Atari 400 Capacitor Replacement Guide
The Atari 400 is a four-board machine: a motherboard, a power supply PCB, a plug-in CPU card and a plug-in RAM card. Every aluminium electrolytic capacitor in the machine except one is on the power supply PCB, and that board is also where the 9 V AC input is rectified and regulated. Everything else on the 400 is ceramic, mylar or polyester film and does not need replacing on age alone.
The values below come from Atari's own parts list in the ATARI Home Computer Field Service Manual 400/800.[1]
How the 400 is numbered
[edit | edit source]Atari allocated a block of reference designators to each board, and this is the quickest way to tell whether a designator you have been given is even possible:[1]
| Board | Atari assembly number | Designators |
| Motherboard | CA014807 | C101–C203, R101–R185, A101–A111, Z101–Z105 |
| Power supply PCB | CA014155 | C201–C213, R201–R203, A201–A203, S201–S203, J201–J204 |
| CPU card | CA017173 | C301–C307, R302–R313, A301–A303, Z301–Z304 |
| RAM card | CA014801 (8K) / CA014802 (16K) | C501–C523, Z501–Z512 |
A capacitor list for the 400 that quotes designators below C101 is not describing this machine.
Visual inspection and failure signs
[edit | edit source]- Bulging or domed tops — internal gas pressure and imminent failure.
- Leaking electrolyte — brown, black or green residue at the base or leads.
- Corrosion or board staining — green or white deposits, or darkened board around the leads.
- Random resets, video noise or audio hum — often traceable to dried-out or high-ESR capacitors on the supply board.
See Capacitor Failure Symptoms for the general case, and Battery Explosion, Capacitor or Corrosion Damage if electrolyte has already reached the board.
Capacitor list
[edit | edit source]Power supply PCB (CA014155)
[edit | edit source]This board carries the mains-derived circuitry, both regulators, the RF modulator and the power and interlock switches. Seven of the machine's eight electrolytics are here.[1]
| Designator | Value | Rating | Package | Atari part number |
| C201 | 470 µF | 16 V | Axial | C014370 |
| C202 | 470 µF | 16 V | Axial | C014370 |
| C204 | 2200 µF | 16 V | Axial | C014373 |
| C205 | 2200 µF | 16 V | Axial | C014373 |
| C207 | 10 µF | 16 V | Axial | C014371 |
| C209 | 4700 µF | 16 V | Radial | C014374-01 or C014374-02 |
| C210 | 22 µF | 16 V | Axial | C014393 |
The remaining capacitors on this board are not electrolytics and should be left alone unless they test faulty: C203, C208 and C211 are 0.22 µF polyester film (C010394), C206 is 0.1 µF ceramic and C212–C213 are 0.001 µF ceramic.[1]
Motherboard (CA014807)
[edit | edit source]| Designator | Value | Rating | Package | Atari part number |
| C192 | 10 µF | 16 V | Axial | C014371 |
C192 is the only aluminium electrolytic on the 400 motherboard. Everything else in the C101–C203 range is ceramic (0.001 µF, 0.01 µF, 0.1 µF, or small NP0 values), mylar (C135–C142 and C181 at 0.047 µF) or polyester (C177–C178 at 820 pF).[1]
CPU and RAM cards
[edit | edit source]Neither plug-in card contains an electrolytic capacitor. C301–C307 on the CPU card and C501–C523 on the RAM card are all ceramic axial types.[1] If someone has sold you a "400 cap kit" containing parts for these cards, it is not a 400 kit.
