 DRAMs (C070067 board) or two 41464 DRAMs (CA200519 board).
RAM Symptoms
RAM Fault Symptoms and Actions
Symptom Probable Cause Diagnostic Action
Black screen, no beep Failure in lower RAM bank (addresses $0000โ€“$3FFF) Replace suspected DRAM(s); lower bank must work for OS to initialise
Garbage screen, immediate freeze Upper RAM failure Replace DRAM(s); check address lines for continuity
Random characters, "ERROR" on boot Partial or intermittent RAM failure Use piggy-back test or RAM diagnostic cartridge
Passes self-test but crashes in programs Intermittent RAM fault Run extended memory test; check for thermal sensitivity
RAM Diagnostic Techniques
  1. Touch test: After 1โ€“2 minutes of operation, a failed DRAM chip may run noticeably hot compared to its neighbours.
  2. Piggy-back test: Press a known-good DRAM chip on top of a suspected bad chip (aligning all pins). If the fault clears, the underlying chip is bad. This works reliably for 4164 chips on the C070067 board.
  3. Diagnostic cartridge: Use the Atari 800XE built-in self-test (hold OPTION during power-on) or an external RAM test cartridge (e.g., Atari Diagnostics, SALT) for precise identification.
  4. Substitution: On the CA200519 board with only two 41464 chips, swap each in turn with a known-good replacement.
Built-in Self-Test
Hold the OPTION key while powering on to enter the XE self-test menu. Select the RAM test to check all 64 KB. The test will identify failing memory ranges, which can be mapped back to specific chips using the board's memory map.
Custom Chip Troubleshooting
ANTIC (Display List Processor)
ANTIC Fault Symptoms
Black screen (no video output at all) ANTIC not generating display or clock Check +5 V at pin 40; verify crystal Y1; swap ANTIC
Solid colour screen, no text ANTIC running but display list corrupted Check RAM; reseat ANTIC; verify address bus
Horizontal bars or tearing ANTIC DMA timing fault Swap ANTIC; check FREDDIE
GTIA (Video Output)
GTIA Fault Symptoms
Black screen with working clock GTIA not generating video Check +5 V at pin 24; swap GTIA
Wrong or missing colours Defective GTIA colour output Swap GTIA; check colour adjustment pot (if present)
Rolling picture, no vertical sync GTIA sync generation failure Swap GTIA; verify composite video output path
Known-bad GTIA batch (CO14889) Manufacturing defect in late-run PAL chips Replace GTIA โ€” see note below
Note: A batch of GTIA chips (CO14889) shipped in late-production XE computers sold in Eastern Europe are known to be defective, producing no video or corrupted colours. The fix is to replace the GTIA with a known-good unit. If the GTIA is soldered directly to the board, consider adding a socket for future serviceability.
POKEY (Sound & I/O)
POKEY Fault Symptoms
No sound, system otherwise boots POKEY audio section failed; or speaker/amp fault Test speaker (apply 1.5 V briefly โ€” should click); swap POKEY
Keyboard completely unresponsive POKEY keyboard scan failure Swap POKEY; test keyboard membrane continuity
Some keys not working Keyboard membrane or connector fault Clean connector; test membrane traces
SIO peripherals not detected POKEY serial section or SIO logic fault Check POKEY; inspect SIO connector; check 74LS logic (U5/U6)
No paddle/analog input POKEY pot scan failure Swap POKEY
PIA (Peripheral Interface)
PIA Fault Symptoms
Joystick port(s) not responding PIA failure or cold solder joint at port Reflow solder joints; swap PIA
System boots but peripheral control erratic PIA control line fault Swap PIA; check port connector continuity
FREDDIE (Memory Controller)
FREDDIE Fault Symptoms
Black screen, all voltages correct FREDDIE not generating DRAM timing Swap FREDDIE
Random RAM failures across multiple chips FREDDIE RAS/CAS timing fault Swap FREDDIE; check for cracked solder joints
Audio & I/O Failures
Audio and I/O Fault Summary
No sound, boots normally POKEY, speaker, or output coupling capacitor Replace POKEY; test speaker; check/replace C24 (audio coupling)
Distorted or weak audio Dried-out coupling capacitor Replace audio-path electrolytics โ€” see Atari 800XE Capacitor Replacement Guide
Joystick port not working Cold solder joint, broken trace, or PIA fault Reflow port joints; continuity test to PIA; swap PIA
SIO (disk/tape) not detected SIO connector, POKEY, or bus logic Clean SIO connector; check POKEY and 74LS logic ICs
Cassette motor control fault Driver transistor failure Check motor control transistor and associated components
Connector & Socket Issues
Many 800XE faults are caused by poor connections rather than component failure, especially in machines that are 35+ years old:
  • Reseat all socketed ICs โ€” RAM, ROM, and custom chips. Oxidised pins are a common cause of intermittent faults.
  • Clean IC socket contacts with DeoxIT or isopropyl alcohol.
  • Clean edge connectors (cartridge slot, SIO, joystick ports) with isopropyl alcohol and a lint-free cloth.
  • Inspect solder joints at the power jack, SIO port, joystick ports, and keyboard connector for cracks or cold joints. Reflow as needed.
  • Check for broken PCB traces near the cartridge slot and keyboard connector โ€” these are stress points.
  • Test continuity from each port pin to its corresponding IC pin if a peripheral fault is suspected.
Cartridge & Peripheral Diagnostics
  • If the system boots with a cartridge but not without, suspect the BASIC or OS ROM.
  • If no cartridge boots, check the cartridge slot for bent pins, cracked solder joints, or corroded contacts.
  • SIO failures often trace to the SIO connector, POKEY, or 74LS bus logic ICs.
  • Cassette motor control issues may be caused by a failed driver transistor or associated resistor.
Error Patterns Quick Reference
Quick Diagnostic Reference
Symptom Pattern Most Likely Component(s)
Black screen, no sound, LED on RAM (lower bank), CPU, or FREDDIE
Black screen, no sound, LED off PSU, fuse, power switch
Blue screen, no READY prompt BASIC ROM or upper RAM
Boots with cartridge only Internal BASIC or OS ROM
Beep/click but no display GTIA or ANTIC
Display OK, no sound POKEY or audio coupling capacitor
Random crashes during use Failing capacitors, intermittent RAM, or overheating IC
Failure Frequency (Statistical)
Based on common repair experience with XE-series machines, component failures rank approximately as follows (most common first):
  1. RAM โ€” especially on older C070067 boards with 4164 DRAMs
  2. Electrolytic capacitors โ€” dried out after 35+ years
  3. ROM โ€” especially BASIC ROM
  4. POKEY
  5. GTIA โ€” including the known-bad CO14889 batch
  6. ANTIC
  7. CPU (6502C) โ€” relatively rare
  8. PIA / FREDDIE โ€” least common
Final Notes
  • Always start with power and visual checks โ€” many faults are caused by bad PSUs or failed capacitors, not IC failure.
  • Use a known-good power supply and test cartridges for initial diagnosis.
  • Fit IC sockets when replacing soldered chips to allow future serviceability.
  • Do not operate with a faulty PSU โ€” overvoltage rapidly destroys custom ICs that are difficult or impossible to replace.
  • The 800XE and 65XE are identical hardware โ€” any 65XE repair resource applies directly to the 800XE.
