IBM PS/2 Model 80 Maintenance Guide
This guide documents preventive maintenance for the IBM PS/2 Model 80 (machine type 8580, all submodels). The Model 80 chassis is the same floor-standing tower used by the IBM PS/2 Model 60, but the planar carries the 32-bit MCA implementation, the 80386DX and the famously-leaky surface-mount aluminium electrolytic capacitors of the IBM PS/2 Model 70 generation.
Safety Warning
[edit | edit source]The 225 W PSU contains mains-rectified bulk capacitors that hold a lethal charge after power-off. Before any work inside the PSU shell:
- Power off and unplug the mains lead.
- Wait at least 30 seconds.
- Discharge the bulk capacitor through a 1 kฮฉ / 5 W resistor.
- Verify with a multimeter.
There is no CRT in the system unit (matching IBM 8503 / 8512 / 8513 / 8514 displays are serviced separately).
Opening the Tower Chassis
[edit | edit source]Tools: Philips #2 screwdriver, T15 Torx (some Model 80 fasteners), anti-static strap.
- Power off and unplug all cables.
- Loosen the screws at the rear top edge of the tower.
- The larger of the two side panels slides off (left side, when looking at the front).
- Inside:
- Planar mounts on the floor of the chassis.
- MCA cards plug into the riser on the left side, accessed through the side panel.
- Drive cage runs vertically up the front of the tower, with the four drive bays stacked.
- PSU sits at the top of the chassis (above the drive cage).
The configured weight of a Model 80 (21.3 kg without the 314 MB drive; heavier with) makes it unwieldy on a bench. Many restorers tip the tower on its side onto a soft surface for easier access to the MCA riser and planar.
Inspect for SMD Electrolyte Leakage
[edit | edit source]The single most important maintenance task on a Model 80. Before any other work, inspect the planar for surface-mount aluminium electrolytic capacitor leakage. The Model 80 planar carries 40โ50 SMD electrolytics, more than the Model 70, and any of them can leak.
- Power off, unplug, discharge PSU.
- Remove the planar from the chassis floor.
- Inspect both sides of the planar under a bright light or with a USB microscope. Look for:
- Brown or green residue near any SMD electrolytic cap.
- Discolouration of solder mask near a cap.
- Crusty deposits on nearby vias.
- Lifted pads or corroded traces near a cap.
- Cap markings that look "scorched" or smell of electrolyte.
- If any SMD cap shows leakage, do NOT power the system on. Read IBM PS/2 Model 80 Capacitor Replacement Guide and recap before further use.
The leak is corrosive even at room temperature with no power applied.
Drive Cage Layout
[edit | edit source]The Model 80 has four drive bays:
- Top bay: 5.25" full-height (used for tape backup, second 5.25" device, or the 314 MB ESDI drive on 8580-311 / A31).
- Bay 2: 3.5" half-height (1.44 MB floppy).
- Bay 3: 3.5" half-height (primary ESDI drive โ 44 / 70 / 115 MB).
- Bay 4: 3.5" half-height (spare or secondary drive on server configs).
Each bay accepts the IBM proprietary plastic drive sled with captive push-pin tabs. The sleds are released by pressing the plastic tabs inward with the IBM "crowbar" plastic spudger that shipped with the system.
Regular Cleaning
[edit | edit source]- Soft brush and low-pressure compressed air for the planar, MCA cards, drive bays and PSU vents.
- Avoid blowing dust into the PSU fan bearing or onto the floppy heads.
- Clean MCA card edge fingers with a soft eraser or a deoxidising contact cleaner before reseating. MCA contacts oxidise after 30+ years and produce intermittent card-not-detected (POST 165) symptoms.
- Clean PS/2 keyboard and mouse Mini-DIN-6 connectors with deoxidising contact cleaner on a foam swab.
- On the planar, don't use compressed air over leaked electrolyte areas โ it spreads electrolyte across more of the planar.
PSU Voltage Checks
[edit | edit source]Probe the PSU output rails at the planar power connector with a multimeter.
| Rail | Acceptable range |
| +5 V | +4.75 V to +5.25 V |
| +12 V | +11.4 V to +12.6 V |
| −5 V | −4.75 V to −5.25 V |
| −12 V | −11.4 V to −12.6 V |
The 225 W PSU is uprated to handle the 314 MB ESDI drive's startup current and the larger MCA card count. The Model 80 PSU is electrically compatible with the IBM PS/2 Model 60 225 W PSU (8560-071); both share the same chassis-position connector. The 207 W PSU (8560-041) is NOT a drop-in for the Model 80 โ insufficient +12 V capacity for the larger ESDI drives.
CMOS / RTC Battery
[edit | edit source]The Model 80 uses the Dallas DS1287 / DS12887 integrated RTC + battery module on the planar (same as Model 50 / 50 Z / 70). The lithium cell inside the module fails after 10โ15 years, producing the classic POST error cluster:
- 161 โ CMOS configuration empty.
- 162 โ CMOS checksum mismatch.
- 163 โ Time and date not set.
Replacement procedure:
- Power off; discharge PSU bulk capacitor.