The Console5 Tech Wiki capacitor list for the 400 agrees with Atari's parts list exactly — the same eight designators at the same values.[2]
What the rails actually are
[edit | edit source]Atari is explicit about this, and it matters because it tells you what each capacitor is working against:
"The Power Supply PCB receives 9 VAC from an external power adaptor (transformer) and provides +5 Vdc, +12 Vdc, and −5 Vdc for the Console system."[3]
| Rail | Purpose |
| +5 V A | Supply voltage for the logic PCBs |
| +5 V B | Specially filtered supply for the video circuitry |
| +12 V | Supply for the dynamic RAM chips (and SIO pin 12) |
| −5 V | Supply for the dynamic RAM chips |
The 16K RAM card is populated with eight DRAMs at Z505–Z512 that need all three of +12 V, +5 V and −5 V; that is why the 400 has rails an XL-series machine does not.[1]
The regulators are A202 (5 V) and A201 (12 V) on the power supply PCB.[1] Console5 identifies these as a 7805 and a 7812 respectively.[2]
Recapping procedure
[edit | edit source]The power supply PCB is fed from a transformer, but its ON/OFF switch (S203) opens the 9 V AC input, and the board carries that AC as far as the rectifier diodes CR206–CR209. Unplug the adaptor at the wall before working on the board, and remember that C209 (4700 µF) can hold a charge after power-off — discharge it through a resistor before touching the board. |
- Unplug the adaptor and all peripherals.
- Open the case and lift out the power supply PCB. Note that the power interlock switch S202 is on this board; it cuts power when the cartridge cover is lifted, so the machine will appear dead on the bench with the lid off.[1]
- Photograph and label every connector before disconnecting: J201 (20-pin socket to the motherboard), J202 (13-pin SIO), J203 (phono) and J204 (power jack).
- Desolder each capacitor with braid or a pump. Take care with the pads around C209 — it is the largest can and its pads carry the full rectified current.
- Clean the pads with isopropyl alcohol and check for lifted traces, particularly if electrolyte has already leaked.
- Fit the new capacitors observing polarity. A higher voltage rating than the original is always acceptable; a lower one never is.
- Reassemble, then verify the rails before fitting the cards back (see below).
Recommended parts
[edit | edit source]- 105 °C radial aluminium electrolytics from a reputable manufacturer (Nichicon, Panasonic, Rubycon).
- C209 is the only radial part in the original design; the rest are axials. Radial replacements are fine electrically but need their leads dressed to reach axial pads.
- See Recommended Tools for soldering and desoldering equipment.
Verifying the result
[edit | edit source]Measure the rails with the machine assembled and running. Atari does not publish a tolerance band for the 400's internal rails, so treat the regulator types as the specification: a healthy 7805 and 7812 sit within a few per cent of nominal, and anything more than about 5 % off, or any visible ripple on a scope, means the job is not finished.
A more useful go/no-go check is the clock, which Atari does specify. With a scope, the following should be present:[4]
| Point | Board | Frequency (MHz) |
| Pin 21 of J101 | CPU card | 1.789 |
| Pin 9 of Z302 | CPU card | 1.789 |
| Pin 35 of A302 (ANTIC) | CPU card | 3.579 |
| Pin 29 of A301 (GTIA) | CPU card | 3.579 |
| Collector of Q104 | Motherboard | 3.579 |
| Pin 7 of A101 (POKEY) | Motherboard | 1.789 |
| Pin 25 of A102 (PIA) | Motherboard | 1.789 |
If the clock is right and the rails are right, a machine that still fails is not a capacitor problem — work through Atari 400 Troubleshooting Guide instead.
[edit | edit source]- Atari 400
- Atari 400 General Maintenance
- Atari 400 Troubleshooting Guide
- Capacitor Failure Symptoms
- Recommended Tools
[edit | edit source]- ↑ 1.0 1.1 1.2 1.3 1.4 1.5 1.6 1.7 1.8 Atari, Inc., ATARI Home Computer Field Service Manual 400/800, June 1982, Section 9, "ATARI 400 Computer Console Parts List", pages 9-1 to 9-6. Hosted on this wiki: File:Atari 400 800 Field Service Manual June 82.pdf. Source of every capacitor value, voltage rating, reference designator and Atari part number on this page.
- ↑ 2.0 2.1 "Atari 400", Console5 Tech Wiki, retrieved September 2026. Secondary source; its capacitor list matches Atari's own parts list designator for designator, and it additionally identifies A201 as a 7812 and A202 as a 7805.
- ↑ Atari, Inc., ATARI Home Computer Field Service Manual 400/800, June 1982, page 1-6, "Power Supply". Source of the 9 V AC input figure and the four-rail breakdown.
- ↑ Atari, Inc., ATARI Home Computer Field Service Manual 400/800, June 1982, Table 5-1, "Clock Circuit", page 5-36. Frequencies and pin numbers for the 400/800 clock chain.
