IBM PC XT/370 Capacitor Replacement Guide
Revision as of 01:41, 22 September 2026 by Josh (talk | contribs) (Rebuild from IBM SA38-0037-00: removed all three invented card capacitor tables (IBM publishes nothing below card level for the 370 cards); corrected the card names and count - IBM says two cards, PC/370-P in slot 4 and PC/370-M in slot 3, with PC/3277-EM only on older models (5160 Models 568/588/589); removed the invented 'matched set' backplane-connector claim and the 5151/5153 CRT paragraph; fixed the red link to the XT guide; cleared Unverified data)
The IBM PC XT/370 is an IBM PC XT with System/370 emulation cards in it. IBM describes it as "an extended version of the 5160 XT with 256Kb of memory on the system board", and lists the cards as standard features of 5160 Models 568, 588 and 589 in the 5160 chapter of its own service manual.[1]
There is therefore no separate capacitor procedure for this machine. The chassis, system board and power supply are the XT's, and the work is documented in full, against board photographs, on the IBM PC XT Capacitor Replacement Guide — sixteen tantalums on the board, thirteen of them on the +5 V line, C55 a ceramic and C56 a tantalum as the only two components on +12 V, 10 µF / 16 V as the replacement part throughout, and the SNCTOL cut-and-graft technique for getting them out without lifting pads.[2][3][4]
Read that page. This one exists only to record the three things that are specific to an XT/370: which cards are fitted and where, what the supply has left to give once they are in, and what is and is not published about the cards themselves.
One of the System/370 emulation cards from an IBM XT/370. IBM published no component-level parts list for any of these cards. (Image: Wikimedia Commons)
The cards, and which slots they occupy
IBM's own description of the machine:[1]
IBM PC XT/370 — card complement
Card Slot What IBM says it does
PC/370-P (Processor card) Expansion slot 4 "The centre of the S/370 operations for the PC XT/370. Contains the microprocessors and control circuits that enable the PC XT/370 to execute S/370 instructions."
PC/370-M (512 KB Memory card) Expansion slot 3 "Contains 512Kb of parity-checked random access memory, which can be used by either the PC/370-P card or by the PC XT. This provides 512Kb of memory for use in S/370 mode, or a total of 640Kb of memory for use in PC XT mode."
PC/3277-EM (optional; older models) — 3277-2 terminal emulation when the XT/370 is linked to a host system, plus screen and listing printing and file transfer between the XT/370 and host disks
Remote Display Terminal Device Emulation Adapter (optional) May be in expansion slot 2 Terminal emulation
IBM 3278/79 Emulation Adapter (optional) — Host connection
Against IBM's 5160 model feature chart, the PC/370-M and PC/370-P cards are standard on Models 568, 588 and 589, and the PC/3277-EM card on Models 568 and 588.[1]
Note the card count. IBM's text says the system unit has two XT/370 adapter cards plugged into the system board, with the PC/3277-EM as a third on older models and the other emulation adapters as options. A machine with three 370 cards in it is a particular model, not the universal configuration — check what is actually fitted before ordering anything or assuming a card is missing.
The XT/370 can be a 10 MB system with one fixed disk in the system unit, or a 20 MB system with two fixed disks in a 5161 Expansion Unit.[1]
What the supply has left
This is the one place where the XT/370 genuinely differs from a plain XT for power work, and it is a matter of headroom rather than of different components.
IBM's figures for the 5160 supply: it is designed for continuous operation at 130 watts; there are two supplies, 120 V AC and 220/240 V AC, both fused; and if DC overcurrent or overvoltage conditions exist, the supply automatically shuts down until the condition is corrected. The system board takes approximately 2 to 4 A of +5 V DC, leaving approximately 11 A of +5 V DC for the adapters in the system expansion slots. The +12 V level powers the diskette drive and the 10 MB fixed disk; −5 V is used by the analogue circuits in the diskette adapter's phase-lock loop; +12 V and −12 V drive the EIA line drivers on the communications adapters. All four levels are bussed across the eight expansion slots.[1]
On an XT/370 that 11 A is shared by two or three large full-length cards, a fixed disk adapter, a diskette adapter and a display adapter. Two practical consequences:
  • A tired supply shows up on an XT/370 before it shows up on a plain XT. If the machine is stable with the 370 cards out and unstable with them in, measure the rails under that load before suspecting the cards.
