Atari 800 Capacitor Replacement Guide
Atari 800
The Atari 800 is a five-board machine: motherboard, power supply PCB, a plug-in CPU card, a plug-in ROM personality module and one to three plug-in RAM modules. Ten aluminium electrolytic capacitors exist in the whole computer, eight of them on the power supply PCB. Nothing on the CPU card, the ROM module or the RAM modules is an electrolytic, and no amount of age will change that.
The values below come from Atari's own parts list in the ATARI Home Computer Field Service Manual 400/800.[1]
How the 800 is numbered
Atari allocated a block of reference designators to each board. Use it as a sanity check on any parts list you are handed:[1]
Atari 800 reference designator blocks
Board Atari assembly number Designators
Motherboard C101–C200, R101–R185, A101–A103, Z101–Z106
Power supply PCB CA014171 C201–C216, R201–R204, A201–A203, S201–S207, J201–J206
CPU card CA017173 C301–C307, R302–R313, A301–A303, Z301–Z304
ROM personality module CA014090-01 / CA014803 C401–C411, R401–R404, A401–A403, Z401–Z403
RAM module CA014802 (16K) C501–C523, Z501–Z512
A list quoting "C56–C65 on the 800 mainboard" is not describing this computer — the motherboard's capacitors start at C101.
Visual inspection and failure signs
  • Bulging or domed tops.
  • Leaking electrolyte — brown, black or green residue at the base or on the board.
  • Corrosion or board staining around the leads.
  • Random lock-ups, video flicker, audio hum or power-on failure.
See Capacitor Failure Symptoms, and Battery Explosion, Capacitor or Corrosion Damage if electrolyte has already spread.
Capacitor list
Power supply PCB (CA014171)
Atari 800 power supply PCB electrolytic capacitors
Designator Value Rating Package Atari part number
C201 470 µF 16 V Axial C014370
C202 470 µF 16 V Axial C014370
C204 2200 µF 16 V Axial C014373
C205 2200 µF 16 V Axial C014373
C207 4700 µF 16 V Radial C014374-01 or C014374-02
C208 4700 µF 16 V Radial C014374-01 or C014374-02
C210 10 µF 16 V Axial C014371
C211 10 µF 16 V Axial C014371
Board revision note. Atari's parts list rates C207 and C208 at 16 V. The Console5 Tech Wiki, which lists the 800 supply board as "Power Supply, REV B", gives 25 V for those two positions and agrees with Atari on everything else.[2] Read what is printed on the parts actually in your machine. Either way a 25 V part is a safe replacement in a 16 V position; the reverse is not true.
The non-electrolytics on this board should be left alone unless they test faulty: C203 and C206 are 0.22 µF 100 V polyester film, C215 is 0.47 µF 100 V mylar, C209 is 0.1 µF ceramic, C212 and C216 are 0.001 µF ceramic and C214 is 10 pF.[1]
Motherboard
Atari 800 motherboard electrolytic capacitors
C179 10 µF 16 V Radial C014392
C199 10 µF 16 V Axial C014371
These two are the only electrolytics on the motherboard. Note that they are different physical parts — C179 is radial, C199 axial — although both are 10 µF 16 V.[1] C179 is one of the components Atari's own symptom checklist names for "tones missing during sound or games".[3]
CPU card, ROM module and RAM modules
None of the plug-in boards contains an electrolytic capacitor.[1] C301–C307, C401–C411 and C501–C523 are all ceramic axial types at 0.001 µF, 0.01 µF, 0.1 µF or small NP0 values. Leave them alone.
What the rails actually are
Atari states that the power supply PCB "receives 9 VAC from an external power adaptor (transformer) and provides +5 Vdc, +12 Vdc, and −5 Vdc for the Console system", and breaks the rails down as follows:[4]
Atari 800 supply rails
Rail Purpose
+5 V A Supply voltage for the logic PCBs
+5 V B Specially filtered supply for the video circuitry
+12 V Supply for the dynamic RAM chips, and SIO pin 12
−5 V Supply for the dynamic RAM chips
There is no "+9 V rail". The 9 V is AC, it is what comes in from the adaptor (Atari part C014319), and it is rectified on the supply board by CR206–CR209 (MR501). The regulators are A202 (5 V, C014348) and A201 (12 V, C014349) on the heatsink assembly CA014708.[1]
Recapping procedure
  1. Unplug the adaptor and all peripherals. Remove the top cover and lift out the ROM and RAM modules.
  2. Remove the metal shielding to reach the boards. On the 800 the module bay is enclosed by a primary shield casting (C012763) and a lower shield (C012764); note the insulator (C015352) when you take it apart.[1]
  3. Label every connector before disconnecting: J204 (13-pin SIO), J205 (DIN monitor socket), J206 (power jack), J201 (22-pin socket) and J202 (4-pin).
  4. Desolder each capacitor with braid or a pump; Atari's assembly solder is high-melting, so use a hot iron and work quickly rather than dwelling on the pad.
  5. Clean the pads with isopropyl alcohol and inspect for lifted traces.
  6. Fit the new capacitors observing polarity and lead spacing. A higher voltage rating is always acceptable; a lower one never is.
  7. Reassemble and verify before refitting the modules.
  • 105 °C radial aluminium electrolytics from a reputable manufacturer. C207/C208 are radial in the original design; C201, C202, C204, C205, C210, C211 and C199 are axial.
  • Keep replacement can heights low enough to clear the shield castings.
  • See Recommended Tools.
Verifying the result
Atari does not publish a tolerance band for the 800's internal rails, so treat the regulator types as the specification and measure at the regulator tabs or at the large filter capacitors. The genuinely specified figures are the clock frequencies:[5]
Clock check points (Atari Table 5-1)
Point Board Frequency (MHz)
Pin 21 of J101 CPU card 1.789
Pin 9 of Z302 CPU card 1.789
Pin 35 of A302 (ANTIC) CPU card 3.579
Pin 29 of A301 (GTIA) CPU card 3.579
Collector of Q102 Motherboard 3.579
Pin 7 of A101 (POKEY) Motherboard 1.789
Pin 25 of A102 (PIA) Motherboard 1.789
If the rails and the clock are both right and the machine still fails, work through Atari 800 Troubleshooting Guide.
  1. 1.0 1.1 1.2 1.3 1.4 1.5 1.6 Atari, Inc., ATARI Home Computer Field Service Manual 400/800, June 1982, Section 9, "ATARI 800 Computer Console Parts List", pages 9-7 to 9-13. Hosted on this wiki: File:Atari 400 800 Field Service Manual June 82.pdf. Source of every capacitor value, voltage rating, reference designator and Atari part number on this page.
  2. "Atari 800", Console5 Tech Wiki, retrieved September 2026. Secondary source. Its list matches Atari's parts list except that it rates C207/C208 at 25 V and labels the board "Power Supply, REV B".
  3. Atari, Inc., ATARI Home Computer Field Service Manual 400/800, June 1982, Section 6, "Symptom Checklist", pages 6-1 and 6-2.
  4. Atari, Inc., ATARI Home Computer Field Service Manual 400/800, June 1982, page 1-6, "Power Supply". Source of the 9 V AC input figure and the rail breakdown.
  5. Atari, Inc., ATARI Home Computer Field Service Manual 400/800, June 1982, Table 5-1, "Clock Circuit", page 5-36.