- Identify the 24-pin DIP marked "DALLAS" on the planar.
- Desolder using solder wick and a fine-tipped iron at no more than 350 ยฐC.
- Fit a fresh Dallas DS12887+ or a socket for future replacements.
- Reassemble; boot Reference Diskette; run SETUP.
MCA Card Maintenance
[edit | edit source]Each MCA card has a unique ID stored in the card itself. The Reference Diskette reads the ID, looks up the ADF (Adapter Definition File) and configures interrupts, DMA and memory addresses. After any card change:
- Boot the Reference Diskette (Model 80-specific; Type 1 vs Type 2 planar matters for 8580-A21 / A31).
- Select Set Configuration โ Run Auto Configuration.
- Insert each option diskette as prompted to load missing ADFs.
Without Auto Configuration, the system reports a 165 card-ID-mismatch error at POST.
The Model 80's 7 ร 32-bit MCA slots (vs. Model 70's 3) mean more cards in the system in practice and a higher 165 incidence rate.
ESDI Drive Maintenance
[edit | edit source]The 8580 ESDI drives are larger and heavier than the Model 60 / 70 ESDI drives, especially the 314 MB drive on the server configurations.
Common faults:
- Drive stiction โ drive does not spin up after long storage. Especially common on the 314 MB drives. Rotate the drive case gently while powered off; reinstall; spindle frees for one boot. Image the contents immediately and replace.
- Aged drive electrolytics โ brown crust around drive logic board caps. Recap with 105 ยฐC low-ESR equivalents.
- Slow startup โ aged spindle motor bearings or drive PSU caps. Drive replacement is the practical fix.
Floppy Drive Maintenance
[edit | edit source]Same as Model 70 and Model 60. 1.44 MB 3.5" half-height. Belt and drive-logic-board recap as in IBM PS/2 Model 80 Capacitor Replacement Guide.
Connector Care
[edit | edit source]- PS/2 keyboard / mouse: Mini-DIN-6 with plastic alignment key.
- Keyboard / mouse fuse (3 A) on the planar protects the +5 V to keyboard and pointing device.
- Serial (DB-25 male) and parallel (DB-25 female).
- MCA edge connectors โ clean cards and slots before any work.
- VGA โ onboard, 15-pin Mini-D-Sub.
Capacitor Health
[edit | edit source]The Model 80 planar has surface-mount aluminium electrolytic capacitors throughout. These age and leak after 30+ years and produce the classic PS/2 plague symptoms โ intermittent faults that progress to a dead planar. The Model 80 carries more SMD electrolytics than the Model 70 because of the larger MCA slot count and the server-class memory subsystem.
Full procedure: IBM PS/2 Model 80 Capacitor Replacement Guide.
Aluminium electrolytics in the 225 W PSU also age and need replacement after 30+ years. Symptoms include sagging rails under load, audible whine, PSU refusing to start when warm.
Type 1 vs Type 2 Planar
[edit | edit source]The Model 80 planar exists in two main revisions:
- Type 1 โ 16 MHz and 20 MHz submodels (8580-041, -071, -111, -311). Original 1987 design.
- Type 2 โ 25 MHz submodels (8580-A21, -A31). Later design with revised memory subsystem.
The two planars are NOT interchangeable. Reference Diskettes differ. SIMM compatibility differs (Type 2 requires faster SIMMs). Both planars share the same SMD electrolyte leakage problem.
Recommended Tools
[edit | edit source]- Philips #2 screwdriver and T15 Torx.
- Anti-static strap.
- Digital multimeter.
- Plastic crowbar / spudger for captive push-pin tabs.
- IPA + foam swabs.
- Reference Diskette + ADF diskettes for all fitted MCA cards (Type 1 or Type 2 as appropriate).
- Spare Dallas DS12887+ for RTC replacement.
- Soldering iron with fine tip + solder wick.
- Hot-air rework station for SMD electrolytic removal (strongly recommended for planar recap).
- Drive belt (54 ร 1 mm flat) for the Mitsubishi MF355C floppy.
- USB microscope for inspecting SMD cap leakage.
Related Pages
[edit | edit source]- IBM PS/2 Model 80
- IBM PS/2 Model 80 Troubleshooting Guide
- IBM PS/2 Model 80 Capacitor Replacement Guide
- IBM PS/2 Model 60 Maintenance Guide โ same tower chassis, 286-class planar
- IBM PS/2 Model 70 Maintenance Guide โ desktop sibling, same planar family
- Recommended Tools
[edit | edit source]- IBM PS/2 Model 80 โ Ardent Tool Quick Reference. Source for the 225 W PSU rating, 8-slot MCA breakdown (1 ร 8-bit + 7 ร 32-bit), four-bay drive cage, FRU listings, planar Type 1 vs Type 2.
- IBM PS/2 Model 80 โ Wikipedia. Source for the April 1987 introduction and OS/2 / NetWare deployment history.
- IBM PS/2 Model 80 โ DOS Days.
- Commonly Failing Electronic Components, minuszerodegrees.net.
- IBM, IBM Personal System/2 Hardware Maintenance Manual (S52G-9971-02, October 1994).