  • A shorted tantalum anywhere presents the same way. The supply latches off, often with the fan still turning, because that is what IBM designed it to do. That is the fault to rule out first, and the method is on the XT page.
IBM's unit specification for the XT/370: heat output 650 BTU/hr, noise level 49.5 dBa with a monochrome display and expansion unit attached, mains nominal 120 V AC (minimum 104 V, maximum 127 V), system unit weight 14.5 kg.[1]
What is published about the cards — and what is not
Nothing below card level, for any of them. IBM's service documentation for the XT/370 is FRU-level: it names the cards, says which slots they go in, and stops. There is no designator map, no parts list and no schematic for the PC/370-P, the PC/370-M or the PC/3277-EM in any document this wiki has located.
The nearest thing to a parts list IBM gives in this manual is for the AT/370, the 5170-based successor: PC/370-P2 card 2684070, PC/370-M2 card 2684069, PC/370-P-M cable 8654374, and 3278/79 Emulation Adapter 8654378.[1] Those are AT/370 parts and do not fit an XT/370, but the existence of a documented cable between the P and M cards on the AT/370 is worth knowing before anyone tries to lever a pair of XT/370 cards out as if they were independent.
This page publishes no capacitor values for any 370 card, because none have been published. What can be said, and is sourced, is that tantalum failure is reported right across the IBM 51xx PC family with cards included, that the cards use the same 10 µF / 16 V parts in the same three-hole footprint as the motherboard, and that no per-card designator map exists for XT-era adapters.[5][4]
So the diagnosis is behavioural rather than by designator: if the system board alone runs cleanly but the supply latches off with a particular card fitted, that card has the short, and the same technique used on the motherboard applies to it.
If you transcribe the capacitor complement of a PC/370-P or PC/370-M — designator, value, voltage, dielectric, position, with photographs and the card's IBM part number — publish it. These are rare cards and no such list appears to exist anywhere.
When to recap
The triggers are the XT's, with one addition:
  • Visible tantalum failure on the board or on any card — a small black hole or "eye" on the body, a cracked or scorched case, or damage to a neighbouring part. In many cases there is no visual sign at all.[5]
  • The supply latching off with a card fitted and coming up without it.
  • A rail outside the regulation tolerances published on the XT page.
  • Instability under the full 370-card load that clears with the cards removed.
  • Mains-side suppression capacitors in the supply that are cracked, discoloured or smell of fish in use. Replace immediately with correctly safety-rated parts of the same class.
Failures happen overwhelmingly on application of power or within about thirty seconds of it, and the rate is high for a board that has sat unpowered for years.[5] Eye protection on first power-up of an unknown XT/370 is sensible, not paranoid: these cards are effectively unobtainable.
  1. ↑ 1.0 1.1 1.2 1.3 1.4 1.5 1.6 IBM, IBM Personal Computer Family Service Information Manual, SA38-0037-00, July 1989. Chapter 6, "5160 PC XT": the 5160 model feature chart (which lists the PC/370-M, PC/370-P and PC/3277-EM cards against particular 5160 models), the power supply description, and the "5160 XT/370" pages covering the card complement, slot assignments and unit specifications. Chapter 18 lists the AT/370 card part numbers. Hosted on this wiki as IBM Personal Computer Family Service Information Manual.
  2. ↑ Short-circuit on the +5 volt line of an IBM 5150/5155/5160 motherboard, minuszerodegrees.net. Source for the count of sixteen tantalum capacitors on the 5160 motherboard and the thirteen on the +5 volt line.
  3. ↑ Short-circuit on the +12 volt line of an IBM 5150/5155/5160 motherboard, minuszerodegrees.net. Source for the statement that the 5160's +12 V line carries exactly two components, C55 and C56, and that C56 is not critical to motherboard operation.
  4. ↑ 4.0 4.1 IBM 51xx motherboards/cards — types wired to use 2-legged tantalum capacitors, minuszerodegrees.net. Gives the replacement value as 10 µF rated at 16 volts, with a higher rating acceptable.
  5. ↑ 5.0 5.1 5.2 Commonly Failing Electronic Components (in vintage computers), minuszerodegrees.net. Source for tantalum failure across the IBM 51xx family including cards, for failures occurring at or shortly after power-on, and for the higher failure rate on boards left unpowered for years.
