IBM PC XT/370
Revision as of 22:08, 24 September 2026 by Josh (talk | contribs) (Fix refs so they render; IBM fits TWO cards not three - PC/370-P in slot 4 and PC/370-M in slot 3, with PC/3277-EM only on older machines and the 3278/79 or Remote Display Terminal adapter as alternatives; add IBMs model numbers (5160 Models 568/588/589), the 10 MB vs 20 MB fixed-disk configurations and IBMs unit specifications; host link is coax not twinax)
IBM PC XT/370
A 370PC emulation card from an IBM XT/370. Modified 68000s and a modified 8087 implement IBM System/370 instructions in hardware
DeveloperIBM Entry Systems Division, Boca Raton, in cooperation with IBM mainframe groups
ManufacturerIBM
TypeDesktop System/370 workstation — a 5160 PC XT with two System/370 adapter cards
ReleasedOctober 1983
DiscontinuedApril 1987 (withdrawn simultaneously with the IBM AT/370)
CPUHost: Intel 8088 @ 4.77 MHz. S/370 side: two modified Motorola 68000s (microcode rewritten to directly execute most S/370 fixed-point and non-floating instructions; unrecognised opcodes trap to a program running on the unmodified 68000) plus a modified Intel 8087 that handles S/370 floating-point. The custom 68000 is sometimes called the Micro/370
MemoryHost (XT side): up to 640 KB with the 370PC-M card contributing 384 KB. S/370 side: 512 KB dual-ported RAM on the 370PC-M card (416 KB usable for S/370 applications); 4 MB virtual memory via hard-disk paging
Storage5.25-inch 360 KB diskette drive. IBM configures it either as a 10 MB system (one fixed disk in the system unit) or a 20 MB system (two fixed disks in a 5161 Expansion Unit)
DisplayIBM 5151 monochrome or IBM 5153 CGA โ€” same as a stock XT
SoundPC speaker
OS / FirmwarePC DOS 2.10 boots first, then loads VM/PC (Virtual Machine/Personal Computer) โ€” IBM's modified VM/CMS for a single user. VM/PC v2 (November 1985) added page-cache support
PredecessorIBM 5100 family (PALM microcode-based S/370 emulation)
SuccessorIBM AT/370 (1984); then IBM 7437 VM/SP Technical Workstation (1987โ€“88); then P/370 MCA card (~1989); then R/390 RISC; eventually software emulators (Hercules, zPDT)
Model no.5160 Models 568, 588 and 589. IBM's card names are PC/370-P (processor, slot 4) and PC/370-M (512 KB memory, slot 3); older machines may also carry a PC/3277-EM card
The IBM PC XT/370 is a desktop System/370 workstation released by IBM in October 1983 as a follow-on to the IBM 5100's PALM-microcode-based mainframe emulation. IBM's own description is "an extended version of the 5160 XT with 256Kb of memory on the system board", carrying two XT/370 adapter cards that execute most System/370 instructions in hardware and let the machine run a single-user version of VM/CMS called VM/PC.[1][2]
It is two cards, not three. IBM names them and gives their slots: the Processor card (PC/370-P) in expansion slot 4 and the 512 KB Memory card (PC/370-M) in expansion slot 3.[1] A third card is often counted in descriptions of this machine, but IBM lists the PC/3277-EM as an option, notes only that "older models of the PC XT/370 might contain" one, and offers the standard 3278/79 Emulation Adapter or a Remote Display Terminal Device Emulation Adapter (which can go in slot 2) as the alternatives.[1] Counting three cards as standard will send you looking for a card a given machine was never built with.
The cards are listed as standard features of 5160 Models 568, 588 and 589 in IBM's 5160 model feature chart.[1]
The XT/370 is the architectural successor to the IBM 5100 / IBM 5110 / IBM 5120's use of the IBM PALM processor's System/360 emulator microcode to run an IBM-mainframe-flavoured interpreter (APLSV) as a self-contained personal computer.
The XT/370 was withdrawn in April 1987, at the same time as the IBM AT/370.[3] Its eventual successor was the IBM 7437 VM/SP Technical Workstation (1987โ€“1988), then the P/370 MCA card for PS/2 systems (~1989), then the R/390 for RS/6000 (mid-1990s).
Launch and Reception
Launch pricing was approximately $3,790 for the three emulation cards alone, or about $8,995 to $12,000 for a complete configuration.[4]
BYTE (Fall 1984, Ernest Sabine) called it "a qualified success", and Computerworld of 25 November 1985 reported sales below IBM's expectations.[5] The XT/370 was withdrawn in April 1987 along with the AT/370.
The XT/370 Cards
IBM's own list, with slots:[1]
IBM XT/370 โ€” cards and slots
Card Slot Status
PC/370-P โ€” Processor card Expansion slot 4 Standard
PC/370-M โ€” 512 KB Memory card Expansion slot 3 Standard
Remote Display Terminal Device Emulation Adapter May be in expansion slot 2 Option
IBM 3278/79 Emulation Adapter — Option
PC/3277-EM — Only on older machines: "older models of the PC XT/370 might contain a PC/3277EM card"
Most secondary accounts, including the earlier version of this page, name the cards 370PC-P and 370PC-M. IBM writes them the other way round โ€” PC/370-P and PC/370-M โ€” in both the feature chart and the XT/370 description.[1] Either form will be understood, but IBM's is the one on the parts lists.
PC/370-P (Processor Card)
  • Two modified Motorola 68000s โ€” the microcode was rewritten to execute most System/370 fixed-point and non-floating-point instructions directly. An opcode the modified part does not recognise traps to a software interpreter running on the unmodified 68000. The custom part is usually called the Micro/370.[6]
  • A modified Intel 8087 implementing System/370 floating point โ€” excess-64 hexadecimal, not the IEEE 754 binary format a standard 8087 does.[6]
  • Bridging logic to the host ISA bus and a dedicated card-to-card connection to the memory card.
IBM's service manual names neither the 68000 nor the 8087. It calls the card "the Processor card (PC/370-P)" and stops there.[1] The chip-level detail above comes from community teardowns and from the engineering literature, and is recorded here as such.
PC/370-M (Memory Card)
  • 512 KB, per IBM's own name for the card: "The 512Kb Memory card (PC/370-M)".[1]
  • Dual-ported between the processor card and the host.
  • Of the 512 KB, about 416 KB is usable by System/370 applications, the rest being emulator runtime.[2]
  • The card also brings the host's memory up from the 256 KB on the system board.[1][7]
PC/3277-EM and the emulation alternatives
The XT/370 needs a terminal-emulation path to a host to load VM/PC and to reach mainframe files. IBM offers three ways of getting one, and which one a given machine has depends on when it was built:[1]
  • PC/3277-EM โ€” the original, on older machines only.
  • IBM 3278/79 Emulation Adapter โ€” the same card the IBM 3270 PC uses.
  • Remote Display Terminal Device Emulation Adapter โ€” which IBM notes can sit in expansion slot 2.
All of them attach to the control unit over coaxial cable, not twinax.[1]
Fixed Disk Configurations
IBM offers two, and the difference is where the second drive lives:[1]
  • 10 MB system โ€” one fixed disk drive in the system unit.
  • 20 MB system โ€” two fixed disk drives in a 5161 Expansion Unit. The expansion unit has its own 130 W PC XT power supply and its own eight extension slots.[1]
Unit Specifications
IBM's figures for the XT/370 system unit:[1]
IBM XT/370 system unit
Item Value
Height 142 mm (5.5 in)
Length 500 mm (19.6 in)
Depth 410 mm (16.1 in)
Weight 14.5 kg (32 lb)
Power cable 1.83 m (6 ft), 18 AWG
Heat output 650 BTU/hr
Noise level 49.5 dBA, system unit with monochrome display
Performance
  • System/370 performance โ€” around 0.1 MIPS sustained when the working set fits in the usable System/370 memory.[2]
  • When the working set exceeds 416 KB, VM/PC pages out to the XT's hard disk, supporting up to 4 MB of virtual memory but with a heavy performance penalty.[2]
Operating Environment: VM/PC
The XT/370 boots PC DOS 2.10 first, then loads VM/PC (Virtual Machine/Personal Computer). VM/PC presents a single-user CMS environment that closely mirrors mainframe VM/CMS:
  • CMS "virtual disks" (minidisks) are stored as PC DOS files. User FRED's minidisk 101 becomes the PC DOS file FRED.101.
  • EXPORT and IMPORT commands transfer files between CMS and PC DOS, with automatic EBCDICโ†”ASCII conversion.
  • CMS commands, EXEC scripts, and most CMS applications run unchanged.
  • No multi-user support โ€” VM/PC is single-user only.
VM/PC version 2 (November 1985) added page-cache support to reduce hard-disk paging overhead.
The IBM AT/370 ships an updated VM/PC for PC DOS 3.0, with the wider 16-bit 370PC-P2 and 370PC-M2 cards (still 512 KB on the M2 card, with 32 KB reserved for microcode).
Hardware Configuration
A 5160 PC XT chassis with 256 KB on the system board, the two XT/370 cards, a 5.25-inch 360 KB diskette drive, one or two fixed disks, an IBM 5151 monochrome or 5153 colour display, and the XT keyboard.[1] Everything outside the two cards is stock XT.
One of the three 370PC emulation cards from an IBM XT/370. The full-length 8-bit ISA cards carry modified 68000s (Micro/370), modified 8087, and 512 KB dual-ported RAM. (Image: Wikimedia Commons, CC BY-SA 3.0)
Service Documents
  • IBM Personal Computer Family Service Information Manual โ€” SA38-0037-00, July 1989, hosted here. Chapter 6 covers the XT/370, chapter 9 the AT/370, chapter 18 the parts.[1]
  • IBM 6137739 โ€” Virtual Machine/Personal Computer User's Guide (December 1984).
  • Kozuh, F. P., Livingston, B., Spillman, R. J. โ€” "System/370 capability in a desktop computer," IBM Systems Journal 23(3):245, 1984. The canonical engineering paper.
Common Faults
The XT/370 chassis is identical to the IBM PC XT (5160), so chassis faults are:
  • RIFA mains-suppression capacitors in the PSU โ€” vent and produce smoke / fish odour. Replace immediately as a preventive measure.
  • Tantalum bypass capacitor shorts on the planar โ€” these pull the +5 V rail down and stop the machine posting.
  • There is no real-time clock on a 5160 planar. Any battery in the machine belongs to an add-in card.
XT/370-specific faults:
  • The XT/370 cards are effectively unobtainable. The modified 68000s and the modified 8087 are custom parts that nobody is making again. A machine with both cards present is museum-grade.
  • Check slots 3 and 4 before concluding a card is missing. IBM's slot assignment is fixed: processor in 4, memory in 3. A card found elsewhere has been moved.
  • Card-to-card connection between the processor and memory cards โ€” oxidation here produces a machine that posts normally as an XT and then fails to start VM/PC. Reseat before suspecting the cards.
  • VM/PC system diskettes โ€” rare, and the original installation route needed a working emulation card attached to a control unit. Image any set you find.
Architectural Significance
The XT/370 sits in IBM's long line of System/360 and System/370 emulation in a personal computer:[8]
  1. IBM 5100 / IBM 5110 / IBM 5120 (1975โ€“1980) โ€” PALM microcode S/360 emulator running APLSV.
  2. IBM PC XT/370 (1983) โ€” modified 68000 plus modified 8087, running VM/PC.
  3. IBM PC AT/370 (1984) โ€” 16-bit cards (370PC-P2, 370PC-M2) on the AT chassis.
  4. IBM 7437 VM/SP Technical Workstation (1987โ€“88) โ€” separate enclosure, channel-attached.
  5. P/370 (~1989) โ€” MCA card for PS/2 Model 60/70/80.
  6. R/390 (mid-1990s) โ€” RISC PCI card for RS/6000.
  7. S/390 Integrated Server (1998).
  8. Eventually superseded by software emulators (Hercules, zPDT) on commodity hardware.
  1. โ†‘ 1.00 1.01 1.02 1.03 1.04 1.05 1.06 1.07 1.08 1.09 1.10 1.11 1.12 1.13 1.14 1.15 IBM, IBM Personal Computer Family Service Information Manual, SA38-0037-00, July 1989 — hosted on this wiki as IBM Personal Computer Family Service Information Manual. Chapter 6, "5160 PC XT": the 5160 model feature chart, which lists the PC/370-M, PC/370-P and PC/3277-EM cards against particular 5160 models; the "5160 XT/370" pages, which give the card complement, the slot assignments, the fixed-disk configurations and the unit specifications; and the 5160 power supply description, which gives the 130 W rating, the per-rail currents and tolerances, the existence of separate 120 V and 220/240 V supplies, and the automatic shutdown on dc overcurrent or overvoltage. Chapter 9 covers the AT/370; chapter 18 lists the card part numbers.
  2. โ†‘ 2.0 2.1 2.2 2.3 Kozuh, F. P., Livingston, B., and Spillman, R. J., "System/370 capability in a desktop computer", IBM Systems Journal 23(3):245, 1984, DOI 10.1147/sj.233.0245. The engineering paper by the team that built it, and the source for the performance figures quoted here. This wiki has not read the full text — it is behind a paywall — so those figures are recorded as attributed rather than verified.
  3. โ†‘ Computer Business Review, "IBM Gives Up on the Personal XT/, AT/370", April 1987, at techmonitor.ai.
  4. โ†‘ IT History Society, "IBM Personal Computer XT/370", at ithistory.org. Secondary; the only source located for the launch pricing.
  5. โ†‘ Computerworld, 25 November 1985, page 25 (Google Books ZUMIDEwANHgC). Secondary.
  6. โ†‘ 6.0 6.1 The CPU Shack — IBM Micro/370 and The Chip Letter — Motorola, Intel, IBM Make A Mainframe in a PC. Community sources for the modified-68000 and modified-8087 story and for the "Micro/370" name. IBM's service manual names neither part.
  7. โ†‘ Mueller, S., Upgrading and Repairing PCs, 2nd edition, 1992, pages 73–75 and 94. Secondary, for the host-memory contribution.
  8. โ†‘ Wikipedia, "PC-based IBM mainframe-compatible systems". Tertiary; used for the product chronology and the succession from the XT/370 through the 7437, P/370 and R/390.
